path: root/drivers/usb/serial/sierra.c
2009-07-12USB: serial: sierra driver id_table additionsElina Pasheva
- Updated the id_table with all devices that Sierra Wireless currently support - Re-ordered the contents of the id_table for better readability Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: Sierra: fix oops upon device closeAlan Stern
This patch (as1263) fixes a mixup that occurred when conflicting patches for the sierra driver were merged incorrectly. The former sierra_shutdown routine should have been become sierra_release, not sierra_disconnect. The symptom this fixes is an oops when the device file is closed after a Sierra device has been unplugged (Bugzilla #13675). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Peter Naulls <peter@mushroomnetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: usb-serial: replace shutdown with disconnect, releaseAlan Stern
This patch (as1254) splits up the shutdown method of usb_serial_driver into a disconnect and a release method. The problem is that the usb-serial core was calling shutdown during disconnect handling, but drivers didn't expect it to be called until after all the open file references had been closed. The result was an oops when the close method tried to use memory that had been deallocated by shutdown. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15+ drivers-usb-serial-sierrac-fix-printk-warning.patch added to -mm treeAndrew Morton
drivers/usb/serial/sierra.c: In function 'sierra_write': drivers/usb/serial/sierra.c:375: warning: format '%d' expects type 'int', but argument 5 has type 'size_t' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Elina Pasheva <epasheva@sierrawireless.com> Cc: Rory Filer <rfiler@SierraWireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: sierra driver sierra_calc_num_ports() fixElina Pasheva
- Removed potential kernel oops from sierra_calc_num_ports() function. Calling this function twice would likely have caused an oops because the function releases allocated memory after the first call. - Modified sierra_probe() function to reflect the changes in sierra_calc_num_ports(). Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: sierra driver interrupt urb resubmit fixElina Pasheva
- Fixed a problem when re-submitting urb from interrupt callback in function sierra_instat_callback(). This suppresses also issuing of error messages in /var/log/kern.log - Removed redundant debug message at the beginning of sierra_instat_callback() function - Changed a debug message to be an error message Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: sierra driver zero length packet fixElina Pasheva
- Fixed a problem with transferring packets with size a multiple of Bulk Xfer size in function sierra_write(). Added transfer flag URB_ZERO_PACKET before submitting the urb to trigger Zero-length data transfer when packet size is a multiple of Bulk Xfer. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: sierra driver read path bug fixElina Pasheva
This patch fixes a problem in function sierra_indat_callback() which would stop receiving traffic from a modem if a number of URB failures occur. Failed URBs are not resubmitted for the next read and there is only a limited number of URBs allocated for the IN path. After this number of failures, the receive path stops working on a particular interface. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com>
2009-06-15USB: serial: sierra driver write path improvementsElina Pasheva
- Updated Copyright notice with new authors names - Version number set to 1.3.6 - Added a MAX_TRANSFER constant following Greg Kroah-Hartman's recommended setting of PAGE_SIZE-512 for USB transfer buffers and modified accordingly sierra_write() function. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: sierra driver debug info visibility improvementElina Pasheva
- Version number set to 1.3.5 - Added "\n" at the end of each string in dev_dbg() code to improve the debug information visibility. Without this change the debug logs are very difficult to read. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: sierra driver performance improvementsElina Pasheva
- Version number set to 1.3.4 - Increased the number of input/output URBs for improved performance (numbers based on an measurement study triggered by a user request). We performed the testing using a network simulator that provided full speeds in the uplink and downlink directions and this combination of URBs provided the best throughput. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11sierra: driver interface blacklistingElina Pasheva
Interface blacklisting is necessary for non-serial interfaces that are handled by a different driver. The interface blacklisting is implemented in sierra driver per device. Each device in need of a blacklist has a static information array kept in the driver. This array contains the interface numbers that are blacklisted. The pointer for each blacklist array and the length of that blacklist are 'bundled' in data structure sierra_iface_info. A pointer to this information is set in id_table when the device is added to the id_table. The following is summary of changes we have made to sierra.c driver in this patch dealing with interface blacklisting support: - Added data structure sierra_iface_info and function is_blacklisted() to support blacklisting - Modified sierra_probe() to handle blacklisted interfaces accordingly - Improved comments in id_table - Added new device in id_table with blacklist interface support Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11sierra: driver urb handling improvementsElina Pasheva
