Expose the core connector state as properties so it can be updated via
atomic ioctl.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Reviewed-by: Sean Paul <seanpaul@chromium.org>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Expose the core plane state as properties, so they can be updated via
atomic ioctl.
v2: atomic property flag
Getting ready to add a lot more standard properties for atomic.
[danvet: Realign function paramaters where the lines shrunk
massively.]
Add functions to check core plane/crtc state.
v2: comments, int-overflow checks, call from core rather than
helpers to be sure drivers can't find a way to bypass core
checks
Once a driver is using atomic helpers for modeset, the next step is to
switch over to atomic properties. To do this, make sure that any
modeset objects have their ->atomic_{get,set}_property() vfuncs suitably
populated if they have custom properties (you did already remember to
plug in atomic-helper func for the legacy ->set_property() vfuncs,
right?), and then set DRIVER_ATOMIC bit in driver_features flag.
A new cap is introduced, DRM_CLIENT_CAP_ATOMIC, for the purposes of
shielding legacy userspace from atomic properties. Mostly for the
benefit of legacy DDX drivers that do silly things like getting/setting
each property at startup (since some of the new atomic properties will
be able to trigger modeset).
[danvet: Squash in fixup patch to check for DRM_MODE_PROP_ATOMIC
instaed of the CAP define when filtering properties. Reported by
Tvrtko Uruslin, acked by Rob.]
Both need to iterate a mode objects properties. Split that out into a
helper shared by both ioctl handlers, since this is going to become more
complicated when we add atomic properties (which will need filtering
from legacy userspace).
We need to hold connection_mutex as we read the properties. Easiest
thing is just widen the scope where connection_mutex is held.
Since we won't be using the obj->properties->values[] array to shadow
property values for atomic drivers, we are going to need a vfunc for
getting prop values. Add that along w/ mandatory wrapper fxns.
v2: more comments and copypasta comment typo fix
As we add properties for all the standard plane/crtc/connector
attributes (in preperation for the atomic ioctl), we are going to want
to handle core state in core (rather than per driver). Intercepting the
core properties will be easier if the atomic_set_property vfuncs are not
called directly, but instead have a mandatory wrapper function (which
will later serve as the point to intercept core properties).
v2: more verbose comments and copypasta comment fix
Backmerge my drm-misc branch because of conflicts. Just simple stuff
but better to clear this out before I merge the other atomic patches.
drivers/gpu/drm/drm_crtc.c
drivers/gpu/drm/drm_edid.c
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
For atomic drivers, we won't use the values array but instead shunt
things off to obj->atomic_get_property(). So to simplify things make
all read/write of properties values go through the accessors.
Keep property pointer, instead of id, in per mode-object attachments.
This will simplify things in later patches.
We can already have object properties, which technically can be fb's.
Switch the property validation logic over to a get/put style interface
so it can take a ref to refcnt'd objects, and then drop that ref after
the driver has a chance to take it's own ref.
Useful since this way we can pass around just the state objects and
will get ther real object, too.
Specifically this allows us to again simplify the parameters for
set_crtc_for_plane.
v2: msm already has it's own specific plane_reset hook, don't forget
that one!
v3: Fixup kerneldoc, reported by 0-day builder.
Cc: Rob Clark <robdclark@gmail.com>
Reviewed-by: Rob Clark <robdclark@gmail.com> (v2)
Tested-by: Rob Clark <robdclark@gmail.com> (v2)
This essentially reverts
commit 934ce1c23624526d9d784e0499190bb48113e6f4
Author: Rob Clark <robdclark@gmail.com>
Date: Wed Nov 19 16:41:33 2014 -0500
drm/atomic: check mode_changed *after* atomic_check
Depending upon the driver both orders (or maybe even interleaving) is
required:
- If ->atomic_check updates ->mode_changed then helper_check_modeset
must be run afters.
- If ->atomic_check depends upon accurate adjusted dotclock values for
e.g. watermarks, then helper_check_modeset must be run first.
