path: root/drivers
2013-10-29MIPS: DECstation I/O ASIC DMA interrupt classesMaciej W. Rozycki
This change complements commits d0da7c002f7b2a93582187a9e3f73891a01d8ee4 [MIPS: DEC: Convert to new irq_chip functions] and 5359b938c088423a28c41499f183cd10824c1816 [MIPS: DECstation I/O ASIC DMA interrupt handling fix] and implements automatic handling of the two classes of DMA interrupts the I/O ASIC implements, informational and errors. Informational DMA interrupts do not stop the transfer and use the `handle_edge_irq' handler that clears the request right away so that another request may be recorded while the previous is being handled. DMA error interrupts stop the transfer and require a corrective action before DMA can be reenabled. Therefore they use the `handle_fasteoi_irq' handler that only clears the request on the way out. Because MIPS processor interrupt inputs, one of which the I/O ASIC's interrupt controller is cascaded to, are level-triggered it is recommended that error DMA interrupt action handlers are registered with the IRQF_ONESHOT flag set so that they are run with the interrupt line masked. This change removes the export of clear_ioasic_dma_irq that now does not have to be called by device drivers to clear interrupts explicitly anymore. Originally these interrupts were cleared in the .end handler of the `irq_chip' structure, before it was removed. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5874/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-10-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Here are the outstanding target pending fixes for v3.12-rc7. This includes a number of EXTENDED_COPY related fixes as a result of Thomas and Doug's continuing testing and feedback. Also included is an important vhost/scsi fix that addresses a long standing issue where the 'write' parameter for get_user_pages_fast() was incorrectly set for virtio-scsi WRITEs -> DMA_TO_DEVICE, and not for virtio-scsi READs -> DMA_FROM_DEVICE. This resulted in random userspace segfaults and other unpleasantness on KVM host, and unfortunately has been an issue since the initial merge of vhost/scsi in v3.6. This patch is CC'ed to stable, along with two other less critical items" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: vhost/scsi: Fix incorrect usage of get_user_pages_fast write parameter target/pscsi: fix return value check target: Fail XCOPY for non matching source + destination block_size target: Generate failure for XCOPY I/O with non-zero scsi_status target: Add missing XCOPY I/O operation sense_buffer iser-target: check device before dereferencing its variable target: Return an error for WRITE SAME with ANCHOR==1 target: Fix assignment of LUN in tracepoints target: Reject EXTENDED_COPY when emulate_3pc is disabled target: Allow non zero ListID in EXTENDED_COPY parameter list target: Make target_do_xcopy failures return INVALID_PARAMETER_LIST
2013-10-27Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "Here is the late fixes pull request for dmaengine while you fly back from KS. We have a new dmaengine ML hosted by vger so a patch for that along with addition of Dave as driver mainatainer for ioat. Other fixes are memeory leak fixes on edma driver, small fixes on rcar-hpbdma driver by Sergei" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: edma: fix another memory leak dma: edma: Fix memory leak MAINTAINERS: add to ioatdma maintainer list MAINTAINERS: add the new dmaengine mailing list
2013-10-26Merge tag 'pm+acpi-3.12-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from "These fix two bugs in the intel_pstate driver, a hibernate bug leading to nasty resume failures sometimes and acpi-cpufreq initialization bug that causes problems to happen during module unload when intel_pstate is in use. Specifics: - Fix for rounding errors in intel_pstate causing CPU utilization to be underestimated from Brennan Shacklett. - intel_pstate fix to always use the correct max pstate value when computing the min pstate from Dirk Brandewie. - Hibernation fix for deadlocking resume in cases when the probing of the device containing the image is deferred from Russ Dill. - acpi-cpufreq fix to prevent the module from staying in memory when the driver cannot be registered and then attempting to unregister things that have never been registered on exit" * tag 'pm+acpi-3.12-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: acpi-cpufreq: Fail initialization if driver cannot be registered PM / hibernate: Move software_resume to late_initcall_sync intel_pstate: Correct calculation of min pstate value intel_pstate: Improve accuracy by not truncating until final result
2013-10-25Merge tag 'for-linus-20131025' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull final mtd fixes from Brian Norris: "A few more last-minute regression fixes, prepared jointly by me and David Woodhouse: - Revert pxa3xx to its old name to avoid breaking existing 'mtdparts=' boot strings. - Return GPMI NAND to its legacy ECC layout for backwards compatibility. We will revisit this in 3.13. A note from David on the latter fix: 'This leaves a harmless cosmetic warning about an unused function. At this point in the cycle I really don't care.'" * tag 'for-linus-20131025' of git://git.infradead.org/linux-mtd: mtd: gpmi: fix ECC regression mtd: nand: pxa3xx: Fix registered MTD name
2013-10-25vhost/scsi: Fix incorrect usage of get_user_pages_fast write parameterNicholas Bellinger
