path: root/drivers/usb/host/isp116x-hcd.c
2012-11-21usb: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Geoff Levand <geoff@infradead.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-02usb: isp116x-hcd: Convert to module_platform_driverTobias Klauser
Use the module_platform_driver macro, move the usb_disabled() check to the probe function and get rid of the rather pointless message on module load. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-09-18USB: irq: Remove IRQF_DISABLEDYong Zhang
This flag is a NOOP and can be removed now. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-19USB: remove remaining usages of hcd->state from usbcore and fix regressionAlan Stern
This patch (as1467) removes the last usages of hcd->state from usbcore. We no longer check to see if an interrupt handler finds that a controller has died; instead we rely on host controller drivers to make an explicit call to usb_hc_died(). This fixes a regression introduced by commit 9b37596a2e860404503a3f2a6513db60c296bfdc (USB: move usbcore away from hcd->state). It used to be that when a controller shared an IRQ with another device and an interrupt arrived while hcd->state was set to HC_STATE_HALT, the interrupt handler would be skipped. The commit removed that test; as a result the current code doesn't skip calling the handler and ends up believing the controller has died, even though it's only temporarily stopped. The solution is to ignore HC_STATE_HALT following the handler's return. As a consequence of this change, several of the host controller drivers need to be modified. They can no longer implicitly rely on usbcore realizing that a controller has died because of hcd->state. The patch adds calls to usb_hc_died() in the appropriate places. The patch also changes a few of the interrupt handlers. They don't expect to be called when hcd->state is equal to HC_STATE_HALT, even if the controller is still alive. Early returns were added to avoid any confusion. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Manuel Lauss <manuel.lauss@googlemail.com> CC: Rodolfo Giometti <giometti@linux.it> CC: Olav Kongas <ok@artecdesign.ee> CC: <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-13USB 3.0 Hub ChangesJohn Youn
Update the USB core to deal with USB 3.0 hubs. These hubs have a slightly different hub descriptor than USB 2.0 hubs, with a fixed (rather than variable length) size. Change the USB core's hub descriptor to have a union for the last fields that differ. Change the host controller drivers that access those last fields (DeviceRemovable and PortPowerCtrlMask) to use the union. Translate the new version of the hub port status field into the old version that khubd understands. (Note: we need to fix it to translate the roothub's port status once we stop converting it to USB 2.0 hub status internally.) Add new code to handle link state change status. Send out new control messages that are needed for USB 3.0 hubs, like Set Hub Depth. This patch is a modified version of the original patch submitted by John Youn. It's updated to reflect the removal of the "bitmap" #define, and change the hub descriptor accesses of a couple new host controller drivers. Signed-off-by: John Youn <johnyoun@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Max Vozeler <mvz@vozeler.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <dbrownell@users.sourceforge.net>
2011-03-13USB: Remove bitmap #define from hcd.hSarah Sharp
Using a #define to redefine a common variable name is a bad thing, especially when the #define is in a header. include/linux/usb/hcd.h redefined bitmap to DeviceRemovable to avoid typing a long field in the hub descriptor. This has unintended side effects for files like drivers/usb/core/devio.c that include that file, since another header included after hcd.h has different variables named bitmap. Remove the bitmap #define and replace instances of it in the host controller code. Cleanup the spaces around function calls and square brackets while we're at it. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Max Vozeler <mvz@vozeler.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <dbrownell@users.sourceforge.net>
2010-10-22USB: isp116x-hcd - use resource_size instead of defining its own ↵Axel Lin
resource_len macro Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: make hcd.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hcd.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-24USB: make transfer_buffer_lengths in struct urb field u32Greg Kroah-Hartman
Roel Kluin pointed out that transfer_buffer_lengths in struct urb was declared as an 'int'. This patch changes this field to be 'u32' to prevent any potential negative conversion and comparison errors. This triggered a few compiler warning messages when these fields were being used with the min macro, so they have also been fixed up in this patch. Cc: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Let some USB host controllers get IRQ flags from resourceMarc Zyngier
