path: root/drivers
2015-03-16ath5k: fix spontaneus AR5312 freezesSergey Ryazanov
commit 8bfae4f9938b6c1f033a5159febe97e441d6d526 upstream. Sometimes while CPU have some load and ath5k doing the wireless interface reset the whole WiSoC completely freezes. Set of tests shows that using atomic delay function while we wait interface reset helps to avoid such freezes. The easiest way to reproduce this issue: create a station interface, start continous scan with wpa_supplicant and load CPU by something. Or just create multiple station interfaces and put them all in continous scan. This patch partially reverts the commit 1846ac3dbec0 ("ath5k: Use usleep_range where possible"), which replaces initial udelay() by usleep_range(). I do not know actual source of this issue, but all looks like that HW freeze is caused by transaction on internal SoC bus, while wireless block is in reset state. Also I should note that I do not know how many chips are affected, but I did not see this issue with chips, other than AR5312. CC: Jiri Slaby <jirislaby@gmail.com> CC: Nick Kossifidis <mickflemm@gmail.com> CC: Luis R. Rodriguez <mcgrof@do-not-panic.com> Fixes: 1846ac3dbec0 ("ath5k: Use usleep_range where possible") Reported-by: Christophe Prevotaux <c.prevotaux@rural-networks.com> Tested-by: Christophe Prevotaux <c.prevotaux@rural-networks.com> Tested-by: Eric Bree <ebree@nltinc.com> Signed-off-by: Sergey Ryazanov <ryazanov.s.a@gmail.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16ACPI / video: Load the module even if ACPI is disabledChris Wilson
commit 6e17cb12881ba8d5e456b89f072dc6b70048af36 upstream. i915.ko depends upon the acpi/video.ko module and so refuses to load if ACPI is disabled at runtime if for example the BIOS is broken beyond repair. acpi/video provides an optional service for i915.ko and so we should just allow the modules to load, but do no nothing in order to let the machines boot correctly. Reported-by: Bill Augur <bill-auger@programmer.net> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Jani Nikula <jani.nikula@intel.com> Acked-by: Aaron Lu <aaron.lu@intel.com> [ rjw: Fixed up the new comment in acpi_video_init() ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16drm/radeon: fix 1 RB harvest config setup for TN/RLAlex Deucher
commit dbfb00c3e7e18439f2ebf67fe99bf7a50b5bae1e upstream. The logic was reversed from what the hw actually exposed. Fixes graphics corruption in certain harvest configurations. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16drm/radeon: use drm_mode_vrefresh() rather than mode->vrefreshAlex Deucher
commit 3d2d98ee1af0cf6eebfbd6bff4c17d3601ac1284 upstream. Just in case it hasn't been calculated for the mode. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: fixup the conflicting keyboard mappings quirkJiri Kosina
commit 8e7b341037db1835ee6eea64663013cbfcf33575 upstream. The ignore check that got added in 6ce901eb61 ("HID: input: fix confusion on conflicting mappings") needs to properly check for VARIABLE reports as well (ARRAY reports should be ignored), otherwise legitimate keyboards might break. Fixes: 6ce901eb61 ("HID: input: fix confusion on conflicting mappings") Reported-by: Fredrik Hallenberg <megahallon@gmail.com> Reported-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: input: fix confusion on conflicting mappingsDavid Herrmann
commit 6ce901eb61aa30ba8565c62049ee80c90728ef14 upstream. On an PC-101/103/104 keyboard (American layout) the 'Enter' key and its neighbours look like this: +---+ +---+ +-------+ | 1 | | 2 | | 5 | +---+ +---+ +-------+ +---+ +-----------+ | 3 | | 4 | +---+ +-----------+ On a PC-102/105 keyboard (European layout) it looks like this: +---+ +---+ +-------+ | 1 | | 2 | | | +---+ +---+ +-+ 4 | +---+ +---+ | | | 3 | | 5 | | | +---+ +---+ +-----+ (Note that the number of keys is the same, but key '5' is moved down and the shape of key '4' is changed. Keys '1' to '3' are exactly the same.) The keys 1-4 report the same scan-code in HID in both layouts, even though the keysym they produce is usually different depending on the XKB-keymap used by user-space. However, key '5' (US 'backslash'/'pipe') reports 0x31 for