Sync up to bring in wacom_w8001 changes to avoid merge conflicts later.
Add support for axis inversion / swapping using the new
touchscreen_parse_properties() and touchscreen_set_mt_pos()
functionality.
Use the touchscreen_parse_properties() and touchscreen_report_pos() to
perform coordinates transformation, instead of DIY code, which results in a
nice cleanup.
Add support for inverting / swapping axes using the new
functionality.
Extend touchscreen_parse_properties() with support for the
touchscreen-inverted-x/y and touchscreen-swapped-x-y properties and
add touchscreen_set_mt_pos() and touchscreen_report_pos() helper
functions for storing coordinates into a input_mt_pos struct, or
directly reporting them, taking these properties into account.
This commit also modifies the existing callers of
touchscreen_parse_properties() to pass in NULL for the new third
argument, keeping the existing behavior.
of_node_put needs to be called when the device node which is got
from of_parse_phandle has finished using.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
rmi_f11_rel_pos_report
The size of relative data in F11 is already defined by RMI_F11_REL_BYTES.
Use the define in rmi_f11_rel_pos_report() to be consistent.
Signed-off-by: Andrew Duggan <aduggan@synaptics.com>
Reviewed-by: Nick Dyer <nick@shmanahar.org>
Remove the data_base_addr_offset variable in rmi_f11_attention(). The
f11 data is read as a single block so there is no need to store an offset
to the data address.
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
The pointer to struct rmi_function in f12_data is never set and was never
used. The fn pointer is also stored in rmi_2d_sensor which is a member of
f12_data.
Calling of_find_node_by_name() assumes that the caller has incremented
the refcount of the of_node being passed in. Currently, the caller is
not incrementing the refcount of the of_node which results in the node
being prematurely freed when of_find_node_by_name() calls of_node_put()
on it. Instead use of_get_child_by_name() which does not call put on the
of_node.
This reverts commit 5f7e5445a2de848c66d2d80ba5479197e8287c33 because
removal of input_mt_report_slot_state() means we no longer generate
tracking IDs for the reported contacts.
Cc: stable@vger.kernel.org
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
Acked-by: Ping Cheng <pinglinux@gmail.com>
Support the two supplies - vdd and vio - to make it possible to control
power to the Synaptics chip.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Rob Herring <robh@kernel.org>
Reviewed-by: Andrew Duggan <aduggan@synaptics.com>
Check CRC of incoming touch packets to ensure that we do not operate on
corrupted data.
Signed-off-by: Jeffrey Lin <jeffrey.lin@rad-ic.com>
... as being the simpler variant.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
This prevents a malicious USB device from causing an oops.
Signed-off-by: Cameron Gutman <aicommander@gmail.com>
The VMWare EFI BIOS will expose port 0x5658 as an ACPI resource. This
causes the port to be reserved by the APCI module as the system comes up,
making it unavailable to be reserved again by other drivers, thus
preserving this VMWare port for special use in a VMWare guest.
This port is designed to be shared among multiple VMWare services, such as
the VMMOUSE. Because of this, VMMOUSE should not try to reserve this port
on its own.
The VMWare non-EFI BIOS does not do this to preserve compatibility with
existing/legacy VMs. It is known that there is small chance a VM may be
configured such that these ports get reserved by other non-VMWare devices,
and if this ever happens, the result is undefined.
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
Cc: <stable@vger.kernel.org> # 4.1-
This driver provides a input driver for the power button on the
HiSi 65xx SoC for boards like HiKey.
This driver was originally by Zhiliang Xue <xuezhiliang@huawei.com>
then basically rewritten by Jorge, but preserving the original
module author credits.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
[jstultz: Reworked commit message, folded in other fixes/cleanups
from Jorge, implemented some larger cleanups suggested by DmitryT]
Signed-off-by: John Stultz <john.stultz@linaro.org>
The touchpad in HP Pavilion 14-ab057ca reports it's version as 12 and
according to Elan both 11 and 12 are valid IC types and should be
identified as hw_version 4.
Reported-by: Patrick Lessard <Patrick.Lessard@cogeco.com>
Tested-by: Patrick Lessard <Patrick.Lessard@cogeco.com>
ThinkPad X60 Tablet PC (pen only device) sometime posts
packets that are larger than W8001_PKTLEN_TPCPEN.
