path: root/drivers
2013-04-05mtd: omap2: Use module_platform_driver()Sachin Kamat
module_platform_driver macro removes some boilerplate and makes the code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: bf5xx_nand: Use module_platform_driver()Sachin Kamat
2013-04-05mtd: denali_dt: Remove redundant use of of_match_ptrSachin Kamat
Since this driver is dt only and denali_nand_dt_ids is always compiled in, use of of_match_ptr() macro is not necessary. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: denali_dt: Change return value to fix smatch warningSachin Kamat
platform_get_irq() also returns -ENXIO upon failure. Use it instead of hardcoded return type. Fixes the following smatch warning: drivers/mtd/nand/denali_dt.c:93 denali_dt_probe() info: why not propagate 'denali->irq' from platform_get_irq() instead of (-6)? Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: denali_dt: Use module_platform_driver()Sachin Kamat
module_platform_driver() removes some boilerplate and makes the code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: denali_dt: Fix incorrect error checkSachin Kamat
The return value of devm_ioremap_nocache should be checked here instead of res. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: nand: subpage write support for hardware based ECC schemesGupta, Pekon
This patch adds support for subpage (partial-page) writes when using hardware based ECC schemes. Advantages: (1) reduces storage overhead when using file-systems like UBIFS, which store LEB header at page-size granularity. (2) allows independent subpage writes, thereby increasing NAND storage efficiency for non-page aligned data. + updated cafe_nand and lpc32xx_mlc NAND drivers for change in chip->write_page interface. Signed-off-by: Gupta, Pekon <pekon@ti.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: omap2: use msecs_to_jiffies()Toan Pham
Fix mtd-utils from returning -EIO. Formatting jffs2 filesystem was impossible when CONFIG_HZ was set to a low value. Signed-off-by: Toan Pham <tpham3783@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: nand_ids: use size macrosArtem Bityutskiy
Use the convenient 'SZ_8K' and 'SZ_16K' macros for the eraseblock size in the NAND IDs table. This is a little more readable. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: nand_ids: improve LEGACY_ID_NAND macro a bitArtem Bityutskiy
Notice that all the flashes belonging to the "legacy ID" class have 512 bytes NAND page. This means we may simplify the 'LEGACY_ID_NAND()' macro as well as the NAND ID table a little. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: add 4 Toshiba nand chips for the full-id caseHuang Shijie
I have 4 Toshiba nand chips which can not be parsed out by the id data. We can not get the oob size from the id data. So add them as the full-id nand chips in the first of nand_flash_ids. The comment for the full-id items is from Brian. Signed-off-by: Huang Shijie <b32955@freescale.com> Reviewed-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: add the support to parse out the full-id nand typeHuang Shijie
When we meet a full-id nand type whose @id_len is not zero, we can use the find_full_id_nand() to parse out the necessary information for a nand chip. If we meet a non full-id nand type, we can handle it in the legacy way. Signed-off-by: Huang Shijie <b32955@freescale.com> Reviewed-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: sh_flctl: Use of_match_ptr() macroSachin Kamat
This eliminates having an #ifdef returning NULL for the case when OF is disabled. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: gpio: Use of_match_ptr() macroSachin Kamat
2013-04-05mtd: gpio: Use devm_kzalloc()Sachin Kamat
devm_kzalloc() is device managed and makes cleanup simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: davinci_nand: Use of_match_ptr()Sachin Kamat
2013-04-05mtd: dataflash: Use of_match_ptr() macroSachin Kamat
2013-04-05mtd: remove h720x flash supportArnd Bergmann
The h720x platform support is going away in linux-3.10, so the MTD driver will also not be needed any more. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: onenand: remove OneNAND simulatorArtem Bityutskiy
This commit remove OneNAND simulator on the basis that it is useless. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: merge mtdchar module with mtdcoreArtem Bityutskiy
The MTD subsystem has historically tried to be as configurable as possible. The side-effect of this is that its configuration menu is rather large, and we are gradually shrinking it. For example, we recently merged partitions support with the mtdcore. This patch does the next step - it merges the mtdchar module to mtdcore. And in this case this is not only about eliminating too fine-grained separation and simplifying the configuration menu. This is also about eliminating seemingly useless kernel module. Indeed, mtdchar is a module that allows user-space making use of MTD devices via /dev/mtd* character devices. If users do not enable it, they simply cannot use MTD devices at all. They cannot read or write the flash contents. Is it a sane and useful setup? I believe not. And everyone just enables mtdchar. Having mtdchar separate is also a little bit harmful. People sometimes miss the fact that they need to enable an additional configuration option to have user-space MTD interfaces, and then they wonder why on earth the kernel does not allow using the flash? They spend time asking around. Thus, let's just get rid of this module and make it part of mtd core. Note, mtdchar had additional configuration option to enable OTP interfaces, which are present on some flashes. I removed that option as well - it saves a really tiny amount space. [dwmw2: Strictly speaking, you can mount file systems on MTD devices just fine without the mtdchar (or mtdblock) devices; you just can't do other manipulations directly on the underlying device. But still I agree that it makes sense to make this unconditional. And Yay! we get to kill off an instance of checking CONFIG_foo_MODULE, which is an abomination that should never happen.] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: mtdcore: cleanup mtdcore.h a littleArtem Bityutskiy
