there is an overflow in the code :
cyz_polling_cycle = (arg * HZ) / 1000,
the multiplicator arg comes from user, so it may be an overflow if
arg is a big number. And the value of cyc_polling_cycle will be
wrong when it is used next time.
Reported-by: Qixue Xiao <xiaoqixue_1@163.com>
Suggested-by: Yongjian Xu <xuyongjiande@gmail.com>
Suggested-by: Yu Chen <chyyuu@gmail.com>
Signed-off-by: Qixue Xiao <xiaoqixue_1@163.com>
New driver for NXP (Philips) UART ICs was introduced in September 2012.
Old driver no longer used anywhere, this patch removes it.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Cc: stable <stable@vger.kernel.org>
Fix the initialisation of older Quatech serial cards which are fitted with
the AMCC PCI Matchmaker interface chip.
Signed-off-by: Jonathan Woithe (jwoithe@just42.net)
Commit 4d9b109060f690f5c835(tty: Prevent deadlock in n_gsm driver)
tried to close all the virtual ports synchronously before closing the
phycial ports, so the tty_vhangup() is used.
But the tty_unlock/lock() is wrong:
tty_release
tty_ldisc_release
tty_lock_pair(tty, o_tty) < == Here the tty is for physical port
tty_ldisc_kill
gsmld_close
gsm_cleanup_mux
gsm_dlci_release
tty = tty_port_tty_get(&dlci->port)
< == Here the tty(s) are for virtual port
They are different ttys, so before tty_vhangup(virtual tty), do not need
to call the tty_unlock(virtual tty) at all which causes unbalanced unlock
warning.
When enabling mutex debugging option, we will hit the below warning also:
[ 99.276903] =====================================
[ 99.282172] [ BUG: bad unlock balance detected! ]
[ 99.287442] 3.10.20-261976-gaec5ba0 #44 Tainted: G O
[ 99.293972] -------------------------------------
[ 99.299240] mmgr/152 is trying to release lock (&tty->legacy_mutex) at:
[ 99.306693] [<c1b2dcad>] mutex_unlock+0xd/0x10
[ 99.311669] but there are no more locks to release!
[ 99.317131]
[ 99.317131] other info that might help us debug this:
[ 99.324440] 3 locks held by mmgr/152:
[ 99.328542] #0: (&tty->legacy_mutex/1){......}, at: [<c1b30ab0>] tty_lock_nested+0x40/0x90
[ 99.338116] #1: (&tty->ldisc_mutex){......}, at: [<c15dbd02>] tty_ldisc_kill+0x22/0xd0
[ 99.347284] #2: (&gsm->mutex){......}, at: [<c15e3d83>] gsm_cleanup_mux+0x73/0x170
[ 99.356060]
[ 99.356060] stack backtrace:
[ 99.360932] CPU: 0 PID: 152 Comm: mmgr Tainted: G O 3.10.20-261976-gaec5ba0 #44
[ 99.370086] ef4a4de0 ef4a4de0 ef4c1d98 c1b27b91 ef4c1db8 c1292655 c1dd10f5 c1b2dcad
[ 99.378921] c1b2dcad ef4a4de0 ef4a528c ffffffff ef4c1dfc c12930dd 00000246 00000000
[ 99.387754] 00000000 00000000 c15e1926 00000000 00000001 ddfa7530 00000003 c1b2dcad
[ 99.396588] Call Trace:
[ 99.399326] [<c1b27b91>] dump_stack+0x16/0x18
[ 99.404307] [<c1292655>] print_unlock_imbalance_bug+0xe5/0xf0
[ 99.410840] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.416110] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.421382] [<c12930dd>] lock_release_non_nested+0x1cd/0x210
[ 99.427818] [<c15e1926>] ? gsm_destroy_network+0x36/0x130
[ 99.433964] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.439235] [<c12931a2>] lock_release+0x82/0x1c0
[ 99.444505] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.449776] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.455047] [<c1b2dc2f>] __mutex_unlock_slowpath+0x5f/0xd0