Reported-by: Chris J Arges <christopherarges@gmail.com>
Tested-by: Chris J Arges <christopherarges@gmail.com>
Signed-off-by: Ping Cheng <pingc@wacom.com>
Reviewed-by: Peter Hutterer <peter.hutterer@who-t.net>
Somehow the patch that added two-finger touch support forgot to update
W8001_MAX_LENGTH from 11 to 13.
trivial fix to spelling mistake in pr_notice message
trivial fix to spelling mistake in dev_warn message
trivial fix to spelling mistake in dev_err message
Acked-by: Thierry Reding <treding@nvidia.com>
Trivial fix to spelling mistake
Xbox One controllers have multiple interfaces which all have the
same class, subclass, and protocol. One of the these interfaces
has only a single endpoint. When Xpad attempts to bind to this
interface, it causes an oops when trying initialize the output URB
by trying to access the second endpoint's descriptor.
This situation was avoided for known Xbox One devices by checking
the XTYPE constant associated with the VID and PID tuple. However,
this breaks when new or previously unknown Xbox One controllers
are attached to the system.
This change addresses the problem by deriving the XTYPE for Xbox
One controllers based on the interface protocol before checking
the interface number.
Fixes: 1a48ff81b391 ("Input: xpad - add support for Xbox One controllers")
This patch changes name of secondary psmouse devices to mach format of
primary device. Format of primary device is "protocol vendor name" and is
set by function psmouse_switch_protocol() in file psmouse-base.c.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Let's bring in HDMI CEC defines to ease merging CEC support in the next
merge window.
This adds a driver for the Pegasus Notetaker Pen. When connected,
this uses the Pen as an input tablet.
This device was sold in various different brandings, for example
"Pegasus Mobile Notetaker M210",
"Genie e-note The Notetaker",
"Staedtler Digital ballpoint pen 990 01",
"IRISnotes Express" or
"NEWLink Digital Note Taker".
Here's an example, so that you know what we are talking about:
http://www.genie-online.de/genie-e-note-2/
https://pegatech.blogspot.com/ seems to be a remaining official resource.
This device can also transfer saved (offline recorded handwritten) data and
there are userspace programs that do this, see https://launchpad.net/m210
(Well, alternatively there are really fast scanners out there :)
It's *really* fun to use as an input tablet though! So let's support this
for everybody.
Signed-off-by: Martin Kepplinger <martink@posteo.de>
Xbox One controllers that shipped with or were upgraded to the 2015
firmware discard the current rumble packets we send. This patch changes
the Xbox One rumble packet to a form that both the newer and older
firmware will accept.
It is based on changes made to support newer Xbox One controllers in
the SteamOS brewmaster-4.1 kernel branch.
Fix the code formatting to use the kernel preferred style
of using the actual variables to determize the size using
the sizeof() operator.
Signed-off-by: Andrew F. Davis <afd@ti.com>
For devices that are incapable of reporting per-contact distance and can
only report ABS_DISTANCE, just distance is not enough for upper layers of
OS to determine whether contact is leaving the area or if it is continuing
hovering, we need BTN_TOOL_FINGER for that:
Contact State
Inactive Hovering Active
(far away) (inside hover area) (touching surface)
BTN_TOUCH 0 0 1
BTN_TOOL_FINGER 0 1 1
ABS_DISTANCE N/A 1 0
Signed-off-by: KT Liao <kt.liao@emc.com.tw>
We should not be ignoring -EPROBE_DEFER reported by
devm_gpiod_get_optional(), but report it as any other error to the upper
layers. While we are at it simplify check for the presence of reset GPIO
and instead of using IS_ERR_OR_NULL just use boolean.
Also do not return -ENOMEM from suspend handler when the device in
bootloader mode as that does not make sense and switch to -EBUSY instead.
Reported-by: Guenter Roeck <groeck@chromium.org>
Reviewed-by: Guenter Roeck <groeck@chromium.org>
This adds support for Raydium I2C touch controllers compatible with
RM32380.
Pwm config may sleep so defer it using a worker.
On a Freescale i.MX53 based board we ran into "BUG: scheduling while
atomic" because input_inject_event locks interrupts, but
imx_pwm_config_v2 sleeps.
Tested on Freescale i.MX53 SoC with 4.6.0.
Signed-off-by: Manfred Schlaegl <manfred.schlaegl@gmx.at>
This change creates a second input device which will handle input from
a Surface Pen. The Surface Pen supplies a different packet header than
touch events, so it is simple to handle one or the other.
This patch handles both the newer Surface Pen with one button, and the
older variant with a second button to switch to Eraser mode.
Signed-off-by: Stephen Just <stephenjust@gmail.com>
Reviewed-and-tested-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Surface Pens can be supported by handling a second report type. Prepare
for this change.
added the according id and incresed XPAD_PKT_LEN to 64 as the elite
controller sends at least 33 byte messages [1].
Verified to be working by [2].
