git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits)
USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c
xhci: Clean up 32-bit build warnings.
USB: update documentation for usbmon
usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops
drivers/usb/class/cdc-acm.c: clear dangling pointer
drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree
drivers/usb/host/isp1760-if.c: introduce missing kfree
usb: option: add ZD Incorporated HSPA modem
usb: ch9: fix up MaxStreams helper
USB: usb-skeleton.c: cleanup open_count
USB: usb-skeleton.c: fix open/disconnect race
xhci: Properly handle COMP_2ND_BW_ERR
USB: remove dead code from suspend/resume path
USB: add quirk for another camera
drivers: usb: wusbcore: Fix dependency for USB_WUSB
xhci: Better debugging for critical host errors.
xhci: Be less verbose during URB cancellation.
xhci: Remove debugging about ring structure allocation.
xhci: Remove debugging about toggling cycle bits.
xhci: Remove debugging for individual transfers.
It is not necessary to use the 'open_count' for handling
runtime pm only, because runtinme pm has built-in counter
to handle this, so remove it to make code clean.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
If usb device is disconnected between usb_get_intfdata()
and kref_get() in skel_open(), kref_get may access a freed
object.
Also check if device is disconnected in ->open.
This converts the drivers in drivers/usb/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Simon Arlott <cxacru@fire.lp0.eu>
Cc: Duncan Sands <duncan.sands@free.fr>
Cc: Matthieu CASTET <castet.matthieu@free.fr>
Cc: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Juergen Stuber <starblue@users.sourceforge.net>
Cc: Cesar Miquel <miquel@df.uba.ar>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Michael Hund <mhund@ld-didactic.de>
Cc: Zack Parsons <k3bacon@gmail.com>
Cc: Melchior FRANZ <mfranz@aon.at>
Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com>
Cc: Dan Carpenter <error27@gmail.com>
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: David Kubicek <dave@awk.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Pedro Ribeiro <pedrib@gmail.com>
BKL not needed at all. Removed without replacement.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Straightforward push into the drivers to allow
auditing individual drivers separately
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: cocci@diku.dk
Correct priority problem in the use of ! and &.
The semantic patch that makes this change is as follows:
// <smpl>
@@ expression E; constant C; @@
- !E & C
+ !(E & C)
// </smpl>
This fixes up the majority of the coding style issues in the
usb-skeleton driver.
Non blocking IO is supported in the read path of usb-skeleton.
This is done by just not blocking. As support for handling signals
without stopping IO is already there, it can be used for O_NONBLOCK, too.
usb:usb-skeleton: honor O_NONBLOCK in write path
nonblocking writes are allowed by using down_trylock if necessary
to reserve an URB
The read code path of the skeleton driver really sucks
- skel_read works only for devices which always send data
- the timeout comes out of thin air
- it blocks signals for the duration of the timeout
- it disallows nonblocking IO by design
This patch fixes it by using a real urb, a completion and interruptible waits.
338b67b0c1a97ca705023a8189cf41aa0828d294 removed the info macro and
replaced its uses with dev_info. This patch does so for
usb-skeleton.c, which was missed.
Signed-off-by: Matt Kraai <kraai@ftbfs.org>
urb->context code cleanup
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This weekend I was hacking around with a trivial USB driver for talking
to the boot load firmware of a USB Bit Whacker. It's running the
MicroChip Pic18 boot loader firmware and I'm putting together a flash
program for writing new FW to the thing.
Anyway in my use of the usb-skeleton.c as my starting point I discovered
my test program was getting hung up after attempting to write a buffer.
The application and driver where hung in a way that required me to
reboot to get it to clean up so I could try again.
It turned out the code path through skel_open can grap the driver's
io_mutex lock and forget to release it.
The following patch fixes the problem for me.
Signed-off-by: Mark Gross <mgross@linux.intel.com>
Cc: Oliver Neukum <oliver@neukum.org>
use anchors in pre/post_reset
Signed-off-by: Oliver Neukum <oneukum@suse.de>
use anchors in suspend/resume handling
use anchors in disconnect handling
This patch set introduces usb_anchor and uses it to implement all modern
APIs in the skeleton driver.