[ 99.461288] [<c1b2dcad>] mutex_unlock+0xd/0x10
[ 99.466365] [<c1b30bb1>] tty_unlock+0x21/0x50
[ 99.471345] [<c15e3dd1>] gsm_cleanup_mux+0xc1/0x170
[ 99.476906] [<c15e44d2>] gsmld_close+0x52/0x90
[ 99.481983] [<c15db905>] tty_ldisc_close.isra.1+0x35/0x50
[ 99.488127] [<c15dbd0c>] tty_ldisc_kill+0x2c/0xd0
[ 99.493494] [<c15dc7af>] tty_ldisc_release+0x2f/0x50
[ 99.499152] [<c15d572c>] tty_release+0x37c/0x4b0
[ 99.504424] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.509695] [<c1b2dcad>] ? mutex_unlock+0xd/0x10
[ 99.514967] [<c1372f6e>] ? eventpoll_release_file+0x7e/0x90
[ 99.521307] [<c1335849>] __fput+0xd9/0x200
[ 99.525996] [<c133597d>] ____fput+0xd/0x10
[ 99.530685] [<c125c731>] task_work_run+0x81/0xb0
[ 99.535957] [<c12019e9>] do_notify_resume+0x49/0x70
[ 99.541520] [<c1b30dc4>] work_notifysig+0x29/0x31
[ 99.546897] ------------[ cut here ]------------
So here we can call tty_vhangup() directly which is for virtual port.
Reviewed-by: Chao Bi <chao.bi@intel.com>
Signed-off-by: Liu, Chuansheng <chuansheng.liu@intel.com>
Mark the function hvc_poll_init() as static in hvc/hvc_console.c because
it is not used outside this file.
This eliminates the following warning in hvc/hvc_console.c:
drivers/tty/hvc/hvc_console.c:791:5: warning: no previous prototype for ‘hvc_poll_init’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Marks the functions gsm_cleanup_mux(), gsm_activate_mux(),
gsm_free_mux(), gsm_alloc_mux() and gsm_change_mtu() as static in
n_gsm.c because they are not used outside this file.
Also, drop the EXPORT_SYMBOL_GPL for the above mentioned functions
because nothing else in the kernel calls them.
This eliminates the following warnings in n_gsm.c:
drivers/tty/n_gsm.c:2022:6: warning: no previous prototype for ‘gsm_cleanup_mux’ [-Wmissing-prototypes]
drivers/tty/n_gsm.c:2076:5: warning: no previous prototype for ‘gsm_activate_mux’ [-Wmissing-prototypes]
drivers/tty/n_gsm.c:2120:6: warning: no previous prototype for ‘gsm_free_mux’ [-Wmissing-prototypes]
drivers/tty/n_gsm.c:2156:17: warning: no previous prototype for ‘gsm_alloc_mux’ [-Wmissing-prototypes]
drivers/tty/n_gsm.c:2714:5: warning: no previous prototype for ‘gsm_change_mtu’ [-Wmissing-prototypes]
When falling back from DMA to interrupt mode the receive interrupt has to
be re-enabled to catch new incoming data.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
In pl011_rx_chars() if pl011_dma_rx_trigger_dma() succeeds it will disable
the receive interrupt, no need to do this again.
During initialisation, a UART may already be in use for a console, so
take care to preserve things like baud rate and data format to avoid
corrupting console output.
Signed-off-by: Jon Medhurst <tixy@linaro.org>
The code to cope with a split tx/rx LCR_H register is non-trivial
so put it into it's own function to avoid duplication.
When the pl011 is being used for a console, pl011_console_write forces
the control register (CR) to enable the UART for transmission and then
restores this to the original value afterwards. It does this while
holding the port lock.
Unfortunately, when the uart is started or shutdown - say in response to
userland using the serial device for a terminal - then this updates the
control register without any locking.