[This version fixes a thinko in the r8a66597 driver] This patch let a few discrete USB host controllers drivers (isp116x-hcd, r8a66597-hcd and sl811-hcd) obtain IRQ flags from their IORESOURCE_IRQ resource if configured as such, much like it's been done for the smc91x driver. It spares people writing support for specific boards the burden to configure the interrupt controller independantly, and keeps all IRQ related information in a single resource. HCD that are integrally part of a SoC have been left aside, as there is probably no "wiring" options... Tested on an Xscale PXA-255 based platform with isp116x-hcd. Signed-off-by: Marc Zyngier <marc.zyngier@altran.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-25Rename WARN() to WARNING() to clear the namespaceArjan van de Ven
We want to use WARN() as a variant of WARN_ON(), however a few drivers are using WARN() internally. This patch renames these to WARNING() to avoid the namespace clash. A few cases were defining but not using the thing, for those cases I just deleted the definition. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Greg KH <greg@kroah.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21USB: Fix bug with byte order in isp116x-hcd.c fio write/readJulien May
URB payload data are transfered in wrong byte order on a big endinan architecture (AVR32). Signed-off-by: Julien May <mailinglist@miromico.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: usb dev_name() instead of dev->bus_idKay Sievers
The bus_id field is going away, use the dev_name() function instead. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: HCDs use the do_remote_wakeup flagAlan Stern
When a USB device is suspended, whether or not it is enabled for remote wakeup depends on the device_may_wakeup() setting. The setting is then saved in the do_remote_wakeup flag. Later on, however, the device_may_wakeup() value can change because of user activity. So when testing whether a suspended device is or should be enabled for remote wakeup, we should always test do_remote_wakeup instead of device_may_wakeup(). This patch (as1076) makes that change for root hubs in several places. The patch also adjusts uhci-hcd so that when an autostopped controller is suspended, the remote wakeup setting agrees with the value recorded in the root hub's do_remote_wakeup flag. And the patch adjusts ehci-hcd so that wakeup events on selectively suspended ports (i.e., the bus itself isn't suspended) don't turn on the PME# wakeup signal. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove dev->power.power_stateAlan Stern
power.power_state is scheduled for removal. This patch (as1053) removes all uses of that field from drivers/usb. Almost all of them were write-only, the most significant exceptions being sl811-hcd.c and u132-hcd.c. Part of this patch was written by Pavel Machek. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-11usb host: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable USB HCDs, to allow re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers; registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04USB: isp116x: fix enumeration on bootAnti Sullin
This patch removes the buffering of the status register. USB core behavior has changed a bit and this buffering was not refreshed at the right time. The core got buffered old value of HCRHPORT and it did not detect any devices on boot. Signed-off-by: Anti Sullin <anti.sullin@artecdesign.ee> Acked by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Drop unnecessary continue in a few driversJulia Lawall
Continue is not needed at the bottom of a loop. The semantic patch implementing this change is as follows: @@ @@ for (...;...;...) { ... if (...) { ... - continue; } } Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: Eliminate urb->status usage!Alan Stern
This patch (as979) removes the last vestiges of urb->status from the host controller drivers and the root-hub emulator. Now the field doesn't get set until just before the URB's completion routine is called. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add urb->unlinked fieldAlan Stern
This patch (as970) adds a new urb->unlinked field, which is used to store the status of unlinked URBs since we can't use urb->status for that purpose any more. To help simplify the HCDs, usbcore will check urb->unlinked before calling the completion handler; if the value is set it will automatically override the status reported by the HCD. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: centralize -EREMOTEIO handlingAlan Stern
This patch (as969) continues the ongoing changes to the way HCDs report URB statuses. The programming interface has been simplified by making usbcore responsible for clearing urb->hcpriv and for setting -EREMOTEIO status when an URB with the URB_SHORT_NOT_OK flag ends up as a short transfer. By moving the work out of the HCDs, this removes a fair amount of repeated code. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: remove unnecessary tests in isp116x and sl811Alan Stern
