path: root/drivers/xen/swiotlb-xen.c
2015-01-29Revert "swiotlb-xen: pass dev_addr to swiotlb_tbl_unmap_single"David Vrabel
commit dbdd74763f1faf799fbb9ed30423182e92919378 upstream. This reverts commit 2c3fc8d26dd09b9d7069687eead849ee81c78e46. This commit broke on x86 PV because entries in the generic SWIOTLB are indexed using (pseudo-)physical address not DMA address and these are not the same in a x86 PV guest. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16swiotlb-xen: pass dev_addr to swiotlb_tbl_unmap_singleStefano Stabellini
commit 2c3fc8d26dd09b9d7069687eead849ee81c78e46 upstream. Need to pass the pointer within the swiotlb internal buffer to the swiotlb library, that in the case of xen_unmap_single is dev_addr, not paddr. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16swiotlb-xen: call xen_dma_sync_single_for_device when appropriateStefano Stabellini
commit 9490c6c67e2f41760de8ece4e4f56f75f84ceb9e upstream. In xen_swiotlb_sync_single we always call xen_dma_sync_single_for_cpu, even when we should call xen_dma_sync_single_for_device. Fix that. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16swiotlb-xen: remove BUG_ON in xen_bus_to_physStefano Stabellini
commit c884227eaae9936f8ecbde6e1387bccdab5f4e90 upstream. On x86 truncation cannot occur because config XEN depends on X86_64 || (X86_32 && X86_PAE). On ARM truncation can occur without CONFIG_ARM_LPAE, when the dma operation involves foreign grants. However in that case the physical address returned by xen_bus_to_phys is actually invalid (there is no mfn to pfn tracking for foreign grants on ARM) and it is not used. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16swiotlb-xen: pass dev_addr to xen_dma_unmap_page and xen_dma_sync_single_for_cpuStefano Stabellini
commit d6883e6f32e07ef2cc974753ba00927de099e6d7 upstream. xen_dma_unmap_page and xen_dma_sync_single_for_cpu take a dma_addr_t handle as argument, not a physical address. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-30xen: swiotlb: handle sizeof(dma_addr_t) != sizeof(phys_addr_t)Ian Campbell
The use of phys_to_machine and machine_to_phys in the phys<=>bus conversions causes us to lose the top bits of the DMA address if the size of a DMA address is not the same as the size of the phyiscal address. This can happen in practice on ARM where foreign pages can be above 4GB even though the local kernel does not have LPAE page tables enabled (which is totally reasonable if the guest does not itself have >4GB of RAM). In this case the kernel still maps the foreign pages at a phys addr below 4G (as it must) but the resulting DMA address (returned by the grant map operation) is much higher. This is analogous to a hardware device which has its view of RAM mapped up high for some reason. This patch makes I/O to foreign pages (specifically blkif) work on 32-bit ARM systems with more than 4GB of RAM. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2013-11-15swiotlb-xen: add missing xen_dma_map_page callStefano Stabellini
swiotlb-xen is missing a xen_dma_map_page call in xen_swiotlb_map_sg_attrs, in the bounce buffer path. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-11-08Merge remote-tracking branch 'stefano/swiotlb-xen-9.1' into ↵Konrad Rzeszutek Wilk
stable/for-linus-3.13 * stefano/swiotlb-xen-9.1: swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrs swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus and range_straddles_page_boundary grant-table: call set_phys_to_machine after mapping grant refs arm,arm64: do not always merge biovec if we are running on Xen swiotlb: print a warning when the swiotlb is full swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/device xen: introduce xen_dma_map/unmap_page and xen_dma_sync_single_for_cpu/device swiotlb-xen: use xen_alloc/free_coherent_pages xen: introduce xen_alloc/free_coherent_pages arm64/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain arm/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain swiotlb-xen: introduce xen_swiotlb_set_dma_mask xen/arm,arm64: enable SWIOTLB_XEN xen: make xen_create_contiguous_region return the dma address xen/x86: allow __set_phys_to_machine for autotranslate guests arm/xen,arm64/xen: introduce p2m arm64: define DMA_ERROR_CODE arm: make SWIOTLB available Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Conflicts: arch/arm/include/asm/dma-mapping.h drivers/xen/swiotlb-xen.c [Conflicts arose b/c "arm: make SWIOTLB available" v8 was in Stefano's branch, while I had v9 + Ack from Russel. I also fixed up white-space issues]
2013-10-29swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrsStefano Stabellini
map_sg returns the number of elements mapped, not a dma_addr_t. In case of error return 0, not DMA_ERROR_CODE. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2013-10-25swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus ↵Stefano Stabellini
and range_straddles_page_boundary This functions are small and called frequently. Static inline them. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2013-10-25swiotlb: print a warning when the swiotlb is fullStefano Stabellini
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Changes in v7: - use dev_warn instead of pr_warn.