This patch addresses a long-standing bug where the get_user_pages_fast() write parameter used for setting the underlying page table entry permission bits was incorrectly set to write=1 for data_direction=DMA_TO_DEVICE, and passed into get_user_pages_fast() via vhost_scsi_map_iov_to_sgl(). However, this parameter is intended to signal WRITEs to pinned userspace PTEs for the virtio-scsi DMA_FROM_DEVICE -> READ payload case, and *not* for the virtio-scsi DMA_TO_DEVICE -> WRITE payload case. This bug would manifest itself as random process segmentation faults on KVM host after repeated vhost starts + stops and/or with lots of vhost endpoints + LUNs. Cc: Stefan Hajnoczi <stefanha@redhat.com> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Asias He <asias@redhat.com> Cc: <stable@vger.kernel.org> # 3.6+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-10-25target/pscsi: fix return value checkWei Yongjun
In case of error, the function scsi_host_lookup() returns NULL pointer not ERR_PTR(). The IS_ERR() test in the return value check should be replaced with NULL test. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-10-25mtd: gpmi: fix ECC regressionDavid Woodhouse
The "legacy" ECC layout used until 3.12-rc1 uses all the OOB area by computing the ECC strength and ECC step size ourselves. Commit 2febcdf84b ("mtd: gpmi: set the BCHs geometry with the ecc info") makes the driver use the ECC info (ECC strength and ECC step size) provided by the MTD code, and creates a different NAND ECC layout for the BCH, and use the new ECC layout. This causes a regression: We can not mount the ubifs which was created by the old NAND ECC layout. This patch fixes this issue by reverting to the legacy ECC layout. We will probably introduce a new device-tree property to indicate that the new ECC layout can be used. For now though, for the imminent 3.12 release, we just unconditionally revert to the 3.11 behaviour. This leaves a harmless cosmetic warning about an unused function. At this point in the cycle I really don't care. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Acked-by: Huang Shijie <b32955@freescale.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Marek Vasut <marex@denx.de>
2013-10-25acpi-cpufreq: Fail initialization if driver cannot be registeredRafael J. Wysocki
Make acpi_cpufreq_init() return error codes when the driver cannot be registered so that the module doesn't stay useless in memory and so that acpi_cpufreq_exit() doesn't attempt to unregister things that have never been registered when the module is unloaded. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-10-24mtd: nand: pxa3xx: Fix registered MTD nameEzequiel Garcia
In a recent commit: commit f455578dd961087a5cf94730d9f6489bb1d355f0 Author: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Date: Mon Aug 12 14:14:53 2013 -0300 mtd: nand: pxa3xx: Remove hardcoded mtd name There's no advantage in using a hardcoded name for the mtd device. Instead use the provided by the platform_device. The MTD name was changed to use the one provided by the platform_device. However, this can be problematic as some users want to set partitions using the kernel parameter 'mtdparts', where the name is needed. Therefore, to avoid regressions in users relying in 'mtdparts' we revert the change and use the previous one 'pxa3xx_nand-0'. While at it, let's put a big comment and prevent this change from happening ever again. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2013-10-24dmaengine: edma: fix another memory leakVinod Koul
commit 4b6271a6 fix a menory leak but one more existed in driver so fix that Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-24dma: edma: Fix memory leakValentin Ilie
When it fails to allocate a slot, edesc should be free'd before return; Signed-off-by: Valentin Ilie <valentin.ilie@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-24target: Fail XCOPY for non matching source + destination block_sizeNicholas Bellinger
This patch adds an explicit check + failure for XCOPY I/O to source + destination devices with a non-matching block_size. This limitiation is currently due to the fact that the scatterlist memory allocated for the XCOPY READ operation is passed zero-copy to the XCOPY WRITE operation. Reported-by: Thomas Glanzmann <thomas@glanzmann.de> Reported-by: Douglas Gilbert <dgilbert@interlog.com> Cc: Thomas Glanzmann <thomas@glanzmann.de> Cc: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-10-24target: Generate failure for XCOPY I/O with non-zero scsi_statusNicholas Bellinger
This patch adds the missing non-zero se_cmd->scsi_status check required for local XCOPY I/O within target_xcopy_issue_pt_cmd() to signal an exception case failure. This will trigger the generation of SAM_STAT_CHECK_CONDITION status from within target_xcopy_do_work() process context code. Reported-by: Thomas Glanzmann <thomas@glanzmann.de> Reported-by: Douglas Gilbert <dgilbert@interlog.com> Cc: Thomas Glanzmann <thomas@glanzmann.de> Cc: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-10-24target: Add missing XCOPY I/O operation sense_bufferNicholas Bellinger
This patch adds the missing xcopy_pt_cmd->sense_buffer[] required for correctly handling CHECK_CONDITION exceptions within the locally generated XCOPY I/O path. Also update target_xcopy_read_source() + target_xcopy_setup_pt_cmd() to pass this buffer into transport_init_se_cmd() to correctly setup se_cmd->sense_buffer. Reported-by: Thomas Glanzmann <thomas@glanzmann.de> Reported-by: Douglas Gilbert <dgilbert@interlog.com> Cc: Thomas Glanzmann <thomas@glanzmann.de> Cc: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-10-24Merge tag 'md/3.12-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull md bugfixes from Neil Brown: "Assorted md bug-fixes for 3.12. All tagged for -stable releases too" * tag 'md/3.12-fixes' of git://neil.brown.name/md: raid5: avoid finding "discard" stripe raid5: set bio bi_vcnt 0 for discard request md: avoid deadlock when md_set_badblocks. md: Fix skipping recovery for read-only arrays.