[Folded from eight patches into one as the original set according to the author "All of the patches need to be applied to obtain a working product" so keeping them split seems unhelpful Merge fixes done versus other conflicting changes and moved the spin_lock_init from open to setup time -- Alan] Summary of the changes and code re-organization in this patch: - The memory for urbs is allocated and urbs are submitted only for the active interfaces (instead of pre-allocating these for all interfaces). This will save memory especially in the case of using composite devices. - The code has been re-organized and functionality has been extracted from sierra_startup(), sierra_shutdown(), sierra_open(), sierra_close() and added in helper functions sierra_release_urb(), sierra_stop_rx_urbs(), sierra_submit_rx_urbs() and sierra_setup_urb() - Added function sierra_release_urb() to free an urb and its transfer buffer. - Removed unecessary include file reference and comment. - Added function sierra_stop_rx_urbs() that takes care of the release of receive and interrupt urbs. This function is to be called by sierra_close() whenever an interface is de-activated. - Added new function sierra_submit_rx_urbs() that handles the submission of receive urbs and interrupt urbs (if any) during the interface activation. This function is to be called by sierra_open(). Added a second parameter to pass the memory allocation (as suggested by Oliver Neukum) so that this function can be used in post_reset() and resume(). - Added new function sierra_setup_urb() that contains the functionality to allocate an urb, fill bulk urb using the supplied memory allocation flag and release urb upon error. Added parameter so that the caller pass the memory allocation flag for flexibility. - Moved sierra_close() before sierra_open() to resolve dependencies introduced by the code reorganization. - Modified sierra_close() to call sierra_stop_rx_urbs() and sierra_release_urb() functions added in previous patch. - Modified sierra_open() to call sierra_setup_urb() and sierra_submit_rx_urbs() functions; note urbs are allocated and submitted for each activated interface. - Modified sierra_startup() so that allocation of urbs happens whenever an interface is activated (urb allocation is moved to sierra_open()). - Modified sierra_shutdown() so that urbs are freed whenever an interface is de-activated (urb freeing moved to sierra_close() as shown in previous patch from the series) - Removed unecessary data structure from sierra_port_private_data - Suppress an entry in logs by not re-submitting an urb when usb_submit_urb() returns -EPERM, as this shows that usb_kill_urb() is running (as suggested by Oliver Neukum) Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Alan Cox <alan.cox@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: resolve some sierra breakageAlan Cox
The various merges into the sierra driver inadvertently undid commit 212b8f0c3f5a2280bfa1d6ab13a6fe98552becaa by Elina Pasheva <epasheva@sierrawireless.com>. Put it back so the OBEX port works again. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11tty: Bring the usb tty port structure into more useAlan Cox
This allows us to clean stuff up, but is probably also going to cause some app breakage with buggy apps as we now implement proper POSIX behaviour for USB ports matching all the other ports. This does also mean other apps that break on USB will now work properly. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-23USB: removal of tty->low_latency hack dating back to the old serial codeOliver Neukum
This removes tty->low_latency from all USB serial drivers that push data into the tty layer at hard interrupt context. It's no longer needed and actually harmful. Signed-off-by: Oliver Neukum <oliver@neukum.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-23USB: serial: sierra driver bug fix for composite interfaceElina Pasheva
This patch fixes a problem in sierra_send_setup() function when composite devices are used. One should not be sending ACM commands to interfaces that are OBEX. Doing this causes an apparent failure as the ACM command has to time out before the interface can start being used. Signed-off-by: Elina Pasheva <epasheva@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-02sierra: Fix formattingAlan Cox
Andrew Morton wrote: in drivers/usb/serial/sierra.c: } else { if (urb->actual_length) { + tty = tty_port_tty_get(&port->port); tty_buffer_request_room(tty, urb->actual_length); it's missing a tab. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-17USB: remove info() macro from usb/serial driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB Serial: Sierra: debug message fixKevin Lloyd
