At some point the Flexcop driver was changed to support newer Flexcop cards.
These modifications however broke the detection of Cablestar 2 DVB-C cards.
The reason is that the earlier version of the driver used to retry
unsuccessful i2c operations. The demodulator of Cablestar 2 cards (stv0297)
seems to be very dependent on these retries and adding them back fixes
Cablestar detection.
This patch restores this behaviour for the CableStar2.
Signed-off-by: Antti Seppälä <a.seppala@gmail.com>
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
A user noticed that there would continue to be 4-6 keypresses even after the
user stopped holding down the button. This was because we were not reading
the bulk pipe faster than the firmware was injecting information, which would
result in a backlog.
Make the query interval faster, and increase the number of cycles before we
start repeating to compensate.
Thanks to Knud Poulsen <knud.poulsen@nokia.com> for pointing this out.
Signed-off-by: Devin Heitmueller <devin.heitmueller@gmail.com>
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
i2c-highlander: Trivial endian casting fixes
i2c-pmcmsp: Fix endianness misannotation
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Commands needing to be retried require a complete re-initialization.
For the console, there is a 1:1 mapping of glyphs which cannot be found
in the current font. This seems to be meant as a kind of 'emergency
fallback' for fonts without unicode mapping which otherwise would
display nothing readable on the screen.
At the moment it affects all chars for which no substitution character
is defined. In particular this means that for all chars (>= 128) where
there is no iso88591-1/unicode character (e.g. control character area)
you'll get the very strange 1:1 mapping of the (cp437) graphics card
glyphs.
I'm pretty sure that the 1:1 mapping should only affect strict ASCII
code characters, i.e. chars < 128.
The patch limits the mapping as it probably was meant anyway.
Signed-off-by: Ingo Brueckl <ib@wupperonline.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Egmont Koblinger <egmont@uhulinux.hu>
There is a major bug in the cp437 to unicode translation table. Char
0x7c is mapped to U+00a5 which is the Yen sign and wrong. The right
mapping is U+00a6 (broken bar).
Furthermore, a mapping for U+00b4 (a widely used character) is missing
even though easily possible.
The patch fixes these, as well as it provides a few other useful
mappings.
The changes are as follows:
0x0f (enhancement) enables a sort of currency symbol
0x27 (bug) enables a sort of acute accent which is a widely used character
0x44 (enhancement) enables a sort of icelandic capital letter eth
0x7c (major bug) corrects mapping
0xeb (enhancement) enables a sort of icelandic small letter eth
0xee (enhancement) enables a sort of math 'element of'
The test-unit-ready portion of this patch was causing boots to fail on
my test machine (as in http://lkml.org/lkml/2008/12/5/161). With this
patch in place, the system is booting reliably.
Mike Anderson found the same problem in the hp_hw_start_stop code,
and I applied the same solution in cdrom_read_cdda_bpc.
Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com>
Cc: Mike Anderson <andmike@linux.vnet.ibm.com>
Fixes sparse warnings:
drivers/i2c/busses/i2c-highlander.c:95:26: warning: incorrect type in argument 1 (different base types)
drivers/i2c/busses/i2c-highlander.c:95:26: expected restricted __be16 const [usertype] *p
drivers/i2c/busses/i2c-highlander.c:95:26: got unsigned short [usertype] *<noident>
drivers/i2c/busses/i2c-highlander.c:106:15: warning: incorrect type in assignment (different base types)
drivers/i2c/busses/i2c-highlander.c:106:15: expected unsigned short [unsigned] [short] [usertype] <noident>
drivers/i2c/busses/i2c-highlander.c:106:15: got restricted __be16
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Paul Mundt <lethal@linux-sh.org>
tmp is used as host-endian and is loaded from a be64, fix the cast and the
endian accessor used.
