path: root/drivers
2006-06-28[AGPGART] Make AGP depend on PCIDave Jones
Fixes possible compile error in amd64 with pci=n pointed out by Adrian Bunk. Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-24[AGPGART] remove unused variableAdrian Bunk
This patch removes an unused variable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-21[AGPGART] Fix pci_register_driver checking in amd64-agpDave Jones
pci_register_driver() never returns a positive number. Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-21[AGPGART] Compile fix for ati-agpDave Jones
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-20[AGPGART] Suspend/Resume support for nVidia nForce AGP.Dave Jones
Based on a patch from the Ubuntu kernel. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-20[AGPGART] Suspend/Resume improvements for ATI AGPDave Jones
Based on patches in the Ubuntu kernel. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-20[AGPGART] Whitespace cleanups for ati-agpDave Jones
2006-06-19Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (51 commits) [MIPS] Make timer interrupt frequency configurable from kconfig. [MIPS] Correct HAL2 Kconfig description [MIPS] Fix R4K cache macro names [MIPS] Add Missing R4K Cache Macros to IP27 & IP32 [MIPS] Support for the RM9000-based Basler eXcite smart camera platform. [MIPS] Support for the R5500-based NEC EMMA2RH Mark-eins board [MIPS] Support SNI RM200C SNI in big endian mode and R5000 processors. [MIPS] SN: include asm/sn/types.h for nasid_t. [MIPS] Random fixes for sb1250 [MIPS] Fix bcm1480 compile [MIPS] Remove support for NEC DDB5476. [MIPS] Remove support for NEC DDB5074. [MIPS] Cleanup memory managment initialization. [MIPS] SN: Declare bridge_pci_ops. [MIPS] Remove unused function alloc_pci_controller. [MIPS] IP27: Extract pci_ops into separate file. [MIPS] IP27: Use symbolic constants instead of magic numbers. [MIPS] vr41xx: remove unnecessay items from vr41xx/Kconfig. [MIPS] IP27: Cleanup N/M mode configuration. [MIPS] IP27: Throw away old unused hacks. ...
2006-06-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (46 commits) IB/uverbs: Don't serialize with ib_uverbs_idr_mutex IB/mthca: Make all device methods truly reentrant IB/mthca: Fix memory leak on modify_qp error paths IB/uverbs: Factor out common idr code IB/uverbs: Don't decrement usecnt on error paths IB/uverbs: Release lock on error path IB/cm: Use address handle helpers IB/sa: Add ib_init_ah_from_path() IB: Add ib_init_ah_from_wc() IB/ucm: Get rid of duplicate P_Key parameter IB/srp: Factor out common request reset code IB/srp: Support SRP rev. 10 targets [SCSI] srp.h: Add I/O Class values IB/fmr: Use device's max_map_map_per_fmr attribute in FMR pool. IB/mthca: Fill in max_map_per_fmr device attribute IB/ipath: Add client reregister event generation IB/mthca: Add client reregister event generation IB: Move struct port_info from ipath to <rdma/ib_smi.h> IPoIB: Handle client reregister events IB: Add client reregister event type ...
2006-06-19Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (109 commits) [ETHTOOL]: Fix UFO typo [SCTP]: Fix persistent slowdown in sctp when a gap ack consumes rx buffer. [SCTP]: Send only 1 window update SACK per message. [SCTP]: Don't do CRC32C checksum over loopback. [SCTP] Reset rtt_in_progress for the chunk when processing its sack. [SCTP]: Reject sctp packets with broadcast addresses. [SCTP]: Limit association max_retrans setting in setsockopt. [PFKEYV2]: Fix inconsistent typing in struct sadb_x_kmprivate. [IPV6]: Sum real space for RTAs. [IRDA]: Use put_unaligned() in irlmp_do_discovery(). [BRIDGE]: Add support for NETIF_F_HW_CSUM devices [NET]: Add NETIF_F_GEN_CSUM and NETIF_F_ALL_CSUM [TG3]: Convert to non-LLTX [TG3]: Remove unnecessary tx_lock [TCP]: Add tcp_slow_start_after_idle sysctl. [BNX2]: Update version and reldate [BNX2]: Use CPU native page size [BNX2]: Use compressed firmware [BNX2]: Add firmware decompression [BNX2]: Allow WoL settings on new 5708 chips ... Manual fixup for conflict in drivers/net/tulip/winbond-840.c
2006-06-19Merge branch 'i915fb' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/intelfb-2.6 * 'i915fb' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/intelfb-2.6: (25 commits) intelfb: fixup clock calculation debugging. Removed hard coded EDID buffer size. intelfb: use regular modedb table instead of VESA intelfb: use firmware EDID for mode database Revert "intelfb driver -- use the regular modedb table instead of the VESA" intelfb: int option fix sync modesetting code with X.org intelfb: align with changes from my X driver. intelfb driver -- use the regular modedb table instead of the VESA Adds support for 256MB aperture on 945 chipsets to the intelfb driver intelfb -- uses stride alignment of 64 on the 9xx chipsets. intelfb: some cleanups for intelfbhw intelfb: fixup pitch calculation like X does intelfb: fixup p calculation This patch makes a needlessly global struct static. intelfb: add i945GM support intelfb: fixup whitespace.. intelfb: add hw cursor support for i9xx intelfb: make i915 modeset intelfb: add support for i945G ...
