path: root/drivers
2010-08-09fix printk typo 'faild'Paul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-09Fix spelling fuction -> function in commentsStefan Weil
To avoid more patches, I also fixed other spelling and grammar bugs when they were in the same or following line: successfull -> successful parse -> parses controler -> controller controlers -> controllers Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (30 commits) Revert "HID: add support for the Wacom Intuos 4 wireless" HID: fix up Kconfig entry for ACRUX driver HID: add ACRUX game controller force feedback support HID: Force input registration for "VEC footpedal" HID: add HID_QUIRK_HIDINPUT_FORCE HID: hid-input.c: indentation fixes HID: hiddev: use usb_find_interface, get rid of BKL HID: ignore digitizer usage Undefined (0x00) HID: Add support for Conceptronic CLLRCMCE HID: hid-ids.h: Whitespace fixup, align using TABs HID: picolcd: implement refcounting of framebuffer HID: picolcd: do not reallocate memory on depth change HID: picolcd: Add minimal palette required by fbcon on 8bpp HID: magicmouse: Correct parsing of large X and Y motions. HID: magicmouse: report last touch up HID: picolcd: fix deferred_io init/cleanup to fb ordering HID: hid-ids.h: keep vendor ids in alphabetical order HID: add proper support for Elecom BM084 bluetooth mouse HID: magicmouse: enable horizontal scrolling HID: magicmouse: add param for scroll speed ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (39 commits) random: Reorder struct entropy_store to remove padding on 64bits padata: update API documentation padata: Remove padata_get_cpumask crypto: pcrypt - Update pcrypt cpumask according to the padata cpumask notifier crypto: pcrypt - Rename pcrypt_instance padata: Pass the padata cpumasks to the cpumask_change_notifier chain padata: Rearrange set_cpumask functions padata: Rename padata_alloc functions crypto: pcrypt - Dont calulate a callback cpu on empty callback cpumask padata: Check for valid cpumasks padata: Allocate cpumask dependend recources in any case padata: Fix cpu index counting crypto: geode_aes - Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used) pcrypt: Added sysfs interface to pcrypt padata: Added sysfs primitives to padata subsystem padata: Make two separate cpumasks padata: update documentation padata: simplify serialization mechanism padata: make padata_do_parallel to return zero on success padata: Handle empty padata cpumasks ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (276 commits) [SCSI] zfcp: Trigger logging in the FCP channel on qdio error conditions [SCSI] zfcp: Introduce experimental support for DIF/DIX [SCSI] zfcp: Enable data division support for FCP devices [SCSI] zfcp: Prevent access on uninitialized memory. [SCSI] zfcp: Post events through FC transport class [SCSI] zfcp: Cleanup QDIO attachment and improve processing. [SCSI] zfcp: Cleanup function parameters for sbal value. [SCSI] zfcp: Use correct width for timer_interval field [SCSI] zfcp: Remove SCSI device when removing unit [SCSI] zfcp: Use memdup_user and kstrdup [SCSI] zfcp: Fix retry after failed "open port" erp action [SCSI] zfcp: Fail erp after timeout [SCSI] zfcp: Use forced_reopen in terminate_rport_io callback [SCSI] zfcp: Register SCSI devices after successful fc_remote_port_add [SCSI] zfcp: Do not try "forced close" when port is already closed [SCSI] zfcp: Do not unblock rport from REOPEN_PORT_FORCED [SCSI] sd: add support for runtime PM [SCSI] implement runtime Power Management [SCSI] convert to the new PM framework [SCSI] Unify SAM_ and SAM_STAT_ macros ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6: ibft: Use IBFT_SIGN instead of open-coding the search string. ibft: convert iscsi_ibft module to iscsi boot lib ibft: separate ibft parsing from sysfs interface ibft: For UEFI machines actually do scan ACPI for iBFT. ibft: Update iBFT handling for v1.03 of the spec.