This reverts commit b1ee26bab14886350ba12a5c10cbc0696ac679bf, along with
the "fixes" for it that all just caused problems:
- c4c6fa9891f3d1bcaae4f39fb751d5302965b566 "radeonfb: fix problem with
color expansion & alignment"
- f3179748a157c21d44d929fd3779421ebfbeaa93 "radeonfb: Disable new color
expand acceleration unless explicitely enabled"
because even when disabled, it breaks for people. See
http://bugzilla.kernel.org/show_bug.cgi?id=12191
for the latest example.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: James Cloos <cloos@jhcloos.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: Jean-Luc Coulon <jean.luc.coulon@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCIe: ASPM: Break out of endless loop waiting for PCI config bits to switch
PCI: stop leaking 'slot_name' in pci_create_slot
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] SN: prevent IRQ retargetting in request_irq()
[IA64] Fix section mismatch ioc3uart_init()/ioc3uart_submodule
[IA64] Clear up section mismatch for ioc4_ide_attach_one.
[IA64] Clear up section mismatch with arch_unregister_cpu()
[IA64] Clear up section mismatch for sn_check_wars.
[IA64] Updated the generic_defconfig to work with the 2.6.28-rc7 kernel.
[IA64] Fix GRU compile error w/o CONFIG_HUGETLB_PAGE
[IA64] eliminate NULL test and memset after alloc_bootmem
[IA64] remove BUILD_BUG_ON from paravirt_getreg()
The pktcdvd created class devices only export some sysfs files,
but have no char dev_t registered in the driver.
At class device creation time they copy the dev_t value of the
block device to the char device, wich will register a new char
device in the driver core and userspace, with a conflicting dev_t
value.
In many cases the class devices dev_t just points to a random
USB device. This fixes the sysfs "duplicate entry" errors.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Peter Osterlund <petero2@telia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: fw-ohci: fix IOMMU resource exhaustion
ieee1394: node manager causes up to ~3.25s delay in freezing tasks
sparc64:
drivers/video/mb862xx/mb862xxfb.c:929: warning: long long unsigned int format, resource_size_t arg (arg 4)
drivers/video/mb862xx/mb862xxfb.c:931: warning: long long unsigned int format, resource_size_t arg (arg 4)
We don't know what type the architecture uses to implement u64, hence they
cannot be printed.
Cc: Dmitry Baryshkov <dbaryshkov@gmail.com>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Matteo Fortini <m.fortini@selcomgroup.com>
Signed-off-by: Balaji Rao <balajirrao@gmail.com>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Fix build error when RTC_INTF_DEV=n:
drivers/rtc/rtc-twl4030.c:402: error: 'twl4030_rtc_ioctl' undeclared here (not in a function)
make[3]: *** [drivers/rtc/rtc-twl4030.o] Error 1
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Samuel Ortiz <sameo@openedhand.com>
Add a call to cancel_work_sync() in fbcon_exit() to cancel any pending
work in the fbcon workqueue.
The current implementation of fbcon_exit() sets the fbcon workqueue
function info->queue.func to NULL, but does not assure that there is no
work pending when it does so. On occasion, depending on system timing,
there will still be pending work in the queue when fbcon_exit() is
called. This results in a null pointer deference when run_workqueue()
tries to call the queue's work function.
Fixes errors on shutdown similar to these:
Console: switching to colour dummy device 80x25
Unable to handle kernel paging request for data at address 0x00000000
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Add missing id_table to the drivers in subject. Patch is against the
latest git. It should go in with 2.6.28 if possible, the drivers won't
work without the id_table bits.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Reported-by: Imre Kaloz <kaloz@openwrt.org>
Tested-by: Imre Kaloz <kaloz@openwrt.org>
Cc: David Brownell <david-b@pacbell.net>
There is a DMA map/ unmap imbalance whenever a block write request
packet is sent and then dequeued with ohci_cancel_packet. The latter
may happen frequently if the AR resp tasklet is executed before the AT
req tasklet for the same transaction.
Add the missing dma_unmap_single. This fixes
https://bugzilla.redhat.com/show_bug.cgi?id=475156
Reported-by: Emmanuel Kowalski
Tested-by: Emmanuel Kowalski
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Makes a Compaq 6735s boot reliably again. It used to hang in the loop
on some boots. Give the link one second to train, otherwise break out
of the loop and reset the previously set clock bits.