This means we can have
pl011_console_write Save CR
pl011_startup Initialise CR, e.g. enable receive
pl011_console_write Restore old CR with receive not enabled
this result is a serial port which doesn't respond to any input.
A similar race in reverse could happen when the device is shutdown.
We can fix these problems by taking the port lock when updating CR.
This reverts commit 17438217a6f5e33d920ed3821a4b857311cc2872 on request
of Linus Walleij:
Greg can you please drop or revert
"serial: pl011: use DMA RX polling by default"
from the TTY tree until this has been sorted out?
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
readline() inadvertently triggers an error recovery path when
pastes larger than 4k overrun the line discipline buffer. The
error recovery path discards input when the line discipline buffer
is full and operating in canonical mode and no newline has been
received. Because readline() changes the termios to non-canonical
mode to read the line char-by-char, the line discipline buffer
can become full, and then when readline() restores termios back
to canonical mode for the caller, the now-full line discipline
buffer triggers the error recovery.
When changing termios from non-canon to canon mode and the read
buffer contains data, simulate an EOF push _without_ the
DISABLED_CHAR in the read buffer.
Importantly for the readline() problem, the termios can be
changed back to non-canonical mode without changes to the read
buffer occurring; ie., as if the previous termios change had not
happened (as long as no intervening read took place).
Preserve existing userspace behavior which allows '\0's already
received in non-canon mode to be read as '\0's in canon mode
(rather than trigger add'l EOF pushes or an actual EOF).
Patch based on original proposal and discussion here
https://bugzilla.kernel.org/show_bug.cgi?id=55991
by Stas Sergeev <stsp@users.sourceforge.net>
Reported-by: Margarita Manterola <margamanterola@gmail.com>
Cc: Maximiliano Curia <maxy@gnuservers.com.ar>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Acked-by: Stas Sergeev <stsp@users.sourceforge.net>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
This is a complex patch for refactoring CLPS711X serial driver.
Major changes:
- Eliminate <mach/hardware.h> usage.
- Devicetree support.
We want the fixes in here as well.
For NUMA systems, initializing the blk-mq layer and using per node hctx.
We initialize submit queues to 1, while blk-mq nr_hw_queues is
initialized to the number of NUMA nodes.
This makes the null_init_hctx function overwrite memory outside of what
it allocated. In my case it lead to writing garbage into struct
request_queue's mq_map.
Signed-off-by: Matias Bjorling <m@bjorling.me>
radeon_hwmon_show_temp_thresh()
Since commit ec39f64bba34 ("drm/radeon/dpm: Convert to use
devm_hwmon_register_with_groups") radeon_hwmon_init() is using
hwmon_device_register_with_groups(), which sets `rdev' as a device
private driver_data, while hwmon_attributes_visible() and
radeon_hwmon_show_temp_thresh() are still waiting for `drm_device'.
Fix them by using dev_get_drvdata(), in order to avoid this oops:
BUG: unable to handle kernel paging request at 0000000000001e28
IP: [<ffffffffa02ae8b4>] hwmon_attributes_visible+0x18/0x3d [radeon]
PGD 15057e067 PUD 151a8e067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
Call Trace:
internal_create_group+0x114/0x1d9
sysfs_create_group+0xe/0x10
sysfs_create_groups+0x22/0x5f
device_add+0x34f/0x501
device_register+0x15/0x18
hwmon_device_register_with_groups+0xb5/0xed
radeon_hwmon_init+0x56/0x7c [radeon]
radeon_pm_init+0x134/0x7e5 [radeon]
radeon_modeset_init+0x75f/0x8ed [radeon]
radeon_driver_load_kms+0xc6/0x187 [radeon]
drm_dev_register+0xf9/0x1b4 [drm]
drm_get_pci_dev+0x98/0x129 [drm]
radeon_pci_probe+0xa3/0xac [radeon]
pci_device_probe+0x6e/0xcf
driver_probe_device+0x98/0x1c4
__driver_attach+0x5c/0x7e
bus_for_each_dev+0x7b/0x85
driver_attach+0x19/0x1b
bus_add_driver+0x104/0x1ce
driver_register+0x89/0xc5
__pci_register_driver+0x58/0x5b
drm_pci_init+0x86/0xea [drm]
radeon_init+0x97/0x1000 [radeon]
do_one_initcall+0x7f/0x117
load_module+0x1583/0x1bb4
SyS_init_module+0xa0/0xaf
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Alexander Deucher <Alexander.Deucher@amd.com>
Pull networking fixes from David Miller:
1) Revert CHECKSUM_COMPLETE optimization in pskb_trim_rcsum(), I can't
figure out why it breaks things.