The failure mode in the first case is usually a totally angry hw
because the pixel format switching doesn't happen. The failure mode in
the later case is usually nothing, since in most cases the old
adjusted mode from the previous modeset wont be too far off to be a
problem. So just underruns and perhaps even just suboptimal (from a
power consumption) watermarks.
Furthermore in the transitional helpers we only call ->atomic_check
after the new modeset state has been fully set up (and hence
computed).
Given that asymmetry in expected failure modes I think it's safer to
go back to the older order. So do that and give msm a special check
function to compensate.
Also update kerneldoc to explain this a bit.
v2: Actually add the missing hunk Rob spotted.
v3: Move msm_atomic_check into msm_atomic.c, requested by Rob.
The default call sequence for these two parts won't fit for all
drivers. So export the two pieces and explain with a bit of kerneldoc
when each should be called.
v2: Squash in fixup from Rob to actually add the newly exported
functions to headers
When a plane is being enabled, plane->crtc has not been set yet. Use
plane->state->crtc.
Commit 28a62277e06f ("drm: Convert proc files to seq_file and introduce
debugfs") converted /proc files to debugfs and in the process dropped
the entry for the vblank statistics. Since that file has been gone for
almost five years, there is no use to keep the code that provides the
file's content around.
Signed-off-by: Thierry Reding <treding@nvidia.com>
When the original drm code was written there were no centralized functions for
doing a coordinated wbinvd across all CPUs. Now (since 2010) there are, so use
them instead of rolling a new one.
v2: On x86 UP systems the wbinvd_on_all_cpus() is defined as a static inline in
smp.h. We must therefore include this file so we don't get compiler errors.
This error was found by 0-DAY kernel test infrastructure. We only need this for
x86.
Cc: Intel GFX <intel-gfx@lists.freedesktop.org>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> (v1)
When compiling in module some symbol aren't missing,
export them correctly.
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
http://git.linaro.org/people/benjamin.gaignard/kernel into drm-next
This series of patches fix various issues in STI drm driver.
Now HDMI i2c adapter could be selected in device tree
and plug detection doesn't use gpio anymore.
I also had fix some signal timing problems after testing the driver
on more hardware.
The remaining patches attemps to simplify the code and prepare
the next evolutions like DVO and auxiliary CRTC support
* 'drm-sti-next-2014-12-11' of http://git.linaro.org/people/benjamin.gaignard/kernel:
drm: sti: correctly cleanup CRTC and planes
drm: sti: add HQVDP plane
drm: sti: add cursor plane
drm: sti: enable auxiliary CRTC
drm: sti: fix delay in VTG programming
drm: sti: prepare sti_tvout to support auxiliary crtc
drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off}
drm: sti: fix hdmi avi infoframe
drm: sti: remove event lock while disabling vblank
drm: sti: simplify gdp code
drm: sti: clear all mixer control
drm: sti: remove gpio for HDMI hot plug detection
drm: sti: allow to change hdmi ddc i2c adapter
git://anongit.freedesktop.org/drm-intel into drm-next
Here's a batch of i915 fixes for 3.19.
* tag 'drm-intel-next-fixes-2014-12-11' of git://anongit.freedesktop.org/drm-intel:
drm/i915: save/restore GMBUS freq across suspend/resume on gen4
drm/i915: Remove '& 0xffff' from the mask given to WA_REG()
drm/i915: Invert the mask and val arguments in wa_add() and WA_REG()
drm/i915/bdw: Fix the write setting up the WIZ hashing mode
drm/i915: Don't complain about stolen conflicts on gen3
drm/i915: resume MST after reading back hw state
drm/i915: Handle inaccurate time conversion issues
drm/i915: compute wait_ioctl timeout correctly
drm/i915: don't always do full mode sets when infoframes are enabled
drm_plane_helper_check_update() currently uses crtc before testing whether
we're disabling the plane (fb == NULL). Move the fb test before the first crtc
usage so that crtc == NULL doesn't have to be handled by the caller.
