The port shouldn't be enabled unless its current MUX
state is DISTRIBUTING which is correctly handled by
ad_mux_machine(), otherwise the packet sent can be
lost because the other end may not be ready.
The issue happens on every port initialization, but
as the ports are expected to move quickly to DISTRIBUTING,
it doesn't cause much problem. However, it does cause
constant packet loss if the other peer has the port
configured to stay in STANDBY (i.e. SYNC set to OFF).
Signed-off-by: Flavio Leitner <fbl@redhat.com>
The Vitesse driver was using the RGMII_ID interface type to determine if
skew was necessary. However, we want to move away from using that
interface type, as it's really a property of the board's PHY connection.
However, some boards depend on it, so we want to support it, while
allowing new boards to use the more flexible "fixups" approach. To do
this, we extract the code which adds skew into its own function, and
call that function when RGMII_ID has been selected.
Another side-effect of this change is that if your PHY has skew set
already, it doesn't clear it. This way, the fixup code can modify the
register without config_init then clearing it.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Driver version updated to 1.5.4.2
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
Moving to Toeplitz function in RSS calculation.
Reporting rxhash in skb.
Not updating common counters from data path.
The checksum counters are per ring, summarizing them when collecting statistics.
Canceling FCS removal where FW allows for better alignment
of incoming data.
Prevent overflow when trying to register more Vlans then the Vlan table in
HW is configured to.
Need to take into acount that the first 2 entries are reserved.
Added recovery check of CA wake status in case of wake up timeout.
Added check of CA wake status in case of wake down timeout.
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Added sanity check for length of CAIF frames, and tear down of
CAIF link-layer device upon protocol error.
CAIF HSI uses a timer for inactivity. Upon timeout HSI-wake signaling
is initiated to allow power-down of the HSI block.
Platform device is no longer removed from caif_hsi at shutdown.
The HSI-platform device must do it's own registration and unregistration.
Some platforms do not allow to put HSI block into low-power
mode when FIFO is not empty. The patch flushes (by reading)
FIFO at wake down sequence. Asynchronous read and write is
implemented for that. As a side effect this will also greatly
improve performance.
Under stressed conditions a race could happen when del_timer_sync() was called
from softirq context at the same time when mod_timer_pending() for the same
timer was called from the workqueue. This leaded to a state mismatch in the
CAIF HSI driver and following unexpected link wakeup procedure.
The fix puts del_timer_sync() and mod_timer_pending() calls under a spin lock
to protect against the race condition.
cfhsi->tx_state was not protected by a spin lock. TX soft-irq could interrupt
cfhsi_tx_done_work work leading to inconsistent state of the driver.
CAIF HSI header may be uninitialized and cause last message to
be repeated if transmit size is ~86 bytes long.
To ease skb->truesize sanitization, its better to be able to localize
all references to skb frags size.
Define accessors : skb_frag_size() to fetch frag size, and
skb_frag_size_{set|add|sub}() to manipulate it.
The extra delay of 2ns to adjust RX clock phase is actually needed
in RGMII mode. Tested on the HDK7108 (STx7108c2).
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
The cs89x0 driver was initial placed in the apple/ when it
should have been placed in the cirrus/. This resolves the
issue by moving the dirver and fixing up the respective
Kconfig(s) and Makefile(s).
Thanks to Sascha for reporting the issue.
-v2 Fix a config error that was introduced with v1 by removing
the dependency on MACE for NET_VENDOR_APPLE.
CC: Russell Nelson <nelson@crynwr.com>
CC: Andrew Morton <akpm@linux-foundation.org>
Reported-by: Sascha Hauer <s.hauer@pengutronix.de>
Fragmented multicast frames are delivered to a single macvlan port,
because ip defrag logic considers other samples are redundant.
Implement a defrag step before trying to send the multicast frame.
Reported-by: Ben Greear <greearb@candelatech.com>
Use 32bit value starting at offset 0x2d for displaying the firmware
version in ethtool. This should work for all current ixgbe HW
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Tested-by: Stephen Ko <stephen.s.ko@intel.com>
The BerliOS project, which currently hosts our mailinglist, will
close with the end of the year. Now take the chance and remove all
occurrences of the mailinglist address from the source files.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
The tcp_end field is not actually used by the hardware, so there
is no need to set it.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Add GRO support to the ehea driver.
v3:
[cascardo] no need to enable GRO, since it's enabled by default
[cascardo] vgrp was removed in the vlan cleanup
In preparation for adding GRO to ehea, remove LRO.
v3:
[cascardo] fixed conflict with vlan cleanup
Switch to using ndo_get_stats64 to get 64bit statistics.
v3:
[cascardo] use rtnl_link_stats64 as port stats
The queue macros are many levels deep and it makes it harder to
work your way through them when many of the versions are unused.
Remove the unused versions.
If a nonlinear skb fits within the immediate area, use skb_copy_bits
instead of copying the frags by hand.
v3:
[cascardo] fixed conflict with use of skb frag API
write_swqe2_TSO and write_swqe2_nonTSO are almost identical.
For TSO we have to set the TSO and mss bits in the wqe and we only
put the header in the immediate area, no data. Collapse both
functions into write_swqe2_immediate.
Based on a patch from Michael Ellerman, clean up a significant
portion of the transmit path. There was a lot of duplication here.
Even worse, we were always checksumming tx packets and ignoring the
skb->ip_summed field.
Also remove NETIF_F_FRAGLIST from dev->features, I'm not sure why
it was enabled.
The ehea adapter has a mode where it will avoid partial cacheline DMA
writes on receive by always padding packets to fall on a cacheline
boundary.