2) Fix comparison in netfilter ipset's hash_netnet4_data_equal(), it
was basically doing "x == x", from Dave Jones.
3) Freescale FEC driver was DMA mapping the wrong number of bytes, from
Sebastian Siewior.
4) Blackhole and prohibit routes in ipv6 were not doing the right thing
because their ->input and ->output methods were not being assigned
correctly. Now they behave properly like their ipv4 counterparts.
From Kamala R.
5) Several drivers advertise the NETIF_F_FRAGLIST capability, but
really do not support this feature and will send garbage packets if
fed fraglist SKBs. From Eric Dumazet.
6) Fix long standing user triggerable BUG_ON over loopback in RDS
protocol stack, from Venkat Venkatsubra.
7) Several not so common code paths can potentially try to invoke
packet scheduler actions that might be NULL without checking. Shore
things up by either 1) defining a method as mandatory and erroring
on registration if that method is NULL 2) defininig a method as
optional and the registration function hooks up a default
implementation when NULL is seen. From Jamal Hadi Salim.
8) Fix fragment detection in xen-natback driver, from Paul Durrant.
9) Kill dangling enter_memory_pressure method in cg_proto ops, from
Eric W Biederman.
10) SKBs that traverse namespaces should have their local_df cleared,
from Hannes Frederic Sowa.
11) IOCB file position is not being updated by macvtap_aio_read() and
tun_chr_aio_read(). From Zhi Yong Wu.
12) Don't free virtio_net netdev before releasing all of the NAPI
instances. From Andrey Vagin.
13) Procfs entry leak in xt_hashlimit, from Sergey Popovich.
14) IPv6 routes that are no cached routes should not count against the
garbage collection limits. We had this almost right, but were
missing handling addrconf generated routes properly. From Hannes
Frederic Sowa.
15) fib{4,6}_rule_suppress() have to consider potentially seeing NULL
route info when they are called, from Stefan Tomanek.
16) TUN and MACVTAP have had truncated packet signalling for some time,
fix from Jason Wang.
17) Fix use after frrr in __udp4_lib_rcv(), from Eric Dumazet.
18) xen-netback does not interpret the NAPI budget properly for TX work,
fix from Paul Durrant.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits)
igb: Fix for issue where values could be too high for udelay function.
