path: root/drivers
2009-07-10hwsim: make testmode_cmd staticJohannes Berg
sparse correctly complains about this, no reason for it not to be static. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: fix queue stall due to underrunChristian Lamparter
Larry Finger discovered a weird behavior under load. In essence, the queue's length count under runs, which in turn renders the associated ac queue unusable. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54usb: fix stalls caused by urb allocation failuresChristian Lamparter
This patch squashes a few old bugs, which have been around since the initial version of p54usb in one form or another. we never freed a orphaned frame, when were denied the resources, which are necessary to pass the data into the usb subsystem. As a result we could end up with a full queue that wasn't emptied, until the device was brought down. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath5k: write PCU registers on initial resetBob Copeland
"Ath5k: unify resets" introduced a regression into 2.6.28 where the PCU registers are never initialized, due to ath5k_reset() always passing true for change_channel. We subsequently program a lot of these registers but several may start in an unknown state. Cc: stable@kernel.org Reported-by: Forrest Zhang <forrest@hifulltech.com> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath5k: do not release irq across suspend/resumeBob Copeland
Paraphrasing Rafael J. Wysocki: "drivers should not release PCI IRQs in suspend." Doing so causes a warning during suspend/resume on some platforms. Cc: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath: remove unnecessary return in ath_regd_get_band_ctlBob Copeland
'default' case already returns NO_CTL Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath5k: rework beacon configurationBob Copeland
Using the enable_beacon flag allows some simplifications and fixes some corner cases in beacon handling. This change adds a state variable for beaconing in ath5k_beacon_config and handles both enabling and disabling, thus eliminating the need for ath5k_beacon_disable. We also now configure the beacon when any of the beacon parameters change, so ath5k_beacon_reconfig is no longer needed (its mmiowb gets moved to ath5k_beacon_config). Finally, by locking around the whole config function, we don't need to worry about clearing the interrupt mask register before installing the new mask. The upshot is this correctly disables beaconing when the interfaces are taken down, it fixes a potential restarting of beaconing when ath5k_reset() is called, and ensures that updates to the beacon interval take effect immediately. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath5k: send buffered frames after the beaconBob Copeland
Enable the "Content" After Beacon queue and utilize it to send any buffered frames for power-saving clients. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54spi: remove dead code and definitionsChristian Lamparter
This patch removes some dead code: p54spi.c:115: warning: ‘p54spi_read16’ defined but not used and while we're at it, p54spi_registers_array is purged as well. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: two endian fixesChristian Lamparter
This patch fixes all CHECK_ENDIAN complains: 1. p54/fwio.c:296:6: warning: restricted __le32 degrades to integer p54/fwio.c:296:6: warning: restricted __le32 degrades to integer 2. p54/p54spi.c:172:32: warning: incorrect type in initializer p54spi.c:172:32: expected restricted __le32 [usertype] buffer p54/p54spi.c:172:32: got unsigned int Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10rt2x00: use wiphy rfkill interfaceIvo van Doorn
Remove the input_polldev from rt2x00 and replace it with the rfkill interface offered by the wiphy structure. This simplifies the entire rfkill handling in rt2x00 and allows us to remove the CONFIG_RT2X00_LIB_RFKILL option and always enables rfkill capabilities. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: fix aggregation limitJohannes Berg
According to the documentation, the limit is 0x3f == 63, not 64. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath9k: remove permissions from debugfs filesJiri Slaby
Don't allow users to open debugfs files, because it can cause oopses. When a user opens some file, driver unlinks it and frees the corresponding structure, we will dereference freed memory. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath5k: remove permissions from debugfs filesJiri Slaby
2009-07-10drivers/net/wireless/ath/ath9k: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: always print buffer when error condition occursReinette Chatre
We want to see the buffer contents when the error occurs without needing to set any debug flags. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: add utility to print buffer when error occursReinette Chatre
2009-07-10iwlagn: re-enable PS support for iwlagnReinette Chatre
The register locking rework addressed the problem where nic access was obtained incorrectly when PS is enabled. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwmc3200wifi: remove B0 hardware supportZhu Yi
The patch removes B0 hardware support. Nobody is using it anyway. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwmc3200wifi: simplify calibration mapZhu Yi
