path: root/drivers/usb
2008-07-10isight: treat firmware data as constgregkh@suse.de
Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10cxacru: treat firmware data as constDavid Woodhouse
2008-07-10ueagle-atm: treat firmware data as constDavid Woodhouse
2008-07-06Revert "USB: don't explicitly reenable root-hub status interrupts"Linus Torvalds
This reverts commit e872154921a6b5256a3c412dd69158ac0b135176. Andrey Borzenkov reports that it resulted in a totally hung machine for him when loading the OHCI driver. Extensive netconsole capture with SysRq output shows that modprobe gets stuck in ohci_hub_status_data() when probing and enabling the OHCI controller, see for example http://lkml.org/lkml/2008/7/5/236 for an analysis. The problem appears to be an interrupt flood triggered by the commit that gets reverted, and Andrey confirmed that the revert makes things work for him again. Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03USB: adding comment for ipaq forcing number of portsOliver Neukum
The reason for forcing a number of ports should be documented. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: fix Oops on loading ipaq module since 2.6.26Oliver Neukum
Fixes bugzilla.kernel.org #10868 Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: add a pl2303 device idGreg Kroah-Hartman
As reported by Ken A Scott <kscott9@sent.com> Cc: Ken A Scott <kscott9@sent.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: another option device idGreg Kroah-Hartman
Thanks to umesh b <umesh.kollam@gmail.com> for the information here. Cc: umesh b <umesh.kollam@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: don't lose disconnections during suspendAlan Stern
This patch (as1111) fixes a bug in the hub driver. When a hub resumes, disconnections that occurred while the hub was suspended are lost. A completely different fix for this problem has already been accepted for 2.6.27; however the problem still needs to be handled in 2.6.26. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Lukas Hejtmanek <xhejtman@ics.muni.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: fix interrupt disabling for HCDs with shared interrupt handlersStefan Becker
USB: fix interrupt disabling for HCDs with shared interrupt handlers As has been discussed several times on LKML, IRQF_SHARED | IRQF_DISABLED doesn't work reliably, i.e. a shared interrupt handler CAN'T be certain to be called with interrupts disabled. Most USB HCD handlers use IRQF_DISABLED and therefore havoc can break out if they share their interrupt with a handler that doesn't use it. On my test machine the yenta_socket interrupt handler (no IRQF_DISABLED) was registered before ehci_hcd and one uhci_hcd instance. Therefore all usb_hcd_irq() invocations for ehci_hcd and for one uhci_hcd instance happened with interrupts enabled. That led to random lockups as USB core HCD functions that acquire the same spinlock could be called twice from interrupt handlers. This patch updates usb_hcd_irq() to always disable/restore interrupts. usb_add_hcd() will silently remove any IRQF_DISABLED requested from HCD code. Signed-off-by: Stefan Becker <stefan.becker@nokia.com> Cc: stable <stable@kernel.org> Acked-by: David Brownell <david-b@pacbell.net> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: New device ID for ftdi_sio driverJon K Hellan
Here's a new device ID for the ftdio_sio driver. The diff is with linus's tree as of this morning. The device is the RigExpert Tiny USB Soundcard Transceiver Interface for ham radio. (I didn't actually test this. A fellow ham couldn't get the device to work, and I suggested binding the device ID using sysfs - see "http://jk.ufisa.uninett.no/usb/". However, he had had moved on to other things by then. I guess adding the device ID to the kernel "on spec" won't hurt. The relevant part of cat /proc/bus/usb/devices shows: T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1 P: Vendor=0403 ProdID=ed22 Rev= 5.00 S: Manufacturer=FTDI S: Product=MixW RigExpert Tiny S: SerialNumber=00000000 C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms ) From: Jon K Hellan <hellan@acm.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03sisusbvga: Fix oops on disconnect.Will Newton
Remove dev_info call on disconnect. The sisusb_dev pointer may have been set to zero by sisusb_delete at this point causing an oops. The message does not provide any extra information over the standard USB subsystem output so removing it does not affect functionality. Signed-off-by: Will Newton <will.newton@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: mass storage: new id for US_SC_CYP_ATACBmatthieu castet
