path: root/drivers/usb/host/ehci-tegra.c
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-10-31DMA-API: usb: use new dma_coerce_mask_and_coherent()Russell King
Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-31DMA-API: usb: use dma_set_coherent_mask()Russell King
The correct way for a driver to specify the coherent DMA mask is not to directly access the field in the struct device, but to use dma_set_coherent_mask(). Only arch and bus code should access this member directly. Convert all direct write accesses to using the correct API. Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-09-30USB: EHCI: tegra: drop clk_put for devm_clk_get in tegra_ehci_probe()Wei Yongjun
devm_clk_get() is used so there is no reason to explicitly call clk_put() in probe or remove functions. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12usb: host: tegra: Tegra30 supportTuomas Tynkkynen
The Tegra30 EHCI controller is mostly compatible with the Tegra20 controller, except Tegra30 includes the HOSTPC register extension. The has_hostpc capability bit must be set in the ehci_hcd structure if the controller has such extensions. The new tegra_ehci_soc_config structure is added to describe the differences between the SoCs. Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-07-29usb: host: tegra: Locate a PHY via standard APITuomas Tynkkynen
Use devm_get_phy_by_phandle to get a PHY device instead of the custom Tegra functions. Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-07-29usb: tegra: host: Remove references to plat dataTuomas Tynkkynen
Platform data is not used in tegra-ehci anymore, so remove all references to it. Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-07-29usb: host: tegra: Remove leftover codeTuomas Tynkkynen
ehci-tegra calls devm_usb_get_phy, which will never succeed since the Tegra PHY does not register itself with the PHY subsystem. It is also completely redundant since the code has already located a PHY via an internal API. Call otg_set_host unconditionally to simplify the code since it should be safe to do so. Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-07-29usb: tegra: Use regulators instead of GPIOs for USB PHY VBUSMikko Perttunen
The tegra ehci driver has enabled USB vbus regulators directly using GPIOs and the device tree attribute nvidia,vbus-gpio. This is ugly and causes error messages on boot when both the regulator driver and the ehci driver want access to the same GPIO. After this patch, usb vbus regulators for tegra usb phy devices are specified with the device tree attribute vbus-supply = <&x> where x is a regulator defined in the device tree. The old nvidia,vbus-gpio property is no longer supported. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-06-17USB: EHCI: tegra: Fix oops in error cleanupThierry Reding
Under some circumstances it happens that the connected PHY can't be powered up properly, in which case the cleanup path currently crashes because it checks the tegra->transceiver field using !IS_ERR(), which will succeed because it is in fact NULL. Dereferencing that pointer causes an oops in tegra_ehci_probe(). This patch fixes the issue by adding an additional label into the cleanup path to separately take down the PHY and the transceiver. Signed-off-by: Thierry Reding <thierry.reding@gmail.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17USB: EHCI: tegra: make use of ehci->privStephen Warren
Rather than allocating struct tegra_ehci_hcd separately, use struct ehci_hcd's priv field instead. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17USB: EHCI: make ehci-tegra a separate driverManjunath Goudar
Separate the Tegra on-chip host controller driver from ehci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> [swarren, reworked Manjunath's patches to split them more logically, minor re-order of added lines to better match layout of other split-up HCD drivers and existing code, add MODULE_DEVICE_TABLE, fix MODULE_LICENSE, adapted to change in earlier patches which removed the ehci_driver_overrides addition, removed all PM code and solved circular dependencies.] Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17USB: EHCI: tegra: fix circular module dependenciesStephen Warren
The Tegra EHCI driver directly calls various functions in the Tegra USB PHY driver. The reverse is also true; the PHY driver calls into the EHCI driver. This is problematic when the two are built as modules. The calls from the PHY to EHCI driver were originally added in commit bbdabdb "usb: add APIs to access host registers from Tegra PHY", for the following reasons: 1) The register being touched is an EHCI register, so logically only the EHCI driver should touch it. 2) (1) implies that some locking may be needed to correctly implement the r/m/w access to this shared register. 