path: root/drivers
2011-05-24Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: switch to dynamic printks UBI: turn some macros into static inline UBI: improve checking in debugging prints UBI: fix typo in a message UBI: fix minor stylistic issues UBI: use __packed instead of __attribute__((packed)) UBI: cleanup comments around volume properties UBI: re-name set volume properties ioctl UBI: make the control character device non-seekable
2011-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (22 commits) m68knommu: Use generic show_interrupts() coldfire_qspi compile fix m68k: merge the mmu and non-mmu versions of sys_m68k.c m68knommu: use asm-generic/bitops/ext2-atomic.h m68knommu: Remove obsolete #include <linux/sys.h> m68k: merge mmu and non-mmu versions of asm-offsets.c m68k: merge non-mmu and mmu versions of m68k_ksyms.c m68knommu: remove un-needed exporting of COLDFIRE symbols m68knommu: move EXPORT of kernel_thread to function definition m68knommu: move EXPORT of local checksumming functions to definitions m68knommu: move EXPORT of dump_fpu to function definition m68knommu: clean up mm/init_no.c m68k: merge the mmu and non-mmu mm/Makefile m68k: mv kmap_mm.c to kmap.c m68knommu: remove stubs for __ioremap() and iounmap() m68knommu: remove unused kernel_set_cachemode() m68k: let Makefile sort out compiling mmu and non-mmu lib/checksum.c m68k: remove duplicate memcpy() implementation m68k: remove duplicate memset() implementation m68k: remove duplicate memmove() implementation ...
2011-05-24coldfire_qspi compile fixSteven King
The m68k/m68knommu merge broke the qspi build. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-23Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits) sh: Ignore R_SH_NONE module relocations. SH: SE7751: Fix pcibios_map_platform_irq prototype. sh: remove warning and warning_symbol from struct stacktrace_ops sh: wire up sys_sendmmsg. clocksource: sh_tmu: Runtime PM support clocksource: sh_tmu: __clocksource_updatefreq_hz() update clocksource: sh_cmt: Runtime PM support clocksource: sh_cmt: __clocksource_updatefreq_hz() update dmaengine: shdma: synchronize RCU before freeing, simplify spinlock dmaengine: shdma: add runtime- and system-level power management dmaengine: shdma: fix locking sh: sh-sci: sh7377 and sh73a0 build fixes sh: cosmetic improvement: use an existing pointer serial: sh-sci: suspend/resume wakeup support V2 serial: sh-sci: Runtime PM support sh: select IRQ_FORCED_THREADING. sh: intc: Set virtual IRQs as nothread. sh: fixup fpu.o compile order i2c: add a module alias to the sh-mobile driver ALSA: add a module alias to the FSI driver ...
2011-05-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits) [media] gspca - sunplus: Fix some warnings and simplify code [media] gspca: Fix some warnings tied to 'no debug' [media] gspca: Unset debug by default [media] gspca - cpia1: Remove a bad conditional compilation instruction [media] gspca - main: Remove USB traces [media] gspca - main: Version change to 2.13 [media] gspca - stk014 / t613: Accept the index 0 in querymenu [media] gspca - kinect: Remove __devinitdata [media] gspca - cpia1: Fix some warnings [media] video/Kconfig: Fix mis-classified devices [media] support for medion dvb stick 1660:1921 [media] tm6000: fix uninitialized field, change prink to dprintk [media] cx231xx: Add support for Iconbit U100 [media] saa7134 add new TV cards [media] Use a more consistent value for RC repeat period [media] cx18: Move spinlock and vb_type initialisation into stream_init [media] tm6000: remove tm6010 sif audio start and stop [media] tm6000: remove unused exports [media] tm6000: add pts logging [media] tm6000: change from ioctl to unlocked_ioctl ...