The patch simplifies calibration map by combining the init_calib_map and periodic_calib_map into one calib_map in struct iwm_conf. Now the initial calibration map is stored in the lower 16 bits of calib_map and the periodic calibration map is stored in the higher 16 bits. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwmc3200wifi: replace netif_rx with netif_rx_niZhu Yi
The patch uses netif_rx_ni() over netif_rx() to post buffers to upper network code because it is always scheduled in a workqueue. The problem was first observed from a dynamic ticks warning: "NOHZ: local_softirq_pending ..." Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10drivers/net/wireless: Use PCI_VDEVICEJoe Perches
2009-07-10ath9k: Handle different TX and RX streams properly.Senthil Balasubramanian
This patch fixes an issue when the TX and RX streams are different. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath9k: race condition in SCANNING state check during ANI calibrationSenthil Balasubramanian
ANI calibration shouldn't be done when we are not on our home channel. This is already verified. However, it is racy. Fix this by proper spin locks. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath9k: stop ani when the STA gets disconnected.Senthil Balasubramanian
ANI is not required when the STA is disconnected. So stop it and enable ANI for adhoc and monitor mode. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath9k: remove unnecessary STATION mode check.Senthil Balasubramanian
Remove unncessary STATION mode check in ath9k_bss_assoc_info() as it is called only for STATION mode. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Modify p54 files for new organizationChristian Lamparter
Modify the remaining p54 files to account for the new file organization. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move TX/RX codeChristian Lamparter
Copy the TX/RX code from p54common.c into a new file txrx.c Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move mac80211 glue codeChristian Lamparter
Copy the mac80211 glue code from p54common.c into a new file main.c Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move LMAC interface definitionsChristian Lamparter
Copy the LMAC Interface specific definitions from p54common.h into a new file lmac.h Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move LED codeChristian Lamparter
Copy the LED code from p54common.c into a new file led.c Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move firmware codeChristian Lamparter
Copy the firmware i/o code from p54common.c into a new file fwio.c Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move eeprom headerChristian Lamparter
Copy the eeprom code from p54common.h into a new file eeprom.h Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: Move eeprom codeChristian Lamparter
Copy the eeprom code from p54common.c into a new file eeprom.c Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10wireless: remove redundant tests on unsignedRoel Kluin
bufsize and remainder are unsigned. When negative they are wrapped and caught by the other test. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10p54: redo rx_status into skb->cbChristian Lamparter
This patch slightly optimizes p54_rx_data's stack and code size. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ar9170usb: module link in sysfsChristian Lamparter
Andrey Yurovsky reported that the driver forwarded erroneously the parent device structure instead of the real thing, which of course led to some dodgy sysfs links (at least?). Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: unify iwl_setup_rxon_timingTomas Winkler
This patch unifies setup_rxon_timing funcions of AGN and 3945. HWs differ only in supported maximal beacon interval. This is reflected in hw_paras.max_beacon_itrvl Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: scan requested channels onlyJohannes Berg
When userspace requests only certain channels to be scanned, we currently ignore that request entirely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: make software queue assignment more efficientJohannes Berg
There really is no reason to be assigning txq->swq_id all the time, once at aggregation setup is sufficient. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: drop sw_crypto from hw_params.Tomas Winkler
Each HW supported by iwlwifi is capable of hardware crypto so drop this flag from hw_params structure. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10iwlwifi: Check HW ready before prepare card.Mohamed Abbas
Hardware may be ready for us to manage it without us trying to prepare it first. Check if this is the case. Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10ath9k: differentiate quality reporting between legacy and HT configurationsLuis R. Rodriguez