3) We were expecting to pass only the PHY register space to the Tegra PHY driver, and hence it would not have access to touch the shared registers. To solve this, that commit added functions in the EHCI driver to touch the shared register on behalf of the PHY driver. In practice, we ended up not having any locking in the implementaiton of those functions, and I've been led to believe this is safe. Equally, (3) did not happen either. Hence, it is possible for the PHY driver to touch the shared register directly. Given that, this patch moves the code to touch the shared register back into the PHY driver, to eliminate the module problems. If we actually need locking or co-ordination in the future, I propose we put the lock support into some pre-existing core module, or into a third separate module, in order to avoid the circular dependencies. I apologize for my contribution to code churn here. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17USB: EHCI: tegra: remove all power managementStephen Warren
The PM routines in ehci-tegra.c use APIs such as ehci_reset(), ehci_halt(), and ehci_tdi_reset() that would need to be exported to convert ehci-tegra.c into a separate module from ehci-hcd.c. However, we'd prefer not to export them. Instead, simply remove all power management functionality. Runtime PM was disabled since it didn't work correctly, and system suspend isn't yet supported in a meaningful way. So, this change doesn't lose any functionality. Hopefully the power management logic can be reimplemented in a cleaner way in the future. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17USB: EHCI: export ehci_handshake for ehci-hcd sub-driversManjunath Goudar
In order to split ehci-hcd.c into separate modules, handshake() must be exported. Rename the symbol to add an ehci_ prefix, to avoid any naming clashes. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> [swarren, split Manjunath's patches more logically, limit this change to export just handshake()] Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-30usb: phy: registering Tegra USB PHY as platform driverVenu Byravarasu
Registered Tegra USB PHY as a separate platform driver. To synchronize host controller and PHY initialization, used deferred probe mechanism. As PHY should be initialized before EHCI starts running, deferred probe of Tegra EHCI driver till PHY probe gets completed. Got rid of instance number based handling in host driver. Made use of DT params to get the PHY Pad registers. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-05-30usb: phy: tegra: Get PHY mode using DTVenu Byravarasu
Added a new PHY mode to support OTG. Obtained Tegra USB PHY mode using DT property. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-05-16USB: set device dma_mask without reference to global dataStephen Warren
Many USB host drivers contain code such as: if (!pdev->dev.dma_mask) pdev->dev.dma_mask = &tegra_ehci_dma_mask; ... where tegra_ehci_dma_mask is a global. I suspect this code originated in commit 4a53f4e "USB: ehci-tegra: add probing through device tree" and was simply copied everywhere else. This works fine when the code is built-in, but can cause a crash when the code is in a module. The first module load sets up the dma_mask pointer, but if the module is removed and re-inserted, the value is now non-NULL, and hence is not updated to point at the new location, and hence points at a stale location within the previous module load address, which in turn causes a crash if the pointer is de-referenced. The simplest way of solving this seems to be to copy the code from ehci-platform.c, which uses the coherent_dma_mask as the target for the dma_mask pointer. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-23usb: phy: tegra: don't call into tegra-ehci directlyArnd Bergmann
Both phy-tegra-usb.c and ehci-tegra.c export symbols used by the other one, which does not work if one of them or both are loadable modules, resulting in an error like: drivers/built-in.o: In function `utmi_phy_clk_disable': drivers/usb/phy/phy-tegra-usb.c:302: undefined reference to `tegra_ehci_set_phcd' drivers/built-in.o: In function `utmi_phy_clk_enable': drivers/usb/phy/phy-tegra-usb.c:324: undefined reference to `tegra_ehci_set_phcd' drivers/built-in.o: In function `utmi_phy_power_on': drivers/usb/phy/phy-tegra-usb.c:447: undefined reference to `tegra_ehci_set_pts' This turns the interface into a one-way dependency by letting the tegra ehci driver pass two function pointers for callbacks that need to be called by the phy driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Felipe Balbi <balbi@ti.com> Cc: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05Merge tag 'usb-for-v3.10' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v3.10 merge window Here is the big Gadget & PHY pull request. Many of us have been really busy lately getting multiple drivers to a better position. Since this pull request is so large, I will divide it in sections so it's easier to grasp what's included. - cleanups: . UDC drivers no longer touch gadget->dev, that's now udc-core responsibility . Many more UDC drivers