i40e: fix null dereference
xen-netback: fix gso_prefix check
net: make neigh_priv_len in struct net_device 16bit instead of 8bit
drivers: net: cpsw: fix for cpsw crash when build as modules
xen-netback: napi: don't prematurely request a tx event
xen-netback: napi: fix abuse of budget
sch_tbf: use do_div() for 64-bit divide
udp: ipv4: must add synchronization in udp_sk_rx_dst_set()
net:fec: remove duplicate lines in comment about errata ERR006358
Revert "8390 : Replace ei_debug with msg_enable/NETIF_MSG_* feature"
xen-netback: make sure skb linear area covers checksum field
net: smc91x: Fix device tree based configuration so it's usable
udp: ipv4: fix potential use after free in udp_v4_early_demux()
macvtap: signal truncated packets
tun: unbreak truncated packet signalling
net: sched: htb: fix the calculation of quantum
net: sched: tbf: fix the calculation of max_size
micrel: add support for KSZ8041RNLI
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI device hotplug
- Move device_del() from pci_stop_dev() to pci_destroy_dev() (Rafael
Wysocki)
Host bridge drivers
- Update maintainers for DesignWare, i.MX6, Armada, R-Car (Bjorn
Helgaas)
- mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin
(Jason Gunthorpe)
Miscellaneous
- Avoid unnecessary CPU switch when calling .probe() (Alexander
Duyck)
- Revert "workqueue: allow work_on_cpu() to be called recursively"
(Bjorn Helgaas)
- Disable Bus Master only on kexec reboot (Khalid Aziz)
- Omit PCI ID macro strings to shorten quirk names for LTO (Michal
Marek)"
* tag 'pci-v3.13-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
MAINTAINERS: Add DesignWare, i.MX6, Armada, R-Car PCI host maintainers
PCI: Disable Bus Master only on kexec reboot
PCI: mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin
PCI: Omit PCI ID macro strings to shorten quirk names
PCI: Move device_del() from pci_stop_dev() to pci_destroy_dev()
PCI: Avoid unnecessary CPU switch when calling driver .probe() method
This patch changes the igb_phy_has_link function to check the value of the
parameter before deciding to use udelay or mdelay in order to be sure that
the value is not too high for udelay function.
CC: stable kernel <stable@vger.kernel.org> # 3.9+
Signed-off-by: Sunil K Pandey <sunil.k.pandey@intel.com>
Signed-off-by: Kevin B Smith <kevin.b.smith@intel.com>
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
If the vsi->tx_rings structure is NULL we don't want to panic.
Change-Id: Ic694f043701738c434e8ebe0caf0673f4410dc10
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Tested-by: Kavindya Deegala <kavindya.s.deegala@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp
Pull EDAC fix from Borislav Petkov:
"Silence a compiler warning in sb_edac"
* tag 'edac_fixes_for_3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
sb_edac: Shut up compiler warning when EDAC_DEBUG is enabled
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
"A set of device-mapper fixes for 3.13.
A fix for possible memory corruption during DM table load, fix a
possible leak of snapshot space in case of a crash, fix a possible
deadlock due to a shared workqueue in the delay target, fix to
initialize read-only module parameters that are used to export metrics
for dm stats and dm bufio.
Quite a few stable fixes were identified for both the thin-
provisioning and caching targets as a result of increased regression
testing using the device-mapper-test-suite (dmts). The most notable
of these are the reference counting fixes for the space map btree that
is used by the dm-array interface -- without these the dm-cache
metadata will leak, resulting in dm-cache devices running out of
metadata blocks. Also, some important fixes related to the
thin-provisioning target's transition to read-only mode on error"
* tag 'dm-3.13-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm array: fix a reference counting bug in shadow_ablock
dm space map: disallow decrementing a reference count below zero
dm stats: initialize read-only module parameter
dm bufio: initialize read-only module parameters
dm cache: actually resize cache
dm cache: update Documentation for invalidate_cblocks's range syntax
dm cache policy mq: fix promotions to occur as expected
dm thin: allow pool in read-only mode to transition to read-write mode
dm thin: re-establish read-only state when switching to fail mode
dm thin: always fallback the pool mode if commit fails
dm thin: switch to read-only mode if metadata space is exhausted
dm thin: switch to read only mode if a mapping insert fails
dm space map metadata: return on failure in sm_metadata_new_block
dm table: fail dm_table_create on dm_round_up overflow
dm snapshot: avoid snapshot space leak on crash
dm delay: fix a possible deadlock due to shared workqueue
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- Genius Gx Imperator Keyboard regression fix (missing break in case),
by Ben Hutchings
- duplicate sysfs entry error fix for hid-sensor-hub driver, by
Srinivas Pandruvada
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: hid-sensor-hub: fix duplicate sysfs entry error
HID: kye: Fix missing break in kye_report_fixup()
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A small set of driver fixes plus one larger core change which changes
the way we check to see if we're using DT so that there aren't any
races between deciding we're using DT and the regulator subsystem
noticing.