CY7C68310 chip also support cypress atacb "ATA command" pass_thru. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: ohci - record data toggle after unlinkDavid Brownell
This patch fixes a problem with OHCI where canceling bulk or interrupt URBs may lose track of the right data toggle. This seems to be a longstanding bug, possibly dating back to the Linux 2.4 kernel, which stayed hidden because (a) about half the time the data toggle bit was correct; (b) canceling such URBs is unusual; and (c) the few drivers which cancel these URBs either [1] do it only as part of shutting down, or [2] have fault recovery logic, which recovers. For those transfer types, the toggle is normally written back into the ED when each TD is retired. But canceling bypasses the mechanism used to retire TDs ... so on average, half the time the toggle bit will be invalid after cancelation. The fix is simple: the toggle state of any canceled TDs are propagated back to the ED in the finish_unlinks function. (Issue found by leonidv11@gmail.com ...) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Leonid <leonidv11@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: ehci - fix timer regressionDavid Brownell
This patch fixes a regression in the EHCI driver's TIMER_IO_WATCHDOG behavior. The patch "USB: EHCI: add separate IAA watchdog timer" changed how that timer is handled, so that short timeouts on the remaining timer (unfortunately, overloaded) would never be used. This takes a more direct approach, reorganizing the code slightly to be explicit about only the I/O watchdog role now being overridable. It also replaces a now-obsolete comment describing older timer behavior. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Leonid <leonidv11@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03USB: fix cdc-acm resume()Oliver Neukum
cdc-acm has - a memory leak in resume() - will fail to reactivate the read code path if this is needed. his corrects it by deleting the useless relict code. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-03OHCI: Fix problem if SM501 and another platform driver is selectedBen Dooks
If the SM501 and another platform driver, such as the SM501 then we end up defining PLATFORM_DRIVER twice. This patch seperated the SM501 onto a seperate define of SM501_OHCI_DRIVER so that it can be selected without overwriting the original definition. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-17Merge branch 'for-linus' of ↵tip-x86-pci-ioapic-boot-irq-quirks-2008-06-23_09.52_Montip-x86-mm-remove-arch-get-ram-range-2008-06-23_09.06_Montip-x86-mm-debug-2008-06-23_09.04_Montip-core-debugobjects-2008-06-23_08.51_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: appletouch - implement reset-resume logic Input: i8042 - retry failed CTR writes when resuming Input: i8042 - add Fujitsu-Siemens Amilo Pro V2030 to nomux table Input: pcspkr - remove negative dependency on snd-pcsp Manually fixed up trivial conflict in drivers/usb/core/quirks.c
2008-06-17Input: appletouch - implement reset-resume logicOliver Neukum
On some boxes the touchpad needs to be reinitialized after resume to make it function again. This fixes bugzilla #10825. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-11USB: don't use reset-resume if drivers don't support itLinus Torvalds
This patch tries to identify which devices are able to accept reset-resume handling, by checking that there is at least one interface driver bound and that all of the drivers have a reset_resume method defined. If these conditions don't hold then during resume processing, the device is logicall disconnected. This is only a temporary fix. Later on we will explicitly unbind drivers that can't handle reset-resumes. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Oliver Neukum <oliver@neukum.org> Cc: Pavel Machek <pavel@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-11USB: isp1760: Assign resource fields before adding hcdNate Case
This fixes the bogus "io mem 0x00000000" message printed during driver init due to hcd->rsrc_start being assigned after the call to usb_add_hcd(). Signed-off-by: Nate Case <ncase@xes-inc.com> Acked-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-11isight_firmware: Avoid crash on loading invalid firmwareMatthew Garrett
Different tools generate slightly different formats of the isight firmware. Ensure that the firmware buffer is not overrun, while still ensuring that the correct amount of data is written if trailing data is present. Signed-off-by: Matthew Garrett <mjg@redhat.com> Report-by: Justin Mattock <justinmattock@gmail.com> Tested-by: Justin Mattock <justinmattock@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-11USB: fix build bug in USB_ISIGHTFWIngo Molnar
