path: root/drivers/virtio/virtio_mmio.c
2013-01-03Drivers: virtio: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-18virtio-mmio: Fix irq parsing in command line parameterPawel Moll
When the resource_size_t is 64-bit long, the sscanf() on the virtio device command line paramter string may return wrong value because its format was defined as "%u". Fixed by using an intermediate local value of a known length. Also added cleaned up the resource creation and added extra comments to make the parameters parsing easier to follow. Reported-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-18virtio: move queue_index and num_free fields into core struct virtqueue.Rusty Russell
They're generic concepts, so hoist them. This also avoids accessor functions (though kept around for merge with DaveM's net tree). This goes even further than Jason Wang's 17bb6d4088 patch ("virtio-ring: move queue_index to vring_virtqueue") which moved the queue_index from the specific transport. Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28virtio_mmio: Don't attempt to create empty virtqueuesBrian Foley
If a virtio device reports a QueueNumMax of 0, vring_new_virtqueue() doesn't check this, and thanks to an unsigned (i < num - 1) loop guard, scribbles over memory when initialising the free list. Avoid by not trying to create zero-descriptor queues, as there's no way to do any I/O with one. Signed-off-by: Brian Foley <brian.foley@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28virtio_mmio: fix off by one error allocating queueBrian Foley
vm_setup_vq fails to allow VirtQueues needing only 2 pages of storage, as it should. Found with a kernel using 64kB pages, but can be provoked if a virtio device reports QueueNumMax where the descriptor table and available ring fit in one page, and the used ring on the second (<= 227 descriptors with 4kB pages and <= 3640 with 64kB pages.) Signed-off-by: Brian Foley <brian.foley@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28virtio: support reserved vqsMichael S. Tsirkin
virtio network device multiqueue support reserves vq 3 for future use (useful both for future extensions and to make it pretty - this way receive vqs have even and transmit - odd numbers). Make it possible to skip initialization for specific vq numbers by specifying NULL for name. Document this usage as well as (existing) NULL callback. Drivers using this not coded up yet, so I simply tested with virtio-pci and verified that this patch does not break existing drivers. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-28virtio-ring: move queue_index to vring_virtqueueJason Wang
Instead of storing the queue index in transport-specific virtio structs, this patch moves them to vring_virtqueue and introduces an helper to get the value. This lets drivers simplify their management and tracing of virtqueues. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-22virtio-mmio: Devices parameter parsingPawel Moll
This patch adds an option to instantiate guest virtio-mmio devices basing on a kernel command line (or module) parameter, for example: virtio_mmio.devices=0x100@0x100b0000:48 Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12virtio: harsher barriers for rpmsg.Rusty Russell
We were cheating with our barriers; using the smp ones rather than the real device ones. That was fine, until rpmsg came along, which is used to talk to a real device (a non-SMP CPU). Unfortunately, just putting back the real barriers (reverting d57ed95d) causes a performance regression on virtio-pci. In particular, Amos reports netbench's TCP_RR over virtio_net CPU utilization increased up to 35% while throughput went down by up to 14%. By comparison, this branch is in the noise. Reference: https://lkml.org/lkml/2011/12/11/22 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-12-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-11-24virtio-mmio: Correct the name of the guest features selectorSasha Levin
Guest features selector spelling mistake. Cc: Pawel Moll <pawel.moll@arm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: virtualization@lists.linux-foundation.org Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-16enable virtio_net to return bus_info in ethtool -i consistent with emulated NICsRick Jones
Add a new .bus_name to virtio_config_ops then modify virtio_net to call through to it in an ethtool .get_drvinfo routine to report bus_info in ethtool -i output which is consistent with other emulated NICs and the output of lspci. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-02virtio: Add platform bus driver for memory mapped virtio devicePawel Moll
This patch, based on virtio PCI driver, adds support for memory mapped (platform) virtio device. This should allow environments like qemu to use virtio-based block & network devices even on platforms without PCI support. One can define and register a platform device which resources will describe memory mapped control registers and "mailbox" interrupt. Such device can be also instantiated using the Device Tree node with compatible property equal "virtio,mmio". Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Michael S.Tsirkin <mst@redhat.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
