path: root/drivers/video/atafb.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17Revert "fbdev: atafb - add palette register check"Geert Uytterhoeven
This reverts commit 8546e3ce6e37c359979b69862442f94e0ef0e03b, as it's a partial duplicate of commit 2f390380ca69e1617cdddb12d8da94f0a9f4319d ("fbdev: add palette register check to several drivers"). The former went in first through the m68k tree, the latter through Andrew Morton. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fbdev: add palette register check to several driversKrzysztof Helt
Add check if palette register number is in correct range for few drivers which miss it. The regno value comes indirectly from user space. Two drivers has converted check from BUG_ON() macro to just return an error (non-zero value). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-06fbdev: atafb - add palette register checkKrzysztof Helt
Add check if palette register number is in correct range for few drivers which miss it. The regno value comes indirectly from user space. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-11-12fb: remove fb_save_state() and fb_restore_state operationsKrzysztof Helt
Remove fb_save_state() and fb_restore_state operations from frame buffer layer. They are used only in two drivers: 1. savagefb - and cause bug #11248 2. uvesafb Usage of these operations is misunderstood in both drivers so kill these operations, fix the bug #11248 and avoid confusion in the future. Tested on Savage 3D/MV card and the patch fixes the bug #11248. The frame buffer layer uses these funtions during switch between graphics and text mode of the console, but these drivers saves state before switching of the frame buffer (in the fb_open) and after releasing it (in the fb_release). This defeats the purpose of these operations. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reported-by: Jochen Hein <jochen@jochen.org> Tested-by: Jochen Hein <jochen@jochen.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Januszewski <spock@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08atafb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove redundant locking of the fb_info->mm_lock mutex before the frambuffer is registered. This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30fbdev: add mutex for fb_mmap lockingKrzysztof Helt
Add a mutex to avoid a circular locking problem between the mm layer semaphore and fbdev ioctl mutex through the fb_mmap() call. Also, add mutex to all places where smem_start and smem_len fields change so the mutex inside the fb_mmap() is actually used. Changing of these fields before calling the framebuffer_register() are not mutexed. This is 2.6.31 material. It removes one lockdep (fb_mmap() and register_framebuffer()) but there is still another one (fb_release() and register_framebuffer()). It also cleans up handling of the smem_start and smem_len fields used by mutexed section of the fb_mmap(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-22m68k: atari - Rename "mfp" to "st_mfp"Geert Uytterhoeven
http://kisskb.ellerman.id.au/kisskb/buildresult/72115/: | net/mac80211/ieee80211_i.h:327: error: syntax error before 'volatile' | net/mac80211/ieee80211_i.h:350: error: syntax error before '}' token | net/mac80211/ieee80211_i.h:455: error: field 'sta' has incomplete type | distcc[19430] ERROR: compile net/mac80211/main.c on sprygo/32 failed This is caused by | # define mfp ((*(volatile struct MFP*)MFP_BAS)) in arch/m68k/include/asm/atarihw.h, which conflicts with the new "mfp" enum in net/mac80211/ieee80211_i.h. Rename "mfp" to "st_mfp", as it's a way too generic name for a global #define. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12m68k: atafb - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: c2p/atafb - Add support for Atari interleaved bitplanesGeert Uytterhoeven
The c2p() for normal bitplanes is not suitable for interleaved bitplanes with 2 bytes of interleave, causing a garbled penguin logo. Add c2p_iplan2(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: atafb - Fix 16 bpp consoleGeert Uytterhoeven
- 16 bpp must use the cfb_*() ops - 16 bpp needs to set up info->pseudo_palette[] (was fbcon_cfb16_cmap[] in 2.4.x) - Kill commented out 2.4.x fbcon remnants Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: atafb - Fix line length handlingGeert Uytterhoeven
- Make sure par->next_line is always set (this was done for Falcon only), as all the text console drawing operations need a valid par->next_line, - Make sure fix->line_length is always set, as some userspace applications need it because they don't have fallback code for the case where it's zero. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-07-24atafb: test virtual screen range before subtraction on unsignedRoel Kluin
dx and dy are u32's, so the test should occur before the subtraction Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Cc: Tim Schmielau <tim@physik3.uni-rostock.de> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20atafb: Register Atari-specific video modes with sysfsGeert Uytterhoeven
Register the Atari-specific video modes with sysfs, so you can see them in /sys/class/graphics/fb0/modes and change the video mode by writing to /sys/class/graphics/fb0/mode. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: Return -ENODEV if no device is foundGeert Uytterhoeven
According to the tests in do_initcalls(), the proper error code in case no device is found is -ENODEV, not -ENXIO or -EIO. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: use DIV_ROUND_UP or roundupJulia Lawall
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) / (d)) but is perhaps more readable. An extract of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression n,d; @@ ( - (n + d - 1) / d + DIV_ROUND_UP(n,d) | - (n + (d - 1)) / d + DIV_ROUND_UP(n,d) ) @depends on haskernel@ expression n,d; @@ - DIV_ROUND_UP((n),d) + DIV_ROUND_UP(n,d) @depends on haskernel@ expression n,d; @@ - DIV_ROUND_UP(n,(d)) + DIV_ROUND_UP(n,d) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Atari fb revivalMichael Schmitz
Update the atari fb to 2.6 by Michael Schmitz, Reformatting and rewrite of bit plane functions by Roman Zippel, A few more fixes by Geert Uytterhoeven. Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ioremap balanced with iounmap for drivers/video/atafbAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Signed-off-by: Amol Lad <amol@verismonetworks.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