2011-05-23hwmon: (coretemp) Add comments describing the handling of HT CPUsGuenter Roeck
The coretemp driver provides a single set of device attributes for each physical core of a HT CPU to avoid duplicate sensors. This functionality was introduced with commit d883b9f09772 ("hwmon: (coretemp) Skip duplicate CPU entries"). Commit e40cc4bdfd4b ("x86/hwmon: register alternate sibling upon CPU removal") extends this functionality to register the HT sibling of a CPU which is taken offline, to ensure that sensor attributes are provided if at least one HT sibling of a core is online. Add comments into the code describing the functionality in some more detail. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-23Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits) ARM: bcmring: convert to use sp804 clockevents ARM: bcmring: convert to sp804 clocksource ARM: 6912/1: bcmring: Add clkdev table in init_early clockevents: ARM sp804: obtain sp804 timer rate via clks clockevents: ARM sp804: allow clockevent name to be specified clocksource: ARM sp804: obtain sp804 timer rate via clks clocksource: ARM sp804: allow clocksource name to be specified clocksource: convert OMAP1 to 32-bit down counting clocksource clocksource: convert MXS timrotv2 to 32-bit down counting clocksource clocksource: convert SPEAr platforms 16-bit up counting clocksource clocksource: convert Integrator/AP 16-bit down counting clocksource clocksource: convert W90x900 24-bit down counting clocksource clocksource: convert ARM 32-bit down counting clocksources clocksource: convert ARM 32-bit up counting clocksources clocksource: add common mmio clocksource ARM: update sa1100 to reflect PXA updates ARM: omap1: convert to using readl/writel instead of volatile struct ARM: omap1: delete useless interrupt handler ARM: s5p: consolidate selection of timer register ARM: 6939/1: fix missing 'cpu_relax()' declaration ...
2011-05-23Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (970 commits) staging: usbip: replace usbip_u{dbg,err,info} and printk with dev_ and pr_ staging:iio: Trivial kconfig reorganization and uniformity improvements. staging:iio:documenation partial update. staging:iio: use pollfunc allocation helpers in remaining drivers. staging:iio:max1363 misc cleanups and use of for_each_bit_set to simplify event code spitting out. staging:iio: implement an iio_info structure to take some of the constant elements out of iio_dev. staging:iio:meter:ade7758: Use private data space from iio_allocate_device staging:iio:accel:lis3l02dq make write_reg_8 take value not a pointer to value. staging:iio: ring core cleanups + check if read_last available in lis3l02dq staging:iio:core cleanup: squash tiny wrappers and use dev_set_name to handle creation of event interface name. staging:iio: poll func allocation clean up. staging:iio:ad7780 trivial unused header cleanup. staging:iio:adc: AD7780: Use private data space from iio_allocate_device + trivial fixes staging:iio:adc:AD7780: Convert to new channel registration method staging:iio:adc: AD7606: Drop dev_data in favour of iio_priv() staging:iio:adc: AD7606: Consitently use indio_dev staging:iio: Rip out helper for software rings. staging:iio:adc:AD7298: Use private data space from iio_allocate_device staging:iio: rationalization of different buffer implementation hooks. staging:iio:imu:adis16400 avoid allocating rx, tx, and state separately from iio_dev. ... Fix up trivial conflicts in - drivers/staging/intel_sst/intelmid.c: patches applied in both branches - drivers/staging/rt2860/common/cmm_data_{pci,usb}.c: removed vs spelling - drivers/staging/usbip/vhci_sysfs.c: trivial header file inclusion
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-23hwmon: (coretemp) Fix compile error if CONFIG_SMP is not definedGuenter Roeck
cpu_sibling_mask() is not defined unless CONFIG_SMP is defined, so it must not be used directly in the code without ifdef protection. To solve the problem and avoid ifdefs in the code, define for_each_sibling() and use it instead. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23Merge branches 'consolidate', 'ep93xx', 'fixes', 'misc', 'mmci', 'remove' ↵Russell King