the upper layout and 0x32 for the lower layout, as defined by the HID spec. This is highly confusing as the linux-input API uses a single keycode for both. So far, this was never a problem as there never has been a keyboard with both of those keys present at the same time. It would have to look something like this: +---+ +---+ +-------+ | 1 | | 2 | | x31 | +---+ +---+ +-------+ +---+ +---+ +-----+ | 3 | |x32| | 4 | +---+ +---+ +-----+ HID can represent such a keyboard, but the linux-input API cannot. Furthermore, any user-space mapping would be confused by this and, luckily, no-one ever produced such hardware. Now, the HID input layer fixed this mess by mapping both 0x31 and 0x32 to the same keycode (KEY_BACKSLASH==0x2b). As only one of both physical keys is present on a hardware, this works just fine. Lets introduce hardware-vendors into this: ------------------------------------------ Unfortunately, it seems way to expensive to produce a different device for American and European layouts. Therefore, hardware-vendors put both keys, (0x31 and 0x32) on the same keyboard, but only one of them is hooked up to the physical button, the other one is 'dead'. This means, they can use the same hardware, with a different button-layout and automatically produce the correct HID events for American *and* European layouts. This is unproblematic for normal keyboards, as the 'dead' key will never report any KEY-DOWN events. But RollOver keyboards send the whole matrix on each key-event, allowing n-key roll-over mode. This means, we get a 0x31 and 0x32 event on each key-press. One of them will always be 0, the other reports the real state. As we map both to the same keycode, we will get spurious key-events, even though the real key-state never changed. The easiest way would be to blacklist 'dead' keys and never handle those. We could simply read the 'country' tag of USB devices and blacklist either key according to the layout. But... hardware vendors... want the same device for all countries and thus many of them set 'country' to 0 for all devices. Meh.. So we have to deal with this properly. As we cannot know which of the keys is 'dead', we either need a heuristic and track those keys, or we simply make use of our value-tracking for HID fields. We simply ignore HID events for absolute data if the data didn't change. As HID tracks events on the HID level, we haven't done the keycode translation, yet. Therefore, the 'dead' key is tracked independently of the real key, therefore, any events on it will be ignored. This patch simply discards any HID events for absolute data if it didn't change compared to the last report. We need to ignore relative and buffered-byte reports for obvious reasons. But those cannot be affected by this bug, so we're fine. Preferably, we'd do this filtering on the HID-core level. But this might break a lot of custom drivers, if they do not follow the HID specs. Therefore, we do this late in hid-input just before we inject it into the input layer (which does the exact same filtering, but on the keycode level). If this turns out to break some devices, we might have to limit filtering to EV_KEY events. But lets try to do the Right Thing first, and properly filter any absolute data that didn't change. This patch is tagged for 'stable' as it fixes a lot of n-key RollOver hardware. We might wanna wait with backporting for a while, before we know it doesn't break anything else, though. Reported-by: Adam Goode <adam@spicenitz.org> Reported-by: Fredrik Hallenberg <megahallon@gmail.com> Tested-by: Fredrik Hallenberg <megahallon@gmail.com> Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16dm snapshot: fix a possible invalid memory access on unloadMikulas Patocka