This patch (as962) cleans up some code I forgot to remove earlier in the isp116x and sl811 HCDs. There is no longer any need to check for unlink-during-submit; it can't happen since the endpoint queues are now under the protection of the HCD-private spinlock. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: make HCDs responsible for managing endpoint queuesAlan Stern
This patch (as954) implements a suggestion of David Brownell's. Now the host controller drivers are responsible for linking and unlinking URBs to/from their endpoint queues. This eliminates the possiblity of strange situations where usbcore thinks an URB is linked but the HCD thinks it isn't. It also means HCDs no longer have to check for URBs being dequeued before they were fully enqueued. In addition to the core changes, this requires changing every host controller driver and the root-hub URB handler. For the most part the required changes are fairly small; drivers have to call usb_hcd_link_urb_to_ep() in their urb_enqueue method, usb_hcd_check_unlink_urb() in their urb_dequeue method, and usb_hcd_unlink_urb_from_ep() before giving URBs back. A few HCDs make matters more complicated by the way they split up the flow of control. In addition some method interfaces get changed. The endpoint argument for urb_enqueue is now redundant so it is removed. The unlink status is required by usb_hcd_check_unlink_urb(), so it has been added to urb_dequeue. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Tony Olech <tony.olech@elandigitalsystems.com> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19isp116x-hcd: prepare for urb->statusAlan Stern
This patch (as931b), adapted from a patch by Olav Kongas, makes a small set of conservative changes to the isp116x-hcd driver in preparation for the removal of urb->status. finish_request() is moved up in the source and is called as soon as the URB is known to have completed, rather than after all the active endpoints have been scanned. The status of a completed URB is kept in a local variable and copied to urb->status only when the URB is about to be given back. -EREMOTEIO error status for control transfers is set after the status stage rather than when the short packet arrives. Some unnecessary uses of urb->lock are removed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: change __init to __devinit for isp116x_probePrarit Bhargava
Change __init to __devinit for isp116x_probe. Resolves MODPOST warning: WARNING: drivers/usb/host/isp116x-hcd.o - Section mismatch: reference to .init.text:isp116x_probe from .data.rel.local between 'isp116x_driver' (at offset 0x0) and 'isp116x_hc_driver' Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: usb: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-21[PATCH] USB: move hardware-specific <linux/usb_*.h> to <linux/usb/*.h>David Brownell
This moves header files for controller-specific platform data from <linux/usb_XXX.h> to <linux/usb/XXX.h> to start reducing some clutter. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: negative index in drivers/usb/host/isp116x-hcd.cEric Sesterhenn
From: Eric Sesterhenn <snakebyte@gmx.de> This fixes coverity Bug #390. With the following code ret = ep->branch = balance(isp116x, ep->period, ep->load); if (ret < 0) goto fail; the problem is that ret and balance are of the type int, and ep->branch is u16. so the int balance() returns gets reduced to u16 and then converted to an int again, which removes the sign. Maybe the following little c program can explain it better:
2006-03-20[PATCH] USB: fix initdata issue in isp116x-hcdGreg Kroah-Hartman
As found by Sam's scripts. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB core and HCDs: don't put_device while atomicAlan Stern
This patch (as640) removes several put_device and the corresponding get_device calls from the USB core and HCDs. Some of the puts were done in atomic contexts, and none of them are needed since the core now guarantees that every endpoint will be disabled and every URB completed before a USB device is released. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: isp116x-hcd: replace mdelay() by msleep()Olav Kongas
Replace mdelay() by msleep() in bus_suspend(); the rest of the system will gain 7ms. The related code is reorganized to minimize the number of locking/unlocking calls. The last hunk of the patch is the formatting change by Lindent. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: isp116x-hcd.c: Removed unused variableDaniel Marjamäki
Removed unused variable Signed-off-by: Daniel Marjamäki <daniel.marjamaki@comhem.se> Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: isp116x-hcd: minor cleanupOlav Kongas
When going to suspend, there's no point in setting HC state in host controller driver as USB core takes care of this. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: wakeup flag updates (3/3) isp116x-hcdDavid Brownell