2013-10-24Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of two fixes which cause oopses (Buslogic, qla2xxx) and one fix which may cause a hang because of request miscounting (sd)" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: [SCSI] sd: call blk_pm_runtime_init before add_disk [SCSI] qla2xxx: Fix request queue null dereference. [SCSI] BusLogic: Fix an oops when intializing multimaster adapter
2013-10-23iser-target: check device before dereferencing its variableVu Pham
This patch changes isert_connect_release() to correctly check for the existence struct isert_device *device before checking for isert_device->use_frwr. Signed-off-by: Vu Pham <vu@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-10-24raid5: avoid finding "discard" stripeShaohua Li
SCSI discard will damage discard stripe bio setting, eg, some fields are changed. If the stripe is reused very soon, we have wrong bios setting. We remove discard stripe from hash list, so next time the strip will be fully initialized. Suitable for backport to 3.7+. Cc: <stable@vger.kernel.org> (3.7+) Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-10-24raid5: set bio bi_vcnt 0 for discard requestShaohua Li
SCSI layer will add new payload for discard request. If two bios are merged to one, the second bio has bi_vcnt 1 which is set in raid5. This will confuse SCSI and cause oops. Suitable for backport to 3.7+ Cc: stable@vger.kernel.org (v3.7+) Reported-by: Jes Sorensen <Jes.Sorensen@redhat.com> Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
2013-10-24md: avoid deadlock when md_set_badblocks.Bian Yu
When operate harddisk and hit errors, md_set_badblocks is called after scsi_restart_operations which already disabled the irq. but md_set_badblocks will call write_sequnlock_irq and enable irq. so softirq can preempt the current thread and that may cause a deadlock. I think this situation should use write_sequnlock_irqsave/irqrestore instead. I met the situation and the call trace is below: [ 638.919974] BUG: spinlock recursion on CPU#0, scsi_eh_13/1010 [ 638.921923] lock: 0xffff8800d4d51fc8, .magic: dead4ead, .owner: scsi_eh_13/1010, .owner_cpu: 0 [ 638.923890] CPU: 0 PID: 1010 Comm: scsi_eh_13 Not tainted 3.12.0-rc5+ #37 [ 638.925844] Hardware name: To be filled by O.E.M. To be filled by O.E.M./MAHOBAY, BIOS 4.6.5 03/05/2013 [ 638.927816] ffff880037ad4640 ffff880118c03d50 ffffffff8172ff85 0000000000000007 [ 638.929829] ffff8800d4d51fc8 ffff880118c03d70 ffffffff81730030 ffff8800d4d51fc8 [ 638.931848] ffffffff81a72eb0 ffff880118c03d90 ffffffff81730056 ffff8800d4d51fc8 [ 638.933884] Call Trace: [ 638.935867] <IRQ> [<ffffffff8172ff85>] dump_stack+0x55/0x76 [ 638.937878] [<ffffffff81730030>] spin_dump+0x8a/0x8f [ 638.939861] [<ffffffff81730056>] spin_bug+0x21/0x26 [ 638.941836] [<ffffffff81336de4>] do_raw_spin_lock+0xa4/0xc0 [ 638.943801] [<ffffffff8173f036>] _raw_spin_lock+0x66/0x80 [ 638.945747] [<ffffffff814a73ed>] ? scsi_device_unbusy+0x9d/0xd0 [ 638.947672] [<ffffffff8173fb1b>] ? _raw_spin_unlock+0x2b/0x50 [ 638.949595] [<ffffffff814a73ed>] scsi_device_unbusy+0x9d/0xd0 [ 638.951504] [<ffffffff8149ec47>] scsi_finish_command+0x37/0xe0 [ 638.953388] [<ffffffff814a75e8>] scsi_softirq_done+0xa8/0x140 [ 638.955248] [<ffffffff8130e32b>] blk_done_softirq+0x7b/0x90 [ 638.957116] [<ffffffff8104fddd>] __do_softirq+0xfd/0x330 [ 638.958987] [<ffffffff810b964f>] ? __lock_release+0x6f/0x100 [ 638.960861] [<ffffffff8174a5cc>] call_softirq+0x1c/0x30 [ 638.962724] [<ffffffff81004c7d>] do_softirq+0x8d/0xc0 [ 638.964565] [<ffffffff8105024e>] irq_exit+0x10e/0x150 [ 638.966390] [<ffffffff8174ad4a>] smp_apic_timer_interrupt+0x4a/0x60 [ 638.968223] [<ffffffff817499af>] apic_timer_interrupt+0x6f/0x80 [ 638.970079] <EOI> [<ffffffff810b964f>] ? __lock_release+0x6f/0x100 [ 638.971899] [<ffffffff8173fa6a>] ? _raw_spin_unlock_irq+0x3a/0x50 [ 638.973691] [<ffffffff8173fa60>] ? _raw_spin_unlock_irq+0x30/0x50 [ 638.975475] [<ffffffff81562393>] md_set_badblocks+0x1f3/0x4a0 [ 638.977243] [<ffffffff81566e07>] rdev_set_badblocks+0x27/0x80 [ 638.978988] [<ffffffffa00d97bb>] raid5_end_read_request+0x36b/0x4e0 [raid456] [ 638.980723] [<ffffffff811b5a1d>] bio_endio+0x1d/0x40 [ 638.982463] [<ffffffff81304ff3>] req_bio_endio.isra.65+0x83/0xa0 [ 638.984214] [<ffffffff81306b9f>] blk_update_request+0x7f/0x350 [ 638.985967] [<ffffffff81306ea1>] blk_update_bidi_request+0x31/0x90 [ 638.987710] [<ffffffff813085e0>] __blk_end_bidi_request+0x20/0x50 [ 