The major and minor number saved in the product_info structure
were copied from the address instead of the data, causing an
inconsistency in the reported versions during firmware loading:
usb 4-1: firmware: requesting edgeport/down.fw
/usr/src/linux/drivers/usb/serial/io_edgeport.c: downloading firmware version (930) 1.16.4
/usr/src/linux/drivers/usb/serial/io_edgeport.c: edge_startup - time 3 4328191260
/usr/src/linux/drivers/usb/serial/io_edgeport.c: FirmwareMajorVersion 0.0.4
This can cause some confusion whether firmware loaded successfully
or not.
Cc: stable@kernel.org
Signed-off-by: Bjørn Mork <bjorn@mork.no>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Simple pasting job using the new ops function. Also fix a couple of devices
directly returning the internal struct (which happens at this point to match
for the fields that matter but isn't correct or futureproof)
Signed-off-by: Alan Cox <alan@linux.intel.com>
Greg prefers this to go through the trivial tree.
http://lkml.org/lkml/2010/6/24/1
There are about 2500 void functions in drivers/usb
Only a few used return; at end of function.
Standardize them a bit.
Moved a statement down a line in drivers/usb/host/u132-hcd.c
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
We have lots of callers that do not need to do this in the first place.
Remove the calls as they both cost CPU and for big buffers can mess up the
multi-page allocation avoidance.
#define dbg adds the newline, messages shouldn't.
Converted dbg("%s", "some string") to dbg("some string")
Johan Hovold points out that get_string() is basically just a
re-implimentation of usb_string(). It is also buggy. It does DMA on
the stack and it doesn't handle negative returns from
usb_get_descriptor(). Plus unicode_to_ascii() is a rubbish function and
moving to usb_string() avoids using it.
Let's eliminate get_string() entirely.
Reported-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Johan Hovold <jhovold@gmail.com>
The original code was passing a stack variable as a dma buffer, so I
made it an allocated variable. Instead of adding a bunch of kfree()
calls, I changed all the error return paths to gotos.
Also I noticed that the error checking wasn't correct because
usb_get_descriptor() can return negative values.
While I was at it, I made an unrelated white space change by moving
the unicode_to_ascii() on to one line.
Cc: Johan Hovold <jhovold@gmail.com>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
And indeed none of them use it. Clean this up as it will make moving to a
standard open method rather easier.
This patch (as1254) splits up the shutdown method of usb_serial_driver
into a disconnect and a release method.
The problem is that the usb-serial core was calling shutdown during
disconnect handling, but drivers didn't expect it to be called until
after all the open file references had been closed. The result was an
oops when the close method tried to use memory that had been
deallocated by shutdown.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This allows us to clean stuff up, but is probably also going to cause
some app breakage with buggy apps as we now implement proper POSIX behaviour
for USB ports matching all the other ports. This does also mean other apps
that break on USB will now work properly.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This removes tty->low_latency from all USB serial drivers that push
data into the tty layer at hard interrupt context. It's no longer needed
and actually harmful.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
err() is going away, so switch to dev_err() or printk() if it's really
needed.
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Use kref in the USB serial drivers so that we don't free tty structures
from under the URB receive handlers as has historically been the case if
you were unlucky. This also gives us a framework for general tty drivers to
use tty_port objects and refcount.
Contains two err->dev_err changes merged together to fix clashes in the
-next tree.
Signed-off-by: Alan Cox <alan@redhat.com>
The edgeport reports negative error codes to functions that do not
expect them. This can cause ports to jam forever
USB serial likes to use port->tty back pointers for the real work it does and
to do so without any actual locking. Unfortunately when you consider hangup
events, hangup/parallel reopen or even worse hangup followed by parallel close
events the tty->port and port->tty pointers are not guaranteed to be the same
as port->tty is the active tty while tty->port is the port the tty may or
may not still be attached to.
So rework the entire API to pass the tty struct. For console cases we need
to pass both for now. This shows up multiple drivers that immediately crash
with USB console some of which have been fixed in the process.
Longer term we need a proper tty as console abstraction
Version number provided in first HEX record.
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org>
* endianness annotations
* endianness fixes
* missing get_unaligned/put_unaligned
It's pretty much all over the place, changes to different files are independent.