and 'spear' into for-linus
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-23clocksource: add common mmio clocksourceRussell King
Add a generic mmio clocksource, covering both 32-bit and 16-bit register access sizes, for up or down counters. This can be used to easily create clocksources for simple counter-based implementations. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Colin Cross <ccross@android.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Erik Gilling <konkers@android.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: linux-omap@vger.kernel.org Acked-by: Nicolas Pitre <nico@fluxnic.net> Cc: Olof Johansson <olof@lixom.net> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Viresh Kumar <viresh.kumar@st.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (coretemp) Fix checkpatch errors hwmon: Remove pkgtemp driver hwmon: (coretemp) Merge pkgtemp with coretemp hwmon: (pmbus) Add support for Analog Devices ADM1275 hwmon: (pmbus) Support for TI UCD90xxx series Sequencer and System Health Controllers hwmon: (pmbus) Add support for TI UCD9200 series of PWM System Controllers hwmon: (pmbus) Use device specific function to read fan configuration hwmon: (pmbus) Expand scope of device specific get_status function hwmon: (pmbus) Introduce infrastructure to detect sensors and limit registers hwmon: Driver for MAX16065 System Manager and compatibles hwmon: (sht15) add support for CRC validation hwmon: (sht15) add support for the status register hwmon: (sht15) clean-up the probe function hwmon: (sht15) general code clean-up hwmon: Add support for MAX6642
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (36 commits) HID: hid-multitouch: cosmetic changes, sort classes and devices HID: hid-multitouch: class MT_CLS_STANTUM is redundant with MT_CLS_CONFIDENCE HID: hid-multitouch: add support for Unitec panels HID: hid-multitouch: add support for Touch International panels HID: hid-multitouch: add support for GoodTouch panels HID: hid-multitouch: add support for CVTouch panels HID: hid-multitouch: add support for ActionStar panels HID: hiddev: fix race between hiddev_disconnect and hiddev_release HID: magicmouse: ignore 'ivalid report id' while switching modes HID: fix a crash in hid_report_raw_event() function. HID: hid-multitouch: add support for Elo TouchSystems 2515 IntelliTouch Plus HID: assorted usage updates from hut 1.12 HID: roccat: fix actual/startup profile sysfs attribute in koneplus HID: hid-multitouch: Add support for Lumio panels HID: 'name' and 'phys' in 'struct hid_device' can never be NULL HID: hid-multitouch: add support for Ilitek dual-touch panel HID: picolcd: Avoid compile warning/error triggered by copy_from_user() HID: add support for Logitech G27 wheel HID: hiddev: fix error path in hiddev_read when interrupted HID: add support for Sony Navigation Controller ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm: apm-emulation: apm_mutex breaks ACK; remove it APM: take over maintainership
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits) ASoC: core: Don't set "(null)" as a driver name ALSA: hda - Use LPIB for ATI/AMD chipsets as default Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets" ASoC: Tegra: Fix compile when debugfs not enabled ASoC: spdif-dit: Add missing MODULE_* SOUND: OSS: Remove Au1550 driver. ALSA: hda - add Intel Panther Point HDMI codec id ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live! ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek ALSA: hda - Fix input-src parse in patch_analog.c ASoC: davinci-mcasp: enable ping-pong SRAM buffers ASoC: add iPAQ hx4700 machine driver ASoC: Asahi Kasei AK4641 codec driver ALSA: hda - Enable Realtek ALC269 codec input layer beep ALSA: intel8x0m: enable AMD8111 modem ALSA: HDA: Add jack detection for HDMI ALSA: sound, core, pcm_lib: fix xrun_log ASoC: Max98095: Move existing NULL check before pointer dereference. ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt ALSA: usb-audio - Add support for USB X-Fi S51 Pro ...