638.989439] [<ffffffff8130862f>] __blk_end_request_all+0x1f/0x30 [ 638.991149] [<ffffffff81308746>] blk_peek_request+0x106/0x250 [ 638.992861] [<ffffffff814a62a9>] ? scsi_kill_request.isra.32+0xe9/0x130 [ 638.994561] [<ffffffff814a633a>] scsi_request_fn+0x4a/0x3d0 [ 638.996251] [<ffffffff813040a7>] __blk_run_queue+0x37/0x50 [ 638.997900] [<ffffffff813045af>] blk_run_queue+0x2f/0x50 [ 638.999553] [<ffffffff814a5750>] scsi_run_queue+0xe0/0x1c0 [ 639.001185] [<ffffffff814a7721>] scsi_run_host_queues+0x21/0x40 [ 639.002798] [<ffffffff814a2e87>] scsi_restart_operations+0x177/0x200 [ 639.004391] [<ffffffff814a4fe9>] scsi_error_handler+0xc9/0xe0 [ 639.005996] [<ffffffff814a4f20>] ? scsi_unjam_host+0xd0/0xd0 [ 639.007600] [<ffffffff81072f6b>] kthread+0xdb/0xe0 [ 639.009205] [<ffffffff81072e90>] ? flush_kthread_worker+0x170/0x170 [ 639.010821] [<ffffffff81748cac>] ret_from_fork+0x7c/0xb0 [ 639.012437] [<ffffffff81072e90>] ? flush_kthread_worker+0x170/0x170 This bug was introduce in commit 2e8ac30312973dd20e68073653 (the first time rdev_set_badblock was call from interrupt context), so this patch is appropriate for 3.5 and subsequent kernels. Cc: <stable@vger.kernel.org> (3.5+) Signed-off-by: Bian Yu <bianyu@kedacom.com> Reviewed-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-10-24md: Fix skipping recovery for read-only arrays.Lukasz Dorau
Since: commit 7ceb17e87bde79d285a8b988cfed9eaeebe60b86 md: Allow devices to be re-added to a read-only array. spares are activated on a read-only array. In case of raid1 and raid10 personalities it causes that not-in-sync devices are marked in-sync without checking if recovery has been finished. If a read-only array is degraded and one of its devices is not in-sync (because the array has been only partially recovered) recovery will be skipped. This patch adds checking if recovery has been finished before marking a device in-sync for raid1 and raid10 personalities. In case of raid5 personality such condition is already present (at raid5.c:6029). Bug was introduced in 3.10 and causes data corruption. Cc: stable@vger.kernel.org Signed-off-by: Pawel Baldysiak <pawel.baldysiak@intel.com> Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-10-23[SCSI] sd: call blk_pm_runtime_init before add_diskAaron Lu
Sujit has found a race condition that would make q->nr_pending unbalanced, it occurs as Sujit explained: " sd_probe_async() -> add_disk() -> disk_add_event() -> schedule(disk_events_workfn) sd_revalidate_disk() blk_pm_runtime_init() return; Let's say the disk_events_workfn() calls sd_check_events() which tries to send test_unit_ready() and because of sd_revalidate_disk() trying to send another commands the test_unit_ready() might be re-queued as the tagged command queuing is disabled. So the race condition is - Thread 1 | Thread 2 sd_revalidate_disk() | sd_check_events() ...nr_pending = 0 as q->dev = NULL| scsi_queue_insert() blk_runtime_pm_init() | blk_pm_requeue_request() -> | nr_pending = -1 since | q->dev != NULL " The problem is, the test_unit_ready request doesn't get counted the first time it is queued, so the later decrement of q->nr_pending in blk_pm_requeue_request makes it unbalanced. Fix this by calling blk_pm_runtime_init before add_disk so that all requests initiated there will all be counted. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Reported-and-tested-by: Sujit Reddy Thumma <sthumma@codeaurora.org> Cc: stable@vger.kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-10-23[SCSI] qla2xxx: Fix request queue null dereference.Chad Dupuis
If an invalid IOCB is returned on the response queue then the index into the request queue map could be invalid and could return to us a bogus value. This could cause us to try to deference an invalid pointer and cause an exception. If we encounter this condition, simply return as no context can be established for this response. Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-10-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "Several last minute bug fixes. Two of them are on the larger side for rc7, the dasd format patch for older storage devices and the store-clock-fast patch where we have been to optimistic with an optimization" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/time: correct use of store clock fast s390/vmlogrdr: fix array access in vmlogrdr_open() s390/compat,signal: fix return value of copy_siginfo_(to|from)_user32() s390/dasd: check for availability of prefix command during format s390/mm,kvm: fix software dirty bits vs. kvm for old machines