2010-08-04Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: amd64_edac: Minor formatting fix amd64_edac: Fix operator precendence error edac, mc: Improve scrub rate handling amd64_edac: Correct scrub rate setting amd64_edac: Fix DCT base address selector amd64_edac: Remove polling mechanism x86, mce: Notify about corrected events too amd64_edac: Remove unneeded defines edac: Remove EDAC_DEBUG_VERBOSE amd64_edac: Sanitize syndrome extraction
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Runtime: Add runtime PM statistics (v3) PM / Runtime: Make runtime_status attribute not debug-only (v. 2) PM: Do not use dynamically allocated objects in pm_wakeup_event() PM / Suspend: Fix ordering of calls in suspend error paths PM / Hibernate: Fix snapshot error code path PM / Hibernate: Fix hibernation_platform_enter() pm_qos: Get rid of the allocation in pm_qos_add_request() pm_qos: Reimplement using plists plist: Add plist_last PM: Make it possible to avoid races between wakeup and system sleep PNPACPI: Add support for remote wakeup PM: describe kernel policy regarding wakeup defaults (v. 2) PM / Hibernate: Fix typos in comments in kernel/power/swap.c
2010-08-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Remove pointless printk from p4-clockmod. [CPUFREQ] Fix section mismatch for powernow_cpu_init in powernow-k7.c [CPUFREQ] Fix section mismatch for longhaul_cpu_init. [CPUFREQ] Fix section mismatch for longrun_cpu_init. [CPUFREQ] powernow-k8: Fix misleading variable naming [CPUFREQ] Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used) [CPUFREQ] arch/x86/kernel/cpu/cpufreq: use for_each_pci_dev() [CPUFREQ] fix brace coding style issue. [CPUFREQ] x86 cpufreq: Make trace_power_frequency cpufreq driver independent [CPUFREQ] acpi-cpufreq: Fix CPU_ANY CPUFREQ_{PRE,POST}CHANGE notification [CPUFREQ] ondemand: don't synchronize sample rate unless multiple cpus present [CPUFREQ] unexport (un)lock_policy_rwsem* functions [CPUFREQ] ondemand: Refactor frequency increase code [CPUFREQ] powernow-k8: On load failure, remind the user to enable support in BIOS setup [CPUFREQ] powernow-k8: Limit Pstate transition latency check [CPUFREQ] Fix PCC driver error path [CPUFREQ] fix double freeing in error path of pcc-cpufreq [CPUFREQ] pcc driver should check for pcch method before calling _OSC [CPUFREQ] fix memory leak in cpufreq_add_dev [CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)" Manually fix up non-data merge conflict introduced by new calling conventions for trace_power_start() in commit 6f4f2723d085 ("x86 cpufreq: Make trace_power_frequency cpufreq driver independent"), which didn't update the intel_idle native hardware cpuidle driver.
2010-08-04Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (88 commits) ips driver: make it less chatty intel_scu_ipc: fix size field for intel_scu_ipc_command intel_scu_ipc: return -EIO for error condition in busy_loop intel_scu_ipc: fix data packing of PMIC command on Moorestown Clean up command packing on MRST. zero the stack buffer before giving random garbage to the SCU Fix stack buffer size for IPC writev messages intel_scu_ipc: Use the new cpu identification function intel_scu_ipc: tidy up unused bits Remove indirect read write api support. intel_scu_ipc: Support Medfield processors intel_scu_ipc: detect CPU type automatically x86 plat: limit x86 platform driver menu to X86 acpi ec_sys: Be more cautious about ec write access acpi ec: Fix possible double io port registration hp-wmi: acpi_drivers.h is already included through acpi.h two lines below hp-wmi: Fix mixing up of and/or directive dell-laptop: make dell_laptop_i8042_filter() static asus-laptop: fix asus_input_init error path msi-wmi: make needlessly global symbols static ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) Input: adp5588-keypad - fix NULL dereference in adp5588_gpio_add() Input: cy8ctmg110 - capacitive touchscreen support Input: keyboard - also match braille-only keyboards Input: adp5588-keys - export unused GPIO pins Input: xpad - add product ID for Hori Fighting Stick EX2 Input: adxl34x - fix leak and use after free Input: samsung-keypad - Add samsung keypad driver Input: i8042 - reset keyboard controller wehen resuming from S2R Input: synaptics - set min/max for finger width Input: synaptics - only report width on hardware that supports it Input: evdev - signal that device is writable in evdev_poll() Input: mousedev - signal that device is writable in mousedev_poll() Input: change input handlers to use bool when possible Input: document the MT event slot protocol Input: introduce MT event slots Input: usbtouchscreen - implement reset_resume Input: usbtouchscreen - implement runtime power management Input: usbtouchscreen - implement basic suspend/resume Input: Add ATMEL QT602240 touchscreen driver Input: fix signedness warning in input_set_keycode() ...