2006-06-19Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] alpha-agp warning fix [AGPGART] uninorth-agp warning fixes [AGPGART] Remove pointless initialisation in intel-agp [AGPGART] Remove pointless code from agp_generic_create_gatt_table()
2006-06-19Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] sets nforce2 minimum PLL divider to 2. [CPUFREQ] Make powernow-k7 work on SMP kernels. [CPUFREQ] cpufreq core {d,}printk adjustments [CPUFREQ] dprintk adjustments to cpufreq-speedstep-centrino [CPUFREQ] dprintk adjustments to cpufreq-nforce2 [CPUFREQ] Prepare powernow-k8 for future CPUs. [CPUFREQ] Make acpi-cpufreq 'sticky'. [CPUFREQ] Remove strange No-op from longrun.c [CPUFREQ] Remove more freq_table reinitialisations. [CPUFREQ] Fix another redundant initialisation in freq_table [CPUFREQ] Remove duplicate assignment in freq_table [CPUFREQ] CodingStyle nits in cpufreq_stats.c [CPUFREQ] Remove duplicate assignment from cpufreq-nforce2 [CPUFREQ] Remove pointless reinitialisations in acpi-cpufreq [CPUFREQ] Remove pointless reinitialisation from powernow-k8 [CPUFREQ] Remove redundant initialisation from longhaul. [CPUFREQ] Clean up longhaul's speed pretty-printer [CPUFREQ] Disambiguate loop indexes in powernow-k7 [CPUFREQ] Typo in powernow-k8
2006-06-19Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (166 commits) [PATCH] net: au1000_eth: PHY framework conversion [PATCH] 3c5zz ethernet: fix section warnings [PATCH] smc ethernet: fix section mismatch warnings [PATCH] hp ethernet: fix section mismatches [PATCH] Section mismatch in drivers/net/ne.o during modpost [PATCH] e1000: prevent statistics from getting garbled during reset [PATCH] smc911x Kconfig fix [PATCH] forcedeth: new device ids [PATCH] forcedeth config: version [PATCH] forcedeth config: module parameters [PATCH] forcedeth config: diagnostics [PATCH] forcedeth config: move functions [PATCH] forcedeth config: statistics [PATCH] forcedeth config: csum [PATCH] forcedeth config: wol [PATCH] forcedeth config: phy [PATCH] forcedeth config: flow control [PATCH] forcedeth config: ring sizes [PATCH] forcedeth config: tso cleanup [DOC] Update bonding documentation with sysfs info ...