2013-10-23Merge branch 'for-rc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management fixes from Zhang Rui: "These includes several commits that are necessary to properly fix regression for TMU test MUX address setting after reset, for exynos thermal driver. Specifics: - fix a regression that the removal of setting a certain field at TMU configuration setting results in immediately shutdown after reset on Exynos4412 SoC. - revert a patch which tries to link the thermal_zone device and its hwmon node but breaks libsensors. - fix a deadlock/lockdep warning issue in x86_pkg_temp thermal driver, which can be reproduced on a buggy platform only. - fix ti-soc-thermal driver to fall back on bandgap reading when reading from PCB temperature sensor fails" * 'for-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: Revert "drivers: thermal: parent virtual hwmon with thermal zone" drivers: thermal: allow ti-soc-thermal run without pcb zone thermal: exynos: Provide initial setting for TMU's test MUX address at Exynos4412 thermal: exynos: Provide separate TMU data for Exynos4412 thermal: exynos: Remove check for thermal device pointer at exynos_report_trigger() Thermal: x86_pkg_temp: change spin lock
2013-10-23platform/x86: fix asus-wmi build errorRandy Dunlap
Fix build error in asus_wmi.c when ASUS_WMI=y and ACPI_VIDEO=m by preventing that combination. drivers/built-in.o: In function `asus_wmi_probe': asus-wmi.c:(.text+0x65ddb4): undefined reference to `acpi_video_unregister' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-23bcache: Fixed incorrect order of arguments to bio_alloc_bioset()Kent Overstreet
Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: linux-stable <stable@vger.kernel.org> # >= v3.10 Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: - Compilation fixes for GCC < 4.4.6 - one Kbuild dependency select fix (selecting videobuf on msi3101) - driver fixes on tda10071, e4000, msi3101, soc_camera, s5p-jpeg, saa7134 and adv7511 - some device quirks needed to make them work properly - some videobuf2 core regression fixes for some features used only on embedded drivers * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] saa7134: Fix crash when device is closed before streamoff [media] adv7511: fix error return code in adv7511_probe() [media] ths8200: fix compilation with GCC < 4.4.6 [media] ad9389b: fix compilation with GCC < 4.4.6 [media] adv7511: fix compilation with GCC < 4.4.6 [media] adv7842: fix compilation with GCC < 4.4.6 [media] s5p-jpeg: Initialize vfd_decoder->vfl_dir field [media] videobuf2-dc: Fix support for mappings without struct page in userptr mode [media] vb2: Allow queuing OUTPUT buffers with zeroed 'bytesused' [media] mx3-camera: locking cleanup in mx3_videobuf_queue() [media] sh_vou: almost forever loop in sh_vou_try_fmt_vid_out() [media] tda10071: change firmware download condition [media] msi3101: correct max videobuf2 alloc [media] Add HCL T12Rg-H to STK webcam upside-down table [media] msi3101: Kconfig select VIDEOBUF2_VMALLOC [media] msi3101: msi3101_ioctl_ops can be static [media] e4000: fix PLL calc bug on 32-bit arch [media] uvcvideo: quirk PROBE_DEF for Microsoft Lifecam NX-3000 [media] uvcvideo: quirk PROBE_DEF for Dell SP2008WFP monitor
2013-10-23Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband bugfix from Roland Dreier: "Disable not-quite-ready userspace ABI for IB flow steering" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/core: Temporarily disable create_flow/destroy_flow uverbs
2013-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Sorry I let so much accumulate, I was in Buffalo and wanted a few things to cook in my tree for a while before sending to you. Anyways, it's a lot of little things as usual at this stage in the game" 1) Make bonding MAINTAINERS entry reflect reality, from Andy Gospodarek. 2) Fix accidental sock_put() on timewait mini sockets, from Eric Dumazet. 3) Fix crashes in l2tp due to mis-handling of ipv4 mapped ipv6 addresses, from François CACHEREUL. 4) Fix heap overflow in __audit_sockaddr(), from the eagle eyed Dan Carpenter. 5) tcp_shifted_skb() doesn't take handle FINs properly, from Eric Dumazet. 6) SFC driver bug fixes from Ben Hutchings. 7) Fix TX packet scheduling wedge after channel change in ath9k driver, from Felix Fietkau. 8) Fix user after free in BPF JIT code, from Alexei Starovoitov. 