path: root/drivers/usb/host/uhci-hub.c
2013-10-07USB/host: Bugfix: Return length of copied buffer in uhci_hub_control()Deng-Cheng Zhu
In addition to the error statuses -ETIMEDOUT and -EPIPE, uhci_hub_control() needs to return the length of copied buffer when appropriate, so that the returned status of ->hub_control() in rh_call_control() in the USB core HCD can be properly handled. This patch also removes the OK() macro to make the code more readable. Reviewed-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-15USB: UHCI: fix for suspend of virtual HP controllerAlan Stern
HP's virtual UHCI host controller takes a long time to suspend (several hundred microseconds), even when no devices are attached. This provokes a warning message from uhci-hcd in the auto-stop case. To prevent this from happening, this patch adds a test to avoid performing an auto-stop when the wait_for_hp quirk flag is set. The controller will still suspend through the normal runtime PM mechanism. And since that pathway includes a 1-ms delay, the slowness of the virtual hardware won't matter. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-and-tested-by: ZhenHua <zhen-hual@hp.com> CC: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-08Merge usb-linus branch into usb-nextGreg Kroah-Hartman
This pulls in a bunch of fixes that are in Linus's tree because we need them here for testing and development. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-25USB: UHCI: notify usbcore about port resumesAlan Stern
This patch (as1651) adds calls to the new usb_hcd_{start,end}_port_resume() functions to uhci-hcd. Now UHCI root hubs won't be runtime suspended while they are sending a resume signal to one of their ports. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-24USB: uhci: beautify source codeChen Gang
get rid of the line breaks in string constants. let comments within 80 with limitation. delete ' \' at the end of a statement. Signed-off-by: Chen Gang <gang.chen@asianux.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-09UHCI: hub_status_data should indicate if ports are resumingAlan Stern
This patch (as1538) causes uhci_hub_status_data() to return a nonzero value when any port is undergoing a resume transition while the root hub is suspended. This will allow usbcore to handle races between root-hub suspend and port wakeup. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-05-06USB: UHCI: Wrap I/O register accessesJan Andersson
This patch is part of a series that extend the UHCI HCD to support non-PCI controllers. This patch replaces in{b,w,l} and out{b,wl} with calls to local inline functions. This is done so that the register access functions can be extended to support register areas not mapped in PCI I/O space. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-06USB: UHCI: Remove PCI dependencies from uhci-hubJan Andersson
This patch is part of a series that extend the UHCI HCD to support non-PCI host controllers. uhci-hub.c contained two PCI vendor checks for silicon quirks. Move these checks into uhci-hcd.c and use bits in uhci_hcd structure to mark that we need to use the quirks. This patch is followed by other patches that will remove PCI dependencies from uhci-hcd.c as well. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: controller resume should check the root hubAlan Stern
This patch (as1394) adds code to ehci-hcd, ohci-hcd, and uhci-hcd for automatically resuming the root hub when the controller is resumed, if the root hub has a wakeup request pending on some port. During resume from system sleep this doesn't matter, because the root hubs will naturally be resumed along with every other device in the system. However it _will_ matter for runtime PM: If the controller is suspended and a remote wakeup request is received then the controller will autoresume, but we need to ensure that the root hub also autoresumes. Otherwise the wakeup request would be ignored, the controller would go back to sleep, and the cycle would repeat a large number of times (I saw this happen before the patch was written). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: convert usb_hcd bitfields into atomic flagsAlan Stern
This patch (as1393) converts several of the single-bit fields in struct usb_hcd to atomic flags. This is for safety's sake; not all CPUs can update bitfield values atomically, and these flags are used in multiple contexts. The flag fields that are set only during registration or removal can remain as they are, since non-atomic accesses at those times will not cause any problems. (Strictly speaking, the authorized_default flag should become atomic as well. I didn't bother with it because it gets changed only via sysfs. It can be done later, if anyone wants.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: add missing delay during remote wakeupAlan Stern
This patch (as1330) fixes a bug in khbud's handling of remote wakeups. When a device sends a remote-wakeup request, the parent hub (or the host controller driver, for directly attached devices) begins the resume sequence and notifies khubd when the sequence finishes. At this point the port's SUSPEND feature is automatically turned off. However the device needs an additional 10-ms resume-recovery time (TRSMRCY in the USB spec). Khubd does not wait for this delay if the SUSPEND feature is off, and as a result some devices fail to behave properly following a remote wakeup. This patch adds the missing delay to the remote-wakeup path. It also extends the resume-signalling delay used by ehci-hcd and uhci-hcd from 20 ms (the value in the spec) to 25 ms (the value we use for non-remote-wakeup resumes). The extra time appears to help some devices. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Cc: Rickard Bellini <rickard.bellini@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: uhci: mark root_hub_hub_des[] as constMing Lei
mark this array as const because it is read-only Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09UHCI: fix port resume problemAlan Stern
