path: root/drivers
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-28sis900: come alive after temporary memory shortageVasily Averin
1) Forgotten counter incrementation in sis900_rx() in case it doesn't get memory for skb, that leads to whole interface failure. Problem is accompanied with messages: eth0: Memory squeeze,deferring packet. eth0: NULL pointer encountered in Rx ring, skipping 2) If counter cur_rx overflows and there'll be temporary memory problems buffer can't be recreated later, when memory IS available. 3) Limit the work in handler to prevent the endless packets processing if new packets are generated faster then handled. Signed-off-by: Konstantin Khorenko <khorenko@sw.ru> Signed-off-by: Vasily Averin <vvs@sw.ru> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[git] change permissions on drivers/net/amd8111e.[ch] to 0644,Jeff Garzik
removing executable bits.
2005-10-28[PATCH] New PowerPC 4xx on-chip ethernet controller driverEugene Surovegin
This patch replaces current PowerPC 4xx EMAC driver with new, re-written from the scratch version. This patch is quite big (~234K) because there is virtualy 0% of common code between old and new version. New driver uses NAPI, it solves stability problems under heavy packet load and low memory, corrects chip register access and fixes numerous small bugs I don't even remember now. This patch has been tested on all supported in 2.6 PPC 4xx boards. It's been used in production for almost a year now on custom 4xx hardware. PPC32 specific parts are already upstream. Patch was acked by the current EMAC driver maintainer (Matt Porter). I will be maintaining this new version. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> -- Kconfig | 72 ibm_emac/Makefile | 13 ibm_emac/ibm_emac.h | 418 +++-- ibm_emac/ibm_emac_core.c | 3414 ++++++++++++++++++++++++---------------------- ibm_emac/ibm_emac_core.h | 313 ++-- ibm_emac/ibm_emac_debug.c | 377 ++--- ibm_emac/ibm_emac_debug.h | 63 ibm_emac/ibm_emac_mal.c | 674 +++++---- ibm_emac/ibm_emac_mal.h | 336 +++- ibm_emac/ibm_emac_phy.c | 335 ++-- ibm_emac/ibm_emac_phy.h | 105 - ibm_emac/ibm_emac_rgmii.c | 201 ++ ibm_emac/ibm_emac_rgmii.h | 68 ibm_emac/ibm_emac_tah.c | 111 + ibm_emac/ibm_emac_tah.h | 96 - ibm_emac/ibm_emac_zmii.c | 255 +++ ibm_emac/ibm_emac_zmii.h | 114 - 17 files changed, 4114 insertions(+), 2851 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] sundance: fix DFE-580TX Tx UnderrunPhilippe De Muyter
Under heavy PCI bus load, ports of the DFE-580TX 4-ethernet port board stop working, with currently no other cure than a powercycle. Here is a tested fix. By the way, I also fixed some references and attribution. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[netdrvr b44] include linux/dma-mapping.h to eliminate warningAndrew Morton
2005-10-28Add fs_enet ethernet network driver, for several embedded platforms.Pantelis Antoniou
2005-10-28[PATCH] starfire: free_irq() on error path of netdev_open()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] Fix CS89x0 KConfig for IXDP2X01Deepak Saxena
IXDP2x01 systems can be built without PCI network cards, so we should not require NET_PCI to build CS89x0 on these systems. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] smc91x: shut down power after probingNicolas Pitre
If the interface is not used right away after being probed it wastes power needlessly. Noted by Holger Schurig. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] sis190.c: fix multicast MAC filterAurelien Jarno
Here is a patch that changes the way the MAC filter is computed for the multicast addresses. The computation is taken from the SiS GPL driver. This patch is necessary to get IPv6 working. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] b44 reports wrong advertised flagsMatthew Wilcox
Looks like someone used the MII constants instead of the ethtool constants. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] s2io: kconfig help fixAkinobu Mita
The documentation about s2io is available at Documentation/networking/s2io.txt. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[wireless prism54] Fix frame lengthRoger While