9) Source address selection test is reversed in __ip_route_output_key(), fix from Jiri Benc. 10) VLAN and CAN layer mis-size netlink attributes, from Marc Kleine-Budde. 11) Fix permission checks in sysctls to use current_euid() instead of current_uid(). From Eric W Biederman. 12) IPSEC policies can go away while a timer is still pending for them, add appropriate ref-counting to fix, from Steffen Klassert. 13) Fix mis-programming of FDR and RMCR registers on R8A7740 sh_eth chips, from Nguyen Hong Ky and Simon Horman. 14) MLX4 forgets to DMA unmap pages on RX, fix from Amir Vadai. 15) IPV6 GRE tunnel MTU upper limit is miscalculated, from Oussama Ghorbel. 16) Fix typo in fq_change(), we were assigning "initial quantum" to "quantum". From Eric Dumazet. 17) Set a more appropriate sk_pacing_rate for non-TCP sockets, otherwise FQ packet scheduler does not pace those flows properly. Also from Eric Dumazet. 18) rtlwifi miscalculates packet pointers, from Mark Cave-Ayland. 19) l2tp_xmit_skb() can be called from process context, not just softirq context, so we must always make sure to BH disable around it. From Eric Dumazet. 20) On qdisc reset, we forget to purge the RB tree of SKBs in netem packet scheduler. From Stephen Hemminger. 21) Fix info leak in farsync WAN driver ioctl() handler, from Dan Carpenter and Salva Peiró. 22) Fix PHY reset and other issues in dm9000 driver, from Nikita Kiryanov and Michael Abbott. 23) When hardware can do SCTP crc32 checksums, we accidently don't disable the csum offload when IPSEC transformations have been applied. From Fan Du and Vlad Yasevich. 24) Tail loss probing in TCP leaves the socket in the wrong congestion avoidance state. From Yuchung Cheng. 25) In CPSW driver, enable NAPI before interrupts are turned on, from Markus Pargmann. 26) Integer underflow and dual-assignment in YAM hamradio driver, from Dan Carpenter. 27) If we are going to mangle a packet in tcp_set_skb_tso_segs() we must unclone it. This fixes various hard to track down crashes in drivers where the SKBs ->gso_segs was changing right from underneath the driver during TX queueing. From Eric Dumazet. 28) Fix the handling of VLAN IDs, and in particular the special IDs 0 and 4095, in the bridging layer. From Toshiaki Makita. 29) Another info leak, this time in wanxl WAN driver, from Salva Peiró. 30) Fix race in socket credential passing, from Daniel Borkmann. 31) WHen NETLABEL is disabled, we don't validate CIPSO packets properly, from Seif Mazareeb. 32) Fix identification of fragmented frames in ipv4/ipv6 UDP Fragmentation Offload output paths, from Jiri Pirko. 33) Virtual Function fixes in bnx2x driver from Yuval Mintz and Ariel Elior. 34) When we removed the explicit neighbour pointer from ipv6 routes a slight regression was introduced for users such as IPVS, xt_TEE, and raw sockets. We mix up the users requested destination address with the routes assigned nexthop/gateway. From Julian Anastasov and Simon Horman. 35) Fix stack overruns in rt6_probe(), the issue is that can end up doing two full packet xmit paths at the same time when emitting neighbour discovery messages. From Hannes Frederic Sowa. 36) davinci_emac driver doesn't handle IFF_ALLMULTI correctly, from Mariusz Ceier. 37) Make sure to set TCP sk_pacing_rate after the first legitimate RTT sample, from Neal Cardwell. 38) Wrong netlink attribute passed to xfrm_replay_verify_len(), from Steffen Klassert. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (152 commits) ax88179_178a: Add VID:DID for Samsung USB Ethernet Adapter ax88179_178a: Correct the RX error definition in RX header Revert "bridge: only expire the mdb entry when query is received" tcp: initialize passive-side sk_pacing_rate after 3WHS davinci_emac.c: Fix IFF_ALLMULTI setup mac802154: correct a typo in ieee802154_alloc_device() prototype ipv6: probe routes asynchronous in rt6_probe netfilter: nf_conntrack: fix rt6i_gateway checks for H.323 helper ipv6: fill rt6i_gateway with nexthop address ipv6: always prefer rt6i_gateway if present bnx2x: Set NETIF_F_HIGHDMA unconditionally bnx2x: Don't pretend during register dump bnx2x: Lock DMAE when used by statistic flow bnx2x: Prevent null pointer dereference on error flow bnx2x: Fix config when SR-IOV and iSCSI are enabled bnx2x: Fix Coalescing configuration bnx2x: Unlock VF-PF channel on MAC/VLAN config error bnx2x: Prevent an illegal pointer dereference during panic bnx2x: Fix Maximum CoS estimation for VFs drivers: net: cpsw: fix kernel warn during iperf test with interrupt pacing ...