Cc: stable@vger.kernel.org
Signed-off-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
In pci_create_slot(), the local variable 'slot_name' is allocated by
make_slot_name(), but never freed. We never use it after passing it to
the kobject core, so we should free it upon function exit.
Cc: stable@kernel.org
Signed-off-by: Alex Chiang <achiang@hp.com>
The firewire nodemanager function "nodemgr_host_thread" contains a loop
that calls try_to_freeze near the top of the loop, but then delays for
up to 3.25 seconds (plus time to do work) before getting back to the top
of the loop. When starting a cycle post-boot, this doesn't seem to bite,
but it is causing a noticeable delay at boot time, when freezing
processes prior to starting to read the image.
The following patch adds invocation of try_to_freeze to the subloops
that are used in the body of this function. With these additions, the
time to freeze when starting to resume at boot time is virtually zero.
I'm no expert on firewire, and so don't know that we shouldn't check
the return value and jump back to the top of the loop or such like after
being frozen, but I submit it for your consideration.
Signed-off-by: Nigel Cunningham <nigel@tuxonice.net>
The delay until nodemgr freezes was up to 0.25s (plus time for node
probes) in Linux 2.6.27 and older and up to 3.25s (plus ~) since Linux
2.6.28-rc1, hence much more noticeable.
try_to_freeze() without any jump is correct. The surrounding code in
the respective loops will catch whether another bus reset happens during
the freeze and handle it.
s/ioc3uart_submodule/ioc3uart_ops/ makes the section mismatch
check happy.
Signed-off-by: Tony Luck <tony.luck@intel.com>
The generic_defconfig has three section mismatches. This clears up
ioc4_ide_attach_one().
Signed-off-by: Robin Holt <holt@sgi.com>
Signed-off-by: Mike Reid <mdr@sgi.com>
Eliminate compile error when compiling without CONFIG_HUGETLB_PAGE.
Signed-off-by: Jack Steiner <steiner@sgi.com>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] Fix alignment fault handling for ARMv6 and later CPUs
[ARM] 5340/1: fix stack placement after noexecstack changes
[ARM] 5339/1: fix __fls() on ARM
[ARM] Orion: fix bug in pcie configuration cycle function field mask
[ARM] omap: fix a pile of issues
* git://git.infradead.org/mtd-2.6:
[MTD] [NAND] fix OOPS accessing flash operations over STM flash on PXA
[MTD] [NAND] drivers/mtd/nand/pasemi_nand.c: Add missing pci_dev_put
[MTD] [NAND] fsl_upm: fix build problem with 2.6.28-rc2
[MTD] physmap: fix memory leak on physmap_flash_remove by using devres
[MTD] m25p80: chip erase != block erase != sector erase
[MTD] m25p80: fix detection of m25p16 flashes
[MTD] m25p80: fix detection of SPI parts
[MTD] [NAND] OMAP: OneNAND: header file relocation (part 2)
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
ata: Fix experimental tags
pata_ninja32: update ID table
pata_sis: Remove bogus cable match
ATA: piix, fix pointer deref on suspend
pata_hpt366: fix clock detection
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: Disable the GM965 MSI errata workaround.
drm/i915: Don't return error in evict_everything when we get to the end.
drm/radeon: don't actually enable the IRQ regs until irq is enabled
This new color expansion acceleration for radeonfb appears to trigger
problems with X on VT switch and suspend/resume on some machines. It
might be a problem in the VT layer or in X, but I haven't quite found
it yet, so in the meantime, this disables the acceleration by default,
reverting to 2.6.27 state. It can be enabled using the "accel_cexp"
module parameter or fbdev argument.
Various tags are now way out of date
Signed-off-by: Alan Cox <alan@redhat.com>
Some systems report SIS 5513 as both vendor/id and subvendor/id
string. In that case we can't distinguish the system by the id
svid/sdid and in fact the entry here breaks some boxes. At some
point we need to find another way to detect the Targa Visionary 1000,
until then this trades a hang for some users with lower performance
for others.
