path: root/drivers/usb/misc/usbtest.c
2010-10-22USB: usbtest - ensure correct isoc data lengthMartin Fuzzey
Check the data length of isochronous transfers is as expected. With this test #16 will now fail if the device side sends no data. Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: usbtest fix coding styleMartin Fuzzey
2010-08-10USB: usbtest: support test device with only one iso-in or iso-out endpointMing Lei
It is very common that one altsetting may include only one iso-in or iso-out single endpoint, especially for high bandwidth endpoint, so support it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: usbtest: avoid to free coherent buffer in atomic contextMing Lei
This patch fixes the warning below: [30753.755998] ------------[ cut here ]------------ [30753.755998] WARNING: at /home/tom/git/linux-2.6/linux-2.6-next/arch/x86/include/asm/dma-mapping.h:155 hcd_buffer_free+0xb1/0xd4 [usbcore]() [30753.755998] Hardware name: 6475EK2 [30753.755998] Modules linked in: uvcvideo ehci_hcd usbtest cdc_ether usbnet vfat fat usb_storage nfsd lockd nfs_acl auth_rpcgss exportfs mii tun videodev v4l1_compat v4l2_compat_ioctl32 fuse bridge stp llc sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf kvm_intel kvm arc4 ecb ath5k usbhid mac80211 snd_hda_codec_conexant ch341 usbserial ath cfg80211 thinkpad_acpi snd_hda_intel pcspkr wmi hwmon yenta_socket iTCO_wdt iTCO_vendor_support i2c_i801 e1000e snd_hda_codec snd_hwdep snd_pcm snd_timer snd soundcore snd_page_alloc pata_acpi uhci_hcd ohci_hcd usbcore i915 drm_kms_helper drm i2c_algo_bit i2c_core video output [last unloaded: uvcvideo] [30753.755998] Pid: 0, comm: swapper Tainted: G W 2.6.35-rc6-gkh-wl+ #49 [30753.755998] Call Trace: [30753.755998] <IRQ> [<ffffffff8104478a>] warn_slowpath_common+0x80/0x98 [30753.755998] [<ffffffff810447b7>] warn_slowpath_null+0x15/0x17 [30753.755998] [<ffffffffa00ce02d>] hcd_buffer_free+0xb1/0xd4 [usbcore] [30753.755998] [<ffffffffa00c1345>] usb_free_coherent+0x1c/0x1e [usbcore] [30753.755998] [<ffffffffa00b13e4>] simple_free_urb+0x23/0x2f [usbtest] [30753.755998] [<ffffffffa00b210b>] iso_callback+0xbb/0x10f [usbtest] [30753.755998] [<ffffffffa00c7390>] usb_hcd_giveback_urb+0x8c/0xc0 [usbcore] [30753.755998] [<ffffffffa0449b35>] ehci_urb_done+0x84/0x95 [ehci_hcd] [30753.755998] [<ffffffffa044b5a5>] ehci_work+0x41a/0x7dd [ehci_hcd] [30753.755998] [<ffffffffa044e298>] ehci_irq+0x33b/0x370 [ehci_hcd] [30753.755998] [<ffffffff8100fb05>] ? sched_clock+0x9/0xd [30753.755998] [<ffffffff8105e641>] ? sched_clock_local+0x1c/0x82 [30753.755998] [<ffffffff8105e76a>] ? sched_clock_cpu+0xc3/0xce [30753.755998] [<ffffffff81067c7e>] ? trace_hardirqs_off+0xd/0xf [30753.755998] [<ffffffff8105e7b8>] ? cpu_clock+0x43/0x5e [30753.755998] [<ffffffffa00c6999>] usb_hcd_irq+0x45/0xa1 [usbcore] [30753.755998] [<ffffffff81092e02>] handle_IRQ_event+0x20/0xa5 [30753.755998] [<ffffffff81094cea>] handle_fasteoi_irq+0x92/0xd2 [30753.755998] [<ffffffff8100c0ed>] handle_irq+0x1f/0x2a [30753.755998] [<ffffffff8100b75d>] do_IRQ+0x57/0xbe [30753.755998] [<ffffffff8136a693>] ret_from_intr+0x0/0x16 [30753.755998] <EOI> [<ffffffff81223baa>] ? acpi_idle_enter_bm+0x231/0x269 [30753.755998] [<ffffffff81223ba3>] ? acpi_idle_enter_bm+0x22a/0x269 [30753.755998] [<ffffffff812c4b6b>] cpuidle_idle_call+0x99/0xce [30753.755998] [<ffffffff81008dd5>] cpu_idle+0x61/0xaa [30753.755998] [<ffffffff8136374b>] start_secondary+0x1c2/0x1c6 [30753.755998] ---[ end trace 904cfaf7ab4cb1a2 ]--- Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB-BKL: Convert usb_driver ioctl to unlocked_ioctlAndi Kleen
And audit all the users. None needed the BKL. That was easy because there was only very few around. Tested with allmodconfig build on x86-64 Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> From: Andi Kleen <ak@linux.intel.com>
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: remove uses of URB_NO_SETUP_DMA_MAPAlan Stern
