path: root/drivers/usb/host/ohci-dbg.c
2005-10-28[PATCH] OHCI PM updatesDavid Brownell
This simplifies the OHCI root hub suspend logic: - Uses new usbcore root hub calls to make autosuspend work again: * Uses a newish usbcore root hub wakeup mechanism, making requests to khubd not keventd. * Uses an even newer sibling suspend hook. - Expect someone always made usbcore call ohci_hub_suspend() before bus glue fires; and that ohci_hub_resume() is only called after that bus glue ran. Previously, only CONFIG_USB_SUSPEND promised those things. (Includes updates to PCI and OMAP bus glue.) - Handle a not-noticed-before special case during resume from one of the swsusp snapshots when using "usb-handoff": the controller isn't left in RESET state. (A bug to fix in the usb-handoff code...) Also cleans up a minor debug printk glitch, and switches an mdelay over to an msleep (how did that stick around for so long?). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/ohci-dbg.c | 4 ---- drivers/usb/host/ohci-hcd.c | 2 +- drivers/usb/host/ohci-hub.c | 42 ++++++++++++------------------------------ drivers/usb/host/ohci-mem.c | 1 - drivers/usb/host/ohci-omap.c | 36 ++++++++++++------------------------ drivers/usb/host/ohci-pci.c | 40 ++++++++-------------------------------- drivers/usb/host/ohci.h | 1 - 7 files changed, 33 insertions(+), 93 deletions(-)
2005-09-12[PATCH] USB: OHCI relies less on NDP registerDavid Brownell
Some OHCI implementations have differences in the way the NDP register (in roothub_a) reports the number of ports present. This patch allows the platform specific code to optionally supply the number of ports. The driver just reads the value at init (if not supplied) instead of reading it every time its needed (except for an AMD756 bug workaround). It also sets the value correctly for the ARM pxa27x architecture. Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] USB: move the usb hcd code to use the new class code.gregkh@suse.de
This moves a kref into the main hcd structure, which detaches it from the class device structure. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
