path: root/drivers/w1/masters/ds1wm.c
2014-06-19w1/masters: use pr_* instead of printkFjodor Schelichow
This patch replaces all calls to the "printk" function within the "masters" subdirectory by calls to the appropriate "pr_*" function thus addressing the following warning generated by the checkpatch script: WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Fjodor Schelichow <fjodor.schelichow@hotmail.com> Signed-off-by: Roman Sommer <romsom2@yahoo.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13drivers/w1/masters/ds1wm.cuse dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16w1: ds1wm: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch proposes to remove the use of the IRQF_DISABLED flag It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15drivers/w1/masters/ds1wm.c: use devm_ functionsJulia Lawall
The various devm_ functions allocate memory that is released when a driver detaches. This patch uses these functions for data that is allocated in the probe function of a platform device and is only freed in the remove function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-01treewide: fix comment/printk/variable typosAnatol Pomozov
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-13W1: split master mutex to avoid deadlocks.NeilBrown
The 'mutex' in struct w1_master is use for two very different purposes. Firstly it protects various data structures such as the list of all slaves. Secondly it protects the w1 buss against concurrent accesses. This can lead to deadlocks when the ->probe code called while adding a slave needs to talk on the bus, as is the case for power_supply devices. ds2780 and ds2781 drivers contain a work around to track which process hold the lock simply to avoid this deadlock. bq27000 doesn't have that work around and so deadlocks. There are other possible deadlocks involving sysfs. When removing a device the sysfs s_active lock is held, so the lock that protects the slave list must take precedence over s_active. However when access power_supply attributes via sysfs, the s_active lock must take precedence over the lock that protects accesses to the bus. So to avoid deadlocks between w1 slaves and sysfs, these must be two separate locks. Making them separate means that the work around in ds2780 and ds2781 can be removed. So this patch: - adds a new mutex: "bus_mutex" which serialises access to the bus. - takes in mutex in w1_search and ds1wm_search while they access the bus for searching. The mutex is dropped before calling the callback which adds the slave. - changes all slaves to use bus_mutex instead of mutex to protect access to the bus - removes w1_ds2790_io_nolock and w1_ds2781_io_nolock, and the related code from drivers/power/ds278[01]_battery.c which calls them. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-07-08w1: ds1wm: add a reset recovery parameterJean-François Dagenais
This fixes a regression in 3.0 reported by Paul Parsons regarding the removal of the msleep(1) in the ds1wm_reset() function: : The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying" : error messages on an HP iPAQ hx4700 PDA (XScale-PXA270): : : <snip> : Driver for 1-wire Dallas network protocol. : DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko : 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko : ds1wm ds1wm: pass: 1 bus error, retrying : ds1wm ds1wm: pass: 2 bus error, retrying : ds1wm ds1wm: pass: 3 bus error, retrying : ds1wm ds1wm: pass: 4 bus error, retrying : ds1wm ds1wm: pass: 5 bus error, retrying : ... : : The visible result is that the battery charging LED is erratic; sometimes : it works, mostly it doesn't. : : The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1, : 3.0-rc2, or 3.0-rc3. This sleep should not be required on normal circuitry provided the pull-ups on the bus are correctly adapted to the slaves. Unfortunately, this is not always the case. The sleep is restored but as a parameter to the probe function in the pdata. [akpm@linux-foundation.org: coding-style fixes] Reported-by: Paul Parsons <lost.distance@yahoo.com> Tested-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26w1: complete the 1-wire (w1) ds1wm driver search algorithmJean-François Dagenais
This adds multi-slave support of the w1 bus for the ds1wm Synthesizable 1-Wire Bus Master. Also many fixes and tweaks based on the rev3 of the datasheet http://datasheets.maxim-ic.com/en/ds/DS1WM.pdf Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Szabolcs Gyurko <szabolcs.gyurko@tlt.hu> Cc: Matt Reimer <mreimer@vpop.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26w1: Use device platform_data to retrieve ds1wm platform bitsSamuel Ortiz
With the addition of the platform device mfd_cell pointer, we can now cleanly pass the sub device drivers platform data pointers through the regular device platform_data one, and get rid of mfd_get_data(). Cc: Matt Reimer <mreimer@vpop.net> Cc: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-23w1: Silence ds1wm warnings related to mfd_get_cell changesAndres Salomon
