path: root/drivers/video/tgafb.c
2014-01-17tgafb: potential NULL dereference in initDan Carpenter
Static checkers complain that there are paths where "tga_type_name" can be NULL. I've re-arranged the code slightly so that's impossible. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-01-17video: Replace local macro with PCI standard macroYijing Wang
Replace local macro TGA_BUS_PCI with PCI standard marco dev_is_pci(). Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-10-29framebuffer: Use fb_<level>Joe Perches
Neaten and shorten the code using the new fb_<level> macros. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-01tgafb: fix cmap memory leakAndres Salomon
Fix cmap leak when register_framebuffer fails. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tgafb: remove a redundant non-mono test in mono imageblitMaciej W. Rozycki
There is a test in tgafb_mono_imageblit() for a colour image with a fall-back to cfb_imageblit(). The test is not necessary as the only caller, which is tgafb_imageblit(), checks it too and only invokes this function for monochrome images. It looks like a left-over from before some changes to tgafb_imageblit(). Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Antonino Daplas <adaplas@pol.net> Cc: Jay Estabrook <Jay.Estabrook@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tgafb: fix an out-of-range shift in mono imageblitMaciej W. Rozycki
The pixel mask calculation in tgafb_mono_imageblit() uses a variable left-shift on a 32-bit data type by up to 32. Shifting by the width of a data type or more produces an unpredictable result according to the C standard. Rather than widening the data type this fix makes sure the count is between 0 and 31. The reason is not to penalise 32-bit platforms with operation on a "long long" type for a marginal case that is meant not to happen (blitting an image of a zero width). The reason it has escaped for so long is the Alpha, being purely 64-bit, :-) does not mask the shift out to 32 bits. This is a valid implementation -- producing the correct result certainly falls within "unpredictable behaviour". It does trigger on MIPS though and it is the recent merge of the TC support which only enabled the driver for use on anything other than the Alpha. For MIPS when the width is 32 the mask ends up being 0 rather than 0xffffffff as it should be and the frame buffer is not updated. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Antonino Daplas <adaplas@pol.net> Cc: Jay Estabrook <Jay.Estabrook@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26drivers/ misc __iomem annotationsAl Viro
2007-07-17tgafb: actually allocate memory for the pseudo_paletteAntonino A. Daplas
No memory allocation was done for the pseudo_palette. Allocate one for it. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08tgafb accelerated codeJames Simmons
Add accelerated panning and accelerated color and mono image drawing. Please apply. Signed-off-by: James Simmons <jsimmons@infradead.org> Acked-by: Maciej W. Rozycki <macro@linux-mips.org> (tested, too!) Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tgafb: TURBOchannel supportMaciej W. Rozycki
This is support for the TC variations of the TGA boards (properly known as SFB+ or Smart Frame Buffer Plus boards). The 8-plane SFB+ board uses the Bt459 RAMDAC (unlike its PCI TGA counterpart, which uses the Bt485), so bits have been added to support this chip as well. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: James Simmons <jsimmons@infradead.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: Fix the PCI ID tableMaciej W. Rozycki
The end marker is missing from the driver's PCI ID table. This set of changes adds the marker, switches to using PCI_DEVICE() and records the table for the use in a module. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: sync-on-green support fixesMaciej W. Rozycki
This sets up the deep register of the TGA ASIC as well as the blank pedestal of the Bt463 RAMDAC correctly for the sync-on-green mode. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: module support fixesMaciej W. Rozycki
This is a set of clean-ups for the module support in the driver -- __devinit and __devexit classifiers are now specified correctly, initialization functions are marked static and a few unnecessary #ifdefs are removed. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: fix the mode register settingMaciej W. Rozycki
There is no need to set the GE bit (Win32 compatibility) in the mode register; it shall get cleared with the next subsequent update to the register anyway. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: support the DirectColor visualMaciej W. Rozycki
The 32-plane variations of the TGA use the Bt463 RAMDAC and are therefore DirectColor rather than TrueColor adapters. This is a set of changes to implement the necessary bits to support this model. A couple of fixes to fix accesses to the RAMDAC are included as a side-effect. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: fix copying overlapping areasMaciej W. Rozycki
The direction of copying in the copyarea functions is selected incorrectly, resulting in corruption. This is a fix. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tgafb: switch to framebuffer_alloc()Maciej W. Rozycki
This is a set of changes to update the driver to the framebuffer_alloc() API. Included, there is also a fix to a memory leak due to the colour map allocation not being freed upon driver's removal. Aside from the fix there are no functional changes. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ioremap balanced with iounmap for drivers/video/tgafbAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] video: use bitrev8Akinobu Mita
Use bitrev8 for nvidiafb, rivafb, and tgafb drivers Cc: Antonino Daplas <adaplas@pol.net> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fbdev: Remove duplicate #include'sAdrian Bunk
Remove unneeded duplicate #include's of the same header file. In the case of fbmon.c linux/pci.h is now #include'd unconditional, but this should be safe. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-21[PATCH] Fix tgafb.c compile failureAdrian Bunk
The untested patch below should fix this compile error. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