This patch (as1350) removes all usages of coherent buffers for USB control-request setup-packet buffers. There's no good reason to reserve coherent memory for these things; control requests are hardly ever used in large quantity (the major exception is firmware transfers, and they aren't time-critical). Furthermore, only seven drivers used it. We might as well always use streaming DMA mappings for setup-packet buffers, and remove some extra complexity from usbcore. The DMA-mapping portion of hcd.c is currently in flux. A separate patch will be submitted to remove support for URB_NO_SETUP_DMA_MAP after everything else settles down. The removal should go smoothly, as by then nobody will be using it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB misc: make USB device id constantNémeth Márton
The id_table field of the struct usb_device_id is constant in <linux/usb.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Németh Márton <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: convert to the runtime PM frameworkAlan Stern
This patch (as1329) converts the USB stack over to the PM core's runtime PM framework. This involves numerous changes throughout usbcore, especially to hub.c and driver.c. Perhaps the most notable change is that CONFIG_USB_SUSPEND now depends on CONFIG_PM_RUNTIME instead of CONFIG_PM. Several fields in the usb_device and usb_interface structures are no longer needed. Some code which used to depend on CONFIG_USB_PM now depends on CONFIG_USB_SUSPEND (requiring some rearrangement of header files). The only visible change in behavior should be that following a system sleep (resume from RAM or resume from hibernation), autosuspended USB devices will be resumed just like everything else. They won't remain suspended. But if they aren't in use then they will naturally autosuspend again in a few seconds. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11usbtest: make module param pattern writeableVikram Pandita
Allow module_param to be writeable. This allows us to change the parameter if usbtest is built-in in the kernel. Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: usbtest fix endless loop in unlink tests.Martin Fuzzey
In tests 11 and 12 if the URB completes with an error status (eg babble) the asynchrous unlink entered an endless loop trying to unlink a non resubmitted URB. Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: clean up redundant tests on unsignedroel kluin
temp, bytes and param->{length,sglen,vary} are unsigned so these tests do nothing. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22USB: usbtest.c: length, sglen and vary are unsigned, so cannot be negativeroel kluin
length, sglen and vary are unsigned, so cannot be negative see vi drivers/usb/misc/usbtest.c +18 struct usbtest_param { ... unsigned iterations; unsigned length; unsigned vary; unsigned sglen; ... }; Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-25Rename WARN() to WARNING() to clear the namespaceArjan van de Ven
We want to use WARN() as a variant of WARN_ON(), however a few drivers are using WARN() internally. This patch renames these to WARNING() to avoid the namespace clash. A few cases were defining but not using the thing, for those cases I just deleted the definition. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Greg KH <greg@kroah.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14usbtest: comment on why this code "expects" negative and positive errnosMarcin Slusarz
On Mon, May 12, 2008 at 01:02:22AM -0700, David Brownell wrote: > On Sunday 11 May 2008, Marcin Slusarz wrote: > > > > test_ctrl_queue expects (?) positive and negative errnos. > > what is going on here? > > The sign is just a way to flag something: > > /* some faults are allowed, not required */ > > The negative ones are required. Positive codes are optional, > in the sense that, depending on how the peripheral happens > to be implemented, they won't necessarily be triggered. > > For example, the test to fetch a device qualifier desriptor > must succeed if the device is running at high speed. So that > test is marked as negative. But when it's full speed, it > could legitimately fail; marked as positive. And so on for > other tests. > > Look at how the codes are *interpreted* to see it work. Lets document it. Based on comment from David Brownell <david-b@pacbell.net>. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02USB: usbtest displays diagnostics againDavid Brownell