USB: fix build bug in USB_ISIGHTFW -tip tree testing found this build bug: drivers/built-in.o: In function `isight_firmware_load': isight_firmware.c:(.text+0x1ade08): undefined reference to `request_firmware' isight_firmware.c:(.text+0x1adf9c): undefined reference to `release_firmware' select FW_LOADER in USB_ISIGHTFW. From: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-09usb: r8a66597-hcd: Add support for SH7723 USB hostYoshihiro Shimoda
R8A66597 is similar to SH7723 USB 2.0 Host/Function module. In addition, the USB of SH7366 is compatible with SH7723. It can support SH7723 USB host by changing Kconfig. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-04isp1760-if iomem annotationsAl Viro
2008-06-04cdc-wdm endianness fixesAl Viro
* wMaxPacketSize is le16; copying it to a field of local structure and then using that field as host-endian (size of object to be allocated) is broken. * bMaxPacketSize0 is 8-bit; feeding it to le16_to_cpu() is bogus and since the result is used as host-endian, it's not even misspelled cpu_to_le16(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-04usb/c67x00 endianness annotationsAl Viro
2008-05-29Revert "USB: EHCI: fix performance regression"Greg Kroah-Hartman
This reverts commit fa38dfcc56b5f6cce787f9aaa5d1830509213802. It wasn't really a regression and David and Alan are still working through the issues reported. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: fsl_usb2_udc: fix recursive lockLi Yang
UDC needs to release lock before calling out to gadget driver, since it may need to reenter. The change fixes kernel BUG observed on rt kernel. > kernel BUG at kernel/rtmutex.c:683! > stopped custom tracer. > Oops: Exception in kernel mode, sig: 5 [#1] > PREEMPT MPC834x ITX > NIP: c021629c LR: c0216270 CTR: 00000000 > REGS: df761d70 TRAP: 0700 Not tainted (2.6.23.9-rt13) > MSR: 00021032 <ME,IR,DR> CR: 28000022 XER: 00000000 > TASK = df632080[241] 'IRQ-38' THREAD: df760000 > GPR00: 00000001 df761e20 df632080 00000000 11111111 00000000 df761e6c > 00000000 > GPR08: df761e48 00000000 df761e50 00000000 80000000 ede5cdde 1fffd000 > 00800000 > GPR16: ffffffff 00000000 007fff00 00000040 00000000 007ffeb0 00000000 > 1fff8b08 > GPR24: 00000000 00000026 00000000 df79a320 c026b2e8 c02240bc 00009032 > df79a320 > NIP [c021629c] rt_spin_lock_slowlock+0x9c/0x200 > LR [c0216270] rt_spin_lock_slowlock+0x70/0x200 > Call Trace: > [df761e20] [c0216270] rt_spin_lock_slowlock+0x70/0x200 (unreliable) > [df761e90] [c0182828] fsl_ep_disable+0xcc/0x154 > [df761eb0] [c0184d30] eth_reset_config+0x88/0x1d0 > [df761ed0] [c0184ec0] eth_disconnect+0x48/0x64 > [df761ef0] [c01831a4] reset_queues+0x60/0x78 > [df761f00] [c0183b74] fsl_udc_irq+0x9b8/0xa58 > [df761f50] [c003ef30] handle_IRQ_event+0x64/0x100 > [df761f80] [c003f758] thread_simple_irq+0x6c/0xc8 > [df761fa0] [c003f888] do_irqd+0xd4/0x2e4 > [df761fd0] [c0032284] kthread+0x50/0x8c > [df761ff0] [c000f9b4] kernel_thread+0x44/0x60 Signed-off-by: Li Yang <leoli@freescale.com> Cc: Eugene T. Bordenkircher <Eugene_Bordenkircher@selinc.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: usb-serial: option: Don't match Huawei driver CD imagesMichael Karcher
Add the interface info matching to all Huawei cards, as they all also contain a Mass Storage Device interface (usually containing Windows drivers) which should not get bound by this driver. See also drivers/usb/storage/unusual_devs.h Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: pl2303: another product IDSteve Murphy
I've just got a USB GPRS/EDGE modem branded Manufacturer Micromax Model MMX610U (see http://www.airtel.in/level2_t3data.aspx?path=1/106/179) working by adding another product ID to pl2303. Modem info reports same module as Max Arnold's i.e.SIMCOM SIM600 but with product ID 0x0612 (cf Ox0611). From: Steve Murphy <steve@gnusis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: add another scanner quirkRené Rebe
Like the HP53{00,70} scanner other devices of the OEM Avision require the USB_QUIRK_STRING_FETCH_255 to correct set a configuration with "recent" Linux kernels. Signed-off-by: René Rebe <rene@exactcode.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: Add support for ROKR W5 in unusual_devs.hJavier Smaldone
This patch adds support for rev 2 of an existing unusual_devs entry enabling ROKR W5s to work. Greg, please apply. From: Javier Smaldone <javier@smaldone.com.ar> Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: Fix M600i unusual_devs entryPhil Dibowitz
It turns out that the unusual_devs entry for the Motorola M600i needs another flag. This patch adds it. Thanks to Atte André Jensen <atte@ballbreaker.dk>. Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: usb-storage: unusual_devs update for Cypress ATACBAlan Stern
