path: root/drivers
2010-02-26V4L/DVB: gspca_pac7302: much improved exposure controlHans de Goede
My experience with fixing up the controls for the PAS sensors in sonixb, has lead me to re-investigate the exposure control for the pac7302. I've now found a regular exposure register in register bank 3 (which seems to be the sensor registers bank), and with this added a proper fine grained exposure control. This patch also updates the do_autogain function to work properly with this new finer grained control. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sonixb: Make sonixb driver handle pas106 and pas202 camerasHans de Goede
Make the sonixb driver handle pas106 and pas202 cameras, when both it and the sn9c102 driver are enabled in the kernel configuration. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sonixb: pas106: fixup bright ctrl and add gain and exposure ctrlsHans de Goede
Fixup brightness ctrl and add gain and exposure ctrls for PAS106B sensors, this allows enabling autogain (done), and makes the cam usable in low light conditions. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: Documentation: gspca.txt: update known mr97310a camsHans de Goede
2010-02-26V4L/DVB: gspca_mr97310a: add support for the Sakar 1638x CyberPixTheodore Kilgore
This camera has a sensor type we did not support sofar, this patch adds support for the new sensor type found in the Sakar 1638x CyberPix. Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gscpa_sonixb: limit ov7630 max framerate at 640x480Hans de Goede
In 640x480, if the reg11 has less than 4, the image is unstable (the bridge goes into a higher compression mode which we have not reverse engineered yet). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sonixb: pas202: fixup brightness ctrl and add gain and ↵Hans de Goede
exposure ctrls Fixup brightness ctrl and add gain and exposure ctrls for PAS202BCB sensors, this allows enabling autogain (done), and makes the cam usable in low light conditions. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gscpa_sonixb: Differentiate between sensors with a coarse and fine ↵Hans de Goede
expo ctrl Some sensors only allow controlling the exposure by changing the clockdiv, which means that exposure takes pretty large jumps (for example when going from a div of 1 to 2, the exposure doubles). Use 2 different entries in the controls array for these 2 different types of exposure (always disabling one), and; Add a new autogain algorithm for the coarse exposure case, which normally changes the gain setting, only touching the exposure setting if the desired luminance cannot be reached with gain, and after an exposure change once more first tries gain, etc. Thus avoiding exposure changes, and the resulting oscilation because of the huge steps these exposure controls take. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sonixb: leave bridge gain at 1.0 when we have a sensor gainHans de Goede
Leave bridge gain at 1.0 when we have a sensor gain, while at it also change the bridge gain setting code to write both registers in one go saving us a usb transaction. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sonixj: Add camera button supportHans de Goede
gspca_sonixj: Add camera button support Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sonixb: Add support for camera buttonHans de Goede
gspca_sonixb: Add support for camera button Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gscpa_zc3xx: Add support for camera buttonHans de Goede
gscpa_zc3xx: Add support for camera button Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gscpa_pac7311: Add support for camera buttonHans de Goede
gscpa_pac7311: Add support for camera button Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gscpa_pac207: Add support for camera buttonHans de Goede
gscpa_pac207: Add support for camera button Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_sq905c: Add an additional USB-IDHans de Goede
gspca_sq905c: Add an additional USB-ID Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca_mr97310a: Simplify sensor detectionTheodore Kilgore
Simplify sensor detection a bit (share more of the code between cif and vga cameras). Also remove an unnecessary write from zero_the_pointer(). Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: ivtv: Tweak Sony GigaPocket Kikyou card entry based on experimentsAndy Walls
Based on experiments by Eric Wescott, edit the Sony GigaPocket (Kikyou) card entry video and audio mux settings. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: ivtv: Add initial entry for Sony VAIO Giga Pocket (Kikyou) cardsEric Anderson
This is a slightly modified version of Eric Anderson's original patch for the Sony Giga Pocket board. It has been updated to apply to the latest ivtv driver version by Hans Verkuil <hverkuil@xs4all.nl> and Andy Walls <awalls@radix.net>. Also Andy Walls modified the patch to use a new Sony BTF-Pnx01Z tuner entry based on Eric Anderson's experimental findings for the bandswitch. >From Eric Anderson's original email: 1. The tuner on the card doesn't seem to match any standard ones. I modified an existing tuner entry. Ideally a new tuner entry should be created. (The only difference from the one I modified is that the low-to-mid range frequency cut-off is slightly different, as are the bit config settings.) 2. It wasn't obvious how to choose a second audio input other than using "radio" as an option. Basically there's two GPIO audio inputs. Using radio allowed me to avoid major restructuring to the code. (perhaps other cards don't have this often...) 3. It's not clear that there's a mute setting that works. Not sure why. 4. I haven't had a chance to test the two Svideo inputs. I set them to COMPOSITE1 and SVIDEO2, but I'm not sure those are the correct settings. The standard composite video inputs seem to work. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: tuner-types: Add Sony BTF-Pxn01Z tuner type used on GigaPocket cardsAndy Walls
