path: root/drivers/usb/host/ohci-platform.c
2012-11-21usb: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21usb: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Geoff Levand <geoff@infradead.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21usb: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: make ohci-platform use devm_request_and_ioremap helperFlorian Fainelli
This patch changes the ohci-platform driver to use the device managed helper function for requesting memory region and ioremapping memory resources. As a result the error path in the probe function is simplified, and the platform driver remove callback does no longer need to release and iounmap memory resources. devm_request_and_ioremap() will use either the ioremap() or ioremap_nocache() handler depending on the resource's CACHEABLE flag, so we are good with this change. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: fix typo in ohci-platform driver on the word "resource"Florian Fainelli
We meant to write "resource" instead of "recourse", this patch fixes this typo. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: OHCI: make ohci-platform use dev_err() instead of pr_err()Florian Fainelli
This patch converts the ohci-platform driver to use dev_err() functions instead of pr_err(). Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: ohci: merge ohci_finish_controller_resume with ohci_resumeFlorian Fainelli
Merge ohci_finish_controller_resume with ohci_resume as suggested by Alan Stern. Since ohci_finish_controller_resume no longer exists, update the various OHCI drivers to call ohci_resume() instead. Some drivers used to set themselves the bit HCD_FLAG_HW_ACCESSIBLE, which is now handled by ohci_resume(). Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22USB: ohci: allow platform driver to specify the number of portsFlorian Fainelli
This patch modifies the ohci platform driver to accept the num_ports parameter to be set via platform_data. Setting the number of ports must be done after the call to ohci_hcd_init(). Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15drivers/usb/host/ohci-platform.c: fix error return codeJulia Lawall
Convert a possibly 0 error return code to a negative one, as returned elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier ret; expression e,e1,e2,e3,e4,x; @@ ( if (\(ret != 0\|ret < 0\) || ...) { ... return ...; } | ret = 0 ) ... when != ret = e1 *x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...); ... when != x = e2 when != ret = e3 *if (x == NULL || ...) { ... when != ret = e4 * return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: host: ohci-platform: add platform specific power callbackKuninori Morimoto
This patch enables to call platform specific power callback function. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: host: ohci-platform: BUG_ON() to WARN_ON() on probeKuninori Morimoto
usb_ohci_pdata is certainly required in ohci-platform driver. This patch avoids using BUG_ON() from driver, and return from probe with WARN_ON() if pdata was NULL. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18usb: Fix various typo within usbMasanari Iida
Correct spelling typo within usb Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-15USB: OHCI: Add a generic platform device driverHauke Mehrtens
This adds a generic driver for platform devices. It works like the PCI driver and is based on it. This is for devices which do not have an own bus but their OHCI controller works like a PCI controller. It will be used for the Broadcom bcma and ssb USB OHCI controller. Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