2011-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) bnx2x: allow device properly initialize after hotplug bnx2x: fix DMAE timeout according to hw specifications bnx2x: properly handle CFC DEL in cnic flow bnx2x: call dev_kfree_skb_any instead of dev_kfree_skb net: filter: move forward declarations to avoid compile warnings pktgen: refactor pg_init() code pktgen: use vzalloc_node() instead of vmalloc_node() + memset() net: skb_trim explicitely check the linearity instead of data_len ipv4: Give backtrace in ip_rt_bug(). net: avoid synchronize_rcu() in dev_deactivate_many net: remove synchronize_net() from netdev_set_master() rtnetlink: ignore NETDEV_RELEASE and NETDEV_JOIN event net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASE bridge: call NETDEV_JOIN notifiers when add a slave netpoll: disable netpoll when enslave a device macvlan: Forward unicast frames in bridge mode to lowerdev net: Remove linux/prefetch.h include from linux/skbuff.h ipv4: Include linux/prefetch.h in fib_trie.c netlabel: Remove prefetches from list handlers. drivers/net: add prefetch header for prefetch users ... Fixed up prefetch parts: removed a few duplicate prefetch.h includes, fixed the location of the igb prefetch.h, took my version of the skbuff.h code without the extra parentheses etc.
2011-05-23apm-emulation: apm_mutex breaks ACK; remove itPaul Parsons
apm_mutex is locked by a process (e.g. apm -s) at the start of apm_ioctl() and remains locked while pm_suspend() is called. Any subsequent process trying to ACK the suspend (e.g. apmd) is then blocked at the start of apm_ioctl(), causing the suspend to be delayed for 5 seconds in apm_suspend_notifier() while the ACK times out. In short, ACKs don't work. The driver's data structures are sufficiently protected by assorted locks. And pm_suspend() has its own mutex to prevent reentrancy. Consequently there is no obvious requirement for apm_mutex, which evolved from earlier BKL calls. So let's remove it. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-23Merge branches 'doc', 'multitouch', 'upstream' and 'upstream-fixes' into ↵Jiri Kosina
for-linus
2011-05-23b43: fix comment typo reqest -> requestJim Cromie
Recent trivial fix corrected 'occured', but left 'reqest'. codespell needs another dictionary entry. cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-23HID: hid-multitouch: cosmetic changes, sort classes and devicesBenjamin Tissoires
This patch sorts the defs for the MT_CLS. I choose to split generic classes and device specific ones to be able to add more generic classes in the future. It also put eGalax devices at their right place (alphabetically) in mt_devices. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-23clocksource: sh_tmu: Runtime PM supportMagnus Damm
Add Runtime PM support to the TMU driver. The hardware device is enabled as long as the clocksource or the clockevent portion of the driver is used. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23clocksource: sh_tmu: __clocksource_updatefreq_hz() updateMagnus Damm
This patch updates the clocksource part of the TMU driver to make use of the __clocksource_updatefreq_hz() function. Without this patch the old code uses clocksource_register() together with a hack that assumes a never changing clock rate (see clk_enable(), clk_get_rate() and clk_disable()). The patch uses clocksource_register_hz() with 1 Hz as initial value, then lets the ->enable() callback update the value with __clocksource_updatefreq_hz() once the struct clk has been enabled and the frequency is stable. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23clocksource: sh_cmt: Runtime PM supportMagnus Damm
Add Runtime PM support to the CMT driver. The hardware device is enabled as long as the clocksource or the clockevent portion of the driver is used. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23clocksource: sh_cmt: __clocksource_updatefreq_hz() updateMagnus Damm
This patch updates the clocksource part of the CMT driver to make use of the __clocksource_updatefreq_hz() function. Without this patch the old code uses clocksource_register() together with a hack that assumes a never changing clock rate (see clk_enable(), clk_get_rate() and clk_disable()). The patch uses clocksource_register_hz() with 1 Hz as initial value, then lets the ->enable() callback update the value with __clocksource_updatefreq_hz() once the struct clk has been enabled and the frequency is stable. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6: ide/ide-scan-pci.c: Use for_each_pci_dev(). ide: Use linux/mutex.h IDE: ide-floppy, remove unnecessary NULL check drivers/ide/pmac.c: Remove unnecessary casts of pci_get_drvdata ide: fix use after free in ide-acpi
2011-05-22Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: allow resync_start to be set while an array is active. md/raid10: reformat some loops with less indenting. md/raid10: remove unused variable. md/raid10: make more use of 'slot' in raid10d. md/raid10: some tidying up in fix_read_error md/raid1: improve handling of pages allocated for write-behind. md/raid1: try fix_sync_read_error before process_checks. md/raid1: tidy up new functions: process_checks and fix_sync_read_error. md/raid1: split out two sub-functions from sync_request_write md: make error_handler functions more uniform and correct. md/multipath: discard ->working_disks in favour of ->degraded md/raid1: clean up read_balance. md: simplify raid10 read_balance md/bitmap: fix saving of events_cleared and other state. md: reject a re-add request that cannot be honoured. md: Fix race when creating a new md device.
