path: root/drivers
2009-03-13[SCSI] iscsi lib: remove qdepth param from iscsi host allocationMike Christie
The qdepth setting was useful when we needed libiscsi to verify the setting. Now we just need to make sure if older tools passed in zero then we need to set some default. So this patch just has us use the sht->cmd_per_lun or if for LLD does a host per session then we can set it on per host basis. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: have lib create work queue for transmitting IOMike Christie
We were using the shost work queue which ended up being a little akward since all iscsi hosts need a thread for scanning, but only drivers hooked into libiscsi need a workqueue for transmitting. So this patch moves the xmit workqueue to the lib. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi class: fix lock dep warning on logoutMike Christie
We never should hit the lock up that is spit out when lock dep is on and we logout. But we have been using the shost work queue in a odd way. This patch has us use the work queue for scanning instead of creating our own, and this ends up also killing the lock dep warnings. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: don't cap queue depth in iscsi modulesMike Christie
There is no need to cap the queue depth in the modules. We set this in userspace and can do that there. For performance testing with ram based targets, this is helpful since we can have very high queue depths. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi_tcp: replace scsi_debug/tcp_debug logging with iscsi conn loggingMike Christie
This makes the logging a compile time option and replaces the tcp_debug macro with a iscsi connection one that prints out a driver model id prefix. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi_tcp: replace tcp_debug/scsi_debug logging with session/conn ↵Mike Christie
logging This makes the logging a compile time option and replaces the scsi_debug and tcp_debug macro with session and connection ones that print out a driver model id prefix. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: replace scsi_debug logging with session/conn loggingMike Christie
This makes the logging a compile time option and replaces the scsi_debug macro with session and connection ones that print out a driver model id prefix. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iser: have iser use its own loggingMike Christie
iser has its own logging inrfastrucutre. Convert it to use it instead of libiscsi. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi tcp: bidi capablePete Wyckoff
Mark iscsi_tcp as being capable of bidirectional transfers. The bsg interface checks this bit before attempting any bidirectional commands. Signed-off-by: Pete Wyckoff <pw@padd.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: fix iscsi pool error pathJean Delvare
Memory freeing in iscsi_pool_free() looks wrong to me. Either q->pool can be NULL and this should be tested before dereferencing it, or it can't be NULL and it shouldn't be tested at all. As far as I can see, the only case where q->pool is NULL is on early error in iscsi_pool_init(). One possible way to fix the bug is thus to not call iscsi_pool_free() in this case (nothing needs to be freed anyway) and then we can get rid of the q->pool check. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] fcoe: fcoe fc crc offload indication by skb->ip_summedYi Zou
If LLD supports FCCRC offload, it should set ip_summed to be CHECKSUM_UNNECESSARY so we don't have to do CRC check again. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] fcoe: add support to FCoE offload support in fcoe_sw through net_deviceYi Zou
This adds implementation of ddp_setup()/ddp_done() in fcoe_sw for its fcoe_sw_libfc_fcn_templ. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libfc: add support of large receive offload by ddp in fc_fcpYi Zou
When LLD supports direct data placement (ddp) for large receive of an scsi i/o coming into fc_fcp, we call into libfc_function_template's ddp_setup() to prepare for a ddp of large receive for this read I/O. When I/O is complete, we call the corresponding ddp_done() to get the length of data ddped as well as to let LLD do clean up. fc_fcp_ddp_setup()/fc_fcp_ddp_done() are added to setup and complete a ddped read I/O described by the given fc_fcp_pkt. They would call into corresponding ddp_setup/ddp_done implemented by the fcoe layer. Eventually, fcoe layer calls into LLD's ddp_setup/ddp_done provided through net_device Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] fcoe: add support to large send by gso through net_device for fcoe_swYi Zou
Change fcoe_xmit to setup gso for LLD LSO offload as well as CRC offload Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libfc: use lso_max for sequence offloadYi Zou
Make sure for large send is supported by LLD in outgoing FCP data, we are only sending the lso_max a time in one single large send, since that is what supported by LLD. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] fcoe, libfc: check offload features from LLD through netdevYi Zou
This checks if net_devices supports FCoE offload ops in netdev_ops and it if it does, then sets up the corresponding flags in the associated fc_lport. For large send offload, the maximum length supported in one large send is now described by the added lso_max in fc_lport, which is setup initially from netdev->gso_max_size. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] net: reclaim 8 upper bits of the netdev->features from GSOChris Leech
Reclaim 8 upper bits of netdev->features from GSO. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Yi Zou <yi.zou@intel.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] net, fcoe: add ETH_P_FCOE for Fibre Channel over Ethernet (FCoE)Yi Zou
This adds eth type ETH_P_FCOE for Fibre Channel over Ethernet (FCoE), consequently, the ETH_P_FCOE from fc_fcoe.h and fcoe skb->protocol is not set as ETH_P_FCOE. Signed-off-by: Yi Zou <yi.zou@intel.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] scsi_dh_rdac: Retry mode select for NO_SENSE, ABORTED_COMMAND, ↵Chauhan, Vijay