2013-10-25swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/deviceStefano Stabellini
Call xen_dma_map_page, xen_dma_unmap_page, xen_dma_sync_single_for_cpu, xen_dma_sync_single_for_device from swiotlb-xen to ensure cpu/device coherency of the pages used for DMA, including the ones belonging to the swiotlb buffer. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2013-10-24tracing/events: Fix swiotlb tracepoint creationThierry Reding
Tracepoints are only created when Xen support is enabled, but they are also referenced within lib/swiotlb.c. So unless Xen support is enabled the tracepoints will be missing, therefore causing builds to fail. Fix this by moving the tracepoint creation to lib/swiotlb.c, which works nicely because the Xen swiotlb support selects the generic swiotlb support. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-10-10swiotlb-xen: use xen_alloc/free_coherent_pagesStefano Stabellini
Use xen_alloc_coherent_pages and xen_free_coherent_pages to allocate or free coherent pages. We need to be careful handling the pointer returned by xen_alloc_coherent_pages, because on ARM the pointer is not equal to phys_to_virt(*dma_handle). In fact virt_to_phys only works for kernel direct mapped RAM memory. In ARM case the pointer could be an ioremap address, therefore passing it to virt_to_phys would give you another physical address that doesn't correspond to it. Make xen_create_contiguous_region take a phys_addr_t as start parameter to avoid the virt_to_phys calls which would be incorrect. Changes in v6: - remove extra spaces. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-10-09swiotlb-xen: introduce xen_swiotlb_set_dma_maskStefano Stabellini
Implement xen_swiotlb_set_dma_mask, use it for set_dma_mask on arm. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2013-10-10xen/arm,arm64: enable SWIOTLB_XENStefano Stabellini
Xen on arm and arm64 needs SWIOTLB_XEN: when running on Xen we need to program the hardware with mfns rather than pfns for dma addresses. Remove SWIOTLB_XEN dependency on X86 and PCI and make XEN select SWIOTLB_XEN on arm and arm64. At the moment always rely on swiotlb-xen, but when Xen starts supporting hardware IOMMUs we'll be able to avoid it conditionally on the presence of an IOMMU on the platform. Implement xen_create_contiguous_region on arm and arm64: for the moment we assume that dom0 has been mapped 1:1 (physical addresses == machine addresses) therefore we don't need to call XENMEM_exchange. Simply return the physical address as dma address. Initialize the xen-swiotlb from xen_early_init (before the native dma_ops are initialized), set xen_dma_ops to &xen_swiotlb_dma_ops. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Changes in v8: - assume dom0 is mapped 1:1, no need to call XENMEM_exchange. Changes in v7: - call __set_phys_to_machine_multi from xen_create_contiguous_region and xen_destroy_contiguous_region to update the P2M; - don't call XENMEM_unpin, it has been removed; - call XENMEM_exchange instead of XENMEM_exchange_and_pin; - set nr_exchanged to 0 before calling the hypercall. Changes in v6: - introduce and export xen_dma_ops; - call xen_mm_init from as arch_initcall. Changes in v4: - remove redefinition of DMA_ERROR_CODE; - update the code to use XENMEM_exchange_and_pin and XENMEM_unpin; - add a note about hardware IOMMU in the commit message. Changes in v3: - code style changes; - warn on XENMEM_put_dma_buf failures.
2013-10-09xen: make xen_create_contiguous_region return the dma addressStefano Stabellini
Modify xen_create_contiguous_region to return the dma address of the newly contiguous buffer. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Changes in v4: - use virt_to_machine instead of virt_to_bus.