converted to usb_gadget_map/unmap_request() . UDC drivers no longer initialize DMA-related fields from gadget's device structure . UDC drivers don't touch gadget.dev.driver directly . UDC drivers don't assign gadget.dev.release directly . Removal of some unused DMA_ADDR_INVALID . Introduction of CONFIG_USB_PHY . All phy drivers have been moved to drivers/usb/phy and renamed to a common naming scheme . Fix PHY layer so it never returns a NULL pointer, also fix all callers to avoid using IS_ERR_OR_NULL() . Sparse fixes all over the place . drivers/usb/otg/ has been deleted . Marvel drivers (mv_udc, ehci-mv, mv_otg and mv_u3d) improved clock usage - new features: . UDC core now provides a generic way for tracking and reporting UDC's state (not attached, resuming, suspended, addressed, default, etc) . twl4030-usb learned that it shouldn't be enabled during init . Full DT support for DWC3 has been implemented . ab8500-usb learned about pinctrl framework . nop PHY learned about DeviceTree and regulators . DWC3 learned about suspend/resume . DWC3 can now be compiled in host-only and gadget-only (as well as DRD) configurations . UVC now enables streaming endpoint based on negotiated speed . isp1301 now implements the PHY API properly . configfs-based interface for gadget drivers which will lead to the removal of all code which just combines functions together to build functional gadget drivers. . f_serial and f_obex were converted to new configfs interface while maintaining old interface around. - non-critical fixes: . UVC gadget driver got fixes for Endpoint usage and stream calculation . ab8500-usb fixed unbalanced clock and regulator API usage . twl4030-usb got a fix for when OMAP3 is booted with cable connected . fusb300_udc got a fix for DMA usage . UVC got fixes for two assertions of the USB Video Class Compliance specification revision 1.1 . build warning issues caused by recent addition of __must_check to regulator API These are all changes which deserve a mention, all other changes are related to these one or minor spelling fixes and other similar tasks. Signed-of-by: Felipe Balbi <balbi@ti.com>
2013-04-03usb: host: ehci-tegra: Fix oops in error cleanupThierry Reding
The cleanup path checks whether the transceiver was properly initialized using IS_ERR(). However it can also happen that the cleanup path is run before the transceiver was initialized (or the operating mode isn't set to TEGRA_USB_OTG) and is therefore NULL. Add a separate label for error unwinding and initialize the transceiver field to ERR_PTR(-ENODEV) when the operating mode isn't TEGRA_USB_OTG to allow for consistent checking. Signed-off-by: Thierry Reding <thierry@gilfi.de> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Venu Byravarasu <vbyravarasu@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-03usb: host: tegra: Reset Tegra USB controller before initVenu Byravarasu
To clear any configurations made by U-Boot on Tegra USB controller, reset it before init in probe. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-21usb: host: ehci-tegra: fix PHY error handlingFelipe Balbi
PHY layer no longer returns NULL, we must switch from IS_ERR_OR_NULL() to IS_ERR(). Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-03-18usb: ehci: tegra: check against CONFIG_USB_PHYFelipe Balbi
CONFIG_USB_OTG_UTILS will be removed very soon, so we should check CONFIG_USB_PHY instead. Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-01-28usb: host: tegra: make use of PHY pointer of HCDVenu Byravarasu
As pointer to PHY structure can be stored in struct usb_hcd making use of it, to call Tegra PHY APIs. Call to usb_phy_shutdown() is moved up in tegra_ehci_remove(), so that to avoid dereferencing of hcd after its freed up. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28usb: host: tegra: don't touch EMC clockStephen Warren
Clock "emc" is for the External Memory Controller. The USB driver has no business touching this clock directly. Remove the code that does so. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28usb: add APIs to access host registers from Tegra PHYVenu Byravarasu
As Tegra PHY driver needs to access one of the host registers, added few APIs. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> [swarren: moved assignment of phy->is_ulpi_phy to previous patch.] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28usb: host: tegra: Resetting PORT0 based on information received via DT.Venu Byravarasu
Tegra USB host driver is using port instance number, to handle some of the hardware issues on SOC e.g. reset PORT0 twice etc. As instance number based handling looks ugly, making use of information passed through DT for achieving this. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-21usb: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-14usb: host: tegra: remove pointless NULL check in tegra_ehci_remove()Wei Yongjun
