path: root/drivers
2011-10-11md: add proper write-congestion reporting to RAID1 and RAID10.NeilBrown
RAID1 and RAID10 handle write requests by queuing them for handling by a separate thread. This is because when a write-intent-bitmap is active we might need to update the bitmap first, so it is good to queue a lot of writes, then do one big bitmap update for them all. However writeback request devices to appear to be congested after a while so it can make some guesstimate of throughput. The infinite queue defeats that (note that RAID5 has already has a finite queue so it doesn't suffer from this problem). So impose a limit on the number of pending write requests. By default it is 1024 which seems to be generally suitable. Make it configurable via module option just in case someone finds a regression. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-11md: rename "mdk_personality" to "md_personality"NeilBrown
"mdk" doesn't mean anything any more. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-11md/bitmap remove fault injection options.NeilBrown
These are too hard to use to be much more than noise. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-11md/raid5: typedef removal: raid5_conf_t -> struct r5confNeilBrown
2011-10-11md/raid1: typedef removal: conf_t -> struct r1confNeilBrown
2011-10-11md/raid10: typedef removal: conf_t -> struct r10confNeilBrown
2011-10-11md/raid0: typedef removal: raid0_conf_t -> struct r0confNeilBrown
2011-10-11md/multipath: typedef removal: multipath_conf_t -> struct mpconfNeilBrown
2011-10-11md/linear: typedef removal: linear_conf_t -> struct linear_confNeilBrown
2011-10-11md/faulty: remove typedef: conf_t -> struct faulty_confNeilBrown
2011-10-11md/linear: remove typedefs: dev_info_t -> struct dev_infoNeilBrown
2011-10-11md: remove typedefs: mirror_info_t -> struct mirror_infoNeilBrown
2011-10-11md: remove typedefs: r10bio_t -> struct r10bio and r1bio_t -> struct r1bioNeilBrown
2011-10-11md: remove typedefs: mdk_thread_t -> struct md_threadNeilBrown
2011-10-11md: remove typedefs: mddev_t -> struct mddevNeilBrown
Having mddev_t and 'struct mddev_s' is ugly and not preferred Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-11md: removing typedefs: mdk_rdev_t -> struct md_rdevNeilBrown
The typedefs are just annoying. 'mdk' probably refers to 'md_k.h' which used to be an include file that defined this thing. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md/raid0: convert some printks to pr_debug.NeilBrown
When md assembles a RAID0 array it prints out lots of info which is really just for debugging, so convert that to pr_debug. It also prints out the resulting configuration which could be interesting, so keep that as 'printk' but tidy it up a bit. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md: remove PRINTK and dprintk debugging and use pr_debugNeilBrown
Being able to dynamically enable these make them much more useful. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md: remove some old DEBUGging code.NeilBrown
This code is not really helpful and is hard to maintain, so just discard it. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md/raid5: convert to macros into inline functions.NeilBrown
More type-safety. Easier to read. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md/raid1/ avoid bio search in end_sync_read()NeilBrown
We know which device we just read from so we don't need to search the bios to find out. Just use ->read_disk. Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md/raid1: factor out common bio handling codeNamhyung Kim
When normal-write and sync-read/write bio completes, we should find out the disk number the bio belongs to. Factor those common code out to a separate function. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md/raid5: remove pointless NULL test.NeilBrown
In the 'abort' branch of run(), 'conf' cannot possibly be NULL, so remove the test. Reported-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-07md/raid1: add documentation to r1_private_data_s data structure.NeilBrown
There wasn't much and it is inconsistent. Also rearrange fields to keep related fields together. Reported-by: Aapo Laine <aapo.laine@shiftmail.org> Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-23md: don't delay reboot by 1 second if no MD devices existDaniel P. Berrange
The md_notify_reboot() method includes a call to mdelay(1000), to deal with "exotic SCSI devices" which are too volatile on reboot. The delay is unconditional. Even if the machine does not have any block devices, let alone MD devices, the kernel shutdown sequence is slowed down. 1 second does not matter much with physical hardware, but with certain virtualization use cases any wasted time in the bootup & shutdown sequence counts for alot. * drivers/md/md.c: md_notify_reboot() - only impose a delay if there was at least one MD device to be stopped during reboot Signed-off-by: Daniel P. Berrange <berrange@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-21trival: md_k.h should be md.h in the beginning comment of file md.hWang Sheng-Hui
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-21md/bitmap: improve handling of 'allclean'.NeilBrown