Serial-parts-Acked-by: Alan Cox <alan@redhat.com>
urb->context code cleanup
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Found these while looking at printk uses.
Add missing newlines to dev_<level> uses
Add missing KERN_<level> prefixes to multiline dev_<level>s
Fixed a wierd->weird spelling typo
Added a newline to a printk
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Greg KH <greg@kroah.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
Cc: James Smart <James.Smart@Emulex.Com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Fix serious regression on non-EPiC edgeport usb-serial devices. Baud
rate and MCR/LCR registers are not being written on these models due
to apparent copy-n-paste errors introduced with EPiC support.
Failure reported by Nick Pasich <Nick@NickAndBarb.net>.
Signed-off-by: Adam Kropelin <akropel1@rochester.rr.com>
Cc: stable <stable@kernel.org>
This done in anticipation of removal of urb->status, which will make
that patch easier to review and apply in the future.
Cc: <linux-usb-devel@lists.sourceforge.net>
Cc: Al Borchers <alborchers@steinerpoint.com>
Cc: Peter Berger <pberger@brimson.com>
usb_unlink_urb() is asynchronous, therefore an URB's buffer may not
be freed without waiting for the completion handler. This patch switches
to usb_kill_urb(), which is synchronous.
Thanks to Alan for making me look at the remaining users of usb_unlink_urb()
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Al Borchers <alborchers@steinerpoint.com>
Fix the misspellings of "propogate", "writting" and (oh, the shame
:-) "kenrel" in the source tree.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
io_edgeport is using a global variable without locking.
This is _the_ classical race condition. This patch switches to atomic_t.
Every usb serial driver should have a pointer to the corresponding usb driver.
So the usb serial core can add a new id not only to the usb serial driver, but
also to the usb driver.
Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag
no_dynamic_id=1. This is added now.
Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de>
This patch adds EPiC support to the io_edgeport driver which adds
support for a number of NCR printers:
- NCR (Axiohm) 7401-K580 printer
- NCR (TEC) 7401-K590 printer, 7402-K592
- NCR (TEC) 7167, 7168 printers
- NCR (TEC) 7197, 7198, F306, F307, F309 printers
- NCR (Axiohm) 7194 printer
- NCR (Axiohm) 7158 printer
and a few more.
It is based on the 2.6.19 kernel.
Signed-off-by: Greg Kroah-Hartman <greg@kroah.com>
This is the grungy swap all the occurrences in the right places patch that
goes with the updates. At this point we have the same functionality as
before (except that sgttyb() returns speeds not zero) and are ready to
begin turning new stuff on providing nobody reports lots of bugs
If you are a tty driver author converting an out of tree driver the only
impact should be termios->ktermios name changes for the speed/property
setting functions from your upper layers.
If you are implementing your own TCGETS function before then your driver
was broken already and its about to get a whole lot more painful for you so
please fix it 8)
Also fill in c_ispeed/ospeed on init for most devices, although the current
code will do this for you anyway but I'd like eventually to lose that extra
paranoia
[akpm@osdl.org: bluetooth fix]
[mp3@de.ibm.com: sclp fix]
[mp3@de.ibm.com: warning fix for tty3270]
[hugh@veritas.com: fix tty_ioctl powerpc build]
[jdike@addtoit.com: uml: fix ->set_termios declaration]
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
Acked-by: Peter Oberparleiter <oberpar@de.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
- usb_kill_urb() cleanup
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
USB serial outside of the kernel tree can not build properly due to
usb-serial.h being buried down in the source tree. This patch moves the
location of the file to include/linux/usb and fixes up all of the usb
serial drivers to handle the move properly.
Cc: Sergei Organov <osv@javad.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Al Borchers suggested to do this in his review of my previous patch.
I guess that I skipped this initially because of my visceral dislike
of sizeof(data). But in this case it seems well localized.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
While an Edgeport is allocating individual port structures, if kmalloc
returns NULL, the serial structure is freed and -ENOMEM, but the ports
allocated before the failure are not freed. This patch addresses that
condition.
Signed-off-by: Christopher Lund <docmax@gmail.com>
Clean up the unicode handling in io_edgeport. Make get_string size-limited.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
The API and code have been through various bits of initial review by
serial driver people but they definitely need to live somewhere for a
while so the unconverted drivers can get knocked into shape, existing
drivers that have been updated can be better tuned and bugs whacked out.
