path: root/drivers/watchdog/hpwdt.c
2014-03-31watchdog: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: linux-watchdog@vger.kernel.org
2014-01-28watchdog: hpwdt patch to display informative stringThomas Mingarelli
This patch is being submitted to output a general string when the panic comes in that informs the user of the possible places to look for the source of the NMI. Because various systems log the message in different places this would give a single display of where to go look instead of code that acts on all these different server names or IDs. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: remove DEFINE_PCI_DEVICE_TABLE macroJingoo Han
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro is not preferred. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-17watchdog: Get rid of MODULE_ALIAS_MISCDEV statementsJean Delvare
I just can't find any value in MODULE_ALIAS_MISCDEV(WATCHDOG_MINOR) and MODULE_ALIAS_MISCDEV(TEMP_MINOR) statements. Either the device is enumerated and the driver already has a module alias (e.g. PCI, USB etc.) that will get the right driver loaded automatically. Or the device is not enumerated and loading its driver will lead to more or less intrusive hardware poking. Such hardware poking should be limited to a bare minimum, so the user should really decide which drivers should be tried and in what order. Trying them all in arbitrary order can't do any good. On top of that, loading that many drivers at once bloats the kernel log. Also many drivers will stay loaded afterward, bloating the output of "lsmod" and wasting memory. Some modules (cs5535_mfgpt which gets loaded as a dependency) can't even be unloaded! If defining char-major-10-130 is needed then it should happen in user-space. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Zwane Mwaikambo <zwane@arm.linux.org.uk> Cc: Jim Cromie <jim.cromie@gmail.com>
2013-10-10watchdog: hpwdt: Patch to ignore auxilary iLO devicesMingarelli, Thomas
This patch is to prevent hpwdt from loading on any auxilary iLO devices defined after the initial (or main) iLO device. All auxilary iLO devices will have a subsystem device ID set to 0x1979 in order for hpwdt to differentiate between the two types. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Tested-by: Lisa Mitchell <lisa.mitchell@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-09-11lto, watchdog/hpwdt.c: make assembler label globalAndi Kleen
We cannot assume that the inline assembler code always ends up in the same file as the original C file. So make any assembler labels that are called with "extern" by C global Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-11watchdog: hpwdt: Add check for UEFI bitsMingarelli, Thomas
This patch is being created to use the UEFI bits in the type 219 SMBIOS record in order to decide whether or not to execute BIOS code. This is a better solution than to depend on the iCRU bit since not all future servers will use iCRU. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> ---- drivers/watchdog/hpwdt.c | 9 ++++++--- 1 files changed, 6 insertions(+), 3 deletions(-)
2012-12-19watchdog: hpwdt.c: Increase version stringTom Mingarelli
Changing the version of the driver for all the latest patches being applied for kdump fixes. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-11-28watchdog: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-10hpwdt: Fix kdump issue in hpwdtToshi Kani
kdump can be interrupted by watchdog timer when the timer is left activated on the crash kernel. Changed the hpwdt driver to disable watchdog timer at boot-time. This assures that watchdog timer is disabled until /dev/watchdog is opened, and prevents watchdog timer to be left running on the crash kernel. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Tested-by: Lisa Mitchell <lisa.mitchell@hp.com> Signed-off-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@vger.kernel.org>
2012-06-28watchdog: hpwdt: Unregister NMI events on exit.Mingarelli, Thomas
This patch is to unregister for NMI events upon exit. Also we are now making the default setting for allow_kdump enabled. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-05-23watchdog: Use module_pci_driverWim Van Sebroeck
This patch converts the PCI watchdog drivers so that they use the module_pci_driver() macro. This makes the code smaller and simpler. Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Thomas Mingarelli <thomas.mingarelli@hp.com> Cc: Marc Vertes <marc.vertes@sigfox.com>
2012-05-21Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Ingo Molnar: "This update: - extends and simplifies x86 NMI callback handling code to enhance and fix the HP hw-watchdog driver - simplifies the x86 NMI callback handling code to fix a kmemcheck bug. - enhances the hung-task debugger" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/nmi: Fix the type of the nmiaction.flags field x86/nmi: Fix page faults by nmiaction if kmemcheck is enabled x86/nmi: Add new NMI queues to deal with IO_CHK and SERR watchdog, hpwdt: Remove priority option for NMI callback hung task debugging: Inject NMI when hung and going to panic
