path: root/drivers
2006-05-06[ARM] rtc-sa1100: fix compiler warnings and error cleanupRussell King
Fix: drivers/rtc/rtc-sa1100.c: In function `sa1100_rtc_proc': drivers/rtc/rtc-sa1100.c:298: warning: unsigned int format, long unsigned int arg (arg 3) and arrange for sa1100_rtc_open() to pass the devid to free_irq() rather than NULL. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [PATCH] powerpc: Use the ibm,pa-features property if available powerpc: Fix incorrect might_sleep in __get_user/__put_user on kernel addresses [PATCH] ppc32 CPM_UART: fixes and improvements [PATCH] ppc32 CPM_UART: Fixed break send on SCC [PATCH] powerpc/kprobes: fix singlestep out-of-line [PATCH] powerpc/pseries: avoid crash in PCI code if mem system not up
2006-05-04Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3490/1: i.MX: move uart resources to board files [ARM] 3488/1: make icedcc_putc do the right thing [ARM] 3487/1: IXP4xx: Support non-PCI systems [ARM] 3486/1: Mark memory as clobbered by the ARM _syscallX() macros
2006-05-04Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] Move set_ios debugging into mmc.c [MMC] Correct mmc_request_done comments [MMC] PXA: reduce the number of lines PXAMCI debug uses [MMC] PXA and i.MX: don't avoid sending stop command on error [MMC] extend data timeout for writes [ARM] 3485/1: i.MX: MX1 SD/MMC fix of unintentional double start possibility
2006-05-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [DECNET]: Fix level1 router hello [TCP]: Fix sock_orphan dead lock [ROSE]: Eleminate HZ from ROSE kernel interfaces [NETROM]: Eleminate HZ from NET/ROM kernel interfaces [AX.25]: Eleminate HZ from AX.25 kernel interfaces [ROSE]: Fix routing table locking in rose_remove_neigh. [AX.25]: Move AX.25 symbol exports [HAMRADIO]: Remove remaining SET_MODULE_OWNER calls from hamradio drivers. [AX25, ROSE]: Remove useless SET_MODULE_OWNER calls. [AX.25]: Spelling fix [ROSE]: Remove useless prototype for rose_remove_neigh(). [NETFILTER]: x_tables: don't use __copy_{from,to}_user on unchecked memory in compat layer [NETFILTER]: H.323 helper: Change author's email address [NETFILTER]: NAT: silence unused variable warnings with CONFIG_XFRM=n [NETFILTER]: H.323 helper: fix use of uninitialized data [NETFILTER]: H.323 helper: fix endless loop caused by invalid TPKT len
2006-05-04[MMC] Move set_ios debugging into mmc.cRussell King
Rather than having every driver duplicate the set_ios debugging, provide a single version in mmc.c which can be expanded as we add additional functionality. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04[ARM] 3490/1: i.MX: move uart resources to board filesSascha Hauer
Patch from Sascha Hauer This patch moves the i.MX uart resources and the gpio pin setup to the board files. This allows the boards to decide how many internal uarts are connected to the outside world and whether they use rts/cts or not. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04[MMC] Correct mmc_request_done commentsRussell King
mmc_request_done should be called at the end of handling a request, not between the data and initial command parts of the request. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-03[HAMRADIO]: Remove remaining SET_MODULE_OWNER calls from hamradio drivers.Ralf Baechle DL5RB
Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[PATCH] Altix: correct ioc4 port orderBrent Casavant
Currently loading the ioc3 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-03[PATCH] EDAC Coexistence with BIOSmark gross
Address the issue of EDAC/BIOS coexistence for the e752x chip-sets. We have found a problem where the BIOS will start the system with the error registers (dev0:fun1) hidden and assuming it has exclusive access to them. The edac driver violates this assumption. The workaround this patch offers is to honor the hidden-ness as an indication that it is not safe to use those registers. Signed-off-by: Mark Gross <mark.gross@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-03[PATCH] ppc32 CPM_UART: fixes and improvementsVitaly Bordug
A number of small issues are fixed, and added the header file, missed from the original series. With this, driver should be pretty stable as tested among both platform-device-driven and "old way" boards. Also added missing GPL statement , and updated year field on existing ones to reflect code update. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-03[PATCH] ppc32 CPM_UART: Fixed break send on SCCVitaly Bordug
SCC uart sends a break sequence each time it is stopped with the CPM_CR_STOP_TX command. That means that each time an application closes the serial device, a break is transmitted. To fix this, graceful tx stop is issued for SCC. Signed-off-by: David Jander <david.jander@protonic.nl> Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-02forcedeth: fix multi irq issuesAyaz Abdulla