Test for tegra and hcd in tegra_ehci_remove() look like potential NULL pointer dereference, but in fact those tests are not needed, so remove these pointless tests entirely. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31USB: EHCI: remove ehci_port_power() routineAlan Stern
This patch (as1623) removes the ehci_port_power() routine and all the places that call it. There's no reason for ehci-hcd to change the port power settings; the hub driver takes care of all that stuff. There is one exception: When the controller is resumed from hibernation or following a loss of power, the ports that are supposed to be handed over to a companion controller must be powered on first. Otherwise the handover won't work. This process is not visible to the hub driver, so it has to be handled in ehci-hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-24usb: host: tegra remove include of <mach/iomap.h>Stephen Warren
Almost nothing from this file is used, and the file will hopefully be deleted soon. Copy the tiny portions that are used directly into ehci-tegra.c. I believe that Venu Byravarasu is working on cleaning up our USB driver, and those cleanups will remove the need for these constants. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Venu Byravarasu <vbyravarasu@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-11Merge tag 'xceiv-for-v3.7' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next usb: xceiv: patches for v3.7 merge window nop xceiv got its own header to avoid polluting otg.h. It has also learned to work as USB2 and USB3 phys so we can use it on USB3 controllers. Together with those two changes to nop xceiv, we're adding basic PHY support to dwc3 driver, this is to allow platforms which actually have a SW-controllable PHY talk to them through dwc3 driver. We're adding a new phy driver for the OMAP architecture. This driver is for the PHY found in OMAP4 SoCs, and a new phy driver for the marvell architecture. An extra phy driver - for Tegra SoCs - is now moving from arch/arm/mach-tegra* to drivers/usb/phy. Also here, there's the creation of <linux/usb/phy.h> which should be used from now on for PHY drivers, even those which don't support OTG.
2012-09-05usb: move phy driver from mach-tegra to drivers/usbVenu Byravarasu
As part of this patch: 1. Moved existing tegra phy driver to drivers/USB directory. 2. Added standard USB phy driver APIs to tegra phy driver. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-08-27Merge v3.6-rc3 into usb-nextGreg Kroah-Hartman
This picks up fixes that we need in this branch for testing. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10drivers/usb/host/ehci-tegra.c: use devm_ functionsJulia Lawall
The various devm_ functions allocate memory that is released when a driver detaches. This patch uses these functions for data that is allocated in the probe function of a platform device and is only freed in the remove function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: host: tegra: fix warning messages in ehci_removeVenu Byravarasu
Existing implementation of tegra_ehci_remove() calls usb_put_hcd(hcd) first and then iounmap(hcd->regs). usb_put_hcd() implementation calls hcd_release() which frees up memory allocated for hcd. As iounmap is trying to unmap hcd->regs, after hcd getting freed up, warning messages were observed during unload of USB. Hence fixing it. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26Merge tag 'usb-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big USB patch set for the 3.6-rc1 merge window. Lots of little changes in here, primarily for gadget controllers and drivers. There's some scsi changes that I think also went in through the scsi tree, but they merge just fine. All of these patches have been in the linux-next tree for a while now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflicts in include/scsi/scsi_device.h (same libata conflict that Jeff had already encountered) * tag 'usb-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (207 commits) usb: Add USB_QUIRK_RESET_RESUME for all Logitech UVC webcams usb: Add quirk detection based on interface information usb: s3c-hsotg: Add header file protection macros in s3c-hsotg.h USB: ehci-s5p: Add vbus setup function to the s5p ehci glue layer USB: add USB_VENDOR_AND_INTERFACE_INFO() macro USB: notify phy when root hub port connect change USB: remove 8 bytes of padding from usb_host_interface on 64 bit builds USB: option: add ZTE MF821D USB: sierra: QMI mode MC7710 moved to qcserial USB: qcserial: adding Sierra Wireless devices USB: qcserial: support generic Qualcomm serial ports USB: qcserial: make probe more flexible USB: qcserial: centralize probe exit path USB: qcserial: consolidate usb_set_interface calls USB: ehci-s5p: Add support for device tree USB: ohci-exynos: Add support for device tree USB: ehci-omap: fix compile failure(v1) usb: host: tegra: pass correct pointer in ehci_setup() USB: ehci-fsl: Update ifdef check to work on 64-bit ppc USB: serial: keyspan: Removed unrequired parentheses. ...