2013-10-22ax88179_178a: Add VID:DID for Samsung USB Ethernet AdapterFreddy Xin
Add VID:DID for Samsung USB Ethernet Adapter. Signed-off-by: Freddy Xin <freddy@asix.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-22ax88179_178a: Correct the RX error definition in RX headerFreddy Xin
Correct the definition of AX_RXHDR_CRC_ERR and AX_RXHDR_DROP_ERR. They are BIT29 and BIT31 in pkt_hdr seperately. Signed-off-by: Freddy Xin <freddy@asix.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-22sony-laptop: don't change keyboard backlight settingsMattia Dongili
Do not touch keyboard backlight unless explicitly passed a module parameter. In this way we won't make wrong assumptions about what are good default values since they actually are different from model to model. The only side effect is that we won't know what is the current value until set via the sysfs attributes. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-22Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Travelling slowed down getting these out. Two vmwgfx fixes, a radeon revert to avoid a regression, i915 fixes, and some ioctl sizing issues fixed with 32 on 64" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon/audio: don't set speaker allocation on DCE4+ drm/radeon: rework audio option drm/radeon/audio: don't set speaker allocation on DCE3.2 drm/radeon: make missing smc ucode non-fatal (CI) drm/radeon: make missing smc ucode non-fatal (r7xx-SI) drm/radeon/uvd: revert lower msg&fb buffer requirements on UVD3 drm/radeon: stop the leaks in cik_ib_test drm/radeon/atom: workaround vbios bug in transmitter table on rs780 drm/i915: Disable GGTT PTEs on GEN6+ suspend drm/i915: Make PTE valid encoding optional drm: Pad drm_mode_get_connector to 64-bit boundary drm: Prevent overwriting from userspace underallocating core ioctl structs drm/vmwgfx: Don't kill clients on VT switch drm/vmwgfx: Don't put resources with invalid id's on lru list drm/i915: disable LVDS clock gating on CPT v2
2013-10-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - a partial revert of exponent parsing changes to make "Unit" exponent item work properly again, by Nikolai Kondrashov - a few new device IDs additions piggy-backing, by AceLan Kao and David Herrmann * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: wiimote: add LEGO-wiimote VID HID: Fix unit exponent parsing again HID: usbhid: quirk for SiS Touchscreen HID: usbhid: quirk for Synaptics Large Touchccreen
2013-10-22Merge branch 'for-3.12-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "The only interesting bit is ata_eh_qc_retry() update which fixes a problem where a SG_IO command may fail across suspend/resume cycle without the command actually being at fault. Other changes are low level driver specific and fairly low impact" * 'for-3.12-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libahci: fix turning on LEDs in ahci_start_port() libata: make ata_eh_qc_retry() bump scmd->allowed on bogus failures ahci_platform: use dev_info() instead of printk() ahci: use dev_info() instead of printk() pata_isapnp: Don't use invalid I/O ports
2013-10-22s390/time: correct use of store clock fastMartin Schwidefsky
The result of the store-clock-fast (STCKF) instruction is a bit fuzzy. It can happen that the value stored on one CPU is smaller than the value stored on another CPU, although the order of the stores is the other way around. This can cause deltas of get_tod_clock() values to become negative when they should not be. We need to be more careful with store-clock-fast, this patch partially reverts git commit e4b7b4238e666682555461fa52eecd74652f36bb "time: always use stckf instead of stck if available". The get_tod_clock() function now uses the store-clock-extended (STCKE) instruction. get_tod_clock_fast() can be used if the fuzziness of store-clock-fast is acceptable e.g. for wait loops local to a CPU. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-22Merge branch 'drm-fixes-3.12' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes Most just regression fixes for audio, dpm, and uvd, plus a resource leak fix for cik. * 'drm-fixes-3.12' of git://people.freedesktop.org/~agd5f/linux: drm/radeon/audio: don't set speaker allocation on DCE4+ drm/radeon: rework audio option drm/radeon/audio: don't set speaker allocation on DCE3.2 drm/radeon: make missing smc ucode non-fatal (CI) drm/radeon: make missing smc ucode non-fatal (r7xx-SI) drm/radeon/uvd: revert lower msg&fb buffer requirements on UVD3 drm/radeon: stop the leaks in cik_ib_test drm/radeon/atom: workaround vbios bug in transmitter table on rs780
2013-10-22Merge tag 'drm-intel-fixes-2013-10-21' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes Just an lvds clock gating fix and a pte clearing hack for hsw to avoid memory corruption when hibernating - something doesn't seem to switch off properly, we're still investigating. * tag 'drm-intel-fixes-2013-10-21' of git://people.freedesktop.org/~danvet/drm-intel: (96 commits) drm/i915: Disable GGTT PTEs on GEN6+ suspend drm/i915: Make PTE valid encoding optional drm/i915: disable LVDS clock gating on CPT v2