This patch fixes the issues with multiple irqs. I am resending based on feedback. I decoupled the dma mask for consistent memory and fixed leak with multiple irq in error path. Thanks to Manfred for catching the spin lock problem. Signed-Off-By: Ayaz Abdulla <aabdulla@nvidia.com>
2006-05-02[PATCH] via-rhine: zero pad short packets on Rhine I ethernet cardsCraig Brind
Fixes Rhine I cards disclosing fragments of previously transmitted frames in new transmissions. Before transmission, any socket buffer (skb) shorter than the ethernet minimum length of 60 bytes was zero-padded. On Rhine I cards the data can later be copied into an aligned transmission buffer without copying this padding. This resulted in the transmission of the frame with the extra bytes beyond the provided content leaking the previous contents of this buffer on to the network. Now zero-padding is repeated in the local aligned buffer if one is used. Following a suggestion from the via-rhine maintainer, no attempt is made here to avoid the duplicated effort of padding the skb if it is known that an aligned buffer will definitely be used. This is to make the change "obviously correct" and allow it to be applied to a stable kernel if necessary. There is no change to the flow of control and the changes are only to the Rhine I code path. The patch has run on an in-service Rhine-I host without incident. Frames shorter than 60 bytes are now correctly zero-padded when captured on a separate host. I see no unusual stats reported by ifconfig, and no unusual log messages. Signed-off-by: Craig Brind <craigbrind@gmail.com> Signed-off-by: Roger Luethi <rl@hellgate.ch> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-02[PATCH] mv643xx_eth: provide sysfs class device symlinkOlaf Hering
On Sat, Mar 11, Olaf Hering wrote: > Why is the /sys/class/net/eth0/device symlink not created for the > mv643xx_eth driver? Does this work for other platform device drivers? > Seems to work for the ps2 keyboard at least. The SET_NETDEV_DEV has to be done before a call to register_netdev. With the new patch below, the device symlink for the platform device was created. Unfortunately, after the 4 ls commands, the network connection died. No idea if the box crashed or if something else broke, lost remote access. Provide sysfs 'device' in /class/net/ethN Also, set module owner field, like pcnet32 driver does. Signed-off-by: Olaf Hering <olh@suse.de> Acked-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-02[MMC] PXA: reduce the number of lines PXAMCI debug usesRussell King
There's no reason for the PXAMCI debug code to print so many lines - it causes the kernel buffer to overflow when trying to debug this driver. Remove some debug messages which are duplicated by core code, and combine other messages, resulting in fewer characters written to the kernel log. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-02[MMC] PXA and i.MX: don't avoid sending stop command on errorRussell King
Always send a stop command at the end of a data transfer. If we avoid sending the stop command, some cards remain in data transfer mode, and refuse to accept further read/write commands. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-02[MMC] extend data timeout for writesRussell King
The CSD contains a "read2write factor" which determines the multiplier to be applied to the read timeout to obtain the write timeout. We were ignoring this parameter, resulting in the possibility for writes being timed out too early. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ipath: tidy up white space in a few files IB/ipath: fix label name in interrupt handler IB/ipath: improve sparse annotation IB/ipath: simplify IB timer usage IB/ipath: simplify RC send posting IB/ipath: prevent hardware from being accessed during reset IB/ipath: fix verbs registration IB/ipath: change handling of PIO buffers IB/ipath: iterate over correct number of ports during reset IB/ipath: set up 32-bit DMA mask if 64-bit setup fails IB/ipath: fix race with exposing reset file IB/mthca: Fix offset in query_gid method
2006-05-01[PATCH] genrtc: fix read on 64-bit platformsAtsushi Nemoto
Fix genrtc's read() routine for 64-bit platforms. Current gen_rtc_read() stores 64bit integer and returns 8 even if an user tried to read a 32bit integer. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] RTC: rtc-dev tweak for 64-bit kernelAtsushi Nemoto
Make rtc-dev work well on 64-bit platforms with 32-bit userland. On those platforms, users might try to read 32-bit integer value. This patch make rtc-dev's read() work well for both "int" and "long" size. This tweak is came from genrtc driver. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] s390: fix ipd handlingHeiko Carstens