prism54 is leaking information when passing transmits to the firmware. There is no requirement to adjust the length to >= ETH_ZLEN. Just pass the skb length (after possible adjustment). Signed-off-by: Roger While <simrw@sim-basis.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28pcnet_cs: fix mii init code for older DL10019 based cardsKomuro
Some older DL10019 based cards need to setup the auto-negotiation-advertisement register to advertise 100Full,100Half,10Full and 10Half. Signed-off-by: <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] ibmveth fix failed addbufSantiago Leon
This patch fixes a bug that happens when the hypervisor can't add a buffer. The old code wrote IBM_VETH_INVALID_MAP into the free_map array, so next time the index was used, a ibmveth_assert() caught it and called BUG(). The patch writes the right value into the free_map array so that the index can be reused. Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] ibmveth lockless TXSantiago Leon
This patch adds the lockless TX feature to the ibmveth driver. The hypervisor has its own locking so the only change that is necessary is to protect the statistics counters. Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] ibmveth fix buffer replenishingSantiago Leon
This patch removes the allocation of RX skb's buffers from a workqueue to be called directly at RX processing time. This change was suggested by Dave Miller when the driver was starving the RX buffers and deadlocking under heavy traffic: > Allocating RX SKBs via tasklet is, IMHO, the worst way to > do it. It is no surprise that there are starvation cases. > > If tasklets or work queues get delayed in any way, you lose, > and it's very easy for a card to catch up with the driver RX'ing > packets very fast, no matter how aggressive you make the > replenishing. By the time you detect that you need to be > "more aggressive" it is already too late. > The only pseudo-reliable way is to allocate at RX processing time. > Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] ibmveth fix buffer pool managementSantiago Leon
This patch changes the way the ibmveth driver handles the receive buffers. The old code mallocs and maps all the buffers in the pools regardless of MTU size and it also limits the number of buffer pools to three. This patch makes the driver malloc and map the buffers necessary to support the current MTU. It also changes the hardcoded names of the buffer pool number, size, and elements to arrays to make it easier to change (with the hope of making them runtime parameters in the future). Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] ibmveth fix bondingSantiago Leon
This patch updates dev->trans_start and dev->last_rx so that the ibmveth driver can be used with the ARP monitor in the bonding driver. Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] tg3: update version and minor fixesMichael Chan
Update version and reldate and add more sanity checking to tg3_set_settings(). Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] tg3: fix ASF heartbeatMichael Chan
Change the ASF heart beat to 5 seconds for faster detection of system crash. The driver sends the heartbeat every 2 seconds and the ASF firmware will timeout and reset the device if no heartbeat is received after 5 seconds. The old scheme of 2 minutes is ineffective. tg3_write_mem_fast() is added to speed up the IO to send the heartbeat. When no workaround is needed, it will use direct MMIO to memory space to write to memory. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] tg3: add 5714/5715 supportMichael Chan
Add complete support for 5714/5715. These chips are very similar to 5780 so the changes are very trivial. A TG3_FLG2_5780_CLASS flag is added to identify these chips. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28Merge branch 'upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-10-28Merge branch 'elevator-switch' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual fixup for trivial "gfp_t" changes.