2012-04-26hpwdt: Only BYTE reads/writes to WD Timer port 0x72Mingarelli, Thomas
This patch is to correct the use of the iLO port 0x72 usage. The port 0x72 is a byte size write/read and hpwdt is currently writing a WORD. Signed-off by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-04-25x86/nmi: Add new NMI queues to deal with IO_CHK and SERRDon Zickus
In discussions with Thomas Mingarelli about hpwdt, he explained to me some issues they were some when using their virtual NMI button to test the hpwdt driver. It turns out the virtual NMI button used on HP's machines do no send unknown NMIs but instead send IO_CHK NMIs. The way the kernel code is written, the hpwdt driver can not register itself against that type of NMI and therefore can not successfully capture system information before panic'ing. To solve this I created two new NMI queues to allow driver to register against the IO_CHK and SERR NMIs. Or in the hpwdt all three (if you include unknown NMIs too). The change is straightforward and just mimics what the unknown NMI does. Reported-and-tested-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1333051877-15755-3-git-send-email-dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-04-25watchdog, hpwdt: Remove priority option for NMI callbackDon Zickus
The NMI_UNKNOWN bucket only allows for one function to register to it. The reason for that is because only functions which can not determine if the NMI belongs to them or not should register and would like to assume/swallow any NMI they see. As a result it doesn't make sense to let more than one function like this register. In fact, letting a second function fail allows us to know that more than one function is going to swallow NMIs on the current system. This is better than silently being ignored. Therefore hpwdt's priority mechanism doesn't make sense any more. They will be always first on the NMI_UNKNOWN queue, if they register. Removing this parameter cleans up the code and simplifies things for the next patch which changes how nmis are registered. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Thomas Mingarelli <thomas.mingarelli@hp.com> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1333051877-15755-2-git-send-email-dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-02-28watchdog: hpwdt: clean up set_memory_x call for 32 bitMaxim Uvarov
1. address has to be page aligned. 2. set_memory_x uses page size argument, not size. Bug causes with following commit: commit da28179b4e90dda56912ee825c7eaa62fc103797 Author: Mingarelli, Thomas <Thomas.Mingarelli@hp.com> Date: Mon Nov 7 10:59:00 2011 +0100 watchdog: hpwdt: Changes to handle NX secure bit in 32bit path commit e67d668e147c3b4fec638c9e0ace04319f5ceccd upstream. This patch makes use of the set_memory_x() kernel API in order to make necessary BIOS calls to source NMIs. Signed-off-by: Maxim Uvarov <maxim.uvarov@oracle.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@vger.kernel.org>
2011-12-26watchdog: hpwdt: Changes to handle NX secure bit in 32bit pathMingarelli, Thomas
This patch makes use of the set_memory_x() kernel API in order to make necessary BIOS calls to source NMIs. This is needed for SLES11 SP2 and the latest upstream kernel as it appears the NX Execute Disable has grown in its control. Signed-off by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off by: Wim Van Sebroeck <wim@iguana.be> Cc: stable@kernel.org
2011-10-10x86, nmi, drivers: Fix nmi splitup build bugIngo Molnar
nmi.c needs an #include <linux/mca.h>: arch/x86/kernel/nmi.c: In function ‘unknown_nmi_error’: arch/x86/kernel/nmi.c:286:6: error: ‘MCA_bus’ undeclared (first use in this function) arch/x86/kernel/nmi.c:286:6: note: each undeclared identifier is reported only once for each function it appears in Another one is the hpwdt driver: drivers/watchdog/hpwdt.c:507:9: error: ‘NMI_DONE’ undeclared (first use in this function) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-10x86, nmi: Wire up NMI handlers to new routinesDon Zickus
Just convert all the files that have an nmi handler to the new routines. Most of it is straight forward conversion. A couple of places needed some tweaking like kgdb which separates the debug notifier from the nmi handler and mce removes a call to notify_die. [Thanks to Ying for finding out the history behind that mce call https://lkml.org/lkml/2010/5/27/114 And Boris responding that he would like to remove that call because of it https://lkml.org/lkml/2011/9/21/163] The things that get converted are the registeration/unregistration routines and the nmi handler itself has its args changed along with code removal to check which list it is on (most are on one NMI list except for kgdb which has both an NMI routine and an NMI Unknown routine). Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Corey Minyard <minyard@acm.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Corey Minyard <minyard@acm.org> Cc: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/1317409584-23662-4-git-send-email-dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-20watchdog: hpwdt: prevent multiple "NMI occurred" messagesNaga Chumbalkar