As pointed out by Paulo Marques <pmarques@grupopie.com> MAX_IPD_TIME is by a factor of ten too small. Since this means that we allow ten times more IPDs in the intended time frame this could result in a cpu check stop of a physical cpu. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] Altix: correct ioc3 port orderPat Gefre
Currently loading the ioc3 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Patrick Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] md: Fix 'rdev->nr_pending' count when retrying barrier requestsNeilBrown
When retrying a failed BIO_RW_BARRIER request, we need to keep the reference in ->nr_pending over the whole retry. Currently, we only hold the reference if the failed request is the *last* one to finish - which is silly, because it would normally be the first to finish. So move the rdev_dec_pending call up into the didn't-fail branch. As the rdev isn't used in the later code, calling rdev_dec_pending earlier doesn't hurt. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] md: Improve detection of lack of barrier support in raid1NeilBrown
Move the test for 'do barrier work' down a bit so that if the first write to a raid1 is a BIO_RW_BARRIER write, the checking done by superblock writes will cause the right thing to happen. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] md: Change ENOTSUPP to EOPNOTSUPPNeilBrown
Because that is what you get if a BIO_RW_BARRIER isn't supported! Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] md: Fixed refcounting/locking when attempting read error correction ↵NeilBrown
in raid10 We need to hold a reference to rdevs while reading and writing to attempt to correct read errors. This reference must be taken under an rcu lock. Signed-off-by: Neil Brown <neilb@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] md: Avoid oops when attempting to fix read errors on raid10NeilBrown
We should add to the counter for the rdev *after* checking if the rdev is NULL!!! Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] s390: make qeth buildableBastian Blank
Signed-off-by: Bastian Blank <bastian@waldi.eu.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01IB/ipath: tidy up white space in a few filesBryan O'Sullivan
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: fix label name in interrupt handlerBryan O'Sullivan
Names that are the opposite of their intended meanings are not so helpful. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: improve sparse annotationBryan O'Sullivan
2006-05-01IB/ipath: simplify IB timer usageBryan O'Sullivan
2006-05-01IB/ipath: simplify RC send postingBryan O'Sullivan
Remove some unnecessarily complicated tests. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: prevent hardware from being accessed during resetBryan O'Sullivan
The reset code now turns off the PRESENT flag during a reset, so that other code won't attempt to access a device that's in mid-reset. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: fix verbs registrationBryan O'Sullivan
Remember when the verbs layer unregisters from the lower-level code. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: change handling of PIO buffersBryan O'Sullivan
Different ipath hardware types have different numbers of buffers available, so we decide on the counts ourselves unless we are specifically overridden with a module parameter. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: iterate over correct number of ports during resetBryan O'Sullivan
2006-05-01IB/ipath: set up 32-bit DMA mask if 64-bit setup failsBryan O'Sullivan
Some systems do not set up 64-bit maps on systems with 2GB or less of memory installed, so we have to fall back to trying a 32-bit setup. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: fix race with exposing reset fileBryan O'Sullivan
We were accidentally exposing the "reset" sysfs file more than once per device. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/mthca: Fix offset in query_gid methodRoland Dreier
GuidInfo records have 8 byte GUIDs in them, so an index should be multiplied by 8 to get an offset. mthca_query_gid() was incorrectly multiplying by 16. Noticed by Leonid Keller <leonid@mellanox.co.il>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [TG3]: Update version and reldate [TG3]: Fix bug in nvram write [TG3]: Add reset_phy parameter to chip reset functions [TG3]: Reset chip when changing MAC address [TG3]: Add phy workaround [TG3]: Call netif_carrier_off() during phy reset [IPV6]: Fix race in route selection. [XFRM]: fix incorrect xfrm_policy_afinfo_lock use [XFRM]: fix incorrect xfrm_state_afinfo_lock use [TCP]: Fix unlikely usage in tcp_transmit_skb() [XFRM]: fix softirq-unsafe xfrm typemap->lock use [IPSEC]: Fix IP ID selection [NET]: use hlist_unhashed() [IPV4]: inet_init() -> fs_initcall [NETLINK]: cleanup unused macro in net/netlink/af_netlink.c [PKT_SCHED] netem: fix loss [X25]: fix for spinlock recurse and spinlock lockup with timer handler