2013-10-02tracing/events: Add bounce tracing to swiotblZoltan Kiss
Ftrace is currently not able to detect when SWIOTLB has to do double buffering. Under Xen you can only see it indirectly in function_graph, when xen_swiotlb_map_page() doesn't stop after range_straddles_page_boundary(), but calls spinlock functions, memcpy() and xen_phys_to_bus() as well. This patch introduces the swiotlb:swiotlb_bounced event, which also prints out the following informations to help you find out why bouncing happened: dev_name: 0000:08:00.0 dma_mask=ffffffffffffffff dev_addr=9149f000 size=32768 swiotlb_force=0 If you use Xen, and (dev_addr + size + 1) > dma_mask, the buffer is out of the device's DMA range. If swiotlb_force == 1, you should really change the kernel parameters. Otherwise, the buffer is not contiguous in mfn space. Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> [v1: Don't print 'swiotlb_force=X', just print swiotlb_force if it is enabled] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-08-09swiotlb-xen: replace dma_length with sg_dma_len() macroStefano Stabellini
swiotlb-xen has an implicit dependency on CONFIG_NEED_SG_DMA_LENGTH. Remove it by replacing dma_length with sg_dma_len. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-06-28xen: Convert printks to pr_<level>Joe Perches
Convert printks to pr_<level> (excludes printk(KERN_DEBUG...) to be more consistent throughout the xen subsystem. Add pr_fmt with KBUILD_MODNAME or "xen:" KBUILD_MODNAME Coalesce formats and add missing word spaces Add missing newlines Align arguments and reflow to 80 columns Remove DRV_NAME from formats as pr_fmt adds the same content This does change some of the prefixes of these messages but it also does make them more consistent. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-01-29x86: Don't panic if can not alloc buffer for swiotlbYinghai Lu
Normal boot path on system with iommu support: swiotlb buffer will be allocated early at first and then try to initialize iommu, if iommu for intel or AMD could setup properly, swiotlb buffer will be freed. The early allocating is with bootmem, and could panic when we try to use kdump with buffer above 4G only, or with memmap to limit mem under 4G. for example: memmap=4095M$1M to remove memory under 4G. According to Eric, add _nopanic version and no_iotlb_memory to fail map single later if swiotlb is still needed. -v2: don't pass nopanic, and use -ENOMEM return value according to Eric. panic early instead of using swiotlb_full to panic...according to Eric/Konrad. -v3: make swiotlb_init to be notpanic, but will affect: arm64, ia64, powerpc, tile, unicore32, x86. -v4: cleanup swiotlb_init by removing swiotlb_init_with_default_size. Suggested-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1359058816-7615-36-git-send-email-yinghai@kernel.org Reviewed-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Cc: linux-mips@linux-mips.org Cc: xen-devel@lists.xensource.com Cc: virtualization@lists.linux-foundation.org Cc: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-10-30swiotlb: Use physical addresses instead of virtual in swiotlb_tbl_sync_singleAlexander Duyck
This change makes it so that the sync functionality also uses physical addresses. This helps to further reduce the use of virt_to_phys and phys_to_virt functions. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_tbl_sync_single I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30swiotlb: Use physical addresses for swiotlb_tbl_unmap_singleAlexander Duyck
This change makes it so that the unmap functionality also uses physical addresses. This helps to further reduce the use of virt_to_phys and phys_to_virt functions. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_tbl_unmap_single I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30swiotlb: Return physical addresses when calling swiotlb_tbl_map_singleAlexander Duyck
This change makes it so that swiotlb_tbl_map_single will return a physical address instead of a virtual address when called. The advantage to this once again is that we are avoiding a number of virt_to_phys and phys_to_virt translations by working with everything as a physical address. One change I had to make in order to support using physical addresses is that I could no longer trust 0 to be a invalid physical address on all platforms. So instead I made it so that ~0 is returned on error. This should never be a valid return value as it implies that only one byte would be available for use. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_tbl_map_single I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-22Merge branch 'stable/late-swiotlb.v3.3' into stable/for-linus-3.7Konrad Rzeszutek Wilk