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23dmaengine: shdma: synchronize RCU before freeing, simplify spinlockGuennadi Liakhovetski
List elements, deleted using list_del_rcu(), cannot be freed without synchronising RCU. Further, the spinlock, used to protect the RCU writer, is called in process context, so, we don't have to save flags. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23dmaengine: shdma: add runtime- and system-level power managementGuennadi Liakhovetski
This patch extends and fixes runtime power management in the shdma driver to support powering down the DMA controller and adds support for system-level suspend and resume. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23dmaengine: shdma: fix lockingGuennadi Liakhovetski
Close multiple theoretical races, especially the one in .device_free_chan_resources(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23sh: sh-sci: sh7377 and sh73a0 build fixesMagnus Damm
Fix sh7377 and sh73a0 build failure: drivers/tty/serial/sh-sci.c: In function 'scif_txfill': drivers/tty/serial/sh-sci.c:338: error: implicit declaration of function 'sci_SCTFDR_in' drivers/tty/serial/sh-sci.c: In function 'scif_rxfill': drivers/tty/serial/sh-sci.c:351: error: implicit declaration of function 'sci_SCRFDR_in' make[3]: *** [drivers/tty/serial/sh-sci.o] Error 1 make[2]: *** [drivers/tty/serial] Error 2 make[1]: *** [drivers/tty] Error 2 make: *** [drivers] Error 2 Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23serial: sh-sci: suspend/resume wakeup support V2Magnus Damm
This patch adds wakeup support to the sh-sci driver. The serial core deals with all details but defaults to wakeup disabled. So to make use of this feature enable wakeup in sysfs: echo enabled > /sys/class/tty/ttySC0/power/wakeup Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23serial: sh-sci: Runtime PM supportMagnus Damm
Add support for Runtime PM in the sh-sci driver. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23Merge branch 'sh/genirq-threading' into sh-latestPaul Mundt
2011-05-23Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
2011-05-22bnx2x: allow device properly initialize after hotplugDmitry Kravkov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22bnx2x: fix DMAE timeout according to hw specificationsDmitry Kravkov
2011-05-22bnx2x: properly handle CFC DEL in cnic flowVladislav Zolotarov
2011-05-22bnx2x: call dev_kfree_skb_any instead of dev_kfree_skbVladislav Zolotarov
replace function calls when possible call in both irq/non-irq contexts Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASEAmerigo Wang
s/NETDEV_BONDING_DESLAVE/NETDEV_RELEASE/ as Andy suggested. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Neil Horman <nhorman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22netpoll: disable netpoll when enslave a deviceAmerigo Wang
V3: rename NETDEV_ENSLAVE to NETDEV_JOIN Currently we do nothing when we enslave a net device which is running netconsole. Neil pointed out that we may get weird results in such case, so let's disable netpoll on the device being enslaved. I think it is too harsh to prevent the device being ensalved if it is running netconsole. By the way, this patch also removes the NETDEV_GOING_DOWN from netconsole netdev notifier, because netpoll will check if the device is running or not and we don't handle NETDEV_PRE_UP neither. This patch is based on net-next-2.6. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22macvlan: Forward unicast frames in bridge mode to lowerdevDavid Ward
Unicast frames between macvlan interfaces in bridge mode are not otherwise sent to network taps on the lowerdev (as all other macvlan frames are), so forward the frames to the receive queue of the lowerdev first. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22drivers/net: add prefetch header for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22rionet: Remove pointless printk of skb pointer.David S. Miller
Casting to u32 warns anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