This patch (as1101) updates the unusual_devs entry for the Cypress ATACB pass-through. The protocol field is changed from US_PR_BULK to US_PR_DEVICE, since the Cypress devices already set bInterfaceProtocol to Bulk-only. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: fix performance regressionAlan Stern
This patch (as1099) fixes a performance regression in ehci-hcd. The fundamental problem is that queue headers get removed from the schedule too quickly, since the code checks for a counter advancing rather than making an actual time-based check. The latency involved in removing the queue header and then relinking it can severely degrade certain kinds of workloads. The patch replaces a simple counter with a timestamp derived from the controller's uframe value. In addition, the delay for unlinking an idle queue header is increased from 5 ms to 10 ms; since some controllers (nVidia) have a latency of up to 1 ms for unlinking, this reduces the relative impact from 20% to 10%. Finally, a logical error left over from the IAA watchdog-timer conversion is corrected. Now the driver will always either unlink an idle queue header or set up a timer to unlink it later. The old code would sometimes fail to do either. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <david-b@pacbell.net> Cc: Leonid <leonidv11@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: fix bug in Iso schedulingAlan Stern
This patch (as1098) changes the way ehci-hcd schedules its periodic Iso transfers. That the current scheduling code is wrong is clear on the face of it: Sometimes it returns -EL2NSYNC (meaning that an URB couldn't be scheduled because it was submitted too late), but it does this even when the URB_ISO_ASAP flag is set (meaning the URB should be scheduled as soon as possible). The new code properly implements as-soon-as-possible scheduling, assigning the next unexpired slot as the URB's starting point. It also is more careful about checking for Iso URB completion: It doesn't bother to check for activity during frames that are already over, and it allows for the possibility that some of the URB's packets may have raced the hardware when they were submitted and so never got used (the packet status is set to -EXDEV). This fixes problems several people have experienced with USB video applications. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: fix remote-wakeup regressionAlan Stern
This patch (as1097) fixes a bug in the remote-wakeup handling in ehci-hcd. The driver currently does not keep track of whether the change-suspend feature is enabled for each port; the feature is automatically reset the first time it is read. But recent changes to the hub driver require that the feature be read at least twice in order to work properly. A bit-vector is added for storing the change-suspend feature values. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: suppress unwanted error messagesAlan Stern
This patch (as1096) fixes an annoying problem: When a full-speed or low-speed device is plugged into an EHCI controller, it fails to enumerate at high speed and then is handed over to the companion controller. But usbcore logs a misleading and unwanted error message when the high-speed enumeration fails. The patch adds a new HCD method, port_handed_over, which asks whether a port has been handed over to a companion controller. If it has, the error message is suppressed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: fix up root-hub TT messAlan Stern
This patch (as1095) cleans up the HCD glue and several of the EHCI bus-glue files. The ehci->is_tdi_rh_tt flag is redundant, since it means the same thing as the hcd->has_tt flag, so it is removed and the other flag used in its place. Some of the bus-glue files didn't get the relinquish_port method added to their hc_driver structures. Although that routine currently doesn't do anything for controllers with an integrated TT, in the future it might. So the patch adds it where it is missing. Lastly, some of the bus-glue files have erroneous entries for their hc_driver's suspend and resume methods. These method pointers are specific to PCI and shouldn't be used otherwise. (The patch also includes an invisible whitespace fix.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2008-05-29USB: add all configs to the "descriptors" attributeAlan Stern