commit 22aa66a3ee5b61e0f4a0bfeabcaa567861109ec3 upstream. When the snapshot target is unloaded, snapshot_dtr() waits until pending_exceptions_count drops to zero. Then, it destroys the snapshot. Therefore, the function that decrements pending_exceptions_count should not touch the snapshot structure after the decrement. pending_complete() calls free_pending_exception(), which decrements pending_exceptions_count, and then it performs up_write(&s->lock) and it calls retry_origin_bios() which dereferences s->origin. These two memory accesses to the fields of the snapshot may touch the dm_snapshot struture after it is freed. This patch moves the call to free_pending_exception() to the end of pending_complete(), so that the snapshot will not be destroyed while pending_complete() is in progress. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16dm: fix a race condition in dm_get_mdMikulas Patocka
commit 2bec1f4a8832e74ebbe859f176d8a9cb20dd97f4 upstream. The function dm_get_md finds a device mapper device with a given dev_t, increases the reference count and returns the pointer. dm_get_md calls dm_find_md, dm_find_md takes _minor_lock, finds the device, tests that the device doesn't have DMF_DELETING or DMF_FREEING flag, drops _minor_lock and returns pointer to the device. dm_get_md then calls dm_get. dm_get calls BUG if the device has the DMF_FREEING flag, otherwise it increments the reference count. There is a possible race condition - after dm_find_md exits and before dm_get is called, there are no locks held, so the device may disappear or DMF_FREEING flag may be set, which results in BUG. To fix this bug, we need to call dm_get while we hold _minor_lock. This patch renames dm_find_md to dm_get_md and changes it so that it calls dm_get while holding the lock. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16dm io: reject unsupported DISCARD requests with EOPNOTSUPPDarrick J. Wong
commit 37527b869207ad4c208b1e13967d69b8bba1fbf9 upstream. I created a dm-raid1 device backed by a device that supports DISCARD and another device that does NOT support DISCARD with the following dm configuration: # echo '0 2048 mirror core 1 512 2 /dev/sda 0 /dev/sdb 0' | dmsetup create moo # lsblk -D NAME DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO sda 0 4K 1G 0 `-moo (dm-0) 0 4K 1G 0 sdb 0 0B 0B 0 `-moo (dm-0) 0 4K 1G 0 Notice that the mirror device /dev/mapper/moo advertises DISCARD support even though one of the mirror halves doesn't. If I issue a DISCARD request (via fstrim, mount -o discard, or ioctl BLKDISCARD) through the mirror, kmirrord gets stuck in an infinite loop in do_region() when it tries to issue a DISCARD request to sdb. The problem is that when we call do_region() against sdb, num_sectors is set to zero because q->limits.max_discard_sectors is zero. Therefore, "remaining" never decreases and the loop never terminates. To fix this: before entering the loop, check for the combination of REQ_DISCARD and no discard and return -EOPNOTSUPP to avoid hanging up the mirror device. This bug was found by the unfortunate coincidence of pvmove and a discard operation in the RHEL 6.5 kernel; upstream is also affected. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Acked-by: "Martin K. Petersen" <martin.petersen@oracle.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16dm mirror: do not degrade the mirror on discard errorMikulas Patocka
commit f2ed51ac64611d717d1917820a01930174c2f236 upstream. It may be possible that a device claims discard support but it rejects discards with -EOPNOTSUPP. It happens when using loopback on ext2/ext3 filesystem driven by the ext4 driver. It may also happen if the underlying devices are moved from one disk on another. If discard error happens, we reject the bio with -EOPNOTSUPP, but we do not degrade the array. This patch fixes failed test shell/lvconvert-repair-transient.sh in the lvm2 testsuite if the testsuite is extracted on an ext2 or ext3 filesystem and it is being driven by the ext4 driver. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16staging: comedi: comedi_compat32.c: fix COMEDI_CMD copy backIan Abbott
