path: root/drivers/video/p9100.c
2010-06-02of/video: fix build breakage in FB driversAnatolij Gustschin
Fixes build errors in a number of framebuffer drivers caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-16p9100: use standard fields for framebuffer physical address and lengthKrzysztof Helt
Use standard fields fbinfo.fix.smem_start and fbinfo.fix.smem_len for physical address and length of framebuffer. This also fixes output of the 'fbset -i' command - address and length of the framebuffer are displayed correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08sparc video: remove open boot prom codeRobert Reif
Replace remaining open boot prom code with of. Boot tested on sparc32 and compile tested on sparc64. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-03sparc video: make blank use proper constantRobert Reif
Make blank functions use proper constant for unblanking. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc: video drivers: add facility levelRobert Reif
Add KERN_ facility level to sparc video drivers. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30[VIDEO]: Fix OOPS in all SBUS framebuffer drivers.David S. Miller
All of these drivers use a silly: struct all_info { struct fb_info info; struct foo_par par; }; struct all_info *all = kzalloc(sizeof(*all), GFP_KERNEL); all->info.par = &all->par; etc. etc. code sequence, basically replicating the provided framebuffer_alloc()/framebuffer_release(), and doing it badly. Not only is this massive code duplication, it also caused a bug in that we weren't setting the fb_info->device pointer which results in an OOPS when fb_is_primary_device() runs. Fix all of this by using framebuffer_{alloc,release}() and passing in "&of_device->dev" as the device pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC]: Convert all FB SBUS drivers to of_driver framework.David S. Miller
2006-01-14[PATCH] fbdev: Sanitize ->fb_mmap prototypeChristoph Hellwig
No need for a file argument. If we'd really need it it's in vma->vm_file already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but the kernel alrady did that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[SBUSFB]: Kill 'list' member from foo_par structs, totally unused.David S. Miller
Based upon a patch from Hareesh Nagarajan. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-12[SBUSFB]: implement ->compat_ioctlChristoph Hellwig
This patch adds a new function, sbusfb_compat_ioctl() to drivers/video/sbuslib.c and uses it as compat_ioctl in all sbus fb drivers This remove the last per-arch compat ioctl bits in arch/sparc64/kernel/ioctl32.c so it would be nice if people could test if this actually copiles and works and if yes apply it :) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-07[SPARC]: Fix p9100 framebuffer in 2.6Tom 'spot' Callaway
The attached patch fixes the p9100 framebuffer so that text is viewable (not black on black, like it was before the patch). The linux logo displays for a very short period of time, then is replaced by a grey box. This leads me to believe that this framebuffer would have problems in X, but since there hasn't been a weitek driver for X in several millennia, this isn't something that I can confirm or deny. But this patch does get color console working on my SPARCbook 3TX. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