This patch (as1094) changes the output of the "descriptors" binary attribute. Now it will contain the device descriptor followed by all the configuration descriptors, not just the descriptor for the current config. Userspace libraries want to have access to the kernel's cached descriptor information, so they can learn about device characteristics without having to wake up suspended devices. So far the only user of this attribute is the new libusb-1.0 library; thus changing its contents shouldn't cause any problems. This should be considered for 2.6.26, if for no other reason than to minimize the range of releases in which the attribute contains only the current config descriptor. Also, it doesn't hurt that the patch removes the device locking -- which was formerly needed in order to know for certain which config was indeed current. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: fix possible deadlock involving sysfs attributesAlan Stern
There is a potential deadlock when the usb_generic driver is unbound from a device. The problem is that generic_disconnect() is called with the device lock held, and it removes a bunch of device attributes from sysfs. If a user task happens to be running an attribute method at the time, the removal will block until the method returns. But at least one of the attribute methods (the store routine for power/level) needs to acquire the device lock! This patch (as1093) eliminates the deadlock by moving the calls to create and remove the sysfs attributes from the usb_generic driver into usb_new_device() and usb_disconnect(), where they can be invoked without holding the device lock. Besides, the other sysfs attributes are created when the device is registered and removed when the device is unregistered. So it seems only fitting for the extra attributes to be created and removed at the same time. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: Firmware loader driver for USB Apple iSight cameraMatthew Garrett
Uninitialised Apple iSight drivers present with a distinctive USB ID. Once firmware has been uploaded, they disconnect and reconnect with a new ID. At this point they can be driven by the uvcvideo driver. As this is unique to the Apple cameras and not functionality shared by any other UVC devices, it makes sense to provide the firmware loading functionality in a separate driver. This driver will read an isight.fw file extracted from the Apple driver using the tools at http://bersace03.free.fr/ift/ and upload it to the camera. It will also handle the case where the device loses its firmware during hibernation and must have it reloaded. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: FTDI_SIO : Add support for Matrix Orbital PID RangeRay Molenkamp
This patch adds support for the range of PIDs that have been allocated for FTDI based devices at Matrix Orbital. A small number of units have been shipped early 2008 with a faulty USB Descriptor. Products that may have this issue have been marked with the existing quirk to work around the problem. Signed-off-by: R. Molenkamp <rmolenkamp@matrixorbital.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: CDC WDM driver USB: ehci-orion: the Orion EHCI root hub does have a Transaction Translator USB: serial: ch341: New VID/PID for CH341 USB-serial USB: build fix USB: pxa27x_udc - Fix Oops USB: OPTION: fix name of Onda MSA501HS HSDPA modem USB: add TELIT HDSPA UC864-E modem to option driver usb-serial: Use ftdi_sio driver for RATOC REX-USB60F
2008-05-20USB: CDC WDM driverOliver Neukum
2008-05-20USB: ehci-orion: the Orion EHCI root hub does have a Transaction TranslatorLennert Buytenhek
Commit 7329e211b987a493cbcfca0e98c60eb108ab42df ("USB: root hubs don't lie about their number of TTs") requires the various platform EHCI glue modules to set ->has_tt if the root hub has a Transaction Translator. The Orion EHCI root hub does have a Transaction Translator, so set ->has_tt in ehci_orion_setup(). This fixes oopsing on plugging in a low speed device. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: serial: ch341: New VID/PID for CH341 USB-serialMichael F. Robbins
Recent USB-serial devices using the WinChipHead CH340/CH341 chipset are being shipped with a new vendor/product ID code pair, but an otherwise identical device. (This is confirmed by looking at INF for the included Windows driver.) Patch is tested and working, both with new and old devices. Signed-off-by: Michael F. Robbins <mrobbins@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: pxa27x_udc - Fix Oopskarl beldan
udc_disable oopses dereferencing udc_command. Signed-off-by: Karl Beldan <karl.beldan@gmail.com> Acked-by: Robert Jarzmik <rjarzmik@free.fr> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: OPTION: fix name of Onda MSA501HS HSDPA modemArnaldo Carvalho de Melo
This fixes the name of the onda MSA501HS device, I guess it is called different things in different countries. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