UNIT_ATTENTION, NOT_READY(02/04/01) This patch is to add retry for mode select if mode select command is returned with sense NO_SENSE, UNIT_ATTENTION, ABORTED_COMMAND, NOT_READY(02/04/01). This patch reorganise the sense keys from if-else to switch-case format for better maintainability. Signed-off-by: Vijay Chauhan <vijay.chauhan@lsi.com> Acked-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Report fc_host_port_type as NPIVChristof Schmitt
Report the fc_host_port_type as FC_PORTTYPE_NPIV when the subchannel is running in NPIV mode. This allows to see the correct type with lsscsi -H -t --list Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Ensure all work is cancelled on adapter dequeueSwen Schillig
A scheduled work might still be pending, running while the adapter is in progress to get dequeued from the system. This can lead to an invalid pointer dereference (Oops). Once the adpater is set online again, ensure the nameserver environment is initialized to the appropriate values again. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: fix queue, scheduled work processing.Swen Schillig
Ensure the refcounting is correct even if we were not able to schedule a work. In addition we have to make sure no scheduled work is pending while we're dequeing the adapter from the systems environment. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: erp failed status bit will not be setMartin Petermann
It will not be necessary to set the erp failed status bit in case a SCSI device is removed by the SCSI mid layer. In the case a SCSI device is unavailable for a short time (15 to 20 seconds) a FCP unit will not get on-line again. Signed-off-by: Martin Petermann <martin@linux.vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Block FC transport rports early on errorsChristof Schmitt
Use the I/O blocking mechanism in the FC transport class to allow faster failovers for multipathing: - Call fc_remote_port_delete early to set the rport to BLOCKED. - Check the rport status in queuecommand with fc_remote_portchkready to no longer accept new I/O for this port and fail the I/O with the appropriate scsi_cmnd result. - Implement the terminate_rport_io handler to abort all pending I/O requests - Return SCSI commands with DID_TRANSPORT_DISRUPTED while erp is running. - When updating the remote port status, check for late changes and update the remote ports status accordingly. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: incorrect reaction on incoming RSCNSwen Schillig
After an error condition resolved a remote storage port was never re-opened. The incoming RSCN was not processed accordingly due to a misinterpreted status flag / return value combination. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Remove PCI flagChristof Schmitt
The usage of the PCI flag to trigger interrupts is optional. Even without setting the flag, qdio still receives interrupts to continue working on the queue. Remove the PCI flag from zfcp, it is not necessary. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: replace current ERP logging with a more convenient versionSwen Schillig
The current number based id ERP logging is replaced by a string based tag version. The benefit is an easier location of the code in question and the removal of the lengthy array referencing the individual messages. The string (7 bytes) based version does not use more space since those bytes were "used" anyway due to the alignment of the structure. The encoding of the 7 byte string is as follows [0-1] = filename [2-5] = task/function [6] = section Due to the character of this string (fixed length) a string termination is not required here. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: prevent adapter close on initial adapter openSwen Schillig
An adapter close was always performed whether it was required, (e.g. in an error scenario) or not (e.g. initial open). This patch is changing the process in only doing an adapter close when it is required. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: remove undefined subtype for status read responseSwen Schillig
The status read response FSF_STATUS_READ_SUB_ERROR_PORT is not defined in the specs and therefore not valid. All occurrences are removed from the code. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Send ELS ADISC from workqueueChristof Schmitt
Issue ELS ADISC requests from workqueue. This allows the link test request to be sent when the request queue is full due to I/O load for other remote ports. It also simplifies request queue locking, zfcp_fsf_send_fcp_command_task is now the only function that has interrupts disabled from the caller. This is also a prereq for the FC passthrough support that issues ELS requests from userspace. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Improve reliability of SCSI eh handlers in zfcpChristof Schmitt
When the SCSI midlayer is running error recovery, the low-level error recovery in zfcp could be running and preventing the SCSI midlayer to issue error recovery requests. To avoid unnecessary error recovery escalation, wait for the zfcp erp to finish and retry if necessary. While reworking the SCSI eh handlers, alsa cleanup the code and simplify the interface from zfcp_scsi to the fsf layer. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Wait for free SBALs when possibleChristof Schmitt
For calls from zfcp erp, scsi_eh and sysfs switch the calls issuing FSF requests to zfcp_fsf_req_sbal_get to wait for free SBALs. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Only increment req_id for successfully issued requestsChristof Schmitt
Only increment the req_id for successfully issued requests. This avoids some confusion when debugging issued fsf requests. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Simplify latency lock handlingChristof Schmitt
The lock only needs to protect the softirq context called from qdio against the userspace context called from sysfs. spin_lock and spin_lock_bh is enough. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: add measurement data for average qdio queue utilisationMartin Peschke
Provide measurement data for the utilisation of the QDIO outbound queue. The additional value allows to calculate an average queue utilisation by looking at the deltas per time unit. Needed for capacity planning. It is up to user space to handle wrap-arounds of the 64 bit value. The new counter neatly complements the existing counter for queue full conditions. That is why, both statistics counter have been integrated. Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Remove UNIT_REGISTERED status flagChristof Schmitt
