path: root/drivers/usb/otg/ulpi.c
2011-10-31usb: Add export.h for EXPORT_SYMBOL/THIS_MODULE where neededPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Use the lightweight version of the header that has just THIS_MODULE and EXPORT_SYMBOL variants. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-22usb: otg: Make USB3319 ULPI ID genericFabio Estevam
On a system with a USB3317 ULPI transceiver the following message is shown on kernel boot: ULPI transceiver vendor/product ID 0x0424/0x0006 Found SMSC USB3319 ULPI transceiver. ULPI integrity check: passed. The reason is that USB3317 has the same vendor/product ID as USB3319. Make the ULPI ID generic for the USB331x transceivers. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: otg/ulpi: extend id's table.Igor Grinberg
Extend id's table to have ulpi phy names in it. Report if the known phy is found. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: otg/ulpi: improve ulpi phy detection.Igor Grinberg
Improve ulpi phy detection by utilizing the "scratch" register. Allow unknown ulpi phy work without the need to hard-code the id. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: otg/ulpi: extend the generic ulpi driver.Igor Grinberg
1) Introduce ulpi specific flags for control of the ulpi phy 2) Extend the generic ulpi driver with support for Function and Interface control of upli phy 3) Update the platforms using the generic ulpi driver with new ulpi flags 4) Remove the otg control flags not in use Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: otg/ulpi: add support for SMSC USB3319 ulpi phyIgor Grinberg
2010-08-10USB: otg/ulpi: remove unused macroIgor Grinberg
2010-08-10USB: otg/ulpi.c : fix register writeEric Bénard
ulpi_set_vbus and ulpi_set_flags are using ULPI_SET(register) to write to the PHY's registers, which means we can only set bits in the PHY's register and not clear them. By directly using the address of the register without any offset, we now get the expected behaviour for these functions. Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Daniel Mack <daniel@caiaq.de> Cc: linux-arm-kernel@lists.infradead.org Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-30USB: otg/ulpi: bail out on read errorsWolfram Sang
otg_read may return errnos, so bail out correctly to prevent bogus ID-numbers. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Daniel Mack <daniel@caiaq.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: otg: ulpi: use the global ULPI register definitionsHeikki Krogerus
Rely on the global ULPI register definitions Signed-off-by: Heikki Krogerus <ext-heikki.krogerus@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-11USB OTG: Add generic driver for ULPI OTG transceiverDaniel Mack
This adds a minimal generic driver for ULPI connected transceivers, using the OTG framework functions recently introduced. The driver got a table to match the ULPI chips, which currently only has one entry for NXP's ISP 1504 transceiver. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Heikki Krogerus <ext-heikki.krogerus@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