This makes the new support for substituting a dummy regulator and
optional regulators work a lot better on DT systems since it ensures
that we don't trigger probe deferral when we shouldn't which was
causing bugs in clients"
* tag 'regulator-v3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: pfuze100: allow misprogrammed ID
regulator: pfuze100: Fix address of FABID
regulator: as3722: set the correct current limit
regulator: core: Check for DT every time we check full constraints
regulator: core: Replace checks of have_full_constraints with a function
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fixes from Mark Brown:
"Two small changes to fix some error handling and checking (both of
which would be quite serious if the errors trigger) plus a trivial
documentation fix"
* tag 'regmap-v3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: use IS_ERR() to check clk_get() results
regmap: make sure we unlock on failure in regmap_bulk_write
regmap: trivial comment fix (copy'n'paste error)
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Here are two simple but wanted fixes for the i2c subsystem"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: imx: Check the return value from clk_prepare_enable()
i2c: mux: Inherit retry count and timeout from parent for muxed bus
Pull MTD fixes from Brian Norris:
"Two MTD fixes, for the pxa3xx-nand driver:
- This driver was not ready to fully Armada 370 NAND, with
particularly notable problems seen on flash with 2KB page sizes.
This "compatible" entry really should have been held back until
3.14 or later.
- Fix a bug seen in rare cases on the error path of a failed probe
attempt, where we free unallocated DMA resources"
* tag 'for-linus-20131212' of git://git.infradead.org/linux-mtd:
mtd: nand: pxa3xx: Use info->use_dma to release DMA resources
Partially revert "mtd: nand: pxa3xx: Introduce 'marvell,armada370-nand' compatible string"
Pull slave-dmaengine fixes from Vinod Koul:
"Here is the common fixes PULL for dmaengine.
Dan has been working on fixing the build issues in bunch of drivers.
Here we have one fixing s3c24xx-dma, along with fix from Russell on
pl08x. Also we have Kuninori rcar dma fixes. The s3c24xx-dma which
was added in last merge window missed updates to usage of DMA_COMPLETE
so converting the last driver"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dma: fix build breakage in s3c24xx-dma
Fix pl08x warnings
rcar-hpbdma: initialise plane information when halted
rcar-hpbdma: fixup channel busy check for double plane
rcar-hpbdma: add max transfer size
dma: mmp_pdma: add missing platform_set_drvdata() in mmp_pdma_probe()
dmaengine: s3c24xx-dma: use DMA_COMPLETE for dma completion status
An old array block could have its reference count decremented below
zero when it is being replaced in the btree by a new array block.
The fix is to increment the old ablock's reference count just before
inserting a new ablock into the btree.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@vger.kernel.org # 3.9+
The old behaviour, returning -EINVAL if a ref_count of 0 would be
decremented, was removed in commit f722063 ("dm space map: optimise
sm_ll_dec and sm_ll_inc"). To fix this regression we return an error
code from the mutator function pointer passed to sm_ll_mutate() and have
dec_ref_count() return -EINVAL if the old ref_count is 0.
Add a DMERR to reflect the potential seriousness of this error.
Also, add missing dm_tm_unlock() to sm_ll_mutate()'s error path.
With this fix the following dmts regression test now passes:
dmtest run --suite cache -n /metadata_use_kernel/
The next patch fixes the higher-level dm-array code that exposed this
regression.
Cc: stable@vger.kernel.org # 3.12+
Merge patches from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: memcg: do not allow task about to OOM kill to bypass the limit
mm: memcg: fix race condition between memcg teardown and swapin
thp: move preallocated PTE page table on move_huge_pmd()
mfd/rtc: s5m: fix register updating by adding regmap for RTC
rtc: s5m: enable IRQ wake during suspend
rtc: s5m: limit endless loop waiting for register update
rtc: s5m: fix unsuccesful IRQ request during probe
drivers/rtc/rtc-s5m.c: fix info->rtc assignment
include/linux/kernel.h: make might_fault() a nop for !MMU
drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
procfs: also fix proc_reg_get_unmapped_area() for !MMU case
mm: memcg: do not declare OOM from __GFP_NOFAIL allocations
include/linux/hugetlb.h: make isolate_huge_page() an inline
Rename old regmap field of "struct sec_pmic_dev" to "regmap_pmic" and
add new regmap for RTC.