Sony makes custome tuners for its GigaPocket line of ivtv based capture cards. This adds an entry to the tuner-types list for such tuners. Parameters are based on experiments by Eric Anderson <rico99@sbcglobal.net>. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: ivtv: Fix ivtv_api_get_data() to avoid unneeded IO during IRQ handlingAndy Walls
ivtv_api_get_data() was performing more PCI MMIO than needed, resulting often in it accounting for more than half the total time spent in ivtv_irq_handler(). Now it only reads at most 7 of the 16 mailbox data words over the PCI bus, and in some instances only 2 or 3 data words as needed. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: V4L - vpfe capture - build environment for isif driverMurali Karicheri
Adding Makefile and Kconfig for ISIF driver Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Murali Karicheri <mkaricheri@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: V4L - vpfe capture - vpss driver enhancements for DM365Murali Karicheri
Enhancements to support DM365 ISP5 and VPSS module configuration. Also cleaned up the driver by removing redundant variables. Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Murali Karicheri <mkaricheri@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: V4L - vpfe capture - source for ISIF driver on DM365Murali Karicheri
This is the source file for ISIF driver on DM365. ISIF driver is equivalent to CCDC driver on DM355 and DM644x. This driver is tested for YUV capture from TVP514x driver. This patch contains the header files required for this driver. Reviewed-by: Nori, Sekhar <nsekhar@ti.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Murali Karicheri <mkaricheri@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: V4L - vpfe capture - header files for ISIF driverMurali Karicheri
This is the header file for ISIF driver on DM365. ISIF driver is equivalent to CCDC driver on DM355 and DM644x. This driver is tested for YUV capture from TVP514x driver. This patch contains the header files required for this driver. Reviewed-by: Nori, Sekhar <nsekhar@ti.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Murali Karicheri <mkaricheri@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: pvrusb2: Adjust 300msec digitizer wait to be more selectiveMike Isely
We know that the 300msec settling time after starting the digitizer is only really needed when the digitizer is a SAA7115. So if we're not using a SAA7115, skip the delay. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: pvrusb2: Reduce encoder quiet periodMike Isely
After implementing a 300msec wait between digitizer start and encoder start, it has been determined that we don't need to wait quite as long before configuring the encoder. This reduces the wait period from 100msec back to 50msec. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: pvrusb2: Enforce a 300msec stabilization interval during stream strartMike Isely
Martin Dauskardt <martin.dauskardt@gmx.de> has determined that the encoder has a much better chance of starting cleanly if we deliberately hold off starting it util the video digitizer has had a chance to run for at least 300msec first. These changes implement an enforced 300msec wait in the state machine that orchestrates streaming start / stop. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: saa7115: fix saa7111a supportHans Verkuil
When the saa7111 driver was merged into saa7115 several bugs were introduced, in particular with the saa7111a support as is used in the mxb.c driver. This patch fixes the saa7111a support. This was tested with the mxb driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: saa7146_vv: fix regression where v4l2_device was registered too lateHans Verkuil
v4l2_device_register needs to be called before the i2c subdevs are loaded. However, it was called afterwards in the saa7146 driver. This caused an oops when loading the mxb and hexium drivers. The vv_init function is now split into two: one registers the v4l2_device, the other does the rest of the initialization. The three drivers that depend on this have been updated to call the new vv_devinit function. Thanks to Michael Hunold for reporting this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: uvcvideo: Check uvc_ctrl_begin return value in VIDIOC_S_CTRLLaurent Pinchart
The function return value wasn't checked due to a missing variable assignment. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: uvcvideo: Blacklist gain control for Asus EeePC T91 integrated webcamLaurent Pinchart