mfd_get_cell returns a const, so change the ds1wm client to store a const mfd cell. This silences type mismatch warnings. Since we're guaranteed to have the mfd_cell, we can also simplify the code a bit to get rid of a temporary variable and NULL check. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23w1: Use mfd_data instead of driver_data for dsw1wm.cAndres Salomon
Use mfd_data for passing information from mfd drivers to mfd clients. The mfd_cell's driver_data field is being phased out. Clients that were using driver_data now access .mfd_data via mfd_get_data(). This changes ds1wm only; mfd drivers with other cells are not modified, with the exception of led_cell. The led_cell.driver_data line is dropped from htc-pasic3.c in this patch as well. It's not used in mainline (there's no leds-pasic3 platform driver), so it should be safe to take care of that here. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to asic3 driversAndres Salomon
No need to explicitly set the cell's platform_data/data_size. Modify clients to use mfd_get_cell helper function instead of accessing platform_data directly. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-05mfd: remove DS1WM clock handlingPhilipp Zabel
This driver requests a clock that usually is supplied by the MFD in which the DS1WM is contained. Currently, it is impossible for a MFD to register their clocks with the generic clock API due to different implementations across architectures. For now, this patch removes the clock handling from DS1WM altogether, trusting that the MFD enable/disable functions will switch the clock if needed. The clock rate is obtained from a new parameter in driver_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2009-04-05mfd: convert DS1WM to use MFD corePhilipp Zabel
This patch converts the DS1WM driver into an MFD cell. It also calculates the bus_shift parameter from the memory resource size. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-16W1: ds1wm.c msleep for resetDavid Fries
Like the previous w1_io.c reset coments and msleep patch, I don't have the hardware to verify the change, but I think it is safe. It also helps to see a comment like this in the code. "We'll wait a bit longer just to be sure." If they are going to calculate delaying 324.9us, but actually delay 500us, why not just give up the CPU and sleep? This is designed for a battery powered ARM system, avoiding busywaiting has to be good for battery life. I sent a request for testers March 7, 2008 to the Linux kernel mailing list and two developers who have patches for ds1wm.c, but I didn't get any respons. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: fix deadlocks and remove w1_control_threadDavid Fries
w1_control_thread was removed which would wake up every second and process newly registered family codes and complete some final cleanup for a removed master. Those routines were moved to the threads that were previously requesting those operations. A new function w1_reconnect_slaves takes care of reconnecting existing slave devices when a new family code is registered or removed. The removal case was missing and would cause a deadlock waiting for the family code reference count to decrease, which will now happen. A problem with registering a family code was fixed. A slave device would be unattached if it wasn't yet claimed, then attached at the end of the list, two unclaimed slaves would cause an infinite loop. The struct w1_bus_master.search now takes a pointer to the struct w1_master device to avoid searching for it, which would have caused a lock ordering deadlock with the removal of w1_control_thread. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04ds1wm: report bus reset errorAnton Vorontsov
The patch replaces dev_dbg() by dev_err(), so the user could actually see the error, instead of wondering why w1 doesn't work. The root cause of the bus reset error isn't yet debugged though, but this sometimes happens on iPaq H5555. And while I'm at it, some cosmetic cleanups also made (few lines were using spaces instead of tabs). Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04ds1wm: should check for IS_ERR(clk) instead of NULLAnton Vorontsov
On the error condition clk_get() returns ERR_PTR(..), so checking for NULL doesn't work. ds1wm module causes a kernel oops when ds1wm clock isn't registered. This patch converts NULL check to IS_ERR(), plus uses PTR_ERR() for the return code. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07DS1WM: decouple host IRQ and INTR active state settingsPhilipp Zabel
The DS1WM driver incorrectly infers the IAS bit (1-wire interrupt active high) from IRQ settings. There are devices that have IAS=0 but still need the IRQ to trigger on a rising edge. With this patch, machines with DS1WM that need IAS=1 have to set .active_high=1 in the ds1wm_platform_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Acked-by: Matt Reimer <mreimer@vpop.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26drivers/ misc __iomem annotationsAl Viro
2007-05-08Driver for the Maxim DS1WM, a 1-wire bus master ASIC coreakpm@linux-foundation.org
Cc: Matt Reimer <mreimer@vpop.net> [akpm@linux-foundation.org: kconfig update] Signed-off-by: Matt Reimer <mreimer@vpop.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