* stable/late-swiotlb.v3.3: xen/swiotlb: Fix compile warnings when using plain integer instead of NULL pointer. xen/swiotlb: Remove functions not needed anymore. xen/pcifront: Use Xen-SWIOTLB when initting if required. xen/swiotlb: For early initialization, return zero on success. xen/swiotlb: Use the swiotlb_late_init_with_tbl to init Xen-SWIOTLB late when PV PCI is used. xen/swiotlb: Move the error strings to its own function. xen/swiotlb: Move the nr_tbl determination in its own function. swiotlb: add the late swiotlb initialization function with iotlb memory xen/swiotlb: With more than 4GB on 64-bit, disable the native SWIOTLB. xen/swiotlb: Simplify the logic. Conflicts: arch/x86/xen/pci-swiotlb-xen.c Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-17xen/swiotlb: Remove functions not needed anymore.Konrad Rzeszutek Wilk
Sparse warns us off: drivers/xen/swiotlb-xen.c:506:1: warning: symbol 'xen_swiotlb_map_sg' was not declared. Should it be static? drivers/xen/swiotlb-xen.c:534:1: warning: symbol 'xen_swiotlb_unmap_sg' was not declared. Should it be static? and it looks like we do not need this function at all. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-17xen/swiotlb: For early initialization, return zero on success.Konrad Rzeszutek Wilk
If everything is setup properly we would return -ENOMEM since rc by default is set to that value. Lets not do that and return a proper return code. Note: The reason the early code needs this special treatment is that it SWIOTLB library call does not return anything (and had it failed it would call panic()) - but our function does. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-17xen/swiotlb: Use the swiotlb_late_init_with_tbl to init Xen-SWIOTLB late ↵Konrad Rzeszutek Wilk
when PV PCI is used. With this patch we provide the functionality to initialize the Xen-SWIOTLB late in the bootup cycle - specifically for Xen PCI-frontend. We still will work if the user had supplied 'iommu=soft' on the Linux command line. Note: We cannot depend on after_bootmem to automatically determine whether this is early or not. This is because when PCI IOMMUs are initialized it is after after_bootmem but before a lot of "other" subsystems are initialized. CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> [v1: Fix smatch warnings] [v2: Added check for xen_swiotlb] [v3: Rebased with new xen-swiotlb changes] [v4: squashed xen/swiotlb: Depending on after_bootmem is not correct in] Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-17xen/swiotlb: Move the error strings to its own function.Konrad Rzeszutek Wilk
That way we can more easily reuse those errors when using the late SWIOTLB init. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-17xen/swiotlb: Move the nr_tbl determination in its own function.Konrad Rzeszutek Wilk
Moving the function out of the way to prepare for the late SWIOTLB init. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-09-12Merge branch 'x86/platform' of ↵Konrad Rzeszutek Wilk
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into stable/for-linus-3.7 * 'x86/platform' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (9690 commits) x86: Document x86_init.paging.pagetable_init() x86: xen: Cleanup and remove x86_init.paging.pagetable_setup_done() x86: Move paging_init() call to x86_init.paging.pagetable_init() x86: Rename pagetable_setup_start() to pagetable_init() x86: Remove base argument from x86_init.paging.pagetable_setup_start Linux 3.6-rc5 HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured Remove user-triggerable BUG from mpol_to_str xen/pciback: Fix proper FLR steps. uml: fix compile error in deliver_alarm() dj: memory scribble in logi_dj Fix order of arguments to compat_put_time[spec|val] xen: Use correct masking in xen_swiotlb_alloc_coherent. xen: fix logical error in tlb flushing xen/p2m: Fix one-off error in checking the P2M tree directory. powerpc: Don't use __put_user() in patch_instruction powerpc: Make sure IPI handlers see data written by IPI senders powerpc: Restore correct DSCR in context switch powerpc: Fix DSCR inheritance in copy_thread() powerpc: Keep thread.dscr and thread.dscr_inherit in sync ...