commit 42b8ce6f55facfa101462e694d33fc6bca471138 upstream. `do_cmd_ioctl()` in "comedi_fops.c" handles the `COMEDI_CMD` ioctl. This returns `-EAGAIN` if it has copied a modified `struct comedi_cmd` back to user-space. (This occurs when the low-level Comedi driver's `do_cmdtest()` handler returns non-zero to indicate a problem with the contents of the `struct comedi_cmd`, or when the `struct comedi_cmd` has the `CMDF_BOGUS` flag set.) `compat_cmd()` in "comedi_compat32.c" handles the 32-bit compatible version of the `COMEDI_CMD` ioctl. Currently, it never copies a 32-bit compatible version of `struct comedi_cmd` back to user-space, which is at odds with the way the regular `COMEDI_CMD` ioctl is handled. To fix it, change `compat_cmd()` to copy a 32-bit compatible version of the `struct comedi_cmd` back to user-space when the main ioctl handler returns `-EAGAIN`. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16sunxi: clk: Set sun6i-pll1 n_start = 1Hans de Goede
commit 76820fcf7aa5a418b69cb7bed31b62d1feb1d6ad upstream. For all pll-s on sun6i n == 0 means use a multiplier of 1, rather then 0 as it means on sun4i / sun5i / sun7i. n_start = 1 is already correctly set for sun6i pll6, but was missing for pll1, this commit fixes this. Cc: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16clk: sunxi: Support factor clocks with N factor starting not from 0Chen-Yu Tsai
commit 9a5e6c7eb5ccbb5f0d3a1dffce135f0a727f40e1 upstream. The PLLs on newer Allwinner SoC's, such as the A31 and A23, have a N multiplier factor that starts from 1, not 0. This patch adds an option to the factor clk driver's config data structures to specify the base value of N. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16clk: zynq: Force CPU_2X clock to be ungatedSoren Brinkmann
commit 3dccfecdb867fe35b305a4e493ef5652b7d9d4cb upstream. The CPU_2X clock does not have a classical in-kernel user, but is, amongst other things, required for OCM and debug access. Make sure this clock is not mistakenly disabled during boot up by enabling it in the platform's clock driver. Fixes: 0ee52b157b8e 'clk: zynq: Add clock controller driver' Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michael Turquette <mturquette@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16fixed invalid assignment of 64bit mask to host dma_boundary for scatter ↵Minh Duc Tran
gather segment boundary limit. commit f76a610a8b4b6280eaedf48f3af9d5d74e418b66 upstream. In reference to bug https://bugzilla.redhat.com/show_bug.cgi?id=1097141 Assert is seen with AMD cpu whenever calling pci_alloc_consistent. [ 29.406183] ------------[ cut here ]------------ [ 29.410505] kernel BUG at lib/iommu-helper.c:13! Signed-off-by: Minh Tran <minh.tran@emulex.com> Fixes: 6733b39a1301b0b020bbcbf3295852e93e624cb1 Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: yet another buggy ELAN touchscreenOliver Neukum
commit a32c99e7ab8410bae7c276a7e94ca84d108de034 upstream. The touchscreen needs the same quirk as the other models. Signed-off-by: Oliver Neukum <oneukum@suse.de> Reported-by: Bryan Poling <poli0048@umn.edu> CC: stable@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: usbhid: enable always-poll quirk for Elan Touchscreen 0103Adel Gadllah
commit fa51ee1085d6f2fa344d4ba64faadc9c6db0a3f1 upstream. Yet another device that needs this quirk. Reported-by: Tanguy de Baritault <tdebaritault@gmail.com> Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: usbhid: add another mouse that needs QUIRK_ALWAYS_POLLOliver Neukum
commit 5235166fbc332c8b5dcf49e3a498a8b510a77449 upstream. There is a second mouse sharing the same vendor strings but different IDs. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: usbhid: fix PIXART optical mouseOliver Neukum
commit 4980f95755e2966b30ac70d1841f4db66d1a8a22 upstream. This mouse keeps disconnecting in runlevel 3. It needs the ALWAYS_POLL quirk. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16HID: microsoft: Add ID for NE7K wireless keyboardJakub Sitnicki
commit ef567cf9ddb682dbfa840bf4a2600931299f9555 upstream. Microsoft Natural Wireless Ergonomic Keyboard 7000 has special My Favorites 1..5 keys which are handled through a vendor-defined usage page (0xff05). Apply MS_ERGONOMY quirks handling to USB PID 0x071d (Microsoft Microsoft 2.4GHz Transceiver V1.0) so that the My Favorites 1..5 keys are reported as KEY_F14..18 events. Link: https://bugzilla.kernel.org/show_bug.cgi?id=52841 Signed-off-by: Jakub Sitnicki <jsitnicki@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-13xhci: no switching back on non-ULT HaswellOliver Neukum