On platforms with no iCRU support don't print two, (possibly conflicting), "NMI occurred" messages when the firmware is unable to source the NMI. Please note that one of the enhancements to the v1.3.0 hpwdt driver is to panic and allow KDUMP to succeed even on NMIs that are unknown to the platform firmware. Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Reviewed-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-28watchdog: hpwdt: add next gen HP serversThomas Mingarelli
This patch is required to enable hpwdt to work on next generation HP servers with iLO. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-15watchdog: convert to DEFINE_PCI_DEVICE_TABLEWim Van Sebroeck
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-14watchdog: hpwdt: eliminate section mismatch warningAxel Lin
hpwdt_init_nmi_decoding() is called in hpwdt_init_one error handling, thus remove the __devexit annotation of hpwdt_exit_nmi_decoding(). This patch fixes below warning: WARNING: drivers/watchdog/hpwdt.o(.devinit.text+0x36f): Section mismatch in reference from the function hpwdt_init_one() to the function .devexit.text:hpwdt_exit_nmi_decoding() The function __devinit hpwdt_init_one() references a function __devexit hpwdt_exit_nmi_decoding(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __devexit annotation of hpwdt_exit_nmi_decoding() so it may be used outside an exit section. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-01-07x86: Convert some devices to use DIE_NMIUNKNOWNDon Zickus
They are a handful of places in the code that register a die_notifier as a catch all in case no claims the NMI. Unfortunately, they trigger on events like DIE_NMI and DIE_NMI_IPI, which depending on when they registered may collide with other handlers that have the ability to determine if the NMI is theirs or not. The function unknown_nmi_error() makes one last effort to walk the die_chain when no one else has claimed the NMI before spitting out messages that the NMI is unknown. This is a better spot for these devices to execute any code without colliding with the other handlers. The two drivers modified are only compiled on x86 arches I believe, so they shouldn't be affected by other arches that may not have DIE_NMIUNKNOWN defined. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Russ Anderson <rja@sgi.com> Cc: Corey Minyard <minyard@acm.org> Cc: openipmi-developer@lists.sourceforge.net Cc: dann frazier <dannf@hp.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294348732-15030-3-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-22x86, nmi_watchdog: Remove ARCH_HAS_NMI_WATCHDOG and rely on ↵Don Zickus
CONFIG_HARDLOCKUP_DETECTOR The x86 arch has shifted its use of the nmi_watchdog from a local implementation to the global one provide by kernel/watchdog.c. This shift has caused a whole bunch of compile problems under different config options. I attempt to simplify things with the patch below. In order to simplify things, I had to come to terms with the meaning of two terms ARCH_HAS_NMI_WATCHDOG and CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing, the former on a local level and the latter on a global level. With the old x86 nmi watchdog gone, there is no need to rely on defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't make sense any more. x86 will now use the global implementation. The changes below do a few things. First it changes the few places that relied on ARCH_HAS_NMI_WATCHDOG to use CONFIG_X86_LOCAL_APIC (the former was an alias for the latter anyway, so nothing unusual here). Those pieces of code were relying more on local apic functionality the nmi watchdog functionality, so the change should make sense. Second, I removed the x86 implementation of touch_nmi_watchdog(). It isn't need now, instead x86 will rely on kernel/watchdog.c's implementation. Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from x86. And tweaked the include/linux/nmi.h file to tell users to look for an externally defined touch_nmi_watchdog in the case of ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This changes removes some of the ugliness in that file. Finally, I added a Kconfig dependency for CONFIG_HARDLOCKUP_DETECTOR that said you can't have ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can only have one nmi_watchdog. Tested with ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig, (various broken configs) Hopefully, after this patch I won't get any more compile broken emails. :-) v3: changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86, nmi_watchdog: Remove all stub function calls from old nmi_watchdogDon Zickus