2013-10-22intel_pstate: Correct calculation of min pstate valueDirk Brandewie
The minimum pstate is supposed to be a percentage of the maximum P state available. Calculate min using max pstate and not the current max which may have been limited by the user Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-22intel_pstate: Improve accuracy by not truncating until final resultBrennan Shacklett
This patch addresses Bug 60727 (https://bugzilla.kernel.org/show_bug.cgi?id=60727) which was due to the truncation of intermediate values in the calculations, which causes the code to consistently underestimate the current cpu frequency, specifically 100% cpu utilization was truncated down to the setpoint of 97%. This patch fixes the problem by keeping the results of all intermediate calculations as fixed point numbers rather scaling them back and forth between integers and fixed point. References: https://bugzilla.kernel.org/show_bug.cgi?id=60727 Signed-off-by: Brennan Shacklett <bpshacklett@gmail.com> Acked-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-21davinci_emac.c: Fix IFF_ALLMULTI setupMariusz Ceier
When IFF_ALLMULTI flag is set on interface and IFF_PROMISC isn't, emac_dev_mcast_set should only enable RX of multicasts and reset MACHASH registers. It does this, but afterwards it either sets up multicast MACs filtering or disables RX of multicasts and resets MACHASH registers again, rendering IFF_ALLMULTI flag useless. This patch fixes emac_dev_mcast_set, so that multicast MACs filtering and disabling of RX of multicasts are skipped when IFF_ALLMULTI flag is set. Tested with kernel 2.6.37. Signed-off-by: Mariusz Ceier <mceier+kernel@gmail.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Set NETIF_F_HIGHDMA unconditionallyMerav Sicron
Current driver implementation incorrectly sets the flag only if 64-bit DMA mask succeeded. Signed-off-by: Merav Sicron <meravs@broadcom.com> Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Don't pretend during register dumpDmitry Kravkov
As part of a register dump, the interface pretends to have the identity of other interfaces of the same physical device in order to perform HW configuration for them - specifically, it needs to prevent attentions from generating on those functions as the register dump accesses registers in common blocks which whose reading might generate an attention. However, such pretension is unsafe - unlike other flows in which the driver uses pretend, during register dump there is no guarantee no other HW access will take place (by other flows). If such access will take place, the HW will be accessed by the wrong interface, and leave both functions in an incorrect state. This patch removes all pretensions from the register dump flow. Instead, it changes initial configuration of attentions such that no fatal attention will be generated for other functions as a result of the register dump (notice however, a debug print claiming an attention from other functions IS possible during the register dump) Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Lock DMAE when used by statistic flowAriel Elior
bnx2x has several clients to its DMAE machines - all of them with the exception of the statistics flow used the same locking mechanisms to synchronize the DMAE machines' usage. Since statistics (which are periodically entered) use DMAE without taking the locks, they may erase the commands which were previously set - e.g., it may cause a VF to timeout while waiting for a PF answer on the VF-PF channel as that command header would have been overwritten by the statistics' header. This patch makes certain that all flows utilizing DMAE will use the same API, assuring that the locking scheme will be kept by all said flows. Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Prevent null pointer dereference on error flowYuval Mintz
If debug message is open and bnx2x_vfop_qdtor_cmd() were to fail, the resulting print would have caused a null pointer dereference. Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Fix config when SR-IOV and iSCSI are enabledAriel Elior
Starting with commit b9871bc "bnx2x: VF RSS support - PF side", if a PF will have SR-IOV supported in its PCI configuration space, storage drivers will not work for that interface. This patch fixes the resource calculation to allow such a configuration to properly work. Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Fix Coalescing configurationDmitry Kravkov
bnx2x drivers configure coalescing incorrectly (e.g., as a result of a call to 'ethtool -c'). Although this is almost invisible to the user (due to NAPI) designated tests will show the configuration is incorrect. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21bnx2x: Unlock VF-PF channel on MAC/VLAN config errorAriel Elior
Current code returns upon failure, leaving the VF-PF in an unusable state; This patch adds the missing release so further commands could pass between PF and VF. Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