This replaces the tty flip buffers with kmalloc objects in rings. In the
normal situation for an IRQ driven serial port at typical speeds the
behaviour is pretty much the same, two buffers end up allocated and the
kernel cycles between them as before.
When there are delays or at high speed we now behave far better as the
buffer pool can grow a bit rather than lose characters. This also means
that we can operate at higher speeds reliably.
For drivers that receive characters in blocks (DMA based, USB and
especially virtualisation) the layer allows a lot of driver specific
code that works around the tty layer with private secondary queues to be
removed. The IBM folks need this sort of layer, the smart serial port
people do, the virtualisers do (because a virtualised tty typically
operates at infinite speed rather than emulating 9600 baud).
Finally many drivers had invalid and unsafe attempts to avoid buffer
overflows by directly invoking tty methods extracted out of the innards
of work queue structs. These are no longer needed and all go away. That
fixes various random hangs with serial ports on overflow.
The other change in here is to optimise the receive_room path that is
used by some callers. It turns out that only one ldisc uses receive room
except asa constant and it updates it far far less than the value is
read. We thus make it a variable not a function call.
I expect the code to contain bugs due to the size alone but I'll be
watching and squashing them and feeding out new patches as it goes.
Because the buffers now dynamically expand you should only run out of
buffering when the kernel runs out of memory for real. That means a lot of
the horrible hacks high performance drivers used to do just aren't needed any
more.
Description:
tty_insert_flip_char is an old API and continues to work as before, as does
tty_flip_buffer_push() [this is why many drivers dont need modification]. It
does now also return the number of chars inserted
There are also
tty_buffer_request_room(tty, len)
which asks for a buffer block of the length requested and returns the space
found. This improves efficiency with hardware that knows how much to
transfer.
and tty_insert_flip_string_flags(tty, str, flags, len)
to insert a string of characters and flags
For a smart interface the usual code is
len = tty_request_buffer_room(tty, amount_hardware_says);
tty_insert_flip_string(tty, buffer_from_card, len);
More description!
At the moment tty buffers are attached directly to the tty. This is causing a
lot of the problems related to tty layer locking, also problems at high speed
and also with bursty data (such as occurs in virtualised environments)
I'm working on ripping out the flip buffers and replacing them with a pool of
dynamically allocated buffers. This allows both for old style "byte I/O"
devices and also helps virtualisation and smart devices where large blocks of
data suddenely materialise and need storing.
So far so good. Lots of drivers reference tty->flip.*. Several of them also
call directly and unsafely into function pointers it provides. This will all
break. Most drivers can use tty_insert_flip_char which can be kept as an API
but others need more.
At the moment I've added the following interfaces, if people think more will
be needed now is a good time to say
int tty_buffer_request_room(tty, size)
Try and ensure at least size bytes are available, returns actual room (may be
zero). At the moment it just uses the flipbuf space but that will change.
Repeated calls without characters being added are not cumulative. (ie if you
call it with 1, 1, 1, and then 4 you'll have four characters of space. The
other functions will also try and grow buffers in future but this will be a
more efficient way when you know block sizes.
int tty_insert_flip_char(tty, ch, flag)
As before insert a character if there is room. Now returns 1 for success, 0
for failure.
int tty_insert_flip_string(tty, str, len)
Insert a block of non error characters. Returns the number inserted.
int tty_prepare_flip_string(tty, strptr, len)
Adjust the buffer to allow len characters to be added. Returns a buffer
pointer in strptr and the length available. This allows for hardware that
needs to use functions like insl or mencpy_fromio.
Cc: Paul Fulghum <paulkf@microgate.com>
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of ARRAY_SIZE. Some trailing whitespaces are also removed.
Patch is compile-tested on i386.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
patch below marks various USB tables and variables as const so that they
end up in .rodata section and don't cacheline share with things that get
written to. For the non-array variables it also allows gcc to optimize
more.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
It is no longer needed, so let's remove it, saving a bit of memory.
This lets drivers, like the usb-serial ones, disable the ability to add
ids from sysfs.
The usb-serial drivers are "odd" in that they are really usb-serial bus
drivers, not usb bus drivers, so the dynamic id logic will have to go
into the usb-serial bus core for those drivers to get that ability.