2012-07-16usb: host: tegra: pass correct pointer in ehci_setup()Laxman Dewangan
The ehci_setup() require the pointer of usb_hcd. Passing the correct pointer in place of ehci_hcd pointer. This is side effect of change: commit 1a49e2ac9651df7349867a5cf44e2c83de1046af Author: Alan Stern <stern@rowland.harvard.edu> EHCI: centralize controller initialization [Although I checked for this specifically, obviously I missed some of the calls. In addition to the mistake in ehci-tegra.c that Laxman fixed here, the same thing needs to be fixed in ehci-orion.c and ehci-xls.c. -- Alan Stern] Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16USB: EHCI: fix up lockingAlan Stern
This patch (as1588) adjusts the locking in ehci-hcd's various halt, shutdown, and suspend/resume pathways. We want to hold the spinlock while writing device registers and accessing shared variables, but not while polling in a loop. In addition, there's no need to call ehci_work() at times when no URBs can be active, i.e., in ehci_stop() and ehci_bus_suspend(). Finally, ehci_adjust_port_wakeup_flags() is called only in situations where interrupts are enabled; therefore it can use spin_lock_irq rather than spin_lock_irqsave. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09EHCI: centralize controller initializationAlan Stern
This patch (as1564c) converts the EHCI platform drivers to use the central ehci_setup() routine for generic controller initialization rather than each having its own idiosyncratic approach. The major point of difficulty lies in ehci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ehci_setup() and some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. One point not addressed by the patch is whether ports should be powered on or off following initialization. The different drivers appear to handle this pretty much at random. In fact it shouldn't matter, because the hub driver turns on power to all ports when it binds to the root hub. Straightening that out will be left for another day. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-02usb: phy: fix return value check of usb_get_phyKishon Vijay Abraham I
usb_get_phy will return -ENODEV if it's not able to find the phy. Hence fixed all the callers of usb_get_phy to check for this error condition instead of relying on a non-zero value as success condition. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-06-25usb: otg: support for multiple transceivers by a single controllerKishon Vijay Abraham I
Add a linked list for keeping multiple PHY instances with different types so that we can have separate USB2 and USB3 PHYs on one single board. _get_phy_ has been changed so that the controller gets the transceiver by type. _remove_phy_ has been added to let the phy be removed from the phy list. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-06-25usb: otg: utils: rename function name in OTG utilsKishon Vijay Abraham I
_transceiver() in otg.c is replaced with _phy. usb_set_transceiver is replaced with usb_add_phy to make it similar to other usb standard function names like usb_add_hcd. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-06-11USB: ehci-tegra: add clk_prepare/clk_unpreparePrashant Gaikwad
Use clk_prepare/clk_unprepare as required by the generic clk framework. Cc: stern@rowland.harvard.edu Cc: gregkh@linuxfoundation.org Cc: linux-usb@vger.kernel.org Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-05-26Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc driver specific updates from Olof Johansson: "These changes are specific to some driver that may be used by multiple boards or socs. The most significant change in here is the move of the samsung iommu code from a platform specific in-kernel interface to the generic iommu subsystem." Fix up trivial conflicts in arch/arm/mach-exynos/Kconfig * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits) mmc: dt: Consolidate DT bindings iommu/exynos: Add iommu driver for EXYNOS Platforms ARM: davinci: optimize the DMA ISR ARM: davinci: implement DEBUG_LL port choice ARM: tegra: Add SMMU enabler in AHB ARM: tegra: Add Tegra AHB driver Input: pxa27x_keypad add choice to set direct_key_mask Input: pxa27x_keypad direct key may be low active Input: pxa27x_keypad bug fix for direct_key_mask Input: pxa27x_keypad keep clock on as wakeup source ARM: dt: tegra: pinmux changes for USB ULPI ARM: tegra: add USB ULPI PHY reset GPIO to device tree ARM: tegra: don't hard-code USB ULPI PHY reset_gpio ARM: tegra: change pll_p_out4's rate to 24MHz ARM: tegra: fix pclk rate ARM: tegra: reparent sclk to pll_c_out1 ARM: tegra: Add pllc clock init table ARM: dt: tegra cardhu: basic audio support ARM: dt: tegra30.dtsi: Add audio-related nodes ARM: tegra: add AUXDATA required for audio ...