commit b45abacde3d551c6696c6738bef4a1805d0bf27a upstream. The switch back is limited to ULT even on HP. The contrary finding arose by bad luck in BIOS versions for testing. This fixes spontaneous resume from S3 on some HP laptops. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12IB/qib: Do not write EEPROMMitko Haralanov
commit 18c0b82a3e4501511b08d0e8676fb08ac08734a3 upstream. This changeset removes all the code that allows the driver to write to the EEPROM and update the recorded error counters and power on hours. These two stats are unused and writing them exposes a timing risk which could leave the EEPROM in a bad state preventing further normal operation of the HCA. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Mitko Haralanov <mitko.haralanov@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12sg: fix read() error reportingTony Battersby
commit 3b524a683af8991b4eab4182b947c65f0ce1421b upstream. Fix SCSI generic read() incorrectly returning success after detecting an error. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12cdc-acm: Add support for Denso cradle CU-321Björn Gerhart
commit b20b1618b8fca858c83e52da4aa22cd6b13b0359 upstream. In order to support an older USB cradle by Denso, I added its vendor- and product-ID to the array of usb_device_id acm_ids. In this way cdc-acm feels responsible for this cradle. The related /dev/ttyACM node is being created properly, and the data transfer works. However, later cradle models by Denso do have proper descriptors, so the patch is not required for these. At the same time both the older and the later model have the same vendor- and product-ID, but they both work with the patched driver. Declaration of the Denso cradles I tested: - both models have the same IDs: vendorID 0x076d, productID 0x0006 - older model: Denso CU-321 (descriptors not properly set) - later model: Denso CU-821 (with proper descriptors) Signed-off-by: Bjoern Gerhart <oss@airbjorn.de> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12usb: musb: core: add pm_runtime_irq_safe()Felipe Balbi
commit 3e43a0725637299a14369e3ef109c25a8ec5c008 upstream. We need a pm_runtime_get_sync() call from within musb_gadget_pullup() to make sure registers are accessible at that time. The problem is that musb_gadget_pullup() is called with IRQs disabled and, because of that, we need to tell pm_runtime that this pm_runtime_get_sync() is IRQ safe. We can simply add pm_runtime_irq_safe(), however, because we need to make our read/write accessor function pointers have been initialized before trying to use them. This means that all pm_runtime initialization for musb_core needs to be moved down so that when we call pm_runtime_irq_safe(), the pm_runtime_get_sync() that it calls on the parent, won't cause a crash due to NULL musb_read/write accessors. Reported-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12usb: gadget: function: phonet: balance usb_ep_disable callsFelipe Balbi
commit 9ec36f7fe20ef919cc15171e1da1b6739222541a upstream. f_phonet's ->set_alt() method will call usb_ep_disable() potentially on an endpoint which is already disabled. That's something the gadget/function driver must guarantee that it's always balanced. In order to balance the calls, just make sure the endpoint was enabled before by means of checking the validity of driver_data. Reported-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: serial: add Google simple serial SubClass supportAnton Staaf
commit 679315e5fae1e4614eed0d9aa26999ddcb6a0f77 upstream. Add support for Google devices that export simple serial interfaces using the vendor specific SubClass/Protocol pair 0x50/0x01. Signed-off-by: Anton Staaf <robotboy@chromium.org> Reviewed-by: Benson Leung <bleung@chromium.org> [johan: move id entries and update Kconfig] Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12HID: microsoft: add support for Japanese Surface Type Cover 3Alan Wu
commit 5e7e9e90b5867a3754159a8ce524299d930fbac8 upstream. Based on code for the US Surface Type Cover 3 from commit be3b16341d5cd8cf2a64fcc7a604a8efe6599ff0 ("HID: add support for MS Surface Pro 3 Type Cover"): Signed-off-by: Alan Wu <alan.c.wu@gmail.com> Tested-by: Karlis Dreizis <karlisdreizis@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12HID: add support for MS Surface Pro 3 Type CoverAlan Wu
