path: root/drivers/usb/image/microtek.c
2006-01-10[PATCH] turn "const static" into "static const"Jesper Juhl
ICC likes to complain about storage class not being first, GCC doesn't care much (except for cases like "inline static"). have a hard time seeing how it could break anything. Thanks to Gabriel A. Devenyi for pointing out http://linuxicc.sourceforge.net/ which is what made me create this patch. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: Adapt microtek driver to new scsi featuresOliver Neukum
the scsi layer now uses very short sg lists. This breaks the microtek driver. Here is a patch fixes this and some other issues. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[PATCH] USB: microtek patch to use kzallocOliver Neukum
here is another one to use kzalloc. Please apply. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-22[PATCH] USB: compilation failure on usb/image/microtek.cHideaki YOSHIFUJI
maybe typo? Signed-off-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] kill old EH constants
Fix up two drivers that incorrectly were using the old return values for their new-style EH methods and kill off scsi_obsolete.h that defined the constants. The initio driver has all these constansts defined locally and uses them internally, I'll fix that up some time later. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