2010-08-04Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (243 commits) V4L/DVB: sms: Convert IR support to use the Remote Controller core V4L/DVB: sms: properly initialize IR phys and IR name V4L/DVB: standardize names at rc-dib0700 tables V4L/DVB: smsusb: enable IR port for Hauppauge WinTV MiniStick V4L/DVB: dib0700: Fix RC protocol logic to properly handle NEC/NECx and RC-5 V4L/DVB: dib0700: properly implement IR change_protocol V4L/DVB: dib0700: break keytable into NEC and RC-5 variants V4L/DVB: dib0700: avoid bad repeat V4L/DVB: Port dib0700 to rc-core V4L/DVB: Add a keymap file with dib0700 table V4L/DVB: dvb-usb: add support for rc-core mode V4L/DVB: dvb-usb: prepare drivers for using rc-core V4L/DVB: dvb-usb: get rid of struct dvb_usb_rc_key V4L/DVB: rj54n1cb0c: fix a comment in the driver V4L/DVB: V4L2: sh_vou: VOU does support the full PAL resolution too V4L/DVB: V4L2: sh_mobile_camera_ceu: add support for CSI2 V4L/DVB: V4L2: soc-camera: add a MIPI CSI-2 driver for SH-Mobile platforms V4L/DVB: V4L2: soc-camera: export soc-camera bus type for notifications V4L/DVB: V4L2: mediabus: add 12-bit Bayer and YUV420 pixel formats V4L/DVB: mediabus: fix ambiguous pixel code names ...
2010-08-04Merge branch 'bkl' into for-linusJiri Kosina
2010-08-04Merge branches 'magicmouse', 'roccat' and 'vec-pedal' into for-linusJiri Kosina
Conflicts: drivers/hid/hid-ids.h
2010-08-04Merge branch 'acrux' into for-linusJiri Kosina
2010-08-04Merge branch 'upstream-fixes' into for-linusJiri Kosina
2010-08-04Merge branch 'upstream' into for-linusJiri Kosina
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-08-04hostap:hostap_hw.c Fix typo in commentJustin P. Mattock
The patch below fixes a typo in a comment. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04Fix spelling contorller -> controller in commentsStefan Weil
2010-08-04amd64_edac: Minor formatting fixBorislav Petkov
EDAC MC3: CE page 0xc32281, offset 0x8a0, grain 0, syndrome 0x1, row 2, channel 1, label "": amd64_edac EDAC MC3: CE - no information available: amd64_edacError Overflow Add the missing space before "Error Overflow" on the second line. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-08-04amd64_edac: Fix operator precendence errorBorislav Petkov
The bitwise AND is of higher precedence, make that explicit. Cc: <stable@kernel.org> # 34.x Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-08-03phy/marvell: add 88ec048 supportCyril Chemparathy
Marvell 88ec048 is a derivative of its 88e1121r device. From the programmer's perspective, the one major difference is the addition of an additional control bit in Page 2 Register 16 - used to control the padding of odd nibble preambles. This patch adds support for this new device, while inheriting as much code as possible from the existing 88e1121r implementation. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03igb: Program MDICNFG register prior to PHY initAlexander Duyck
This patch addresses an issue seen on 82580 in which the MDICNFG register will be reset during a single function reset and as a result we will be unable to communicate with the PHY. To correct the issue, added a call to reset_mdicnfg just prior to the first access of the MDICNFG register in sgnii_uses_mdio. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03e1000e: correct MAC-PHY interconnect register offset for 82579Bruce Allan
The MAC-PHY interconnect register set on ICH/PCH parts is accessed through a peephole mechanism by writing an offset to a CSR register. The offset for the interconnect's half-duplex control register (which is used in a jumbo frame workaround for 82579) is incorrect. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03hso: Add new product IDFilip Aben
This patch adds a new product ID to the hso driver. Signed-off-by: Filip Aben <f.aben@option.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03can: Add driver for esd CAN-USB/2 deviceMatthias Fuchs
This patch adds a driver for esd's USB high speed CAN interface. The driver supports devices with multiple CAN interfaces. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: do not warn unnecessarily UBI: do not print message about corruptes PEBs if we have none of them UBI: improve delete-compatible volumes handling UBI: fix error message and compilation warnings UBI: generate random image_seq when formatting MTD devices UBI: improve ECC error message UBI: improve corrupted flash handling UBI: introduce eraseblock counter variables UBI: introduce a new IO return code UBI: simplify IO error codes