The Asus EeePC T91 integrated webcam exposes a gain control in the processing unit but stalls when the control is queried. Blacklist the gain control for that camera. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: uvcvideo: Clamp control values to the minimum and maximum valuesLaurent Pinchart
When setting a control, the V4L2 specification requires drivers to either clamp the control value to the [minimum, maximum] range or return the -ERANGE error. Fix the driver to clamp control values to the valid range in uvc_ctrl_set() and make sure the value differs from the minimum by an integer multiple of step. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: uvcvideo: Cache control min, max, res and def query resultsLaurent Pinchart
2010-02-26V4L/DVB: uvcvideo: Return -ERANGE when setting a control to an out-of-range ↵Laurent Pinchart
menu index The V4L2 specification states that out of bounds control values must either be clamped to the valid range or result in a -ERANGE error code. Fix the driver to return -ERANGE instead of -EINVAL when setting a menu control to an invalid value. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: uvcvideo: Use %pUl printk format specifier to print GUIDsLaurent Pinchart
Replace the UVC_GUID_FORMAT and UVC_GUID_ARGS macros with the new %pUl printk format specifier. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: uvcvideo: Increase the streaming control timeout to 5 secondsLaurent Pinchart
This fixes timeout issues with some Logitech webcams. The timeout value seems to match the one used in the Logitech Windows driver, so no further increase should be necessary. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca - main: Fix a compile error when CONFIG_INPUT is not setJean-François Moine
Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: gspca - sonixj: Set the vertical flip at capture start for all sensorsJean-François Moine
2010-02-26V4L/DVB: gspca - sonixj: Add vertical flip control for sensor hv7131rJean-François Moine
2010-02-26V4L/DVB: videobuf: add missing checks for kzalloc returning NULLPawel Osciak
Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: cx88-alsa: prevent out-of-range volume settingClemens Ladisch
Ensure that volume values are always in the allowed range. Otherwise, it would be possible to set other bits in the AUD_VOL_CTL register or to get a wrong sign in the AUD_BAL_CTL register. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: mfd: Add timb-radio to the timberdale MFDRichard Röjfors
This patch addes timb-radio to all configurations of the timberdale MFD. Connected to the FPGA is a TEF6862 tuner and a SAA7706H DSP, the I2C board info of these devices is passed via the timb-radio platform data. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Cc: sameo@linux.intel.com Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: dvb-usb/opera1: misplaced parenthesisRoel Kluin
The parenthesis was misplaced, tmp is set to 0 or break occurs, while debugging opera1_usb_i2c_msgxfer() retval was not shown. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> CC: Marco Gittler <g.marco@freenet.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: tuner-xc2028: Fix demod breakage for XC3028LMauro Carvalho Chehab
A small mistake on the last patch broke demod s-code setup for XC3028L (firmware 3.2 and upper). Fix it. Thanks-to: Stefan Ringel <stefan.ringel@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: tuner-xc2028: fix tuning logic to solve a regression in AustraliaMauro Carvalho Chehab
There's one reported regression in Australia (DTV7) and some reported troubles with newer firmwares found on xc3028l chips. Rework the logic to improve tuner on those cases. Thanks-to: Robert Lowery <rglowery@exemail.com.au> Thanks-to: Stefan Ringel <stefan.ringel@arcor.de> Tested-by: Robert Lowery <rglowery@exemail.com.au> CC: stable.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: bttv: Let the user disable IR supportJean Delvare
Add a new module parameter "disable_ir" to disable IR support. Several other drivers do that already, and this can be very handy for debugging purposes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: em28xx : Terratec Cinergy Hybrid T USB XS FR is workingCatimimi
I succeeded in running Cinergy Hybrid T USB XS FR in both modes. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: dvb: fix sparse warningsRandy Dunlap
Fix sparse warnings in media/dvb/frontends: drivers/media/dvb/frontends/dibx000_common.c:177:13: warning: non-ANSI function declaration of function 'systime' drivers/media/dvb/frontends/tda665x.c:136:55: warning: right shift by bigger than source value [mchehab@redhat.com: removed the change at dib0090 since it got fixed by a previous patch] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: V4L: dvb-usb, add extra sync to down-up input eventsJiri Slaby
Userspace is allowed to coalesce events between SYNCs. And since the code emits UP right after DOWN for the same key, it may be missed (up+down=nothing). Add an extra sync in between UP and DOWN events to disable the coalesce. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: add missing 'p' at card name 'Hauppauge HD PVR'Lars Hanisch
I don't know if there are applications which rely on this name, but after all it's a spelling mistake. Signed-off-by: Lars Hanisch <dvb@cinnamon-sage.de> CC: Janne Granau <j@jannau.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