2006-06-19Make sure to re-enable SCI after an ACPI suspendLinus Torvalds
According to the ACPI spec, it should be enabled on return from suspend, but bugs happen. Apparently especially on the Apple Intel Macs. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19Improve SATA core suspend/resumeLinus Torvalds
Doing a full ata_busy_sleep() seems to get suspend and resume working fine on the Apple Mac Mini, at least. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Remove support for NEC DDB5476.Ralf Baechle
As warned several times before. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-18intelfb: fixup clock calculation debugging.Dave Airlie
The debugging code for pll clocks was wrong and causing div by 0. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-06-18Merge branch 'master' into upstreamJeff Garzik
2006-06-17[NET]: Add NETIF_F_GEN_CSUM and NETIF_F_ALL_CSUMHerbert Xu
The current stack treats NETIF_F_HW_CSUM and NETIF_F_NO_CSUM identically so we test for them in quite a few places. For the sake of brevity, I'm adding the macro NETIF_F_GEN_CSUM for these two. We also test the disjunct of NETIF_F_IP_CSUM and the other two in various places, for that purpose I've added NETIF_F_ALL_CSUM. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TG3]: Convert to non-LLTXMichael Chan
Herbert Xu pointed out that it is unsafe to call netif_tx_disable() from LLTX drivers because it uses dev->xmit_lock to synchronize whereas LLTX drivers use private locks. Convert tg3 to non-LLTX to fix this issue. tg3 is a lockless driver where hard_start_xmit and tx completion handling can run concurrently under normal conditions. A tx_lock is only needed to prevent netif_stop_queue and netif_wake_queue race condtions when the queue is full. So whether we use LLTX or non-LLTX, it makes practically no difference. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TG3]: Remove unnecessary tx_lockMichael Chan
Remove tx_lock where it is unnecessary. tg3 runs lockless and so it requires interrupts to be disabled and sync'ed, netif_queue and NAPI poll to be stopped before the device can be reconfigured. After stopping everything, it is no longer necessary to get the tx_lock. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Update version and reldateMichael Chan
Update driver version to 1.4.42. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Use CPU native page sizeMichael Chan
Use CPU native page size to determine various ring sizes. This allows order-0 memory allocations on all systems. Added check to limit the page size to 16K since that's the maximum rx ring size that will be used. This will prevent using unnecessarily large page sizes on some architectures with large page sizes. [Suggested by David Miller] Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Use compressed firmwareMichael Chan
Change bnx2_fw.h to use compressed text for all CPU images. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Add firmware decompressionMichael Chan
Add functions to decompress firmware before loading to the internal CPUs. Compressing the firmware reduces the driver size significantly. Added file name length sanity check in the gzip header to prevent going past the end of buffer [suggested by DaveM]. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Allow WoL settings on new 5708 chipsMichael Chan
Allow WOL settings on 5708 B2 and newer chips that have the problem fixed. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Add an rx drop counterMichael Chan
Add a counter for packets dropped by firmware. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BNX2]: Endian fixes.Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: irda-usb.c: STIR421x cleanupsNick Fedchik
This cleans the STIR421x part of the irda-usb code. We also no longer try to load all existing firmwares but only the matching one (according to the USB id we get from the dongle). Signed-off-by: Nick Fedchik <nfedchik@atlantic-link.com.ua> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NET] ppp: Remove unnecessary pskb_may_pullHerbert Xu
In ppp_receive_nonmp_frame, we call pskb_may_pull(skb, skb->len) if the tailroom is >= 124. This is pointless because this pskb_may_pull is only needed if the skb is non-linear. However, if it is non-linear then the tailroom would be zero. So it can be safely removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NET]: Clean up skb_linearizeHerbert Xu
The linearisation operation doesn't need to be super-optimised. So we can replace __skb_linearize with __pskb_pull_tail which does the same thing but is more general. Also, most users of skb_linearize end up testing whether the skb is linear or not so it helps to make skb_linearize do just that. Some callers of skb_linearize also use it to copy cloned data, so it's useful to have a new function skb_linearize_cow to copy the data if it's either non-linear or cloned. Last but not least, I've removed the gfp argument since nobody uses it anymore. If it's ever needed we can easily add it back. Misc bugs fixed by this patch: * via-velocity error handling (also, no SG => no frags) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NET]: Add netif_tx_lockHerbert Xu
Various drivers use xmit_lock internally to synchronise with their transmission routines. They do so without setting xmit_lock_owner. This is fine as long as netpoll is not in use. With netpoll it is possible for deadlocks to occur if xmit_lock_owner isn't set. This is because if a printk occurs while xmit_lock is held and xmit_lock_owner is not set can cause netpoll to attempt to take xmit_lock recursively. While it is possible to resolve this by getting netpoll to use trylock, it is suboptimal because netpoll's sole objective is to maximise the chance of getting the printk out on the wire. So delaying or dropping the message is to be avoided as much as possible. So the only alternative is to always set xmit_lock_owner. The following patch does this by introducing the netif_tx_lock family of functions that take care of setting/unsetting xmit_lock_owner. I renamed xmit_lock to _xmit_lock to indicate that it should not be used directly. I didn't provide irq versions of the netif_tx_lock functions since xmit_lock is meant to be a BH-disabling lock. This is pretty much a straight text substitution except for a small bug fix in winbond. It currently uses netif_stop_queue/spin_unlock_wait to stop transmission. This is unsafe as an IRQ can potentially wake up the queue. So it is safer to use netif_tx_disable. The hamradio bits used spin_lock_irq but it is unnecessary as xmit_lock must never be taken in an IRQ handler. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[CONNECTOR]: Fix warning in cn_queue.cAndreas Schwab
