git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
During a HW reset, the diversity config is programmed
in the set_board_values() eeprom callback, there is no
need to do it again by calling ath_ant_comb_update().
Fixed antenna support is not fully handled for 1-stream
cards, it can be done later.
prism2_open() as an .ndo_open handler should not return positive numbers
in case of failure, but it does return 1 in a couple of places.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
WB225 based cards like CUS198 and CUS230 support
both fast antenna diversity and LNA combining. Add support
for this and also program the SWCOM register with the
correct "ant_ctrl_comm2g_switch_enable" value.
CUS198/CUS230 cards require a custom value to be
programmed into the SWCOM register. Assign this during
init time.
This variable is redundant since we can use
common->bt_ant_diversity to determine if diversity
has to be enabled/disabled.
The MC_GAIN_CTL/CCK_DETECT registers have to be programmed
with the correct configuration values if WLAN/BT RX diversity
is enabled. Add this and also take care of the BTCOEX mode
when fast diversity is enabled/disabled.
A custom solution for Asus is WB195 based and supports
WLAN/BT Rx diversity. Identify this card and set the
capability.
CUS198/CUS230, which are based on WB225 also support
Use "ath9k_hw_set_bt_ant_diversity" instead.
Make use of this capability to restrict the usage of the
debugfs file and modparam using which this feature can
be enabled.
For single-chain WLAN+BT cards, the BT antenna can be used for
WLAN RX when the BT interface is disabled. Rename the modparam
"antenna_diversity" to "bt_ant_diversity" to clarify this.
CUS198/CUS230 need a few tweaks in the antenna diversity
algorithm to accomodate RSSI variation. Add a couple
of knobs to control low RSSI threshold and fast antenna
diversity bias values.
There's an underlying race condition with the unjoin_work() call that is
sometimes triggered depending on scheduling order and the phase of the
moon. This doesn't fix the race condition, but it does remove the
ill-advised BUG_ON() call in an easily-recoverable situation.
Signed-off-by: Solomon Peachy <pizza@shaftnet.org>
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-next
Using rfkill switch can make firmware unstable, what cause various
Microcode errors and kernel warnings. Reseting firmware just after
rfkill off (radio on) helped with that.
Resolve:
https://bugzilla.redhat.com/show_bug.cgi?id=977053
Reported-and-tested-by: Justin Pearce <whitefox@guardianfox.net>
Cc: stable@vger.kernel.org
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
If device was put into a sleep and system was restarted or module
reloaded, we have to wake device up before sending other commands.
Otherwise it will fail to start with Microcode error.
There is a function to do a ratio comparison for ALT,
so make use of it.
Right now, it is being done for all cases.
4965 version of Eric patch "iwl3945: better skb management in rx path".
It fixes several problems :
1) skb->truesize is underestimated.
We really consume PAGE_SIZE bytes for a fragment,
not the frame length.
2) 128 bytes of initial headroom is a bit low and forces reallocations.
3) We can avoid consuming a full page for small enough frames.
With recent patches ssb can fetch info about serial flash and register
it as a platform device. No more reasons to mark it BROKEN.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Move rtl92cu_update_hal_rate_tbl declaration to hw.h to correspond with function
definition in hw.c.
Fixes sparse warning in hw.c warning: symbol 'rtl92cu_update_hal_rate_tbl' was
not declared.
Signed-off-by: Mark Schulte <schultetwin@gmail.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Whenever available, use cfg80211_scan_request to populates rates
in outgoing probe request. This will help to advertise band specific
rates and fix an issue where 11b rates were advertised in probe
request going out on 11a band.
This will also ensure that we do not advertise 11b rates while P2P
scan is going on.
Signed-off-by: Avinash Patil <patila@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
It has introduced by recent commit 6b41f941d7cd: "mwifiex:
handle driver initialization error paths" which adds error
path handling for mwifiex_fw_dpc().
release_firmware(adapter->*) is called for success as well
as failure paths. In failure paths, adapter is already freed
at this point.
The issue is fixed by moving mwifiex_free_adapter() call.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
net/bluetooth/hci_core.c
We missed bss_mode check for P2P client.
Signed-off-by: Stone Piao <piaoyun@marvell.com>
This patch fixes an issue wherein adhoc rates were being copied
into association request from P2P client.
Cc: <stable@vger.kernel.org> # 3.10.y
This patch fixes an issue wherein association would fail on P2P
interfaces. This happened because we are checking priv->mode
against NL80211_IFTYPE_STATION. While this check is correct for
infrastructure stations, it would fail P2P clients for which mode
is NL80211_IFTYPE_P2P_CLIENT.
Better check would be bss_role which has only 2 values: STA/AP.
This feature is fully supported by iwlwmvm, so advertise
it.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
When the NIC is expected to operate in high temperature,
it is advisable to put more aggresive thermal throttling
parameters, in order to prevent CT-kill.
Signed-off-by: eytan lifshitz <eytan.lifshitz@intel.com>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Set beacon abort escape timer values - 6 beacons in D0 state,
9 beacons in D3 and D0i3.
Signed-off-by: Alexander Bondar <alexander.bondar@intel.com>
The rate scale windows are cleared twice as part of the init.
Cleanup this duplication in both mvm and dvm.
Signed-off-by: Eyal Shapira <eyal@wizery.com>
This API isn't valid any more. It wasn't used anyway.
Instead of reporting the maximum signal strength and the
antenna bitmap in the antenna field (which is really just
for radiotap and defined differently), report the signal
strength values per chain and set the chain bitmap.
If fw_restart is disabled, using the fw_restart debugfs
file will enable fw_restart and then send the failing
command, but this still frequently fails restart because
it resets fw_restart afterwards and is thus racy.
Fix this by tracking fw_restart separately and allowing
"always restart", "never restart" and "restart N times".
Signed-off-by: Eran Harary <eran.harary@intel.com>
Change beacon filtering command due to a change in the API.
In case the FW supports the old API, we do not send the
BF HCMD and assume that since the corresponding struct in
the FW is zeroed by default then we don't need to disable
it in the FW actively.
Signed-off-by: Hila Gonen <hila.gonen@intel.com>
Signed-off-by: Dor Shaish <dor.shaish@intel.com>
The current registered the per-vif debugfs handler for
STA mode only.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
To make maintaining some constant default values in the
driver easier, declare them in a separate file.