Closes: #12092
I've found this issue in the mmotm 2008-12-02-17-08.
Commit
ata_piix: add borked Tecra M4 to broken suspend list
introduced DMI variables checking, but they can be null, so that
we possibly dereference null.
Check if they are null and avoid checks in that case.
Solves:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
IP: [<ffffffff8043da97>] piix_pci_device_suspend+0x117/0x230
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Jeff Garzik <jgarzik@redhat.com>
Cc: Alexandru Romanescu <a_romanescu@yahoo.co.uk>
Cc: Tejun Heo <tj@kernel.org>
pata_hpt366 had its clock detection wrong and detected 25Mhz as 40Mhz
and vice-versa. Fix it.
Since applying the fix suggested by the errata (disabling MSI), we've had
issues with interrupts being stuck on despite IIR being 0 on GM965 hardware.
Most reporters of the issue have confirmed that turning MSI back on fixes
things, and given the difficulties experienced in getting reliable MSI working
on Linux, it's believable that the errata was about software issues and not
actual hardware issues.
Returning -ENOMEM errored all the way out of execbuf, so the rendering never
occurred.
vblank can try and enable the IRQ registers before we've set the interrupt
handler up.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
tproxy: fixe a possible read from an invalid location in the socket match
zd1211rw: use unaligned safe memcmp() in-place of compare_ether_addr()
mac80211: use unaligned safe memcmp() in-place of compare_ether_addr()
ipw2200: fix netif_*_queue() removal regression
iwlwifi: clean key table in iwl_clear_stations_table function
tcp: tcp_vegas ssthresh bug fix
can: omit received RTR frames for single ID filter lists
ATM: CVE-2008-5079: duplicate listen() on socket corrupts the vcc table
netx-eth: initialize per device spinlock
tcp: make urg+gso work for real this time
enc28j60: Fix sporadic packet loss (corrected again)
hysdn: fix writing outside the field on 64 bits
b1isa: fix b1isa_exit() to really remove registered capi controllers
can: Fix CAN_(EFF|RTR)_FLAG handling in can_filter
Phonet: do not dump addresses from other namespaces
netlabel: Fix a potential NULL pointer dereference
bnx2: Add workaround to handle missed MSI.
xfrm: Fix kernel panic when flush and dump SPD entries
IDE pmac host driver build fails with CONFIG_BLK_DEV_IDEDMA_PMAC=n
as reported by Kamalesh:
> drivers/ide/pmac.c: In function 'pmac_ide_set_pio_mode':
> drivers/ide/pmac.c:527: error: implicit declaration of function 'kauai_lookup_timing'
> drivers/ide/pmac.c:527: error: 'shasta_pio_timings' undeclared (first use in this function)
> drivers/ide/pmac.c:527: error: (Each undeclared identifier is reported only once
> drivers/ide/pmac.c:527: error: for each function it appears in.)
> drivers/ide/pmac.c:534: error: 'kauai_pio_timings' undeclared (first use in this function)
> drivers/ide/pmac.c: In function 'pmac_ide_do_resume':
> drivers/ide/pmac.c:914: error: 'IDE_WAKEUP_DELAY' undeclared (first use in this function)
> drivers/ide/pmac.c: At top level:
> drivers/ide/pmac.c:1007: error: 'pmac_ide_init_dma' undeclared here (not in a function)
> drivers/ide/pmac.c: In function 'pmac_ide_setup_device':
> drivers/ide/pmac.c:1107: error: 'IDE_WAKEUP_DELAY' undeclared (first use in this function)
> drivers/ide/pmac.c: In function 'pmac_ide_macio_attach':
> drivers/ide/pmac.c:1209: error: 'pmac_ide_hwif_t' has no member named 'dma_regs'
> drivers/ide/pmac.c:1210: error: 'pmac_ide_hwif_t' has no member named 'dma_regs'
> make[2]: *** [drivers/ide/pmac.o] Error 1
Fix it by removing the superfluous config option.