This patch moves dbg calls to dev_dbg where possible. It also fixes some issues with a previous submission aiming to do the same thing. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13tty: usb-serial krefsAlan Cox
Use kref in the USB serial drivers so that we don't free tty structures from under the URB receive handlers as has historically been the case if you were unlucky. This also gives us a framework for general tty drivers to use tty_port objects and refcount. Contains two err->dev_err changes merged together to fix clashes in the -next tree. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23USB Serial: Sierra: Add MC8785 VID/PIDKevin Lloyd
Add another MC8785 VID/PID Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: Correct Sierra Wireless USB EVDO Modem Device IDTony Murray
I was trying to figure out why my device wasn't supported by the drivers/usb/serial/sierra.c driver, while looking throught the device IDs I spotted what I believe to be a typo in the device IDs. Please apply the following patch If you look down further, there is another HP wireless broadband card, which has a vendor ID of 03f0, like my device. Below is my "lsusb -v -d 03f0:1b1d". Bus 001 Device 005: ID 03f0:1b1d Hewlett-Packard Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x03f0 Hewlett-Packard idProduct 0x1b1d bcdDevice 0.01 iManufacturer 1 HP iProduct 2 HP ev2200 1xEV-DO Broadband Wireless Module iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 67 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 7 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 255 Vendor Specific Protocol iInterface 3 Data Interface Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0010 1x 16 bytes bInterval 128 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x04 EP 4 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x85 EP 5 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x05 EP 5 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Device Status: 0x0000 (Bus Powered) From: Tony Murray <murraytony@gmail.com> Cc: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB Serial: Sierra: Device addition & version revKevin Lloyd
This patch adds devices to the sierra driver and rev's the driver version. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: serial: remove CONFIG_USB_DEBUG from sierra and option driversGreg Kroah-Hartman
These drivers should not be relying on CONFIG_USB_DEBUG. By doing this, it prevents users of kernels that do not enable this option from enabling debugging in these drivers, unlike all other usb-serial drivers. Cc: Matthias Urlichs <smurf@smurf.noris.de> Cc: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB Serial Sierra: TRU-Install feature updateKevin Lloyd
Moves responsbility of TRU-Install (i.e. ZeroCD) to the usb-storage driver. See patch 04/04 of this set. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB Serial Sierra: Dynamic interface detectionKevin Lloyd
This patch changes the method by which the number of ports per interface is assigned so that it is more dynamic and calculated on the fly (as opposed to hard coding it). This will allow for faster and easier addition of products. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB Serial Sierra: clean-upKevin Lloyd
Very minor changes to clean up sierra code. Adds a prefix to debug messages so that Sierra messages are easily recognized. Removes extraneous code. This targets kernel 2.6.26-rc9 Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-22tty-usb-sierra: Coding style - minorAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22usb_serial: API all changeAlan Cox
USB serial likes to use port->tty back pointers for the real work it does and to do so without any actual locking. Unfortunately when you consider hangup events, hangup/parallel reopen or even worse hangup followed by parallel close events the tty->port and port->tty pointers are not guaranteed to be the same as port->tty is the active tty while tty->port is the port the tty may or may not still be attached to. So rework the entire API to pass the tty struct. For console cases we need to pass both for now. This shows up multiple drivers that immediately crash with USB console some of which have been fixed in the process. Longer term we need a proper tty as console abstraction Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24USB: remove unnecessary type casting of urb->contextMing Lei
urb->context code cleanup Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24usb serial: more fixes and groundwork for tty changesAlan Cox
- If a termios change fails due to lack of memory we should copy the old settings back over as the device has not changed - Note various locking problems - kl5kusb105 had various remaining tty flag handling problems - Make safe_serial use tty_insert_flip_string not open coded loops - set termios speed properly in usb_serial Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: serial: remove unneeded number endpoints settingsGreg Kroah-Hartman