On S5M8767A registers were not properly updated and read due to usage of
the same regmap as the PMIC. This could be observed in various hangs,
e.g. in infinite loop during waiting for UDR field change.
On this chip family the RTC has different I2C address than PMIC so
additional regmap is needed.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
Acked-by: Sangbeom Kim <sbkim73@samsung.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Add PM suspend/resume ops to rtc-s5m driver and enable IRQ wake during
suspend so the RTC would act like a wake up source. This allows waking
up from suspend to RAM on RTC alarm interrupt.
Cc: Mark Brown <broonie@linaro.org>
After setting alarm or time the driver is waiting for UDR register to be
cleared indicating that registers data have been transferred.
Limit the endless loop to only 5 retries.
Probe failed for rtc-s5m:
s5m-rtc s5m-rtc: Failed to request alarm IRQ: 12: -22
s5m-rtc: probe of s5m-rtc failed with error -22
Fix rtc-s5m interrupt request by using regmap_irq_get_virq() for mapping
the IRQ.
Cc: <stable@vger.kernel.org>
Fix this warning:
drivers/rtc/rtc-s5m.c: In function `s5m_rtc_probe':
drivers/rtc/rtc-s5m.c:545: warning: assignment from incompatible pointer type
struct s5m_rtc_info.rtc has type "struct regmap *", while
struct sec_pmic_dev.rtc has type "struct i2c_client *".
Probably the author wanted to assign "struct sec_pmic_dev.regmap", which
has the correct type.
Also, as "rtc" doesn't make much sense as a name for a regmap, rename it
to "regmap".
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: Sachin Kamat <sachin.kamat@linaro.org>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Update month and day of month to the alarm month/day instead of current
day/month when setting the RTC alarm mask.
Signed-off-by: Linus Pizunski <linus@narrativeteam.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Pull ARM SoC fixes from Olof Johansson:
"Another week, another batch of fixes.
Again, OMAP regressions due to move to DT is the bulk of the changes
here, but this should be the last of it for 3.13. There are also a
handful of OMAP hwmod changes (power management, reset handling) for
USB on OMAP3 that fixes some longish-standing bugs around USB resets.
There are a couple of other changes that also add up line count a bit:
One is a long-standing bug with the keyboard layout on one of the PXA
platforms. The other is a fix for highbank that moves their
power-off/reset button handling to be done in-kernel since relying on
userspace to handle it was fragile and awkward"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: sun6i: dt: Fix interrupt trigger types
ARM: sun7i: dt: Fix interrupt trigger types
MAINTAINERS: merge IMX6 entry into IMX
ARM: tegra: add missing break to fuse initialization code
ARM: pxa: prevent PXA270 occasional reboot freezes
ARM: pxa: tosa: fix keys mapping
ARM: OMAP2+: omap_device: add fail hook for runtime_pm when bad data is detected
ARM: OMAP2+: hwmod: Fix usage of invalid iclk / oclk when clock node is not present
ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module
ARM: OMAP2+: hwmod: Fix SOFTRESET logic
ARM: OMAP4+: hwmod data: Don't prevent RESET of USB Host module
ARM: dts: Fix booting for secure omaps
ARM: OMAP2+: Fix the machine entry for am3517
ARM: dts: Fix missing entries for am3517
ARM: OMAP2+: Fix overwriting hwmod data with data from device tree
ARM: davinci: Fix McASP mem resource names
ARM: highbank: handle soft poweroff and reset key events
ARM: davinci: fix number of resources passed to davinci_gpio_register()
gpio: davinci: fix check for unbanked gpio
In commit:
commit 62e8b851783138a11da63285be0fbf69530ff73d
Author: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Date: Fri Oct 4 15:30:38 2013 -0300
mtd: nand: pxa3xx: Allocate data buffer on detected flash size
the way the buffer is allocated was changed: the first READ_ID is issued
with a small kmalloc'ed buffer. Only once the flash page size is detected
the DMA buffers are allocated, and info->use_dma is set.