- proper error reporting in the skeleton driver
- implementation of flush()
This patch (as908) adds central protection in usbcore for the
prototypical race between opening and unregistering a char device.
The spinlock used to protect the minor-numbers array is replaced with
an rwsem, which can remain locked across a call to a driver's open()
method. This guarantees that open() and deregister() will be mutually
exclusive.
The private locks currently used in several individual drivers for
this purpose are no longer necessary, and the patch removes them. The
following USB drivers are affected: usblcd, idmouse, auerswald,
legousbtower, sisusbvga/sisusb, ldusb, adutux, iowarrior, and
usb-skeleton.
As a side effect of this change, usb_deregister_dev() must not be
called while holding a lock that is acquired by open(). Unfortunately
a number of drivers do this, but luckily the solution is simple: call
usb_deregister_dev() before acquiring the lock.
In addition to these changes (and their consequent code
simplifications), the patch fixes a use-after-free bug in adutux and a
race between open() and release() in iowarrior.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Iet's kill BKL where we can. This is relative to the last patch to the
skeleton driver.
compilation of the skeleton driver is currently broken. It doesn't compile.
So while I am it:
- fix typo
- add comments to answer common questions
- actually allow autosuspend in the driver struct
- increase paralellism by restricting code under locks
as the skeleton driver was made ready for autosuspend a race condition
was introduced. The reference to get device must be gotten before the
autosuspend counter is upped, as this operation may sleep, dropping BKL.
Dropping BKL means that the pointer to the device may become invalid.
Here's the fix.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
This patch (as741) makes the non-hub parts of usbcore actually use the
autosuspend facilities added by an earlier patch.
Devices opened through usbfs are autoresumed and then
autosuspended upon close.
Likewise for usb-skeleton.
Devices are autoresumed for usb_set_configuration.
o CodingStyle fixes
o Removes trailing spaces
o Do not make not needed initialiation of automatic variables
o Use usb_endpoint_* functions
o If we get an error in the write URB callback print an error message instead
of a debug one
(Pretty unrelated changes, but spliting this up doesn't pay off as our main
changes are just CodingStyle fixes).
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Making structs const prevents accidental bugs and with the proper debug
options they're protected against corruption.
This patch (as712b) is a slight revision of one submitted earlier. It
fixes the usb-skeleton example driver so that it won't try to submit
URBs after skel_disconnect() has returned. This could cause errors, if
the driver was unbound and then a different driver was bound to the
device. It also fixes a couple of small bugs in the skel_write()
routine.
The revised patch uses a slightly different test, suggested by Dave
Brownell, for determining whether to free a transfer buffer. It's a
little clearer than the earlier version.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
drivers
As there is no more usb devfs support, these bits would just confuse
people.
Prevents a compiler warning and uses down_interruptible() instead of down() in
process context.
Signed-off-by: Sam Bishop <sam@bishop.dhs.org>
Fix buffer size limiting.
Signed-off-by: Olav Kongas <ok@artecdesign.ee>
this introduces limits whose lack in the skeleton driver someone recently
complained about.
Signed-off-by: Oliver Neukum <oliver@neukum.name>
It is no longer needed, so let's remove it, saving a bit of memory.
needed
Also fixes all drivers that set this field, and removes some other devfs
specfic USB logic.
drivers/usb/class/usblp.c | 3 +--
drivers/usb/core/file.c | 19 ++++---------------
drivers/usb/image/mdc800.c | 3 +--
drivers/usb/input/aiptek.c | 2 +-
drivers/usb/input/hiddev.c | 3 +--
drivers/usb/media/dabusb.c | 3 +--
drivers/usb/misc/auerswald.c | 3 +--
drivers/usb/misc/idmouse.c | 5 ++---
drivers/usb/misc/legousbtower.c | 5 ++---
drivers/usb/misc/rio500.c | 3 +--
drivers/usb/misc/sisusbvga/sisusb.c | 5 -----
drivers/usb/misc/usblcd.c | 9 ++++-----
drivers/usb/usb-skeleton.c | 3 +--
include/linux/usb.h | 7 ++-----
14 files changed, 22 insertions(+), 51 deletions(-)
Compare endpoint address to USB_ENDPOINT_DIR_MASK to determine endpoint
direction...
infrastructure for it.
Let it rip!
