path: root/drivers/usb/host/ohci-hub.c
2005-11-29[PATCH] USB: Fix USB suspend/resume crasher (#2)Benjamin Herrenschmidt
This patch closes the IRQ race and makes various other OHCI & EHCI code path safer vs. suspend/resume. I've been able to (finally !) successfully suspend and resume various Mac models, with or without USB mouse plugged, or plugging while asleep, or unplugging while asleep etc... all without a crash. Alan, please verify the UHCI bit I did, I only verified that it builds. It's very simple so I wouldn't expect any issue there. If you aren't confident, then just drop the hunks that change uhci-hcd.c I also made the patch a little bit more "safer" by making sure the store to the interrupt register that disables interrupts is not posted before I set the flag and drop the spinlock. Without this patch, you cannot reliably sleep/wakeup any recent Mac, and I suspect PCs have some more sneaky issues too (they don't frankly crash with machine checks because x86 tend to silently swallow PCI errors but that won't last afaik, at least PCI Express will blow up in those situations, but the USB code may still misbehave). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: Rename hcd->hub_suspend to hcd->bus_suspendAlan Stern
This patch (as580) is perhaps the only result from the long discussion I had with David about his changes to the root-hub suspend/resume code. It renames the hub_suspend and hub_resume methods in struct usb_hcd to bus_suspend and bus_resume. These are more descriptive names, since the methods really do suspend or resume an entire USB bus, and less likely to be confused with the hub_suspend and hub_resume routines in hub.c. It also takes David's advice about removing the layer of bus glue, where those methods are called. And it implements a related change that David made to the other HCDs but forgot to put into dummy_hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] OHCI PM updatesDavid Brownell
This simplifies the OHCI root hub suspend logic: - Uses new usbcore root hub calls to make autosuspend work again: * Uses a newish usbcore root hub wakeup mechanism, making requests to khubd not keventd. * Uses an even newer sibling suspend hook. - Expect someone always made usbcore call ohci_hub_suspend() before bus glue fires; and that ohci_hub_resume() is only called after that bus glue ran. Previously, only CONFIG_USB_SUSPEND promised those things. (Includes updates to PCI and OMAP bus glue.) - Handle a not-noticed-before special case during resume from one of the swsusp snapshots when using "usb-handoff": the controller isn't left in RESET state. (A bug to fix in the usb-handoff code...) Also cleans up a minor debug printk glitch, and switches an mdelay over to an msleep (how did that stick around for so long?). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/ohci-dbg.c | 4 ---- drivers/usb/host/ohci-hcd.c | 2 +- drivers/usb/host/ohci-hub.c | 42 ++++++++++++------------------------------ drivers/usb/host/ohci-mem.c | 1 - drivers/usb/host/ohci-omap.c | 36 ++++++++++++------------------------ drivers/usb/host/ohci-pci.c | 40 ++++++++-------------------------------- drivers/usb/host/ohci.h | 1 - 7 files changed, 33 insertions(+), 93 deletions(-)
2005-10-28[PATCH] remove some USB_SUSPEND dependenciesDavid Brownell
This simplifies some of the PM-related #ifdeffing by recognizing that USB_SUSPEND depends on PM. Also, OHCI drivers were often testing for USB_SUSPEND when they should have tested just PM. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/core/hcd.c | 2 ++ drivers/usb/host/ohci-hcd.c | 2 +- drivers/usb/host/ohci-hub.c | 4 ++-- drivers/usb/host/ohci-omap.c | 2 +- drivers/usb/host/ohci-pci.c | 2 +- drivers/usb/host/ohci-ppc-soc.c | 4 ++-- drivers/usb/host/ohci-pxa27x.c | 2 +- drivers/usb/host/ohci-s3c2410.c | 3 +-- drivers/usb/host/ohci-sa1111.c | 2 +- 9 files changed, 12 insertions(+), 11 deletions(-)
2005-09-12[PATCH] USB: OHCI relies less on NDP registerDavid Brownell
Some OHCI implementations have differences in the way the NDP register (in roothub_a) reports the number of ports present. This patch allows the platform specific code to optionally supply the number of ports. The driver just reads the value at init (if not supplied) instead of reading it every time its needed (except for an AMD756 bug workaround). It also sets the value correctly for the ARM pxa27x architecture. Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-12[PATCH] USB: coverity: (desc->bitmap)[] overrun fixKAMBAROV, ZAUR
The length of the array desc->bitmap is 3, and not 4: Definitions involved: In drivers/usb/core/hcd.h 464 #define bitmap DeviceRemovable In drivers/usb/host/ohci-hub.c 395 struct usb_hub_descriptor *desc In drivers/usb/core/hub.h 130 struct usb_hub_descriptor { 131 __u8 bDescLength; 132 __u8 bDescriptorType; 133 __u8 bNbrPorts; 134 __u16 wHubCharacteristics; 135 __u8 bPwrOn2PwrGood; 136 __u8 bHubContrCurrent; 137 /* add 1 bit for hub status change; round to bytes */ 138 __u8 DeviceRemovable[(USB_MAXCHILDREN + 1 + 7) / 8]; 139 __u8 PortPwrCtrlMask[(USB_MAXCHILDREN + 1 + 7) / 8]; 140 } __attribute__ ((packed)); In include/linux/usb.h 306 #define USB_MAXCHILDREN (16) This defect was found automatically by Coverity Prevent, a static analysis tool. (akpm: this code should be shot. Field `bitmap' doesn't exist in struct usb_hub_descriptor. And this .c file is #included in drivers/usb/host/ohci-hcd.c, and someone somewhere #defines `bitmap' to `DeviceRemovable'. >From a maintainability POV it would be better to memset the whole array beforehand - I changed the patch to do that) Signed-off-by: Zaur Kambarov <zkambarov@coverity.com> Cc: <linux-usb-devel@lists.sourceforge.net? Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