This patch (as863) fixes a problem encountered sometimes when resuming a port on a UHCI controller. The hardware may turn off the Resume-Detect bit before turning off the Suspend bit, leading usbcore to think that the port is still suspended and the resume has failed. The patch makes uhci_finish_suspend() wait until both bits are safely off. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20UHCI: module parameter to ignore overcurrent changesAlan Stern
Certain boards seem to like to issue false overcurrent notifications, for example on ports that don't have anything connected to them. This looks like a hardware error, at the level of noise to those ports' overcurrent input signals (or non-debounced VBUS comparators). This surfaces to users as truly massive amounts of syslog spam from khubd (which is appropriate for real hardware problems, except for the volume from multiple ports). Using this new "ignore_oc" flag helps such systems work more sanely, by preventing such indications from getting to khubd (and spamming syslog). The downside is of course that true overcurrent errors will be masked; they'll appear as spontaneous disconnects, without the diagnostics that will let users troubleshoot issues like short-circuited cables. In addition, controllers with no devices attached will be forced to poll for new devices rather than relying on interrupts, since each overcurrent event would generate a new interrupt. This patch (as826) is essentially a copy of David Brownell's ignore_oc patch for ehci-hcd, ported to uhci-hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27UHCI: increase Resume-Detect-off delayAlan Stern
The UHCI controller in my laptop takes longer to turn off the Resume-Detect bit than the 4 us allowed by uhci-hcd. Presumably other computers will have the same problem. This patch (as752) increases the maximum delay to 10 us, which should be plenty, and uses polling to avoid penalizing systems which can turn the bit off more quickly. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] UHCI: remove hc_inaccessible flagAlan Stern
This patch (as706) removes the private hc_inaccessible flag from uhci-hcd. It's not needed because it conveys exactly the same information as the generic HCD_FLAG_HW_ACCESSIBLE bit. In its place goes a new flag recording whether the controller is dead. The new code allows a complete device reset to resurrect a dead controller (although usbcore doesn't yet implement such a facility). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] UHCI: Reimplement FSBRAlan Stern
This patch (as683) re-implements Full-Speed Bandwidth Reclamation (FSBR) properly. It keeps track of which endpoint queues have advanced, and when none have advanced for a sufficiently long time, FSBR is turned off. The next TD on each of the non-moving queues is modified to generate an interrupt on completion, so that FSBR can be re-enabled as soon as the hardware starts to make some progress. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] USB: UHCI: don't track suspended portsAlan Stern
Someone recently posted a bug report where it turned out that uhci-hcd was disagreeing with the UHCI controller over whether or not a port was suspended: The driver thought it wasn't and the hardware thought it was. This patch (as665) fixes the problem and simplifies the driver by removing the internal state-tracking completely. Now the driver just asks the hardware whether a port is suspended. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: UHCI: Increase port-reset completion delay for HP controllersAlan Stern
This patch (as657) increases the port-reset completion delay in uhci-hcd for HP's embedded controllers. Unlike other UHCI controllers, the HP chips can take as long as 250 us to carry out the processing associated with finishing a port reset. This fixes Novell bug #148761. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-12[PATCH] USB UHCI: remove the FSBR kernel timerAlan Stern
This patch (as558) removes from the UHCI driver a kernel timer used for checking Full Speed Bandwidth Reclamation (FSBR). The checking can be done during normal root-hub polling; it doesn't need a separate timer. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB UHCI: Use root-hub IRQs while suspendedAlan Stern
This patch, which has as478b as a prerequisite, enables the uhci-hcd driver to take advantage of root-hub IRQs rather than polling during the time it is suspended. (Unfortunately the hardware doesn't support port-change interrupts while the controller is running.) It also turns off the driver's private timer while the controller is suspended, as it isn't needed then. The combined elimination of polling interrupts and timer interrupts ought to be enough to allow some systems to save a noticeable amount of power while they are otherwise idle. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB UHCI: Add root-hub suspend/resume supportAlan Stern
This patch implements (finally!) separate suspend and resume routines for the root hub and the controller in the UHCI driver. It also changes the sequence used to reset the controller during initial probing, so as to preserve the existing state during a Resume-From-Disk. (This new sequence is what should be used in the PCI Quirks code for early USB handoffs, incidentally.) Lastly it adds a notion of the controller being "inaccessible" while in a PCI low-power state, when normal I/O operations shouldn't be allowed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB UHCI: Add root hub statesAlan Stern
This patch starts making some serious changes to the UHCI driver. There's a set of private states for the root hub, and the internal routines for suspending and resuming work completely differently, with transitions based on the new states. Now the driver distinguishes between a privately auto-stopped state and a publicly suspended state, and it will properly suspend controllers with broken resume-detect interrupts instead of resetting them. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB UHCI: Minor improvementsAlan Stern
This patch makes a few small improvements in the UHCI driver. Some code is moved between different source files and a more useful pointer is passed to a callback routine. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