Signed-off-by: Matt Roper <matthew.d.roper@intel.com>
Should probably just init this in the GMbus code all the time, based on
the cdclk and HPLL like we do on newer platforms. Ville has code for
that in a rework branch, but until then we can fix this bug fairly
easily.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=76301
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Tested-by: Nikolay <mar.kolya@gmail.com>
Cc: stable@vger.kernel.org
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
When bind failed make sure that CRTC and planes are
completely clean up to avoid properties duplication.
High Quality Video Data Plane is hardware IP dedicated
to video rendering. Compare to GPD (graphic planes) it
have better scaler capabilities.
HQVDP use VID layer to push data into hardware compositor
without going into DDR. From data flow point of view HQVDP
and VID are nested so HQVPD update/disable VID.
stih407 SoC have a dedicated hardware cursor plane,
this patch enable it.
The hardware have a color look up table, fix it to
be able to use ARGB8888.
For stih407 SoC enable the second mixer to get two CRTC.
Allow GPD planes and encoders to be connected to this new CRTC.
Cursor plane can only be set on first CRTC.
GPD clocks needed change the parent clock depending on which
CRTC GPD are used.
The HDMI path introduce a delay of 6 pixels.
This delay should be take into account while programming
VTG for the HDMI. Without this delay, the HDMI active
window area is shift of 6 pixel on the right.
Set also timing for DVO output.
Change some functions prototype to prepare the introduction of
auxiliary crtc. It will also help to have a DVO encoder.
Make sure that vblank is enabled when crtc commit is call.
Replace drm_vblank_off() by drm_crtc_vblank_off()
The hardware expect to have the infoframe checksum in the first byte.
In consequence shift all infoframe on one byte.
Stop use event_lock in vblank disable function.
This was creating a dead lock.
Store the physical address at node creation time
to avoid use of virt_to_dma and dma_to_virt everywhere
Make sure that mixer control register is correctly reset
before use it.
gpio used for HDMI hot plug detection is useless,
HDMI_STI register contains an hot plug detection status bit.
Fix binding documentation.
Depending of the board configuration i2c for ddc could change,
this patch allow to use a phandle to specify which i2c controller to use.
Merge drm core fixes from Daniel.
* tag 'topic/core-stuff-2014-12-10' of git://anongit.freedesktop.org/drm-intel:
drm: Zero out DRM object memory upon cleanup
drm: fix a typo in a comment
drm: fix a word repetition in a comment
drm: Fix memory leak at error path of drm_read()
drm/Documentation: Fix rowspan value in drm-kms-properties
drm/edid: Restore kerneldoc consistency
drm/edid: new drm_edid_block_checksum helper function V3
drm/edid: shorten log output in case of all zeroes edid block
drm/edid: move drm_edid_is_zero to top, make edid argument const
We may be hidding bugs by doing that, so let remove it and have the
actual mask value shine through, for better or worse.
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
While trying to unify the order of those arguments throughout the
driver, Daniel noticed what we were inverting them in this part of the
code.
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
sizeof(type) is the variant used most commonly and required by
checkpatch.
All prior conditional blocks return from the function, so the else block
can be at the top level of the function.
Single statement blocks don't need to be enclosed in a pair of braces.
checkpatch requires the assignment and the check to be separate
statements.
Fixes a couple of checkpatch warnings regarding the use of kmalloc()
with a multiplication. kmalloc_array() is the preferred API.
Fixes a couple of checkpatch warnings regarding the use of kzalloc()
with a multiplication. kcalloc() is the preferred API.
A couple of whitespace changes required to silent various errors and
warnings flagged by checkpatch.
checkpatch requires that the opening brace be on the same line as a
variable declaration. Furthermore an empty line is required after a
block of variable declarations. Trailing whitespace as well as using
spaces before tabs is considered an error or warning, respectively.
Finally, the closing parenthesis of an if condition and the opening
brace of the conditional block should be separated by a space.
The ->load_lut() callback is optional, therefore a dummy implementation
is not needed.
is not needed.
Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org>
is not needed.
