path: root/drivers/usb/usb-skeleton.c
2007-10-12USB: usb-skeleton leaking locks on openMark Gross
This weekend I was hacking around with a trivial USB driver for talking to the boot load firmware of a USB Bit Whacker. It's running the MicroChip Pic18 boot loader firmware and I'm putting together a flash program for writing new FW to the thing. Anyway in my use of the usb-skeleton.c as my starting point I discovered my test program was getting hung up after attempting to write a buffer. The application and driver where hung in a way that required me to reboot to get it to clean up so I could try again. It turned out the code path through skel_open can grap the driver's io_mutex lock and forget to release it. The following patch fixes the problem for me. Signed-off-by: Mark Gross <mgross@linux.intel.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton: use anchors in pre/post resetOliver Neukum
use anchors in pre/post_reset Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton" use anchors in suspend/resume handlingOliver Neukum
use anchors in suspend/resume handling Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton: use anchors in disconnect handlingOliver Neukum
use anchors in disconnect handling Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb-skeleton: usb anchor to implement flushOliver Neukum
This patch set introduces usb_anchor and uses it to implement all modern APIs in the skeleton driver. - proper error reporting in the skeleton driver - implementation of flush() Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: prevent char device open/deregister raceAlan Stern
This patch (as908) adds central protection in usbcore for the prototypical race between opening and unregistering a char device. The spinlock used to protect the minor-numbers array is replaced with an rwsem, which can remain locked across a call to a driver's open() method. This guarantees that open() and deregister() will be mutually exclusive. The private locks currently used in several individual drivers for this purpose are no longer necessary, and the patch removes them. The following USB drivers are affected: usblcd, idmouse, auerswald, legousbtower, sisusbvga/sisusb, ldusb, adutux, iowarrior, and usb-skeleton. As a side effect of this change, usb_deregister_dev() must not be called while holding a lock that is acquired by open(). Unfortunately a number of drivers do this, but luckily the solution is simple: call usb_deregister_dev() before acquiring the lock. In addition to these changes (and their consequent code simplifications), the patch fixes a use-after-free bug in adutux and a race between open() and release() in iowarrior. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: kill BKL in skeleton driverOliver Neukum
Iet's kill BKL where we can. This is relative to the last patch to the skeleton driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: fix skeleton driverOliver Neukum
compilation of the skeleton driver is currently broken. It doesn't compile. So while I am it: - fix typo - add comments to answer common questions - actually allow autosuspend in the driver struct - increase paralellism by restricting code under locks Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: fix autosuspend race in skeleton driverOliver Neukum
as the skeleton driver was made ready for autosuspend a race condition was introduced. The reference to get device must be gotten before the autosuspend counter is upped, as this operation may sleep, dropping BKL. Dropping BKL means that the pointer to the device may become invalid. Here's the fix. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27usbcore: non-hub-specific uses of autosuspendAlan Stern
This patch (as741) makes the non-hub parts of usbcore actually use the autosuspend facilities added by an earlier patch. Devices opened through usbfs are autoresumed and then autosuspended upon close. Likewise for usb-skeleton. Devices are autoresumed for usb_set_configuration. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27usb-skeleton: small updateLuiz Fernando N. Capitulino
o CodingStyle fixes o Removes trailing spaces o Do not make not needed initialiation of automatic variables o Use usb_endpoint_* functions o If we get an error in the write URB callback print an error message instead of a debug one (Pretty unrelated changes, but spliting this up doesn't pay off as our main changes are just CodingStyle fixes). Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27usb-skeleton: don't submit URBs after disconnectionAlan Stern
This patch (as712b) is a slight revision of one submitted earlier. It fixes the usb-skeleton example driver so that it won't try to submit URBs after skel_disconnect() has returned. This could cause errors, if the driver was unbound and then a different driver was bound to the device. It also fixes a couple of small bugs in the skel_write() routine. The revised patch uses a slightly different test, suggested by Dave Brownell, for determining whether to free a transfer buffer. It's a little clearer than the earlier version. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: remove some left over devfs droppings hanging around in the usb ↵Greg Kroah-Hartman
drivers As there is no more usb devfs support, these bits would just confuse people. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: fix usb-skeleton limit resource usage patch.Sam Bishop
Prevents a compiler warning and uses down_interruptible() instead of down() in process context. Signed-off-by: Sam Bishop <sam@bishop.dhs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: fix buffer size limiting in skeleton driverOlav Kongas
Fix buffer size limiting. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: Limiting of resource use in skeleton driverOliver Neukum
this introduces limits whose lack in the skeleton driver someone recently complained about. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] devfs: Remove the mode field from usb_class_driver as it's no longer ↵Greg Kroah-Hartman
needed Also fixes all drivers that set this field, and removes some other devfs specfic USB logic. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/class/usblp.c | 3 +-- drivers/usb/core/file.c | 19 ++++--------------- drivers/usb/image/mdc800.c | 3 +-- drivers/usb/input/aiptek.c | 2 +- drivers/usb/input/hiddev.c | 3 +-- drivers/usb/media/dabusb.c | 3 +-- drivers/usb/misc/auerswald.c | 3 +-- drivers/usb/misc/idmouse.c | 5 ++--- drivers/usb/misc/legousbtower.c | 5 ++--- drivers/usb/misc/rio500.c | 3 +-- drivers/usb/misc/sisusbvga/sisusb.c | 5 ----- drivers/usb/misc/usblcd.c | 9 ++++----- drivers/usb/usb-skeleton.c | 3 +-- include/linux/usb.h | 7 ++----- 14 files changed, 22 insertions(+), 51 deletions(-)
2005-07-29[PATCH] USB: fix Bug in usb-skeleton.cConger, Chris A
Compare endpoint address to USB_ENDPOINT_DIR_MASK to determine endpoint direction... From: "Conger, Chris A." <CHRIS.A.CONGER@saic.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