commit be3b16341d5cd8cf2a64fcc7a604a8efe6599ff0 upstream. Surface Pro 3 Type Cover that works with Ubuntu (and possibly Arch) from this thread. Both trackpad and keyboard work after compiling my own kernel. http://ubuntuforums.org/showthread.php?t=2231207&page=2&s=44910e0c56047e4f93dfd9fea58121ef Also includes Jarrad Whitaker's message which sources http://winaero.com/blog/how-to-install-linux-on-surface-pro-3/ which he says is sourced from a Russian site Signed-off-by: Alan Wu <alan.c.wu@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12HID: hid-microsoft: Add support for scrollwheel and special keypad keysHans de Goede
commit 3faed1aff786a007b3ea0549ac469e09f48c98f9 upstream. The Microsoft Office keyboard has a scrollwheel as well as some special keys above the keypad which are handled through the custom MS usage page, this commit adds support for these. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12HID: pidff: Fix initialisation forMicrosoft Sidewinder FF Pro 2Jim Keir
commit afd700d933963d07391e3e3dfbfbc05e905960ef upstream. The FF2 driver (usbhid/hid-pidff.c) sends commands to the stick during ff_init. However, this is called inside a block where driver_input_lock is locked, so the results of these initial commands are discarded. This behavior is the "killer", without this nothing else works. ff_init issues commands using "hid_hw_request". This eventually goes to hid_input_report, which returns -EBUSY because driver_input_lock is locked. The change is to delay the ff_init call in hid-core.c until after this lock has been released. Calling hid_device_io_start() releases the lock so the device can be configured. We also need to call hid_device_io_stop() on exit for the lock to remain locked while ending the init of the drivers. [ benjamin.tissoires@redhat.com: imrpoved the changelog a lot ] Signed-off-by: Jim Keir <jimkeir@oracledbadirect.com> Reviewed-by: Benjamin.tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12HID: apple: fix battery support for the 2009 ANSI wireless keyboardRoss Skaliotis
commit cbd366bea2b8513bc0fc1c9e8832cb0ab221d6d5 upstream. Enabled quirks necessary for correct battery capacity reporting. Cleaned up surrounding style. Signed-off-by: Ross Skaliotis <rskaliotis@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12tty: fix up atime/mtime mess, take fourJiri Slaby
commit f0bf0bd07943bfde8f5ac39a32664810a379c7d3 upstream. This problem was taken care of three times already in * b0de59b5733d18b0d1974a060860a8b5c1b36a2e (TTY: do not update atime/mtime on read/write), * 37b7f3c76595e23257f61bd80b223de8658617ee (TTY: fix atime/mtime regression), and * b0b885657b6c8ef63a46bc9299b2a7715d19acde (tty: fix up atime/mtime mess, take three) But it still misses one point. As John Paul correctly points out, we do not care about setting date. If somebody ever changes wall time backwards (by mistake for example), tty timestamps are never updated until the original wall time passes. So check the absolute difference of times and if it large than "8 seconds or so", always update the time. That means we will update immediatelly when changing time. Ergo, CAP_SYS_TIME can foul the check, but it was always that way. Thanks John for serving me this so nicely debugged. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: John Paul Perry <john_paul.perry@alcatel-lucent.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: serial: fix tty-device error handling at probeJohan Hovold
commit ca4383a3947a83286bc9b9c598a1f55e867871d7 upstream. Add missing error handling when registering the tty device at port probe. This avoids trying to remove an uninitialised character device when the port device is removed. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: serial: fix potential use-after-free after failed probeJohan Hovold
commit 07fdfc5e9f1c966be8722e8fa927e5ea140df5ce upstream. Fix return value in probe error path, which could end up returning success (0) on errors. This could in turn lead to use-after-free or double free (e.g. in port_remove) when the port device is removed. Fixes: c706ebdfc895 ("USB: usb-serial: call port_probe and port_remove at the right times") Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12TTY: fix tty_wait_until_sent on 64-bit machinesJohan Hovold