2012-09-05xen: Use correct masking in xen_swiotlb_alloc_coherent.Ronny Hegewald
When running 32-bit pvops-dom0 and a driver tries to allocate a coherent DMA-memory the xen swiotlb-implementation returned memory beyond 4GB. The underlaying reason is that if the supplied driver passes in a DMA_BIT_MASK(64) ( hwdev->coherent_dma_mask is set to 0xffffffffffffffff) our dma_mask will be u64 set to 0xffffffffffffffff even if we set it to DMA_BIT_MASK(32) previously. Meaning we do not reset the upper bits. By using the dma_alloc_coherent_mask function - it does the proper casting and we get 0xfffffffff. This caused not working sound on a system with 4 GB and a 64-bit compatible sound-card with sets the DMA-mask to 64bit. On bare-metal and the forward-ported xen-dom0 patches from OpenSuse a coherent DMA-memory is always allocated inside the 32-bit address-range by calling dma_alloc_coherent_mask. This patch adds the same functionality to xen swiotlb and is a rebase of the original patch from Ronny Hegewald which never got upstream b/c the underlaying reason was not understood until now. The original email with the original patch is in: http://old-list-archives.xen.org/archives/html/xen-devel/2010-02/msg00038.html the original thread from where the discussion started is in: http://old-list-archives.xen.org/archives/html/xen-devel/2010-01/msg00928.html Signed-off-by: Ronny Hegewald <ronny.hegewald@online.de> Signed-off-by: Stefano Panella <stefano.panella@citrix.com> Acked-By: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: stable@vger.kernel.org
2012-08-23xen/swiotlb: Remove functions not needed anymore.Konrad Rzeszutek Wilk
Sparse warns us off: drivers/xen/swiotlb-xen.c:506:1: warning: symbol 'xen_swiotlb_map_sg' was not declared. Should it be static? drivers/xen/swiotlb-xen.c:534:1: warning: symbol 'xen_swiotlb_unmap_sg' was not declared. Should it be static? and it looks like we do not need this function at all. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-08-21xen/apic/xenbus/swiotlb/pcifront/grant/tmem: Make functions or variables static.Konrad Rzeszutek Wilk
There is no need for those functions/variables to be visible. Make them static and also fix the compile warnings of this sort: drivers/xen/<some file>.c: warning: symbol '<blah>' was not declared. Should it be static? Some of them just require including the header file that declares the functions. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-28X86 & IA64: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [removed swiotlb related changes and replaced it with wrappers, merged with IA64 patch to avoid inter-patch dependences in intel-iommu code] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Luck <tony.luck@intel.com>
2011-12-20Merge tag 'v3.2-rc6' of /home/airlied/devel/kernel/linux-2.6 into drm-core-nextDave Airlie
Merge in the upstream tree to bring in the mainline fixes. Conflicts: drivers/gpu/drm/exynos/exynos_drm_fbdev.c drivers/gpu/drm/nouveau/nouveau_sgdma.c
2011-12-15xen/swiotlb: Use page alignment for early buffer allocation.Konrad Rzeszutek Wilk
This fixes an odd bug found on a Dell PowerEdge 1850/0RC130 (BIOS A05 01/09/2006) where all of the modules doing pci_set_dma_mask would fail with: ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) ata_piix 0000:00:1f.1: can't derive routing for PCI INT A ata_piix 0000:00:1f.1: BMDMA: failed to set dma mask, falling back to PIO The issue was the Xen-SWIOTLB was allocated such as that the end of buffer was stradling a page (and also above 4GB). The fix was spotted by Kalev Leonid which was to piggyback on git commit e79f86b2ef9c0a8c47225217c1018b7d3d90101c "swiotlb: Use page alignment for early buffer allocation" which: We could call free_bootmem_late() if swiotlb is not used, and it will shrink to page alignment. So alloc them with page alignment at first, to avoid lose two pages And doing that fixes the outstanding issue. CC: stable@kernel.org Suggested-by: "Kalev, Leonid" <Leonid.Kalev@ca.com> Reported-and-Tested-by: "Taylor, Neal E" <Neal.Taylor@ca.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-06swiotlb: Expose swiotlb_nr_tlb function to modulesKonrad Rzeszutek Wilk
As a mechanism to detect whether SWIOTLB is enabled or not. We also fix the spelling - it was swioltb instead of swiotlb. CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> [v1: Ripped out swiotlb_enabled] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-10-31xen: Add export.h for THIS_MODULE/EXPORT_SYMBOL to various xen users.Paul Gortmaker