2010-08-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (291 commits) ARM: AMBA: Add pclk support to AMBA bus infrastructure ARM: 6278/2: fix regression in RealView after the introduction of pclk ARM: 6277/1: mach-shmobile: Allow users to select HZ, default to 128 ARM: 6276/1: mach-shmobile: remove duplicate NR_IRQS_LEGACY ARM: 6246/1: mmci: support larger MMCIDATALENGTH register ARM: 6245/1: mmci: enable hardware flow control on Ux500 variants ARM: 6244/1: mmci: add variant data and default MCICLOCK support ARM: 6243/1: mmci: pass power_mode to the translate_vdd callback ARM: 6274/1: add global control registers definition header file for nuc900 mx2_camera: fix type of dma buffer virtual address pointer mx2_camera: Add soc_camera support for i.MX25/i.MX27 arm/imx/gpio: add spinlock protection ARM: Add support for the LPC32XX arch ARM: LPC32XX: Arch config menu supoport and makefiles ARM: LPC32XX: Phytec 3250 platform support ARM: LPC32XX: Misc support functions ARM: LPC32XX: Serial support code ARM: LPC32XX: System suspend support ARM: LPC32XX: GPIO, timer, and IRQ drivers ARM: LPC32XX: Clock driver ...
2010-08-03[CPUFREQ] fix brace coding style issue.Neal Buckendahl
This patch fixes up a brace warning found by the checkpatch.pl tool Signed-off-by: Neal Buckendahl <nealb001@tbcnet.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] x86 cpufreq: Make trace_power_frequency cpufreq driver independentThomas Renninger
and fix the broken case if a core's frequency depends on others. trace_power_frequency was only implemented in a rather ungeneric way in acpi-cpufreq driver's target() function only. -> Move the call to trace_power_frequency to cpufreq.c:cpufreq_notify_transition() where CPUFREQ_POSTCHANGE notifier is triggered. This will support power frequency tracing by all cpufreq drivers trace_power_frequency did not trace frequency changes correctly when the userspace governor was used or when CPU cores' frequency depend on each other. -> Moving this into the CPUFREQ_POSTCHANGE notifier and pass the cpu which gets switched automatically fixes this. Robert Schoene provided some important fixes on top of my initial quick shot version which are integrated in this patch: - Forgot some changes in power_end trace (TP_printk/variable names) - Variable dummy in power_end must now be cpu_id - Use static 64 bit variable instead of unsigned int for cpu_id Signed-off-by: Thomas Renninger <trenn@suse.de> CC: davej@redhat.com CC: arjan@infradead.org CC: linux-kernel@vger.kernel.org CC: robert.schoene@tu-dresden.de Tested-by: robert.schoene@tu-dresden.de Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] ondemand: don't synchronize sample rate unless multiple cpus presentJocelyn Falempe
For UP systems this is not required, and results in a more consistent sample interval. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jocelyn Falempe <jocelyn.falempe@motorola.com> Signed-off-by: Mike Chan <mike@android.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] unexport (un)lock_policy_rwsem* functionsAmerigo Wang
lock_policy_rwsem_* and unlock_policy_rwsem_* functions are scheduled to be unexported when 2.6.33. Now there are no other callers of them out of cpufreq.c, unexport them and make them static. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] ondemand: Refactor frequency increase codeMike Chan
Make simpler to read and call. *** v3 - Always call when powersave_bias is enabled. Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Mike Chan <mike@android.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] fix memory leak in cpufreq_add_devXiaotian Feng