The usb-serial core no longer checks these fields so remove them from all of the individual drivers. They will be removed from the usb-serial core in a patch later in the series. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24usb/usb-serial-sierra-add-new-dev-groupKevin Lloyd
This patch is for the sierra driver and adds support for a new group of devices that have a new USB configuration. This targets kernel 2.6.25-rc7 Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: Serial: Sierra: C597 fixKevin Lloyd
This patch is for the sierra driver and fixes a Compass 597 bug that allows users to access the SD-Card. This targets kernel 2.6.25-rc7 Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: Serial: Sierra: Clean upKevin Lloyd
This patch cleans up some of the sierra driver code. Please package this with the other patches in this group as I would like the driver version to reflect their changes as well. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: Add HP hs2300 Broadband Wireless Module to sierra.cStefan Seyfried
Add the HP hs2300 Broadband Wireless Module (relabeled MC8775) USB IDs Signed-off-by: Stefan Seyfried <seife@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: sierra: add another device idKevin Lloyd
Add support for the MC8775 device to the sierra driver. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: sierra: dma fixesOliver Neukum
while I was adding autosuspend to that driver I noticed a few issues. You were having DMAed buffers as a part of a structure. This will fail on platforms that are not DMA-coherent (arm, sparc, ppc, ...) Please test this patch to fix it. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21USB: serial: move zte MF330 from sierra to optionKevin Lloyd
Move the Onda H600/ZTE MF33 device from the sierra driver to the option driver. The reason it was moved is because the sierra driver is starting to support more and more sierra proprietary features, so it makes more sense to keep sierra only devices in there. Signed-off-by: Kevin Lloyd <klloyd@sierrawireless.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: make sure usb serial drivers don't flush to logically disconnected devicesOliver Neukum
If disconnect() is called for a logical disconnect, no more IO must be done after disconnect() returns, or the old and new drivers may conflict. This patch avoids this by using the flag and lock introduced by the earlier patch for the mos7720 driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: sierra driver - add update dtr logicKevin Lloyd
The following improvements were made: - Fixed control line issue where asserting DTR on ep5 would close ep2 - Added support for calc_num_ports (will help support future composite devices) Signed-off-by: Kevin Lloyd <linux@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: sierra: add support for Onda H600/Zte MF330 datacard to USB Driver for ↵Bruno Redondi
Sierra Wireless Added support for Onda H600/Zte MF330 GPRS/UMTS/HSDPA datacard Cc: stable <stable@kernel.org> Signed-off-by: Bruno Redondi <bruno.redondi@altarisoluzione.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: sierra driver - add devicesKevin Lloyd
The following improvements were made: - Added new product support: MC5725, AC 880 U, MP 3G (UMTS & CDMA) Cc: stable <stable@kernel.org> Signed-off-by: Kevin Lloyd <linux@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Sierra - Add support for Aircard 881UJessica L. Blank
Adds the appropriate vendor and device IDs for the AirCard 881U to sierra.c. (This device is often rebadged by AT&T as the USBConnect 881). Cc: stable <stable@kernel.org> Signed-off-by: Jessica L Blank <j@twu.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-22USB: VID/PID update for sierraKevin R Page
Adds VID/PID for the MC8775 found internally in the Thinkpad X61s laptop (and likely others). For commercial reasons the driver maintainer cannot add VID/PIDs for laptop OEM devices himself. Signed-off-by: Kevin R Page <linux-kernel@krp.org.uk> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-17USB: sierra: fix product idagilmore@wirelessbeehive.com
Attached is a patch to fix the addition of the new product ids I sent. It is against 2.6.24-rc4, as Linus included the broken version of the patch I sent you in that tree. :( Not sure if this is the right method to go about this, but hopefully I got it right this time. Signed-off-by: Andrew Gilmore <agilmore@wirelessbeehive.com> CC: Kevin Lloyd <klloyd@sierrawireless.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: sierra: new product idagilmore@wirelessbeehive.com
Per the maintainer of the usbserial/sierra.c driver, the patch below adds a new id to the list of supported cards for the sierra driver. Tested and working for me on Fedora 8, kernel 2.6.23 and on the more recent sierra.c available in http://www.sierrawireless.com/resources/support/Software/Linux/v.1.2.6b(kernel2.6.21).zip Hardware is a MiniPCI card in a Lenovo T61p. Signed-off-by: Andrew Gilmore <agilmore@wirelessbeehive.com> Cc: Kevin Lloyd <linux@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-25USB: sierra: termiosAlan Cox
No hardware termios setting in this case so keep the old settings Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