2012-05-22Merge tag 'usb-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB 3.5-rc1 changes from Greg Kroah-Hartman: "Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window. It's touches a lot of different parts of the kernel, all USB drivers, due to some API cleanups (getting rid of the ancient err() macro) and some changes that are needed for USB 3.0 power management updates. There are also lots of new drivers, pimarily gadget, but others as well. We deleted a staging driver, which was nice, and finally dropped the obsolete usbfs code, which will make Al happy to never have to touch that again. There were some build errors in the tree that linux-next found a few days ago, but those were fixed by the most recent changes (all were due to us not building with CONFIG_PM disabled.) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits) xhci: Fix DIV_ROUND_UP compile error. xhci: Fix compile with CONFIG_USB_SUSPEND=n USB: Fix core compile with CONFIG_USB_SUSPEND=n brcm80211: Fix compile error for .disable_hub_initiated_lpm. Revert "USB: EHCI: work around bug in the Philips ISP1562 controller" MAINTAINERS: Add myself as maintainer to the USB PHY Layer USB: EHCI: fix command register configuration lost problem USB: Remove races in devio.c USB: ehci-platform: remove update_device USB: Disable hub-initiated LPM for comms devices. xhci: Add Intel U1/U2 timeout policy. xhci: Add infrastructure for host-specific LPM policies. USB: Add macros for interrupt endpoint types. xhci: Reserve one command for USB3 LPM disable. xhci: Some Evaluate Context commands must succeed. USB: Disable USB 3.0 LPM in critical sections. USB: Add support to enable/disable USB3 link states. USB: Allow drivers to disable hub-initiated LPM. USB: Calculate USB 3.0 exit latencies for LPM. USB: Refactor code to set LPM support flag. ... Conflicts: arch/arm/mach-exynos/mach-nuri.c arch/arm/mach-exynos/mach-universal_c210.c drivers/net/wireless/ath/ath6kl/usb.c
2012-05-22Merge tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm soc-specific pinctrl changes from Olof Johansson: "With this, five platforms are moving to the relatively new pinctrl subsystem for their pin management, replacing the older soc specific in-kernel interfaces with common code. There is quite a bit of net addition of code for each platform being added to the pinctrl subsystem. But the payback comes later when adding new boards can be done by only providing new device trees instead." Fix up trivial conflicts in arch/arm/mach-ux500/{Makefile,board-mop500.c} * tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) mtd: nand: gpmi: fix compile error caused by pinctrl call ARM: PRIMA2: select PINCTRL and PINCTRL_SIRF in Kconfig ARM: nomadik: enable PINCTRL_NOMADIK where needed ARM: mxs: enable pinctrl support video: mxsfb: adopt pinctrl support ASoC: mxs-saif: adopt pinctrl support i2c: mxs: adopt pinctrl support mtd: nand: gpmi: adopt pinctrl support mmc: mxs-mmc: adopt pinctrl support serial: mxs-auart: adopt pinctrl support serial: amba-pl011: adopt pinctrl support spi/imx: adopt pinctrl support i2c: imx: adopt pinctrl support can: flexcan: adopt pinctrl support net: fec: adopt pinctrl support ARM: ux500: switch MSP to using pinctrl for pins ARM: ux500: alter MSP registration to return a device pointer ARM: ux500: switch to using pinctrl for uart0 ARM: ux500: delete custom pin control system ARM: ux500: switch over to Nomadik pinctrl driver ...
2012-05-10Merge tag 'v3.5-soc' of git://gitorious.org/linux-davinci/linux-davinci into ↵Olof Johansson
next/drivers DaVinci SoC updates for v3.5 This pull request updates the DaVinci SoC support to implement DEBUG_LL port choice and optimizes the DMA ISR by removing unnecessary register reads. * tag 'v3.5-soc' of git://gitorious.org/linux-davinci/linux-davinci: ARM: davinci: optimize the DMA ISR ARM: davinci: implement DEBUG_LL port choice + sync with Linux 3.4-rc6 Signed-off-by: Olof Johansson <olof@lixom.net>
2012-05-09Merge branch 'for-3.5/usb-ulpi' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/drivers By Stephen Warren (30) and others via Stephen Warren * 'for-3.5/usb-ulpi' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra: (7 commits) ARM: dt: tegra: pinmux changes for USB ULPI ARM: tegra: add USB ULPI PHY reset GPIO to device tree ARM: tegra: don't hard-code USB ULPI PHY reset_gpio ARM: tegra: change pll_p_out4's rate to 24MHz ARM: tegra: fix pclk rate ARM: tegra: reparent sclk to pll_c_out1 ARM: tegra: Add pllc clock init table + depends/pinctrl/mergebase branch Pinctrl mergebase has a conflict in drivers/pinctrl/core.c that was resolved. Signed-off-by: Olof Johansson <olof@lixom.net>
