- white space changes.
- list_for_each_entry/list_for_each_entry_safe and reverse changes.
- small coding style changes.
- removed redundant NULL checks.
- use attribute group and macros instead of direct device attributes.
Patch is havily based on work from Adrian Bunk and Dmitry Torokhov,
thanks guys.
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
drivers/zorro/zorro-sysfs.c: update device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
Real fix for big endian machines - crc must be calculated
using little endian byte order.
infrastructure for it.
Let it rip!