commit 79fbf4a550ed6a22e1ae1516113e6c7fa5d56a53 upstream. Fix overflow bug in tty_wait_until_sent on 64-bit machines, where an infinite timeout (0) would be passed to the underlying tty-driver's wait_until_sent-operation as a negative timeout (-1), causing it to return immediately. This manifests itself for example as tcdrain() returning immediately, drivers not honouring the drain flags when setting terminal attributes, or even dropped data on close as a requested infinite closing-wait timeout would be ignored. The first symptom was reported by Asier LLANO who noted that tcdrain() returned prematurely when using the ftdi_sio usb-serial driver. Fix this by passing 0 rather than MAX_SCHEDULE_TIMEOUT (LONG_MAX) to the underlying tty driver. Note that the serial-core wait_until_sent-implementation is not affected by this bug due to a lucky chance (comparison to an unsigned maximum timeout), and neither is the cyclades one that had an explicit check for negative timeouts, but all other tty drivers appear to be affected. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Reported-by: ZIV-Asier Llano Palacios <asier.llano@cgglobal.com> Signed-off-by: Johan Hovold <johan@kernel.org> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: serial: fix infinite wait_until_sent timeoutJohan Hovold
commit f528bf4f57e43d1af4b2a5c97f09e43e0338c105 upstream. Make sure to handle an infinite timeout (0). Note that wait_until_sent is currently never called with a 0-timeout argument due to a bug in tty_wait_until_sent. Fixes: dcf010503966 ("USB: serial: add generic wait_until_sent implementation") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12xhci: fix reporting of 0-sized URBs in control endpointAleksander Morgado
commit 45ba2154d12fc43b70312198ec47085f10be801a upstream. When a control transfer has a short data stage, the xHCI controller generates two transfer events: a COMP_SHORT_TX event that specifies the untransferred amount, and a COMP_SUCCESS event. But when the data stage is not short, only the COMP_SUCCESS event occurs. Therefore, xhci-hcd must set urb->actual_length to urb->transfer_buffer_length while processing the COMP_SUCCESS event, unless urb->actual_length was set already by a previous COMP_SHORT_TX event. The driver checks this by seeing whether urb->actual_length == 0, but this alone is the wrong test, as it is entirely possible for a short transfer to have an urb->actual_length = 0. This patch changes the xhci driver to rely on a new td->urb_length_set flag, which is set to true when a COMP_SHORT_TX event is received and the URB length updated at that stage. This fixes a bug which affected the HSO plugin, which relies on URBs with urb->actual_length == 0 to halt re-submitting the RX URB in the control endpoint. Signed-off-by: Aleksander Morgado <aleksander@aleksander.es> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12xhci: Allocate correct amount of scratchpad buffersMathias Nyman
commit 6596a926b0b6c80b730a1dd2fa91908e0a539c37 upstream. Include the high order bit fields for Max scratchpad buffers when calculating how many scratchpad buffers are needed. I'm suprised this hasn't caused more issues, we never allocated more than 32 buffers even if xhci needed more. Either we got lucky and xhci never really used past that area, or then we got enough zeroed dma memory anyway. Should be backported as far back as possible Reported-by: Tim Chen <tim.c.chen@linux.intel.com> Tested-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12usb: dwc3: dwc3-omap: Fix disable IRQGeorge Cherian
commit 96e5d31244c5542f5b2ea81d76f14ba4b8a7d440 upstream. In the wrapper the IRQ disable should be done by writing 1's to the IRQ*_CLR register. Existing code is broken because it instead writes zeros to IRQ*_SET register. Fix this by adding functions dwc3_omap_write_irqmisc_clr() and dwc3_omap_write_irq0_clr() which do the right thing. Fixes: 72246da40f37 ("usb: Introduce DesignWare USB3 DRD Driver") Signed-off-by: George Cherian <george.cherian@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12usb: ftdi_sio: Add jtag quirk support for Cyber Cortex AV boardsMax Mansfield