Minor cleanup to the "usbtest" driver, mostly to resolve a regression: all the important diagnostics were at KERN_DEBUG, so that when the "#define DEBUG" was removed from the top of that file it stopped providing diagnostics. Fix by using KERN_ERROR. Also: - Stop using the legacy dbg() calls - Simplify the internal debug macros - Correct some test descriptions: * Test #10 subcase 7 should *always* stall * Test #10 subcase 8 *may* stall - Diagnostic about control queue test failures is more informative - Fix some whitespace "bugs" And add a warning about the rude interaction between usbfs ioctl() and khubd during device disconnect ... don't unplug a device under test, that will wedge. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove unnecessary type casting of urb->contextMing Lei
urb->context code cleanup Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove dev->power.power_stateAlan Stern
power.power_state is scheduled for removal. This patch (as1053) removes all uses of that field from drivers/usb. Almost all of them were write-only, the most significant exceptions being sl811-hcd.c and u132-hcd.c. Part of this patch was written by Pavel Machek. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: use DIV_ROUND_UPJulia Lawall
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) / (d)) but is perhaps more readable. An extract of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression n,d; @@ ( - (n + d - 1) / d + DIV_ROUND_UP(n,d) | - (n + (d - 1)) / d + DIV_ROUND_UP(n,d) ) @depends on haskernel@ expression n,d; @@ - DIV_ROUND_UP((n),d) + DIV_ROUND_UP(n,d) @depends on haskernel@ expression n,d; @@ - DIV_ROUND_UP(n,(d)) + DIV_ROUND_UP(n,d) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-02USB: fix bug in sg initialization in usbtestAlan Stern
This patch (as1062) fixes a bug in the scatter-gather initialization code in the usbtest driver. When the sg-helper conversion was performed, it wasn't done correctly. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: testing driver: don't free a locked mutexAndrew Morton
Dopey thing to do and lockdep will (or should) warn. Spotted by Daniel Walker. Cc: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: Daniel Walker <dwalker@mvista.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: testing driver: convert dev->sem to mutexMatthias Kaehlcke
USB testing driver: convert semaphore dev->sem to the mutex API Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01usb: fix usbtest halt check on big endian systemsJan Andersson
usbtest did not swap the received status information when checking for a non-zero value and failed to discover halted endpoints on big endian systems. Cc: stable <stable@kernel.org> Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-07-19USB: misc: usbtest: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01USB: usbtest: Use usb_endpoint_* functionsLuiz Fernando N. Capitulino
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-11USB: usbtest.c: unsigned retval makes ctrl_out return 0 in case of errorOrjan Friberg
In my quest to try and figure out why test 14 (control write) doesn't work with my EZ-USB board, I noticed that sometimes testusb reported no error even though the kernel log complained "byte 0 is 0 not 2" etc. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] usbtest: report errors in iso testsAlan Stern
This patch (as693b) makes the usbtest driver report errors in the isochronous bulk transfer tests instead of always returning 0. As an arbitrary cutoff, an error is returned if more than 10% of the packet transfers fail. It also stops a test immediately upon receiving an URB submission error. For a test harness, it's especially important to report when errors occur! Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Fix a deadlock in usbtestFranck Bui-Huu
ctrl_complete functions acquires ctx->lock and tries to unlink all queued urbs in case of errors through usb_unlink_urb func. In its turn usb_unlink_urb calls, through the hcd driver, usb_hcd_giveback_urb which calls ctrl_complete again. At this time, ctx->lock is already taken by the same function. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] USB: usbtest: scatterlist OUT data pattern testingDavid Brownell