cn_queue.c:130: warning: value computed is not used There is no point in testing the atomic value if the result is thrown away. From Evgeniy: It was created to put implicit smp barrier, but it is not needed there. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TG3]: update version and reldateMichael Chan
Update version to 3.60. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TG3]: Add recovery logic when MMIOs are re-orderedMichael Chan
Add recovery logic when we suspect that the system is re-ordering MMIOs. Re-ordered MMIOs to the send mailbox can cause bogus tx completions and hit BUG_ON() in the tx completion path. tg3 already has logic to handle re-ordered MMIOs by flushing the MMIOs that must be strictly ordered (such as the send mailbox). Determining when to enable the flush is currently a manual process of adding known chipsets to a list. The new code replaces the BUG_ON() in the tx completion path with the call to tg3_tx_recover(). It will set the TG3_FLAG_MBOX_WRITE_REORDER flag and reset the chip later in the workqueue to recover and start flushing MMIOs to the mailbox. A message to report the problem will be printed. We will then decide whether or not to add the host bridge to the list of chipsets that do re-ordering. We may add some additional code later to print the host bridge's ID so that the user can report it more easily. The assumption that re-ordering can only happen on x86 systems is also removed. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TG3]: Add 5786 PCI IDMichael Chan
Add PCI ID for BCM5786 which is a variant of 5787. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: ali-ircc: using device model power managementSamuel Ortiz
This patch gets rid of the old power management code and now uses the device model for the ali-ircc driver. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: stir4200, switching to the kthread APIChristoph Hellwig
stir4200 uses a kernel thread for its TX/RX operations, and it is now converted to the kernel kthread API. Tested on an STIR4200 based dongle. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: Initial support for MCS7780 based donglesSamuel Ortiz
The MosChip MCS7780 chipset is an IrDA USB bridge that doesn't conform with the IrDA-USB standard and thus needs its separate driver. Tested on an actual MCS7780 based dongle. Original implementation by Brian Pugh <bpugh@cs.pdx.edu> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Do not use for_each_cpu().Andrew Morton
for_each_cpu() is going away (and is gone in -mm). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Utility functions for offloading sk_buff to iovec copiesChris Leech
Provides for pinning user space pages in memory, copying to iovecs, and copying from sk_buffs including fragmented and chained sk_buffs. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Setup the networking subsystem as a DMA clientChris Leech
Attempts to allocate per-CPU DMA channels Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Move PCI_DEVICE_ID_INTEL_IOAT to linux/pci_ids.hDavid S. Miller
2006-06-17[I/OAT]: ioatdma.c needs linux/dma-mapping.hDavid S. Miller
For DMA_*_MASK defines. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: Driver for the Intel(R) I/OAT DMA engineChris Leech
Adds a new ioatdma driver Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[I/OAT]: DMA memcpy subsystemChris Leech
Provides an API for offloading memory copies to DMA devices Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17IB/uverbs: Don't serialize with ib_uverbs_idr_mutexRoland Dreier
Currently, all userspace verbs operations that call into the kernel are serialized by ib_uverbs_idr_mutex. This can be a scalability issue for some workloads, especially for devices driven by the ipath driver, which needs to call into the kernel even for datapath operations. Fix this by adding reference counts to the userspace objects, and then converting ib_uverbs_idr_mutex into a spinlock that only protects the idrs long enough to take a reference on the object being looked up. Because remove operations may fail, we have to do a slightly funky two-step deletion, which is described in the comments at the top of uverbs_cmd.c. This also still leaves ib_uverbs_idr_lock as a single lock that is possibly subject to contention. However, the lock hold time will only be a single idr operation, so multiple threads should still be able to make progress, even if ib_uverbs_idr_lock is being ping-ponged. Surprisingly, these changes even shrink the object code: add/remove: 23/5 grow/shrink: 4/21 up/down: 633/-693 (-60) Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB/mthca: Make all device methods truly reentrantRoland Dreier
Documentation/infiniband/core_locking.txt says: All of the methods in struct ib_device exported by a low-level driver must be fully reentrant. The low-level driver is required to perform all synchronization necessary to maintain consistency, even if multiple function calls using the same object are run simultaneously. However, mthca's modify_qp, modify_srq and resize_cq methods are currently not reentrant. Add a mutex to the QP, SRQ and CQ structures so that these calls can be properly serialized. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB/mthca: Fix memory leak on modify_qp error pathsRoland Dreier
Some error paths after the mthca_alloc_mailbox() call in mthca_modify_qp() just do a "return -EINVAL" without freeing the mailbox. Convert these returns to "goto out" to avoid leaking the mailbox storage. Signed-off-by: Roland Dreier <rolandd@cisco.com>