Things like THIS_MODULE and EXPORT_SYMBOL were simply everywhere because module.h was also everywhere. But we are fixing the latter. So we need to call out the real users in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-26xen-swiotlb: When doing coherent alloc/dealloc check before swizzling the MFNs.Konrad Rzeszutek Wilk
The process to swizzle a Machine Frame Number (MFN) is not always necessary. Especially if we know that we actually do not have to do it. In this patch we check the MFN against the device's coherent DMA mask and if the requested page(s) are contingous. If it all checks out we will just return the bus addr without doing the memory swizzle. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-26xen-swiotlb: fix printk and panic argsRandy Dunlap
Fix printk() and panic() args [swap them] to fix build warnings: drivers/xen/swiotlb-xen.c:201: warning: format '%s' expects type 'char *', but argument 2 has type 'int' drivers/xen/swiotlb-xen.c:201: warning: format '%d' expects type 'int', but argument 3 has type 'char *' drivers/xen/swiotlb-xen.c:202: warning: format '%s' expects type 'char *', but argument 2 has type 'int' drivers/xen/swiotlb-xen.c:202: warning: format '%d' expects type 'int', but argument 3 has type 'char *' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-26xen-swiotlb: Fix wrong panic.Konrad Rzeszutek Wilk
Propagate the baremetal git commit "swiotlb: fix wrong panic" (fba99fa38b023224680308a482e12a0eca87e4e1) in the Xen-SWIOTLB version. wherein swiotlb's map_page wrongly calls panic() when it can't find a buffer fit for device's dma mask. It should return an error instead. Devices with an odd dma mask (i.e. under 4G) like b44 network card hit this bug (the system crashes): http://marc.info/?l=linux-kernel&m=129648943830106&w=2 If xen-swiotlb returns an error, b44 driver can use the own bouncing mechanism. CC: stable@kernel.org Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-26xen-swiotlb: Retry up three times to allocate Xen-SWIOTLBKonrad Rzeszutek Wilk
We can fail seting up Xen-SWIOTLB if: - The host does not have enough contiguous DMA32 memory available (can happen on a machine that has fragmented memory from starting, stopping many guests). - Not enough low memory (almost never happens). We retry allocating and exchanging the swath of contiguous memory up to three times. Each time we decrease the amount we need - the minimum being of 2MB. If we compleltly fail, we will print the reason for failure on the Xen console on top of doing it to earlyprintk=xen console. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-09Merge branch 'stable/xen-swiotlb.bugfix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6 * 'stable/xen-swiotlb.bugfix' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6: swiotlb: Export swioltb_nr_tbl and utilize it as appropiate.
2011-06-06swiotlb: Export swioltb_nr_tbl and utilize it as appropiate.FUJITA Tomonori
By default the io_tlb_nslabs is set to zero, and gets set to whatever value is passed in via swiotlb_init_with_tbl function. The default value passed in is 64MB. However, if the user provides the 'swiotlb=<nslabs>' the default value is ignored and the value provided by the user is used... Except when the SWIOTLB is used under Xen - there the default value of 64MB is used and the Xen-SWIOTLB has no mechanism to get the 'io_tlb_nslabs' filled out by setup_io_tlb_npages functions. This patch provides a function for the Xen-SWIOTLB to call to see if the io_tlb_nslabs is set and if so use that value. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-27swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough.Konrad Rzeszutek Wilk
This patchset: PV guests under Xen are running in an non-contiguous memory architecture. When PCI pass-through is utilized, this necessitates an IOMMU for translating bus (DMA) to virtual and vice-versa and also providing a mechanism to have contiguous pages for device drivers operations (say DMA operations). Specifically, under Xen the Linux idea of pages is an illusion. It assumes that pages start at zero and go up to the available memory. To help with that, the Linux Xen MMU provides a lookup mechanism to translate the page frame numbers (PFN) to machine frame numbers (MFN) and vice-versa. The MFN are the "real" frame numbers. Furthermore memory is not contiguous. Xen hypervisor stitches memory for guests from different pools, which means there is no guarantee that PFN==MFN and PFN+1==MFN+1. Lastly with Xen 4.0, pages (in debug mode) are allocated in descending order (high to low), meaning the guest might never get any MFN's under the 4GB mark. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Albert Herranz <albert_herranz@yahoo.es> Cc: Ian Campbell <Ian.Campbell@citrix.com>
