path: root/drivers/watchdog/advantechwdt.c
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] more coding style clean-up'sWim Van Sebroeck
More coding style clean-up's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Clean-up includesWim Van Sebroeck
Use #include <linux/io.h> instead of <asm/io.h> Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Clean-up includes. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-27[WATCHDOG 02/57] clean up and check advantech watchdogAlan Cox
Clean up the advantech watchdog code and inspect for BKL problems Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