Use the device pointer in zfcp_unit for tracking if we have a registered SCSI device. With this approach, the flag ZFCP_STATUS_UNIT_REGISTERED is only redundant and can be removed. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] zfcp: Remove some port flagsChristof Schmitt
PORT_PHYS_CLOSING is only set and cleared, but not actually used for status checking. PORT_INVALID_WWPN is set when the GID_PN request does not return a d_id for a remote port, e.g. when a remote port has been unplugged. For this case, the d_id is zero. In the erp we can check the d_id and use the normal escalation procedure that gives up after three retries and remove the special case. PORT_NO_WWPN is unused: Each port in the remote port list has a valid wwpn. The WKA ports are now tracked outside the port list. Remove the PORT_NO_WWPN flag, since this is no longer set for any port. Acked-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] fix /proc memory leak in the SCSI coreAlan Stern
The SCSI core calls scsi_proc_hostdir_add() from within scsi_host_alloc(), but the corresponding scsi_proc_hostdir_rm() routine is called from within scsi_remove_host(). As a result, if a host is allocated and then deallocated without ever being registered, the host's directory in /proc is leaked. This patch (as1181b) fixes this bug in the SCSI core by moving scsi_proc_hostdir_rm() into scsi_host_dev_release(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: don't flood syslog with negotiation messagesTony Battersby
sym53c8xx prints a negotiation message after every check condition. This can add up to a lot of messages for removable-medium devices (CD-ROM, tape drives, etc.) that are being polled, since they return check condition when no medium is present. This patch suppresses the negotiation message if it would be the same as the last one printed. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: use a queue depth of 1 for untagged devicesTony Battersby
sym53c8xx uses a command queue depth of 2 for untagged devices, without good reason. This _mostly_ seems to work ok, but it has caused me some subtle problems. For example, I have an application where one thread sends write commands to a tape drive, and another thread sends log sense polling commands. With a queue depth of 2, the polling commands end up being starved for long periods of time while multiple write commands are serviced (this may also be related to the fact the the sg driver queues commands in LIFO order). This problem is fixed by changing the queue depth to 1 for untagged devices. I have tested this change extensively with many different tape drives, medium changers, and disk drives (disk drives of course use tagged commands and are therefore unaffected by this patch). Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: handle pci_iomap() failuresTony Battersby
sym_init_device() doesn't check if pci_iomap() fails. It also tries to map device RAM without first checking FE_RAM. 1) Move some initialization from sym_init_device() to the top of sym2_probe(). 2) Rename sym_init_device() to sym_iomap_device(). 3) Call sym_iomap_device() after sym_check_supported() instead of before so that device->chip.features will be set. 4) Check FE_RAM in sym_iomap_device() before mapping RAM. 5) If sym_iomap_device() cannot map registers, then abort. 6) If sym_iomap_device() cannot map RAM, then fall back to not using RAM and continue. 7) Remove the check for FE_RAM in sym_attach() since dev->ram_base is now always set correctly. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: unmap pci memory after probe errorsTony Battersby
During sym2_probe(), sym_init_device() does pci_iomap(), but there is no corresponding pci_iounmap() if an error occurs before sym_attach() copies sym_device::s.{ioaddr,ramaddr} to np. 1) Add the sym_iounmap_device() function. 2) Call sym_iounmap_device() if an error occurs between sym_init_device() and the time sym_attach() allocates np. 3) Make sym_attach() copy sym_device::s.{ioaddr,ramaddr} to np before calling any function that can fail so that sym_free_resources() will do the unmap instead of sym_iounmap_device(). Also fixed by this patch: During sym2_probe(), if sym_check_raid() returns nonzero, then pci_release_regions() is never called. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: fix bogus free_irq() on error pathTony Battersby
If sym_attach() gets an error at or before request_irq(), then sym_free_resources() will call free_irq() for an unregistered interrupt handler. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: fix NULL deref on error pathTony Battersby
If sym_attach() fails to allocate np, the error path will dereference a NULL pointer for printk. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sym53c8xx: fix shost use-after-free and memory leakTony Battersby
This patch fixes two bugs: 1) rmmod sym53c8xx uses shost after freeing it with scsi_put_host(shost). 2) insmod sym53c8xx doesn't call scsi_put_host(shost) if scsi_add_host() fails, causing a memory leak on the error path. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] ipr: Expose debug and fastfail parametersWayne Boyer
Expose the debug and fastfail parameters to /sys/module/ipr/parameters such that they can be enabled/disabled at run time. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sd: tell the user when a disk's capacity is adjustedAlan Stern
This patch (as1188) combines the tests for decrementing a drive's reported capacity and expands the comment. It also adds an informational message to the system log, informing the user when the reported value has been changed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] ses: code_set == 1 is tested twiceRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sg: remove the own list management for struct sg_fdFUJITA Tomonori
This replaces the own list management for struct sg_fd with the standard list_head structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] sg: use ALIGN macroFUJITA Tomonori
This changes sg_build_indirect() to use ALIGN macro instead of calculating by hand. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