The 'allclean' flag is used to cache the fact that there is nothing to do, so we can avoid waking up and scanning the bitmap regularly. The two sorts of pages that might need the attention of the bitmap daemon are BITMAP_PAGE_PENDING and BITMAP_PAGE_NEEDWRITE pages. So make sure allclean reflects exactly when there are none of those. So: set it before scanning all pages with either bit set. clear it whenever these bits are set clear it when we desire not to clear one of these bits. don't clear it any other time. Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-21md/bitmap: rename and tidy up BITMAP_PAGE_CLEANNeilBrown
The flag 'BITMAP_PAGE_CLEAN' has a confusing name as it doesn't mean that the page is clean, but rather that there are counters in the page which allow bits in the bitmap to be cleared - i.e. maybe cleaning can happen. So change it to BITMAP_PAGE_PENDING and fix some irregularities: - Don't set it in bitmap_init_from_disk as bitmap_set_memory_bits sets it when needed - in bitmap_daemon_work, if we find a counter that is '1', but need_sync is set, then set BITMAP_PAGE_PENDING again (it was recently cleared) to ensure we don't forget about this bit. Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-21md: Avoid waking up a thread after it has been freed.NeilBrown
Two related problems: 1/ some error paths call "md_unregister_thread(mddev->thread)" without subsequently clearing ->thread. A subsequent call to mddev_unlock will try to wake the thread, and crash. 2/ Most calls to md_wakeup_thread are protected against the thread disappeared either by: - holding the ->mutex - having an active request, so something else must be keeping the array active. However mddev_unlock calls md_wakeup_thread after dropping the mutex and without any certainty of an active request, so the ->thread could theoretically disappear. So we need a spinlock to provide some protections. So change md_unregister_thread to take a pointer to the thread pointer, and ensure that it always does the required locking, and clears the pointer properly. Reported-by: "Moshe Melnikov" <moshe@zadarastorage.com> Signed-off-by: NeilBrown <neilb@suse.de> cc: stable@kernel.org
2011-09-10md: Fix handling for devices from 2TB to 4TB in 0.90 metadata.NeilBrown
0.90 metadata uses an unsigned 32bit number to count the number of kilobytes used from each device. This should allow up to 4TB per device. However we multiply this by 2 (to get sectors) before casting to a larger type, so sizes above 2TB get truncated. Also we allow rdev->sectors to be larger than 4TB, so it is possible for the array to be resized larger than the metadata can handle. So make sure rdev->sectors never exceeds 4TB when 0.90 metadata is in used. Also the sanity check at the end of super_90_load should include level 1 as it used ->size too. (RAID0 and Linear don't use ->size at all). Reported-by: Pim Zandbergen <P.Zandbergen@macroscoop.nl> Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-10md/raid1,10: Remove use-after-free bug in make_request.NeilBrown
A single request to RAID1 or RAID10 might result in multiple requests if there are known bad blocks that need to be avoided. To detect if we need to submit another write request we test: if (sectors_handled < (bio->bi_size >> 9)) { However this is after we call **_write_done() so the 'bio' no longer belongs to us - the writes could have completed and the bio freed. So move the **_write_done call until after the test against bio->bi_size. This addresses https://bugzilla.kernel.org/show_bug.cgi?id=41862 Reported-by: Bruno Wolff III <bruno@wolff.to> Tested-by: Bruno Wolff III <bruno@wolff.to> Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-10md/raid10: unify handling of write completion.NeilBrown
A write can complete at two different places: 1/ when the last member-device write completes, through raid10_end_write_request 2/ in make_request() when we remove the initial bias from ->remaining. These two should do exactly the same thing and the comment says they do, but they don't. So factor the correct code out into a function and call it in both places. This makes the code much more similar to RAID1. The difference is only significant if there is an error, and they usually take a while, so it is unlikely that there will be an error already when make_request is completing, so this is unlikely to cause real problems. Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-31md/raid5: fix a hang on device failure.NeilBrown
Waiting for a 'blocked' rdev to become unblocked in the raid5d thread cannot work with internal metadata as it is the raid5d thread which will clear the blocked flag. This wasn't a problem in 3.0 and earlier as we only set the blocked flag when external metadata was used then. However we now set it always, so we need to be more careful. Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-30md: fix clearing of 'blocked' flag in the presence of bad blocks.NeilBrown