Reported-and-tested-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
This reverts commit e9eb8388306364295308132265c00bea685f409f since
it could break resume (thanks to Paul Collins for the report).
I'll look into sorting this out properly for 2.6.29
but for 2.6.28 it is the best to just revert my patch.
Reported-by: Paul Collins <paul@burly.ondioline.org>
Cc: rjw@sisk.pl
no argument named @msg in i2o_msg_get_wait(), remove it.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Fix incorrect use of loose in i2o_block.c
It should be 'lose', not 'loose'.
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
[Folded together as one diff from 3]
This reverts commit 558073dd56707864f09d563b64e7c37c021e89d2, along with
the failed try to fix the regression it caused ("ACPI: Fix ACPI battery
regression introduced by commit 558073"), which just made things worse.
Commit aaad077638be1a25871bcae5e43952d6b63abfca (that failed "Fix ACPI
battery regression") got the voltage conversion confused, and fixed the
problem with Rafael's battery monitor apparently just by mistake.
So revert them both, getting us back to the 2.6.27 state in this, and
let's revisit it when people understand what's going on.
Noted-by: Paul Martin <pm@debian.org>
Requested-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Len Brown <len.brown@intel.com>
Cc: Alexey Starikovskiy <astarikovskiy@suse.de>
Under my 2.6.28-rc6 sparc64, when associating to an AP through my
zd1211rw device, I was seeing kernel log messages like (not exact output):
Kernel unaligned access at TPC[10129b68] zd_mac_rx+0x144/0x32c [zd1211rw]
For the zd1211rw module, on RX, the 80211 packet will be located after
the PLCP header in the skb data buffer. The PLCP header being 5 bytes
long, the 80211 header will start unaligned from an aligned skb
buffer.
As per Documentation/unaligned-memory-access.txt, we must replace the
not unaligned() safe compare_ether_addr() with memcmp() to protect
architectures that require alignment.
Signed-off-by: Shaddy Baddah <shaddy_baddah@hotmail.com>
In "ipw2200: Call netif_*_queue() interfaces properly", netif_stop_queue()
and netif_wake_queue() were removed with the reason
"netif_carrier_{on,off}() handles starting and stopping packet flow into
the driver". The patch also removes a valid condition check that
ipw_tx_skb() cannot be called if device is not in STATUS_ASSOCIATED state.
But netif_carrier_off() doesn't guarantee netdev->hard_start_xmit won't
be called because linkwatch event is handled in a delayed workqueue. This
caused a kernel oops reported by Frank Seidel:
https://bugzilla.novell.com/show_bug.cgi?id=397390
This patch fixes the problem by moving the STATUS_ASSOCIATED check back
to ipw_tx_skb(). It also adds a missing netif_carrier_off() call to
ipw_disassociate().
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Signed-off-by: Chatre, Reinette <reinette.chatre@intel.com>
Tested-by: Frank Seidel <fseidel@suse.de>
This patch cleans uCode key table bit map iwl_clear_stations_table
since all stations are cleared also the key table must be.
Since the keys are not removed properly on suspend by mac80211
this may result in exhausting key table on resume leading
to memory corruption during removal
This patch also fixes a memory corruption problem reported in
http://marc.info/?l=linux-wireless&m=122641417231586&w=2 and tracked in
http://bugzilla.kernel.org/show_bug.cgi?id=12040.
When the key is removed a second time the offset is set to 255 - this
index is not valid for the ucode_key_table and corrupts the eeprom pointer
(which is 255 bits from ucode_key_table).
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Reported-by: Carlos R. Mafra <crmafra2@gmail.com>
Reported-by: Lukas Hejtmanek <xhejtman@ics.muni.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev:
[PATCH] fix bogus argument of blkdev_put() in pktcdvd
[PATCH 2/2] documnt FMODE_ constants
[PATCH 1/2] kill FMODE_NDELAY_NOW
[PATCH] clean up blkdev_get a little bit
[PATCH] Fix block dev compat ioctl handling
[PATCH] kill obsolete temporary comment in swsusp_close()