commit c7d373c3f0da2b2b78c4b1ce5ae41485b3ef848c upstream. This patch integrates Cyber Cortex AV boards with the existing ftdi_jtag_quirk in order to use serial port 0 with JTAG which is required by the manufacturers' software. Steps: 2 [ftdi_sio_ids.h] 1. Defined the device PID [ftdi_sio.c] 2. Added a macro declaration to the ids array, in order to enable the jtag quirk for the device. Signed-off-by: Max Mansfield <max.m.mansfield@gmail.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: ftdi_sio: add PIDs for Actisense USB devicesMark Glover
commit f6950344d3cf4a1e231b5828b50c4ac168db3886 upstream. These product identifiers (PID) all deal with marine NMEA format data used on motor boats and yachts. We supply the programmed devices to Chetco, for use inside their equipment. The PIDs are a direct copy of our Windows device drivers (FTDI drivers with altered PIDs). Signed-off-by: Mark Glover <mark@actisense.com> [johan: edit commit message slightly ] Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: usbfs: don't leak kernel data in siginfoAlan Stern
commit f0c2b68198589249afd2b1f2c4e8de8c03e19c16 upstream. When a signal is delivered, the information in the siginfo structure is copied to userspace. Good security practice dicatates that the unused fields in this structure should be initialized to 0 so that random kernel stack data isn't exposed to the user. This patch adds such an initialization to the two places where usbfs raises signals. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Dave Mielke <dave@mielke.cc> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12USB: serial: cp210x: Adding Seletek device id'sMichiel vd Garde
commit 675af70856d7cc026be8b6ea7a8b9db10b8b38a1 upstream. These device ID's are not associated with the cp210x module currently, but should be. This patch allows the devices to operate upon connecting them to the usb bus as intended. Signed-off-by: Michiel van de Garde <mgparser@gmail.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mei: make device disabled on stop unconditionallyAlexander Usyskin
commit 6c15a8516b8118eb19a59fd0bd22df41b9101c32 upstream. Set the internal device state to to disabled after hardware reset in stop flow. This will cover cases when driver was not brought to disabled state because of an error and in stop flow we wish not to retry the reset. Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12iio: ad5686: fix optional reference voltage declarationUrs Fässler
commit da019f59cb16570e78feaf10380ac65a3a06861e upstream. When not using the "_optional" function, a dummy regulator is returned and the driver fails to initialize. Signed-off-by: Urs Fässler <urs.fassler@bytesatwork.ch> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12iio: imu: adis16400: Fix sign extensionRasmus Villemoes
commit 19e353f2b344ad86cea6ebbc0002e5f903480a90 upstream. The intention is obviously to sign-extend a 12 bit quantity. But because of C's promotion rules, the assignment is equivalent to "val16 &= 0xfff;". Use the proper API for this. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12target: Check for LBA + sectors wrap-around in sbc_parse_cdbNicholas Bellinger
commit aa179935edea9a64dec4b757090c8106a3907ffa upstream. This patch adds a check to sbc_parse_cdb() in order to detect when an LBA + sector vs. end-of-device calculation wraps when the LBA is sufficently large enough (eg: 0xFFFFFFFFFFFFFFFF). Cc: Martin Petersen <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12target: Add missing WRITE_SAME end-of-device sanity checkNicholas Bellinger
commit 8e575c50a171f2579e367a7f778f86477dfdaf49 upstream. This patch adds a check to sbc_setup_write_same() to verify the incoming WRITE_SAME LBA + number of blocks does not exceed past the end-of-device. Also check for potential LBA wrap-around as well. Reported-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Martin Petersen <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