Now that the bulk of the old nmi_watchdog is gone, remove all the stub variables and hooks associated with it. This touches lots of files mainly because of how the io_apic nmi_watchdog was implemented. Now that the io_apic nmi_watchdog is forever gone, remove all its fingers. Most of this code was not being exercised by virtue of nmi_watchdog != NMI_IO_APIC, so there shouldn't be anything to risky here. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: fweisbec@gmail.com Cc: gorcunov@openvz.org LKML-Reference: <1289578944-28564-3-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-13watchdog: hpwdt (12/12): Make NMI decoding a compile-time optiondann frazier
hpwdt is quite functional without the NMI decoding feature. This change lets users disable the NMI portion at compile-time via the new HPWDT_NMI_DECODING config option. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (11/12): move NMI-decoding init and exit to seperate functionsdann frazier
Move NMI-decoding initialisation and exit code to seperate functions so that we can ifdef-out parts of it in the future. Also, this is for a device, so let's use dev_info instead of printk. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (10/12): Use "decoding" instead of "sourcing"dann frazier
The term "decoding" more clearly explains what hpwdt is doing. It isn't just finding the source of the interrupt, but rather aids in decoding what the interrupt means. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (9/12): hpwdt_pretimeout reorganizationdann frazier
Reorganize this function to remove excess indentation and highlight the single return code. (No functional change). Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (8/12): implement WDIOC_GETTIMELEFTdann frazier
Let applications check the amount of time left before the watchdog will fire. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (7/12): allow full range of timer values supported by hardwaredann frazier
The hpwdt timer is a 16 bit value with 128ms resolution. Let applications use this entire range. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (6/12): Introduce SECS_TO_TICKS() macrodann frazier
Define a macro to convert from seconds to timer ticks. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (5/12): Make x86 assembly ifdef guard more strictdann frazier
The 32-bit assembly is guarded by an #ifndef CONFIG_X86_64. Kconfig prevents us from building this driver on !X86, so that happens to suffice - but we should really lock it down to #ifdef CONFIG_X86_32. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (4/12): Despecificate driver from iLO2dann frazier
This driver supports both iLO2 and iLO3, but our user-visible strings currently only reference iLO2. Let's just call it "iLO2+" to avoid having to update strings for each iLO generation. This driver doesn't support iLO ASICs prior to iLO2, but that is sufficiently explained in Kconfig. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (3/12): Group NMI sourcing specific items togetherdann frazier
* Group together includes specific to NMI sourcing * Group defines only used by NMI sourcing together * Group declarations specific to NMI sourcing together This gives a clean seperation of watchdog specific items and NMI sourcing specific items (which is needed for making it possible to build hpwdt without the NMI functionality). Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (2/12): Group options that affect watchdog behavior togetherdann frazier
Reorganization only. Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-13watchdog: hpwdt (1/12): clean-up include-files.dann frazier
* remove unnecessary includes * We use a spinlock, but lacked the include * We need bitops.h for test_and_set_bit/clear_bit Signed-off-by: dann frazier <dannf@hp.com> Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-08-08watchdog: hpwdt: formatting of pointers in printk()Kulikov Vasiliy
Use %p instead of %08x in printk(). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] hpwdt - fix lower timeout limit [WATCHDOG] iTCO_wdt: TCO Watchdog patch for additional Intel Cougar Point DeviceIDs [WATCHDOG] doc: Fix use of WDIOC_SETOPTIONS ioctl. [WATCHDOG] doc: watchdog simple example: don't fail on fsync() [WATCHDOG] set max63xx driver as ARM only [WATCHDOG] powerpc: pika_wdt ident cannot be const
2010-04-06[WATCHDOG] hpwdt - fix lower timeout limitThomas Mingarelli
[Novell Bug 581103] HP Watchdog driver has arbitrary (wrong) timeout limits. Fix the lower timeout limit to a more appropriate value. Signed-off-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-23[WATCHDOG] hpwdt: Add NMI priority optionTom Mingarelli
Add a priority option so that the user can choose if we do the NMI first or last. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-18[WATCHDOG] hpwdt: Add NMI sourcingThomas Mingarelli
Add NMI sourcing functionality (Can only be active if nmi_watchdog is inactive). Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
