path: root/drivers/usb/musb/blackfin.c
2011-08-12usb: musb: blackfin: include prefetch head fileBob Liu
After the prefetch/list.h restructure, drivers need to explicitly include linux/prefetch.h in order to use the prefetch() function. Otherwise, the current driver fails to build: drivers/usb/musb/blackfin.c: In function 'musb_write_fifo': drivers/usb/musb/blackfin.c:43: error: implicit declaration of function 'prefetch' Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-05-18usb: musb: fix compile errorFelipe Balbi
commit 35a83365da6aa10095c6138cc428c15853409c32 (usb: musb: drop unneeded musb_debug trickery) introduced a compile error for blackfin and tusb6010 glue layers. Fix it. Reported-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-05-13usb: musb: drop unneeded musb_debug trickeryFelipe Balbi
We have a generic way of enabling/disabling different debug messages on a driver called DYNAMIC_PRINTK. Anyone interested in enabling just part of the debug messages, please read the documentation under: Documentation/dynamic-debug-howto.txt for information on how to use that great infrastructure. Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-05-06usb: fix building musb driversAnatolij Gustschin
Commit 3dacdf11 "usb: factor out state_string() on otg drivers" broke building musb drivers since there is already another otg_state_string() function in musb drivers, but with different prototype. Fix musb drivers to use common otg_state_string(), too. Also provide a nop for otg_state_string() if CONFIG_USB_OTG_UTILS is not defined. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13USB: musb: blackfin: work around anomaly 05000450Mike Frysinger
DMA mode 1 data corruption anomaly on Blackfin systems. This issue is specific to the Blackfin silicon as the bug appears to be related to the connection of the musb ip to the bus/dma fabric. Data corruption when using USB DMA mode 1. (Issue manager 17-01-0105) DMA mode 1 allows large size transfers to generate a single interrupt at the end of the entire transfer. The transfer is split up in packets of length specified in the Maximum Packet Size field for that endpoint. If the transfer size is not an integer multiple of the Maximum Packet Size, a short packet will be present at the end of the transfer. Under certain conditions this packet may be corrupted in the USB FIFO. Workaround: Use DMA mode 1 to transfer (n* Maximum Packet Size) and schedule DMA mode 0 to transfer the short packet. As an example if your transfer size is 33168 bytes and Maximum Packet Size equals 512, schedule [33168 - (33168 mod 512)] in DMA mode 1 and the remainder (33168 mod 512) in DMA mode 0. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-23usb: musb: blackfin: fix typo in new bfin_musb_vbus_status funcMike Frysinger
The common code has a "get" in the middle, but each implementation does not have it. Cc: stable@kernel.org Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23usb: musb: blackfin: fix typo in new dev_pm_ops structBob Liu
Cc: stable@kernel.org Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23usb: musb: blackfin: fix typo in platform driver nameMike Frysinger
The modularization of the Blackfin driver set the name to "musb-blackfin" in all the boards, but "musb-bfin" in the driver itself. Since the driver file name uses "blackfin", change the driver to "musb-blackfin". This is also easier as it's only one file to change. Cc: stable@kernel.org Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-01usb: musb: disable double buffering when it's brokenFelipe Balbi
We know that blackfin doesn't support double buffering feature as of today. So we add a flag set by musb_platform_init() to forcefully disable that feature. Such flag is created and marked as deprecated to force us to find a solution for the missing double buffering support on blackfin. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-16Merge branch 'usb-next' into musb-mergeGreg Kroah-Hartman
* usb-next: (132 commits) USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added usb: gadget: f_ncm.c added usb: gadget: u_ether: prepare for NCM usb: pch_udc: Fix setup transfers with data out usb: pch_udc: Fix compile error, warnings and checkpatch warnings usb: add ab8500 usb transceiver driver USB: gadget: Implement runtime PM for MSM bus glue driver USB: gadget: Implement runtime PM for ci13xxx gadget USB: gadget: Add USB controller driver for MSM SoC USB: gadget: Introduce ci13xxx_udc_driver struct USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc USB: gadget: Separate out PCI bus code from ci13xxx_udc ...