We were not differentiating quality between legacy and HT configurations. We change this to consider the differences. New theory for reporting quality: At a hardware RSSI of 45 you will be able to use MCS 7 reliably. At a hardware RSSI of 45 you will be able to use MCS 15 reliably. At a hardware RSSI of 35 you should be able use 54 Mbps reliably. MCS 7 is the highets MCS index usable by a 1-stream device. MCS 15 is the highest MCS index usable by a 2-stream device. All ath9k devices are either 1-stream or 2-stream. How many bars you see is derived from the qual reporting. A more elaborate scheme can be used here but it requires tables of SNR/throughput for each possible mode used. For the MCS table you can refer to the wireless wiki: http://wireless.kernel.org/en/developers/Documentation/ieee80211/802.11n This should fix this bug report: http://bugzilla.kernel.org/show_bug.cgi?id=13537 Cc: Janath.Peiris@atheros.com Cc: Matt.Smith@atheros.com Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10libertas: fix card cleanup order in SDIO driverAndrey Yurovsky
The SDIO driver sets the surpriseremoved flag before calling lbs_remove_card. With IEEE PS enabled, lbs_remove_card must issue a command to exit IEEE PS mode, however with that flag set the command path is blocked and the card is never taken out of IEEE PS mode. This step is required to ensure that the driver can be reloaded. This patch moves the setting of surpriseremoved after lbs_remove_card is called. Tested with V9 firmware by ensuring that IEEE PS is disabled when the driver is removed. Reloading the driver is not fully tested due to a separate issue with module reload in the SDIO driver, however this patch at least leaves the card in a better state when we bring the driver down. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10libertas: correct card cleanup order in SPI driverAndrey Yurovsky
The SPI driver does a couple of card cleanup steps in the wrong order on module removal. If IEEE PS is enabled, this results in the card being left in IEEE PS mode and subsequent failures to reload the module. The problem is that the surpriseremoved flag is set before calling lbs_remove_card, but that function needs to issue a command to exit IEEE PS mode (the flag blocks the command path). In addition, lbs_stop_card should be called first because it clears out any pending commands. Tested on a GSPI device with V9 firmware by confirming that we can reload the module with or without IEEE PS enabled. Also fix a warning from the wrong uint format in a printk. V2: use z modifier, thanks Sebastian. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10libertas: copy WPA keys to priv when associatingAndrey Yurovsky
Libertas currently maintains a copy of the WPA unicast and group keys when using WPA or WPA2. This copy is checked when deciding whether or not to return to sleep in IEEE PS mode but the actual copying back to priv was omitted, which breaks IEEE PS mode with WPA/WPA2 when one issues commands that require temporarily keeping the device awake. This patch introduces the omitted copy-back of the keys so that IEEE PS functions correctly in WPA/WPA2 mode. Thanks to Dan Williams for clearing up the issue. V2: fix typo. Also, this has been tested on GSPI and SDIO with V9 firmware. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10orinoco: fix printk format specifier for size_t argumentsDavid Kilroy
This addresses the following compile warnings on 64-bit platforms. drivers/net/wireless/orinoco/scan.c: In function 'orinoco_add_hostscan_results': drivers/net/wireless/orinoco/scan.c:194: warning: format '%d' expects type 'int', but argument 3 has type 'size_t' drivers/net/wireless/orinoco/scan.c:211: warning: format '%d' expects type 'int', but argument 3 has type 'size_t' drivers/net/wireless/orinoco/scan.c:211: warning: format '%d' expects type 'int', but argument 4 has type 'size_t' Signed-off-by: David Kilroy <kilroyd@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: implement iwpowerJohannes Berg
Just on/off and timeout, and with a hacky cfg80211 method until we figure out what we want, though this is probably sufficient as we want to use pm_qos for wifi everywhere. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: introduce nl80211 testmode commandJohannes Berg
This introduces a new NL80211_CMD_TESTMODE for testing and calibration use with nl80211. There's no multiplexing like like iwpriv had, and the command is not available by default, it needs to be explicitly enabled in Kconfig and shouldn't be enabled in most kernels. The command requires a wiphy index or interface index to identify the device to operate on, and the new TESTDATA attribute. There also is API for sending replies to the command, and testmode multicast messages (on a testmode multicast group). I've also updated mac80211 to be able to pass through the command to the driver, since it itself doesn't implement the testmode command. Additionally, to give people an idea of how to use the command, I've added a little code to hwsim that makes use of the new command to set the powersave mode, this is currently done via debugfs and should remain there, and the testmode command only serves as an example of how to use this best -- with nested netlink attributes in the TESTDATA attribute. A hwsim testmode tool can be found at http://git.sipsolutions.net/hwsim.git/. This tool is BSD licensed so people can easily use it as a basis for their own internal fabrication and validation tools. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10mac80211_hwsim: fix-up build damage from removal of skb->dstJohn W. Linville