2005-10-28Merge branch 'generic-dispatch' of ↵Linus Torvalds
2005-10-28Merge branch 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
2005-10-28[PATCH] gfp_t: remaining bits of drivers/*Al Viro
2005-10-28[PATCH] gfp_t: drivers/netAl Viro
2005-10-28[PATCH] gfp_t: drivers/infinibandAl Viro
2005-10-28[PATCH] gfp_t: drivers/scsiAl Viro
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-10-28[PATCH] gfp_t: dma-mapping (parisc)Al Viro
2005-10-28[PATCH] gfp_t: block layer coreAl Viro
2005-10-28[BLOCK] Leftover reference to ->max_back_kbJens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[BLOCK] elevator switch fixes/cleanupJens Axboe
- 100msec sleep is a little excessive, lots of requests can complete in that timeframe. Use 10msec instead. - Rename QUEUE_FLAG_BYPASS to QUEUE_FLAG_ELVSWITCH to indicate what is going on. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[BLOCK] Reimplement elevator switchTejun Heo
This patch reimplements elevator switch. This patch assumes generic dispatch queue patchset is applied. * Each request is tagged with REQ_ELVPRIV flag if it has its elevator private data set. * Requests which doesn't have REQ_ELVPRIV flag set never enter iosched. They are always directly back inserted to dispatch queue. Of course, elevator_put_req_fn is called only for requests which have its REQ_ELVPRIV set. * Request queue maintains the current number of requests which have its elevator data set (elevator_set_req_fn called) in q->rq->elvpriv. * If a request queue has QUEUE_FLAG_BYPASS set, elevator private data is not allocated for new requests. To switch to another iosched, we set QUEUE_FLAG_BYPASS and wait until elvpriv goes to zero; then, we attach the new iosched and clears QUEUE_FLAG_BYPASS. New implementation is much simpler and main code paths are less cluttered, IMHO. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[BLOCK] kill generic max_back_kb handlingTejun Heo
This patch kills max_back_kb handling from elv_dispatch_sort() and kills max_back_kb field from struct request_queue. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] 04/05 remove last_merge handling from ioschedsTejun Heo
Remove last_merge handling from all ioscheds. This patch removes merging capability of noop iosched. Signed-off-by: Tejun Heo <htejun@gmail.com>
2005-10-28[PATCH] 03/05 move last_merge handlin into generic elevator codeTejun Heo
Currently, both generic elevator code and specific ioscheds participate in the management and usage of last_merge. This and the following patches move last_merge handling into generic elevator code. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] 02/05: update ioscheds to use generic dispatch queueJens Axboe
This patch updates all four ioscheds to use generic dispatch queue. There's one behavior change in as-iosched. * In as-iosched, when force dispatching (ELEVATOR_INSERT_BACK), batch_data_dir is reset to REQ_SYNC and changed_batch and new_batch are cleared to zero. This prevernts AS from doing incorrect update_write_batch after the forced dispatched requests are finished. * In cfq-iosched, cfqd->rq_in_driver currently counts the number of activated (removed) requests to determine whether queue-kicking is needed and cfq_max_depth has been reached. With generic dispatch queue, I think counting the number of dispatched requests would be more appropriate. * cfq_max_depth can be lowered to 1 again. Original from Tejun Heo, modified version applied. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] elevator: leftover function declarationJens Axboe
2005-10-28[PATCH] generic dispatch fixesJens Axboe
- Split elv_dispatch_insert() into two functions - Rename rq_last_sector() to rq_end_sector() Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] 01/05 Implement generic dispatch queueTejun Heo
Implements generic dispatch queue which can replace all dispatch queues implemented by each iosched. This reduces code duplication, eases enforcing semantics over dispatch queue, and simplifies specific ioscheds. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[PATCH] fix try_module_get race in elevator_findTejun Heo
This patch removes try_module_get race in elevator_find. try_module_get should always be called with the spinlock protecting what the module init/cleanup routines register/unregister to held. In the case of elevators, we should be holding elv_list to avoid it going away between spin_unlock_irq and try_module_get. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28Following the same idea, it occurs to me that we should only updateChen, Kenneth W
disk stat when "now" is different from disk->stamp. Otherwise, we are again needlessly adding zero to the stats. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28[patch] remove gendisk->stamp_idle fieldChen, Kenneth W
struct gendisk has these two fields: stamp, stamp_idle. Update to stamp_idle is always in sync with stamp and they are always the same. Therefore, it does not add any value in having two fields tracking same timestamp. Suggest to remove it. Also, we should only update gendisk stats with non-zero value. Advantage is that we don't have to needlessly calculate memory address, and then add zero to the content. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-27Merge branch 'master'Jeff Garzik