2006-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: make EVIOCGSND return meaningful data Input: ressurect EVIOCGREP and EVIOCSREP Input: psmouse - fix new device detection logic Input: move input_device_id to mod_devicetable.h Input: allow using several chords for braille Input: allow passing NULL to input_free_device() Input: spitzkbd - fix the reversed Address and Calender keys Input: ads7846 - improve filtering for thumb press accuracy Input: ads7846 - report 0 pressure value along with pen up event Input: ads7846 - handle IRQs that were latched during disabled IRQs Input: ads7846 - miscellaneous fixes Input: ads7846 - use msleep() instead of udelay() in suspend Input: ads7846 - debouncing and rudimentary sample filtering Input: ads7846 - power down ADC a bit later Input: ads7846 - add pen_down sysfs attribute Input: wistron - add support for Fujitsu N3510 Input: wistron - add signature for Amilo M7400
2006-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsa: (22 commits) [ALSA] via82xx - Use DXS_SRC as default for VIA8235/8237/8251 chips [ALSA] hda-codec - Add model entry for ASUS Z62F [ALSA] PCMCIA sound devices shouldn't depend on ISA [ALSA] hda-codec - Fix capture from line-in on VAIO SZ/FE laptops [ALSA] Fix Oops at rmmod with CONFIG_SND_VERBOSE_PROCFS=n [ALSA] PCM core - introduce CONFIG_SND_PCM_XRUN_DEBUG [ALSA] adding __devinitdata to pci_device_id [ALSA] add __devinitdata to all pci_device_id [ALSA] hda-codec - Add codec id for AD1988B codec chip [ALSA] hda-codec - Add model entry for ASUS M9 laptop [ALSA] pcxhr - Fix a compiler warning on 64bit architectures [ALSA] via82xx: tweak VT8251 workaround [ALSA] intel8x0 - Disable ALI5455 SPDIF-input [ALSA] via82xx: add support for VIA VT8251 (AC'97) [ALSA] Fix typos and add information about Jack support to Audiophile-Usb.txt [ALSA] Fix double free in error path of miro driver [ALSA] hda-codec - Add entry for Epox EP-5LDA+ GLi [ALSA] sound/pci/: remove duplicate #include's [ALSA] hda-codec - Use model 'hp' for all HP laptops with AD1981HD [ALSA] continue on IS_ERR from platform device registration ...
2006-04-30[ARM] 3485/1: i.MX: MX1 SD/MMC fix of unintentional double start possibilityPavel Pisa
Patch from Pavel Pisa The clock starting imxmci_start_clock() function contains hardware issue workaround, which repeats start attempt, if SDHC does not react on the first trial. But the second start attempt can be taken even, if the first succeed and test code misses time limited clock running phase due to delay caused by schedule to other task or some another device interrupt. This change enables to detect such situation. The performance is not issue, because usually at full clock rate only about six loops in delay cycle are needed. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-30[ARM] 3486/1: Mark memory as clobbered by the ARM _syscallX() macrosMarkus Gutschke
Patch from Markus Gutschke In order to prevent gcc from making incorrect optimizations, all asm() statements that define system calls should report memory as clobbered. Recent versions of the headers for i386 have been changed accordingly, but the ARM headers are still defective. This patch fixes the bug tracked at http://bugzilla.kernel.org/show_bug.cgi?id=6205 Signed-off-by: Markus Gutschke <markus@google.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-29[TG3]: Update version and reldateMichael Chan
Update version to 3.57. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-29[TG3]: Fix bug in nvram writeMichael Chan
Fix bug in nvram write function. If the starting nvram address offset happens to be the last dword of the page, the NVRAM_CMD_LAST bit will not get set in the existing code. This patch fixes the bug by changing the "else if" to "if" so that the last dword condition always gets checked. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-29[TG3]: Add reset_phy parameter to chip reset functionsGary Zambrano
Add a reset_phy parameter to tg3_reset_hw() and tg3_init_hw(). With the full chip reset during MAC address change, the automatic PHY reset during chip reset will cause a link down and bonding will not work properly as a result. With this reset_phy parameter, we can do a chip reset without link down when changing MAC address or MTU. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