[1]: https://franticrain.github.io/sniffs/XboxOneSniff.html
[2]: https://github.com/paroj/xpad/issues/23
Signed-off-by: Pierre-Loup A. Griffais <eduke32@plagman.net>
Signed-off-by: Pavel Rojtberg <rojtberg@gmail.com>
Signed-off-by: Thomas Debesse <dev@illwieckz.net>
Signed-off-by: aronschatz <aronschatz@aselabs.com>
After initially connecting a wired Xbox 360 controller or sending it
a command to change LEDs, a status/response packet is interpreted as
controller input. This causes the state of buttons represented in
byte 2 of the controller data packet to be incorrect until the next
valid input packet. Wireless Xbox 360 controllers are not affected.
Writing a new value to the LED device while holding the Start button
and running jstest is sufficient to reproduce this bug. An event will
come through with the Start button released.
Xboxdrv also won't attempt to read controller input from a packet
where byte 0 is non-zero. It also checks that byte 1 is 0x14, but
that value differs between wired and wireless controllers and this
code is shared by both. I think just checking byte 0 is enough to
eliminate unwanted packets.
The following are some examples of 3-byte status packets I saw:
01 03 02
02 03 00
03 03 03
08 03 00
otherwise we lose ff commands: https://github.com/paroj/xpad/issues/27
The end ')' needs to be removed if the macro is ever used or there
would be a compiler error as it does not have a matching '('.
Signed-off-by: Clifton Barnes <clifton.a.barnes@gmail.com>
When running a 32-bit userspace on a 64-bit kernel, the UI_SET_PHYS
ioctl needs to be treated with special care, as it has the pointer
size encoded in the command.
Signed-off-by: Ricky Liang <jcliang@chromium.org>
This is a basic driver for the Surface 3. I am not so sure it will work
with any firmwares as most values are encoded, but given that I only have
access to my current device with its firmware and I don't have the
datasheet, it should be OK for now.
The Surface Pen is not supported (if it is supposed to be). I'll work on
this when I get one.
Tested-by: Bastien Nocera <hadess@hadess.net>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Commit 4369c64c79a22 ("Input: Send events one packet at a time")
significantly reduced amount of entropy input core was feeding to the rest
of the system, because only the very first event in the event block would
be used as source of entropy.
With this change we will be calling add_input_randomness() for every event
that is not filtered by the input core as a duplicate. In addition, all
EV_SYN events are ignored.
Acked-by: Henrik Rydberg <rydberg@bitmath.org>
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk>
The migor touchscreen driver is now available for COMPILE_TEST,
so we run into a harmless randconfig warning on ARM when CONFIG_PM
is disabled:
drivers/input/touchscreen/migor_ts.c:216:12: error: 'migor_ts_resume' defined but not used [-Werror=unused-function]
drivers/input/touchscreen/migor_ts.c:205:12: error: 'migor_ts_suspend' defined but not used [-Werror=unused-function]
This shuts up the warning by marking the two functions as __maybe_unused.
We could do the same thing by adding an #ifdef, but this version is
more reliable.
The newly added Atmal captouch driver fails to build when CONFIG_I2C
is disabled:
drivers/input/misc/atmel_captouch.c: In function 'atmel_read':
drivers/input/misc/atmel_captouch.c:115:8: error: implicit declaration of function 'i2c_transfer' [-Werror=implicit-function-declaration]
This adds an explicit Kconfig dependency to prevent the broken
configuration.
Fixes: b06d43f7a3db ("Input: add Atmel Captouch Button driver")
Add I2C driver for Atmel Capacitive Touch Button device.
Signed-off-by: Hung-yu Wu <hywu@google.com>
Signed-off-by: Grant Grundler <grundler@chromium.org>
The driver only has runtime but no build time dependency with SH_MIGOR, so
it can be built for testing purposes if the COMPILE_TEST option is enabled.
This is useful to have more build coverage and make sure that drivers are
not affected by changes that could cause build regressions.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
There is a typo in the driver for the I2C device table that is passed to
the MODULE_DEVICE_TABLE() macro, this leads to the following build error:
CC [M] drivers/input/touchscreen//migor_ts.o
drivers/input/touchscreen//migor_ts.c:233:21: error: 'migor_ts' undeclared here (not in a function)
MODULE_DEVICE_TABLE(i2c, migor_ts);
drivers/input/touchscreen//migor_ts.c:233:31: error: '__mod_i2c__migor_ts_device_table' aliased to undefined symbol 'migor_ts'
scripts/Makefile.build:295: recipe for target 'drivers/input/touchscreen//migor_ts.o' failed
make[1]: *** [drivers/input/touchscreen//migor_ts.o] Error 1
Makefile:1446: recipe for target '_module_drivers/input/touchscreen/' failed
make: *** [_module_drivers/input/touchscreen/] Error 2