Remove useless extern qualifiers. Not that this is a problem, but we more often declare function prototypes without 'extern', so this is just about being more consistent. And I am going to add a couple more prototypes here. Additionally, remove a useless comment. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: mtdchar: use proper kernel print levelArtem Bityutskiy
We normally use 'pr_err()' for error messages, not 'pr_notice()'. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: mtdcore: remove few useless #ifdef'sArtem Bityutskiy
Remove a couple of useles '#ifdef CONFIG_PROC_FS's around procfs functions which anyway turn into empty function in 'proc_fs.h' file when CONFIG_PROC_FS is not defined. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the h1910 NAND driverArtem Bityutskiy
This driver is marked as broken for 2 years, and no one cares to make it compile and work. Now it is time to zap it. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the ppchameleonevb NAND driverArtem Bityutskiy
This driver has been marked as broken for long time and it depends on a non-existing PPCHAMELEONEVB Kconfig symbol. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: davinci_nand: use module_platform_driver_probe()Jingoo Han
This patch uses module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: txx9ndfmc: use module_platform_driver_probe()Jingoo Han
2013-04-05mtd: sh_flctl: use module_platform_driver_probe()Jingoo Han
2013-04-05mtd: fsmc_nand: use module_platform_driver_probe()Jingoo Han
2013-04-05mtd: atmel_nand: use module_platform_driver_probe()Jingoo Han
2013-04-05mtd: orion_nand: use module_platform_driver_probe()Jingoo Han
2013-04-05mtd: doc: use module_platform_driver_probe()Jingoo Han
2013-04-05mtd: bcm47xxsflash: define opcodesRafał Miłecki
We need them to add erase/write support. This may duplicate some defines with bcma and/or ssb code, but it makes more sense to keep that in bcm47xxsflash which is supposed to work with both buses. Duplicated defines will be removed from ssb/bcma. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: bcm47xxsflash: store info about flash typeRafał Miłecki
It's going to be needed for erase and write operations, they differ between Atmel and ST flashes. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: bcm47xxsflash: keep a reference to the BCMARafał Miłecki
To implement erase and write support we need to "talk" with ChipCommon BCMA core which serial flash it attached to. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: mtdcore: use const qualifierArtem Bityutskiy
Be a bit stricter and add few more 'const' qualifiers. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: devices: add const qualifiersArtem Bityutskiy
2013-04-05mtd: maps: add const qualifiersArtem Bityutskiy
2013-04-05mtd: physmap_of: add const qualifiersArtem Bityutskiy
2013-04-05ssb: driver_mipscore: add a const qualifierArtem Bityutskiy
Be a bit stricter and add few more 'const' qualifiers. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Michael Buesch <m@bues.ch> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05bcma_mips: add a const qualifierArtem Bityutskiy
Be a bit stricter and add few more 'const' qualifiers. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: "Rafał Miłecki" <zajec5@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: physmap: add const qualifiersArtem Bityutskiy
2013-04-05mtd: plat-ram: add const quilifiersArtem Bityutskiy
2013-04-05mtd: add 'const' qualifier to a couple of register functionsArtem Bityutskiy
'mtd_device_parse_register()' and 'parse_mtd_partitions()' functions accept a an array of character pointers. These functions modify neither the pointers nor the characters they point to. The characters are actually names of the MTD parsers. At the moment, the argument type is 'const char **', which means that only the names of the parsers are constant. Let's turn the argument type into 'const char * const *', which means that both names and the pointers which point to them are constant. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the ixp2000 map driverArtem Bityutskiy
This driver depends on CONFIG_IXP2000 which is not defined anywhere, which means this driver is dead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the dilnetpc map driver supportArtem Bityutskiy
This driver is marked as broken for very long time. Most probably this board is just something ancient no one cares about anyway. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the tqm8xxl map driverArtem Bityutskiy
This driver depends on the CONFIG_TQM8xxL symbol, which is not defined anywhere, which means that this driver is dead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: maps: kill the rpxlite map driverArtem Bityutskiy
This driver depends on the CONFIG_RPXCLASSIC and CONFIG_RPXLITE symbols, which are not defined anywhere, and this means that this driver is dead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-pcmcia@lists.infradead.org Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the mbx860 map driverArtem Bityutskiy
This driver depends on CONFIG_MBX which is not defined anywhere, which means this driver is dead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-pcmcia@lists.infradead.org Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: remove the dmv182 map driverArtem Bityutskiy
This driver depends on the CONFIG_DMV182 symbol which is not defined anywhere, and this means that this driver is dead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