This makes the ISP116x HCD use the driver model wakeup flags for its controller, not the flags in the HCD glue (which will be removed). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: isp116x-hcd: cleanupOlav Kongas
The attached patch makes a cleanup of isp116x-hcd. Most of the volume of the patch comes from 2 sources: moving the code around to get rid of a few function prototypes and reworking register dumping functions/macros. Among other things, switched over from using procfs to debugfs. Cleanup. The following changes were made: - Rework register dumping code so it can be used for dumping to both syslog and debugfs. - Switch from procfs to debugfs.. - Die gracefully on Unrecoverable Error interrupt. - Fix memory leak in isp116x_urb_enqueue(), if HC happens to die in a narrow time window. - Fix a 'sparce' warning (unnecessary cast). - Report Devices Removable for root hub ports by default (was Devices Permanently Attached). - Move bus suspend/resume functions down in code to get rid of a few function prototypes. - A number of one-line cleanups. - Add an entry to MAINTAINERS. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> MAINTAINERS | 6 drivers/usb/host/isp116x-hcd.c | 429 ++++++++++++++++------------------------- drivers/usb/host/isp116x.h | 83 +++++-- 3 files changed, 230 insertions(+), 288 deletions(-)
2006-01-04[PATCH] USB: isp116x-hcd: support reiniting HC on resumeOlav Kongas
Until now the isp116x-hcd had no support to reinitialize the HC on resume, if the controller lost its state during suspend. This patch, generated against your Oct 26 git tree, adds that support. The patch is basically the same as the one tested by Ivan Kalatchev, who reported the problem, on 2.6.13. Please apply, Support reinitializing the isp116x host controller from scratch on resume, if the controller has lost its state. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: Rename hcd->hub_suspend to hcd->bus_suspendAlan Stern
This patch (as580) is perhaps the only result from the long discussion I had with David about his changes to the root-hub suspend/resume code. It renames the hub_suspend and hub_resume methods in struct usb_hcd to bus_suspend and bus_resume. These are more descriptive names, since the methods really do suspend or resume an entire USB bus, and less likely to be confused with the hub_suspend and hub_resume routines in hub.c. It also takes David's advice about removing the layer of bus glue, where those methods are called. And it implements a related change that David made to the other HCDs but forgot to put into dummy_hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] ISP116x PM updatesDavid Brownell
This makes the isp116x driver stop using usb_suspend_device() and usb_resume_device() ... usbcore now calls to the root hub methods, removing the need for this. It also switches from keventd to khubd for remote wakeup. (Compile tested.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/isp116x-hcd.c | 29 ++++------------------------- drivers/usb/host/isp116x.h | 1 - 2 files changed, 4 insertions(+), 26 deletions(-)
2005-10-28[PATCH] remove usb_suspend_device() parameterDavid Brownell
This patch removes the extra usb_suspend_device() parameter. The original reason to pass that parameter was so that this routine could suspend any active children. A previous patch removed that functionality ... leaving no reason to pass the parameter. A close analogy is pci_set_power_state, which doesn't need a pm_message_t either. On the internal code path that comes through the driver model, the parameter is now used to distinguish cases where USB devices need to "freeze" but not suspend. It also checks for an error case that's accessible through sysfs: attempting to suspend a device before its interfaces (or for hubs, ports). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/core/hub.c | 34 +++++++++++++++++++++------------- drivers/usb/core/usb.c | 23 +++++++++++++++++++++-- drivers/usb/host/ehci-hcd.c | 2 +- drivers/usb/host/isp116x-hcd.c | 2 +- drivers/usb/host/ohci-pci.c | 2 +- include/linux/usb.h | 2 +- 6 files changed, 46 insertions(+), 19 deletions(-)
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-10-17[PATCH] isp116x-hcd: fix handling of short transfersOlav Kongas
Increased use of scatter-gather by usb-storage driver after 2.6.13 has exposed a buggy codepath in isp116x-hcd, which was probably never visited before: bug happened only for those urbs, for which URB_SHORT_NOT_OK was set AND short transfer occurred. The fix attached was tested in 2 ways: (a) it fixed failing initialization of a flash drive with an embedded hub; (b) the fix was tested with 'usbtest' against a modified g_zero driver (on top of net2280), which generated short bulk IN transfers of various lengths including multiples and non-multiples of max_packet_length. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