When the 'blocked' flag on a device is cleared while there are unacknowledged bad blocks we must fail the device. This is needed for backwards compatability of the interface. The code currently uses the wrong test for "unacknowledged bad blocks exist". Change it to the right test. Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-25md/linear: avoid corrupting structure while waiting for rcu_free to complete.NeilBrown
I don't know what I was thinking putting 'rcu' after a dynamically sized array! The array could still be in use when we call rcu_free() (That is the point) so we mustn't corrupt it. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-25md: use REQ_NOIDLE flag in md_super_write()Namhyung Kim
Queue idling is used for the anticipation of immediate sequencial I/O's but md_super_write() is a kind of one- shot operation, coupled with md_super_wait(), so the idling in this case will be just a waste of time. Specifying REQ_NOIDLE prevents it. Instead of adding the flag to submit_bio() directly, use pre-defined macro WRITE_FLUSH_FUA. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-25md: ensure changes to 'write-mostly' are reflected in metadata.NeilBrown
The 'write-mostly' flag can be changed through sysfs. With 0.90 metadata, those changes are reflected in the metadata. For 1.x metadata, they aren't. So fix super_1_sync to record 'write-mostly' status. Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-25md: report failure if a 'set faulty' request doesn't.NeilBrown
Sometimes a device will refuse to be set faulty. e.g. RAID1 will never let the last working device become faulty. So check if "md_error()" did manage to set the faulty flag and fail with EBUSY if it didn't. Resolves-Debian-Bug: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=601198 Reported-by: Mike Hommey <mh+reportbug@glandium.org> Signed-off-by: NeilBrown <neilb@suse.de>
2011-08-23Merge git://git.infradead.org/users/cbou/battery-3.1Linus Torvalds
* git://git.infradead.org/users/cbou/battery-3.1: s3c-adc-battery: Fix compilation error due to missing header (module.h) max8997_charger: Needs module.h max8998_charger: Needs module.h
2011-08-23drm/radeon: Extended DDC Probing for Toshiba L300D Radeon Mobility X1100 ↵Thomas Reim
HDMI-A Connector Toshiba Satellite L300D with ATI Mobility Radeon X1100 sends data to i2c bus for a HDMI connector that is not implemented/existent on the notebook's board. Fix by applying extented DDC probing for this connector. Requires [PATCH] drm/radeon: Extended DDC Probing for Connectors with Improperly Wired DDC Lines Tested for kernel 2.6.38 on Toshiba Satellite L300D notebook BugLink: http://bugs.launchpad.net/bugs/826677 Signed-off-by: Thomas Reim <reimth@gmail.com> Acked-by: Chris Routh <routhy@gmail.com> Cc: <stable@kernel.org> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-23drm/ttm: ensure ttm for new node is bound before calling move_notify()Ben Skeggs
This was true for new TTM_PL_SYSTEM and new TTM_PL_TT cases, but wasn't the case on TTM_PL_SYSTEM<->TTM_PL_TT moves, which causes trouble on some paths as nouveau's move_notify() hook requires that the dma addresses be valid at this point. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-23drm/ttm: unbind ttm before destroying node in accel move cleanupBen Skeggs
Nouveau makes the assumption that if a TTM is bound there will be a mm_node around for it and the backwards ordering here resulted in a use-after-free on some eviction paths. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-23drm/ttm: fix ttm_bo_add_ttm(user) failure pathMarcin Slusarz
ttm_tt_destroy kfrees passed object, so we need to nullify a reference to it. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: stable@kernel.org Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-22drm/radeon: Make vramlimit parameter actually work.Michel Dänzer
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-22drm/radeon: Explicitly print GTT/VRAM offsets on test failure.Michel Dänzer
Otherwise these would need to be painstakingly calculated looking at the source code. Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-22drm/radeon: Take IH ring into account for test size calculation.Michel Dänzer
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-22drm/radeon/alpha: Add Alpha support to Radeon DRM codeJay Estabrook
Alpha needs to have available the system bus address for the Radeon's local memory, so that it can be used in ttm_bo_vm_fault(), when building the PTEs for accessing that VRAM. So, we make bus.addr hold the ioremap() return, and then we can modify bus.base appropriately for use during page fault processing. Signed-off-by: Jay Estabrook <jay.estabrook@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-21Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: core: handle ack_busy when fetching the Config ROM
2011-08-20pci: fix new kernel-doc warning in pci.cRandy Dunlap
Fix new kernel-doc warning in pci.c: Warning(drivers/pci/pci.c:3259): No description found for parameter 'mps' Warning(drivers/pci/pci.c:3259): Excess function parameter 'rq' description in 'pcie_set_mps' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/drm-intel * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/drm-intel: drm/i915: set GFX_MODE to pre-Ivybridge default value even on Ivybridge