Unfortunately we currently aren't allocating enough space for a full
ethernet MTU packet to be rounded up, so this optimisation doesn't hit.
It's unfortunate that the next largest packet size exposed by the
hypervisor interface is 2kB, meaning our skb allocation comes out of a
4kB SLAB. However the performance increase due to this optimisation is
quite large and my TCP stream numbers increase from 900MB to 1000MB/sec.
We weren't enabling any VLAN features so we missed out on checksum
offload and TSO when using VLANs. Enable them.
It seems like the ehea xmit routine and an ethtool change of TSO
mode could race, resulting in corrupt packets. Checking gso_size
is enough and we can use the helper function.
The num_tx_qps module option allows a user to configure a different
number of tx and rx queues. Now the networking stack is multiqueue
aware it makes little sense just to enable the tx queues and not the
rx queues so remove the option.
v3:
[cascardo] fixed conflict with get_stats change
commit 18604c548545 (ehea: NAPI multi queue TX/RX path for SMP) added
driver specific logic for exiting napi mode. I'm not sure what it was
trying to solve and it should be up to the network stack to decide when
we are done polling so remove it.
v3:
[cascardo] Fixed extra parentheses.
The ehea driver had some multiqueue support but was missing the last
few years of networking stack improvements:
- Use skb_record_rx_queue to record which queue an skb came in on.
- Remove the driver specific netif_queue lock and use the networking
stack transmit lock instead.
- Remove the driver specific transmit queue hashing and use
skb_get_queue_mapping instead.
- Use netif_tx_{start|stop|wake}_queue where appropriate. We can also
remove pr->queue_stopped and just check the queue status directly.
- Print all 16 queues in the ethtool stats.
We now enable multiqueue by default since it is a clear win on all my
testing so far.
v3:
[cascardo] fixed use_mcs parameter description
[cascardo] set ehea_ethtool_stats_keys as const
Remove the deprecated NETIF_F_LLTX feature. Since the network stack
now provides the locking we can remove the driver specific
pr->xmit_lock.
git://git.infradead.org/users/linville/wireless-next into for-davem
Implement support for ethtool -E
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
This patch makes sure that register writes are in little endian and
also converts the reads back to big-endian.
Kvm and the Xen pci-back driver will set a flag in the virtual function
pci device dev_flags when the VF is assigned to a guest VM. Before
destroying subordinate VFs check to see if the flag is set and if so
skip the call to pci_disable_sriov() to avoid system crashes.
Copy the maintainer for the Xen pci-back driver. Also CC'ing
maintainers of all drivers found to call pci_disable_sriov().
V2 - Fix uninitialized variable warning
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Christian Benvenuti <benve@cisco.com>
Cc: Sathya Perla <sathya.perla@emulex.com>
Cc: Dimitris Michailidis <dm@chelsio.com>
Cc: Jon Mason <jdmason@kudzu.us>
Cc: James Smart <james.smart@emulex.com>
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Changes to clean up the VLAN Rx path by Jiri Pirko broke trunk VLAN.
Trunk VLANs in a VF driver are those set using
"ip link set <pfdev> vf <n> <vlanid>"
CC: Jiri Pirko <jpirko@redhat.com>
Private rx_csum flags are now duplicate of netdev->features & NETIF_F_RXCSUM.
Removing this needs deeper surgery.
Things noticed:
- HW VLAN acceleration probably can be toggled, but it's left as is
- the resets on RX csum offload change can probably be avoided
- there is A LOT of copy-and-pasted code here
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
When enabling hardware timestamping for ptp v2 event packets, the
software does not setup the queue for l4 packets, although layer 4
packets are valid for v2. This patch adds the flag which enables
setting up a queue and enabling udp packet timestamping.
Signed-off-by: Jacob E Keller <jacob.e.keller@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Implements the new netdev op to allow user configuration of spoof
checking on a per VF basis.
V2 - Change netdev spoof check op setting to bool
Commit 67fd4fcb (e1000e: convert to stats64) added the ability to update
statistics more accurately and on-demand through the net_device_ops
.ndo_get_stats64 hook, but introduced a locking bug on 82577/8/9 when
linked at half-duplex (seen on kernels with CONFIG_DEBUG_ATOMIC_SLEEP=y and
CONFIG_PROVE_LOCKING=y). The commit introduced code paths that caused a
mutex to be locked in atomic contexts, e.g. an rcu_read_lock is held when
irqbalance reads the stats from /sys/class/net/ethX/statistics causing the
mutex to be locked to read the Phy half-duplex statistics registers.
The mutex was originally introduced to prevent concurrent accesses of
resources (the NVM and Phy) shared by the driver, firmware and hardware
a few years back when there was an issue with the NVM getting corrupted.
It was later split into two mutexes - one for the NVM and one for the Phy
when it was determined the NVM, unlike the Phy, should not be protected by
the software/firmware/hardware semaphore (arbitration of which is done in
part with the SWFLAG bit in the EXTCNF_CTRL register). This latter
semaphore should be sufficient to prevent resource contention of the Phy in
the driver (i.e. the mutex for Phy accesses is not needed), but to be sure
the mutex is replaced with an atomic bit flag which will warn if any
contention is possible.
Also add additional debug output to help determine when the sw/fw/hw
semaphore is owned by the firmware or hardware.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Reported-by: Francois Romieu <romieu@fr.zoreil.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
The recent changes to only power the device when the interface up
introduced a bug: changing interface type, legal when the interface
is down, performs device I/O.
Fix this functionality by validating and recording the interface
type when the change is requested, but only applying the change
if/when the interface is brought up.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Dan Williams <dcbw@redhat.com>
Renamed to be in sync with Marketing term and to avoid
confusion with other chip names.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