Currently, if the device detection fails, the driver checks the 'use_dma'
module parameter and tries to release unallocated DMA resources.
Fix this by checking the proper indicator of the DMA allocation, which
is 'info->use_dma'.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
compatible string"
This partially reverts c0f3b8643a6fa2461d70760ec49d21d2b031d611.
The "armada370-nand" compatible support is not complete, and it was mistake
to add it. Revert it and postpone the support until the infrastructure is
in place.
Cc: <stable@vger.kernel.org> # 3.12
Acked-by: Jason Cooper <jason@lakedaemon.net>
clk_prepare_enable() may fail, so let's check its return value and propagate it
in the case of error.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
If a muxed i2c bus gets created the default retry count and
timeout of the muxed bus is zero. Hence it it possible that you
end up with a situation where the parent controller sets a default
retry count and timeout which gets applied and used while the muxed
bus (using the same controller) has a default retry count of zero
and a default timeout of 1s (set in i2c_add_adapter()). This can be
solved by initializing the retry count and timeout of the muxed
bus with the values used by the the parent at creation time.
Signed-off-by: Elie De Brauwer <eliedebrauwer@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"A fix for recent sysfs breakage in serio subsystem plus a fixup to
adxl34x driver"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: adxl34x - Fix bug in definition of ADXL346_2D_ORIENT
Input: serio - fix sysfs layout
There is a mistake in checking the gso_prefix mask when passing large
packets to a guest. The wrong shift is applied to the bit - the raw skb
gso type is used rather then the translated one. This leads to large packets
being handed to the guest without the GSO metadata. This patch fixes the
check.
The mistake manifested as errors whilst running Microsoft HCK large packet
offload tests between a pair of Windows 8 VMs. I have verified this patch
fixes those errors.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A dvb core deadlock fix, a couple videobuf2 fixes an a series of media
driver fixes"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (30 commits)
[media] videobuf2-dma-sg: fix possible memory leak
[media] vb2: regression fix: always set length field.
[media] mt9p031: Include linux/of.h header
[media] rtl2830: add parent for I2C adapter
[media] media: marvell-ccic: use devm to release clk
[media] ths7303: Declare as static a private function
[media] em28xx-video: Swap release order to avoid lock nesting
[media] usbtv: Add support for PAL video source
[media] media_tree: Fix spelling errors
[media] videobuf2: Add support for file access mode flags for DMABUF exporting
[media] radio-shark2: Mark shark_resume_leds() inline to kill compiler warning
[media] radio-shark: Mark shark_resume_leds() inline to kill compiler warning
[media] af9035: unlock on error in af9035_i2c_master_xfer()
[media] af9033: fix broken I2C
[media] v4l: omap3isp: Don't check for missing get_fmt op on remote subdev
[media] af9035: fix broken I2C and USB I/O
[media] wm8775: fix broken audio routing
[media] marvell-ccic: drop resource free in driver remove
[media] tef6862/radio-tea5764: actually assign clamp result
[media] cx231xx: use after free on error path in probe
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fix from Guenter Roeck:
"Fix HIH-6130 driver to work with BeagleBone"
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: HIH-6130: Support I2C bus drivers without I2C_FUNC_SMBUS_QUICK
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon fixes from Jean Delvare.
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: Prevent some divide by zeros in FAN_TO_REG()
hwmon: (w83l768ng) Fix fan speed control range
hwmon: (w83l786ng) Fix fan speed control mode setting and reporting
hwmon: (lm90) Unregister hwmon device if interrupt setup fails
