path: root/drivers/video/tcx.c
2013-10-30video: Remove unnecessary semicolonsJoe Perches
These aren't necessary after switch, for, and if blocks. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-09-26video: tcx: Remove redundant dev_set_drvdataSachin Kamat
Driver core sets driver data to NULL upon failure or remove. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-03-22video: add missing framebuffer_release in error pathaxel lin
This patch fixes a memory leak in the error path. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-02-28dt/video: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/video. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-06-02of/video: fix build breakage in FB driversAnatolij Gustschin
Fixes build errors in a number of framebuffer drivers caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-16tcx: use standard fields for framebuffer physical address and lengthKrzysztof Helt
Use standard fields fbinfo.fix.smem_start and fbinfo.fix.smem_len for physical address and length of framebuffer. This also fixes output of the 'fbset -i' command - address and length of the framebuffer are displayed correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08sparc video: remove open boot prom codeRobert Reif
Replace remaining open boot prom code with of. Boot tested on sparc32 and compile tested on sparc64. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-03sparc: tcx.c remove unnecessary functionRobert Reif
From: Robert Reif <reif@earthlink.net> Replaced tcx_init_one with tcx_probe. Fixed some checkpatch problems. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc: video drivers: add facility levelRobert Reif
Add KERN_ facility level to sparc video drivers. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc: tcx.c make tcx_init and tcx_exit staticRobert Reif
Make tcx_init and tcx_exit static. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-26sparc: fix drivers/video/tcx.c warningRobert Reif
Fix compile warning: CC drivers/video/tcx.o drivers/video/tcx.c: In function ‘tcx_init_one’: drivers/video/tcx.c:477: warning: format ‘%lx’ expects type ‘long unsigned int’, but argument 4 has type ‘resource_size_t’ This was the only sparc driver to use the resource directly in the printk so I changed it to physbase like the other drivers. Boot tested on SS4. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30[VIDEO]: Fix OOPS in all SBUS framebuffer drivers.David S. Miller
All of these drivers use a silly: struct all_info { struct fb_info info; struct foo_par par; }; struct all_info *all = kzalloc(sizeof(*all), GFP_KERNEL); all->info.par = &all->par; etc. etc. code sequence, basically replicating the provided framebuffer_alloc()/framebuffer_release(), and doing it badly. Not only is this massive code duplication, it also caused a bug in that we weren't setting the fb_info->device pointer which results in an OOPS when fb_is_primary_device() runs. Fix all of this by using framebuffer_{alloc,release}() and passing in "&of_device->dev" as the device pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC]: Convert all FB SBUS drivers to of_driver framework.David S. Miller
2006-01-14[PATCH] fbdev: Sanitize ->fb_mmap prototypeChristoph Hellwig
No need for a file argument. If we'd really need it it's in vma->vm_file already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but the kernel alrady did that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[SBUSFB] tcx: Use FB_BLANK_UNBLANK instead of magic constant.Hareesh Nagarajan
From: Hareesh Nagarajan <hnagar2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-12[SBUSFB]: Kill 'list' member from foo_par structs, totally unused.David S. Miller
Based upon a patch from Hareesh Nagarajan. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-12[SBUSFB]: implement ->compat_ioctlChristoph Hellwig
This patch adds a new function, sbusfb_compat_ioctl() to drivers/video/sbuslib.c and uses it as compat_ioctl in all sbus fb drivers This remove the last per-arch compat ioctl bits in arch/sparc64/kernel/ioctl32.c so it would be nice if people could test if this actually copiles and works and if yes apply it :) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SPARC]: TCX Framebuffer fixesTom 'spot' Callaway
Using the same logic as the other framebuffer fixes committed in 2.6.11, this is a set of fixes to make TCX functional on the console again. Adds the tcx_pan_display function, sets the all->info.var.{red,green,blue}.length values to 8, and runs fb_set_cmap. Also looks for the correct SUNW,tcx prom value. This patch just slipped through the cracks. Originally by: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
