path: root/drivers/usb/misc/ftdi-elan.c
2007-02-12[PATCH] mark struct file_operations const 6Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-20USB: u132-hcd/ftdi-elan: add support for Option GT 3G Quad cardTony Olech
ELAN's U132 is a USB to CardBus OHCI controller adapter, designed specifically for CardBus 3G data cards to function in machines without a CardBus slot. The "ftdi-elan" module is a USB client driver, that detects a supported CardBus OHCI controller plugged into the U132 adapter and thereafter provides the conduit for for access by the "u132-hcd" module. The "u132-hcd" module is a (cut-down OHCI) host controller that supports a single OHCI function of the CardBus card inserted into the U132 adapter. The problem with the initial implementation is that when the CardBus card inserted into the U132 adapter has multiple functions (and a CardBus card can support up to 4 functions), it was the first function that was arbitrarily choosen. The first batch of 3G cards tested, like the Merlin Qualcomm V620, have two functions each supporting a seperate USB OHCI host controller, of which it was that first function that is wired up to the 3G modem. Then along comes the Vodafone Mobile Connect 3G/GPRS data card, aka "Option GT 3G Quad" as printed on it's rear or "Option N.V. GlobeTrotter Fusion Quad Lite" as read with "lspci -v". And it has the meaningful functionality in the second CardBus function. That presents a problem because it was the "ftdi-elan" module alone that knows how to communicate to the embedded CardBus slot and the "u132-hcd" module alone that knows how to access the pcmcia configuration and CardBus accessible memory space. And of course, the information about attached (internally hardwired) devices is contained within USB configuration embedded somewhere within the CardBus card. If only the "u132-hcd" module probe() interface could return a result code that propagated back to the instigating function platform_device_register() then the "ftdi-elan" module could try an alternative CardBus function. However in spite of the recent changes to the drivers/base/ routines that moved device_attach() from bus_add_device() to bus_attach_device() both of those routines lose the "failed to attach" 0 result code and thus the calling routine, namely device_add() is incapable of propaging the "failed to attach" condition back to platform_device_add() and consequently back to the caller of platform_device_register() Experiments show that patching bus_attach_device() to return ENODEV fails with the kernel locking up very early during boot. But, however, if the patch is restricted to calls from platform_device_add() then it does seem to work. Unfortunately, until the kernel's drivers/base is properly modified to propagate -ENODEV back to the caller of platform_device_register(), it is necessary to "fix" the "ftdi-elan" module by importing knowledge from the "u132-hcd" module. This is the reason for the duplicated functionality introduced in this patch. Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-01USB: ftdi-elan.c: fixes and cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the needlessly global ftdi_release_platform_dev() static - remove the unused usb_ftdi_elan_read_reg() - proper prototypes for the following functions: - usb_ftdi_elan_read_pcimem() - usb_ftdi_elan_write_pcimem() Note that the misplaced prototypes for the latter ones in drivers/usb/host/u132-hcd.c were buggy. Depending on the calling convention of the architecture calling one of them could have turned your stack into garbage. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01USB: ftdi-elan: Use usb_endpoint_* functionsLuiz Fernando N. Capitulino
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-17USB: ftdi-elan.c: remove dead codeAdrian Bunk
The Coverity checker spotted this obviously dead code. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17USB: ftdi-elan: fix sparse warningsGreg Kroah-Hartman
Deleted some unused code that could do bad things on non-x86 platforms. Also fixed some minor formatting errors. Thanks to Al Viro for pointing out the sparse errors. Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-27USB: ftdi-elan: client driver for ELAN Uxxx adaptersTony Olech
This "ftdi-elan" module is one half of the "driver" for ELAN's Uxxx series adapters which are USB to PCMCIA CardBus adapters. Currently only the U132 adapter is available and it's module is called "u132-hcd". When the USB hot plug subsystem detects a Uxxx series adapter it should load this module. Upon a successful device probe() the jtag device file interface is created and the status workqueue started up. The jtag device file interface exists for the purpose of updating the firmware in the Uxxx series adapter, but as yet it had never been used. The status workqueue initializes the Uxxx and then sits there polling the Uxxx until a supported PCMCIA CardBus device is detected it will start the command and respond workqueues and then load the module that handles the device. This will initially be only the u132-hcd module. The status workqueue then just polls the Uxxx looking for card ejects. The command and respond workqueues implement a command sequencer for communicating with the firmware on the other side of the FTDI chip in the Uxxx. This "ftdi-elan" module exports some functions to interface with the sequencer. Note that this module is a USB client driver. Note that the "u132-hcd" module is a (cut-down OHCI) host controller. Thus we have a topology with the parent of a host controller being a USB client! This really stresses the USB subsystem semaphore/mutex handling in the module removal. Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