2010-12-16Revert "USB: musb: blackfin: pm: make it work"Greg Kroah-Hartman
This reverts commit 1e393c6eece048052d4131ec4dad3b98e35a98e2. Needed to properly merge the musb changes that are in the usb-next branch into Linus's tree. Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10usb: musb: drop board_set_vbusFelipe Balbi
that's not used anymore. So let's drop it. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: blackfin: usb dev_pm_ops structureFelipe Balbi
instead of using musb_platform_suspend_resume, we can use dev_pm_ops and let platform_device core handle when to call musb_core's suspend and glue layer's suspend. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: drop musb_platform_save/restore_contextFelipe Balbi
... that can be easily folded into the musb_platform_suspend/resume calls. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: pass platform_ops via platform_dataFelipe Balbi
... then we don't need to export any symbols from glue layer to musb_core. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: blackfin: give it a context structureFelipe Balbi
that structure currently only holds a device pointer to our own platform_device and musb's platform_device, but soon it will hold pointers to our clock structures and glue-specific bits and pieces. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: split blackfin to its own platform_driverFelipe Balbi
Just adding its own platform_driver, not really using it yet. Later patches will come to split power management code from musb_core and move it completely to HW glue layer. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-07usb: musb: make all glue layer export struct musb_platform_opsFelipe Balbi
preparing to a big refactor on musb code. We need to be able to compile in all glue layers (or at least all ARM-based ones) together and have a working binary. While preparing for that, we move every glue layer to export only one symbol, which is a struct musb_platform_ops, and make all other functions static. Later patches will come to allow for compiling all glue layers together and have a working binary. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-01usb: musb: remove board_data parameter from musb_platform_init()Hema Kalliguddi
Removed the board_data parameter being passed to musb_platform_init function as board_data can be extracted from device structure which is already member of musb structure. Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Hema HK <hemahk@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-11-05USB: musb: blackfin: push clkin value to platform resourcesBob Liu
In order to not touch the driver file for different xtal usage, push the clkin value to board file and calculate the register value instead of hardcoding it. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-11-05USB: musb: blackfin: fix dynamic device<->host changingBob Liu
We need to restart the timer in order to recognize USB devices in host-only mode. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-11-05USB: musb: blackfin: pm: make it workBob Liu
Split the USB MMR init steps out into a helper func that both the platform init and the resume code may call. Then while suspending, the gpio_vrsel will change from high to low which will generate a wakeup event and resume the system immediately, so we need to manually drive it low before we sleep. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-10-22usb: musb: blackfin: call gpio_free() on error path in musb_platform_init()Sergei Shtylyov
Blackfin's musb_platform_init() needs to call gpio_free() for error cleanup iff otg_get_transceiver() call returns NULL. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22usb: musb: blackfin: call usb_nop_xceiv_unregister() in musb_platform_exit()Sergei Shtylyov
Blackfin's musb_platform_exit() forgets to call usb_nop_xceiv_unregister(). While fixing this, also remove the unneeded blank line there. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: stable <stable@kernel.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: MUSB: fix kernel WARNING/oops when unloading module in OTG modeSergei Shtylyov
Since commit 461972d8a4c94bc44f11a13046041c78a7cf18dd (musb_core: don't call musb_platform_exit() twice), unloading the driver module results in a WARNING "kobject: '(null)' (c73de788): is not initialized, yet kobject_put() is being called." (or even kernel oops) on e.g. DaVincis, though only in the OTG mode. There exists dubious and unbalanced put_device() call in musb_free() which takes place only in the OTG mode. As this commit caused musb_platform_exit() to be called (and so unregister the NOP transceiver) before this put_device() call, this function references already freed memory. On the other hand, all the glue layers miss the otg_put_transceiver() call, complementary to the otg_get_transceiver() call that they do. So, I think the solution is to get rid of the strange put_device() call, and instead call otg_put_transceiver() in the glue layers... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: stable <stable@kernel.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20MUSB: Blackfin: remove musb_platform_{suspend|resume}()Sergei Shtylyov
These functions do nothing and also are both unnecessarily 'extern'; actually, musb_platform_resume() in not even called... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20MUSB: Blackfin: remove bfin_vbus_power()Sergei Shtylyov
This function does nothing... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: musb: support host/gadget role switching on Blackfin partsCliff Cai
Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: musb: allow the Blackfin vrsel gpio to be active lowCliff Cai
Rather than hardcoding the gpio levels for vrsel, allow the platform resources to handle this so boards can be active high or low. Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20usb: musb: Set transceiver interface typeMaulik Mankad
Program the OTG_INTERFSEL register based on transcevier type passed from board file. Adapt signature of musb_platform_init() function for davinci, blackfin and tusb6010. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: David Brownell <david-b@pacbell.net> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: Olof Johansson <olof@lixom.net> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-30MUSB: Blackfin: don't fake blackfin_interrupt() resultSergei Shtylyov
Commit a5073b52833e4df8e16c93dc4cbb7e0c558c74a2 (musb_gadget: fix unhandled endpoint 0 IRQs) misses this change to blackfin.c: stop faking successful result of blackfin_interrupt() and emitting a debug message on an unhandled interrupt. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02usb: musb: clean up commit 'workaround Blackfin FIFO anomalies'Bryan Wu
The version applied had a few comments which are now done. Thanks to Sergei for pointing out. Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-23USB: musb: workaround Blackfin FIFO anomaliesBryan Wu
Some of these workarounds are already in place, but labeled as affecting all BF52x parts. Since we have official anomaly numbers now, use those defines. And since writing to the FIFO has a similar hang issue as reading from the FIFO, implement the workaround there too when necessary. Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB: musb: fix musb_platform_set_mode() definitionBryan Wu
Update function definition to match latest MUSB framework. Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB: musb: kill some useless comments in Blackfin driverBryan Wu
2009-12-11USB: musb: tweak musb_read_fifo() to avoid unused warningsMike Frysinger
Otherwise gcc will whine about epnum/dma_reg being unused when building for BF54x parts. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-09USB: musb: make HAVE_CLK support optionalMike Frysinger
The Blackfin port doesn't support HAVE_CLK and the musb driver works fine with support stubbed out, so take the existing Blackfin clk stubs and move them to common musb code so we can drop the Kconfig dependency. Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15musb: proper hookup to transceiver driversDavid Brownell
Let the otg_transceiver in MUSB be managed by an external driver; don't assume it's integrated. OMAP3 chips need it to be external, and there may be ways to interact with the transceiver which add functionality to the system. Platform init code is responsible for setting up the transeciver, probably using the NOP transceiver for integrated transceivers. External ones will use whatever the board init code provided, such as twl4030 or something more hands-off. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: musb: Kill some compiling warning in musb Blackfin partBryan Wu
Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: musb: Make sure we program the correct values in only when necessary.Robin Getz
Make sure we program the correct values in only when necessary. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: musb: add Blackfin driver to MUSB framework (v2)Bryan Wu
- replace MUSB_FIFOSIZE register to MUSB_TXCOUNT, cause no MUSB_FIFOSIZE register on Blackfin - use #ifdef to replace #if defined() Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