We didn't free policy->related_cpus in error path err_unlock_policy. This is catched by following kmemleak report: unreferenced object 0xffff88022a0b96d0 (size 512): comm "modprobe", pid 886, jiffies 4294689177 (age 780.694s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff8111ebe5>] create_object+0x186/0x281 [<ffffffff814fad4f>] kmemleak_alloc+0x60/0xa7 [<ffffffff8111127a>] kmem_cache_alloc_node_notrace+0x120/0x142 [<ffffffff81262e4f>] alloc_cpumask_var_node+0x2c/0xd7 [<ffffffff81262f0b>] alloc_cpumask_var+0x11/0x13 [<ffffffff81262f1c>] zalloc_cpumask_var+0xf/0x11 [<ffffffff8140fac0>] cpufreq_add_dev+0x11f/0x547 [<ffffffff81334bda>] sysdev_driver_register+0xc2/0x11d [<ffffffff8140e334>] cpufreq_register_driver+0xcb/0x1b8 [<ffffffffa032e040>] 0xffffffffa032e040 [<ffffffff810021ba>] do_one_initcall+0x5e/0x15c [<ffffffff81087f94>] sys_init_module+0xa6/0x1e6 [<ffffffff81009bc2>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call ↵Andrej Gelenberg
(second call site)" 395913d0b1db37092ea3d9d69b832183b1dd84c5 ("[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)") is not needed, because there is no rwsem lock in cpufreq_ondemand and cpufreq_conservative anymore. Lock should not be released until the work done. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=1594 Signed-off-by: Andrej Gelenberg <andrej.gelenberg@udo.edu> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03PARISC: led.c - fix potential stack overflow in led_proc_write()Helge Deller
avoid potential stack overflow by correctly checking count parameter Reported-by: Ilja <ilja@netric.org> Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-03ips driver: make it less chattyJesse Barnes
We don't need a dev_warn when we exceed a thermal or power limit as we'll handle it appropriately by clamping down on the CPU, GPU or both as needed. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03edac, mc: Improve scrub rate handlingBorislav Petkov
Fortify the interface to not accept negative values, remove memctrl_int_store() as a result. Also, sanitize bandwidth setting by making the argument a simple u32 instead of strange u32 pointer being passed around for no obvious reason. Then, fix error handling and teach it to return proper error values. Finally, make code more readable, simplify debug messages. Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Arthur Jones <ajones@riverbed.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-08-03amd64_edac: Correct scrub rate settingBorislav Petkov
Exit early when setting scrub rate on unknown/unsupported families. Cc: <stable@kernel.org> # 32.x 33.x 34.x Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-08-03amd64_edac: Fix DCT base address selectorBorislav Petkov
The correct check is to verify whether in high range we're below 4GB and not to extract the DctSelBaseAddr again. See "2.8.5 Routing DRAM Requests" in the F10h BKDG. Cc: <stable@kernel.org> # .32.x .33.x .34.x Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-08-03amd64_edac: Remove polling mechanismBorislav Petkov
Switch to reusing the mcheck core's machine check polling mechanism instead of duplicating functionality by using the EDAC polling routine. Correct formatting while at it. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-08-03amd64_edac: Remove unneeded definesBorislav Petkov
All F2x110-related bit defines are used at only one place so replace them with simple BIT() macros. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-08-03edac: Remove EDAC_DEBUG_VERBOSEBorislav Petkov
This option differs from EDAC_DEBUG only by printing the file and line of where the debug statement is placed, which contains unneeded information. So remove it. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-08-03amd64_edac: Sanitize syndrome extractionBorislav Petkov
Remove the two syndrome extraction macros and add a single function which does the same thing but with proper typechecking. While at it, make sure to cache ECC syndrome size and dump it in debug output. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-08-03intel_scu_ipc: fix size field for intel_scu_ipc_commandHong Liu
Size for PMIC read/write command is byte, while it is DWORD for other IPC commands. Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: ALan Cox <alan@linux.intel.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03intel_scu_ipc: return -EIO for error condition in busy_loopHong Liu
Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03intel_scu_ipc: fix data packing of PMIC command on MoorestownHong Liu
Data is 2-byte per entry for PMIC read-modify-update command. Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