Previously, scatterlist tests didn't write patterned data. Given how many corner cases are addresed by them, this was a significant gap in Linux-USB test coverage. Moreover, when peripherals checked for correct data patterns, false error reports would drown out the true ones. This adds the pattern on the way OUT from the host, so scatterlist tests can now be used to uncover bugs like host TX or peripheral RX paths failing for back-to-back short packets. It's easy enough to get an error there with at least one of the {DMA,PIO}{RX,TX} code paths, or run into hardware races that need to be defended against. Note this patch doesn't add checking for correct data patterns on the way IN from peripherals, just a FIXME for later. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: kzalloc() conversion for rest of drivers/usbEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: move CONFIG_USB_DEBUG checks into the MakefileGreg Kroah-Hartman
This lets us remove a lot of code in the drivers that were all checking the same thing. It also found some bugs in a few of the drivers, which has been fixed up. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-28[PATCH] Missing transfer_flags setting in usbtestAlan Stern
This patch (as582) adds a missing transfer_flags setting to the usbtest driver. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] usb_interface power stateDavid Brownell
This updates the handling of power state for USB interfaces. - Formalizes an existing invariant: interface "power state" is a boolean: ON when I/O is allowed, and FREEZE otherwise. It does so by defining some inlined helpers, then using them. - Adds a useful invariant: the only interfaces marked active are those bound to non-suspended drivers. Later patches build on this invariant. - Simplifies the interface driver API (and removes some error paths) by removing the requirement that they record power state changes during suspend and resume callbacks. Now usbcore does that. A few drivers were simplified to address that last change. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/core/hub.c | 33 +++++++++------------ drivers/usb/core/message.c | 1 drivers/usb/core/usb.c | 65 +++++++++++++++++++++++++++++++++---------- drivers/usb/core/usb.h | 18 +++++++++++ drivers/usb/input/hid-core.c | 2 - drivers/usb/misc/usbtest.c | 10 ------ drivers/usb/net/pegasus.c | 2 - drivers/usb/net/usbnet.c | 2 - 8 files changed, 85 insertions(+), 48 deletions(-)
2005-09-08[PATCH] USB: URB_ASYNC_UNLINK flag removed from the kernelAlan Stern
29 July 2005, Cambridge, MA: This afternoon Alan Stern submitted a patch to remove the URB_ASYNC_UNLINK flag from the Linux kernel. Mr. Stern explained, "This flag is a relic from an earlier, less-well-designed system. For over a year it hasn't been used for anything other than printing warning messages." An anonymous spokesman for the Linux kernel development community commented, "This is exactly the sort of thing we see happening all the time. As the kernel evolves, support for old techniques and old code can be jettisoned and replaced by newer, better approaches. Proprietary operating systems do not have the freedom or flexibility to change so quickly." Mr. Stern, a staff member at Harvard University's Rowland Institute who works on Linux only as a hobby, noted that the patch (labelled as548) did not update two files, keyspan.c and option.c, in the USB drivers' "serial" subdirectory. "Those files need more extensive changes," he remarked. "They examine the status field of several URBs at times when they're not supposed to. That will need to be fixed before the URB_ASYNC_UNLINK flag is removed." Greg Kroah-Hartman, the kernel maintainer responsible for overseeing all of Linux's USB drivers, did not respond to our inquiries or return our calls. His only comment was "Applied, thanks." Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] USB: usbtest updatesDavid Brownell
Updates to "usbtest" driver: * Improve some diagnostics. One path that never generated diagnostics before should now generate two ... unless you hit a GCC bug that all my compilers seem to have, go figure. * Add suspend/resume support, so this behaves when the Linux host being used for testing suspends. * Don't test the "zero byte ep0 read" case unless real-world relevance for the testing is is irrelevant. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
