path: root/drivers/usb/host/ehci-pmcmsp.c
2013-12-08usb: hcd: move controller wakeup setting initialization to individual driverPeter Chen
Individual controller driver has different requirement for wakeup setting, so move it from core to itself. In order to align with current etting the default wakeup setting is enabled (except for chipidea host). Pass compile test with below commands: make O=outout/all allmodconfig make -j$CPU_NUM O=outout/all drivers/usb Signed-off-by: Peter Chen <peter.chen@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-23Revert "Revert "USB: EHCI: support running URB giveback in tasklet context""Greg Kroah-Hartman
This reverts commit 3b8d7321ed4b8511e17048303b806ffcc2806077, which brings back commit 428aac8a81058e2303677a8fbf26670229e51d3a as it should be working for the 3.13-rc1 merge window now that Alan's other fixes are here in the tree already. Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17Revert "USB: EHCI: support running URB giveback in tasklet context"Greg Kroah-Hartman
This reverts commit 428aac8a81058e2303677a8fbf26670229e51d3a. This isn't quite ready for 3.12, we need some more EHCI driver changes that are just now showing up. So revert this for now, and queue it up later for 3.13. Reported-by: Alan Stern <stern@rowland.harvard.edu> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12USB: EHCI: support running URB giveback in tasklet contextMing Lei
All 4 transfer types can work well on EHCI HCD after switching to run URB giveback in tasklet context, so mark all HCD drivers to support it. Also we don't need to release ehci->lock during URB giveback any more. >From below test results on 3 machines(2 ARM and one x86), time consumed by EHCI interrupt handler droped much without performance loss. 1 test description 1.1 mass storage performance test: - run below command 10 times and compute the average performance dd if=/dev/sdN iflag=direct of=/dev/null bs=200M count=1 - two usb mass storage device: A: sandisk extreme USB 3.0 16G(used in test case 1 & case 2) B: kingston DataTraveler G2 4GB(only used in test case 2) 1.2 uvc function test: - run one simple capture program in the below link http://kernel.ubuntu.com/~ming/up/capture.c - capture format 640*480 and results in High Bandwidth mode on the uvc device: Z-Star 0x0ac8/0x3450 - on T410(x86) laptop, also use guvcview to watch video capture/playback 1.3 about test2 and test4 - both two devices involved are tested concurrently by above test items 1.4 how to compute irq time(the time consumed by ehci_irq) - use trace points of irq:irq_handler_entry and irq:irq_handler_exit 1.5 kernel 3.10.0-rc3-next-20130528 1.6 test machines Pandaboard A1: ARM CortexA9 dural core Arndale board: ARM CortexA15 dural core T410: i5 CPU 2.67GHz quad core 2 test result 2.1 test case1: single mass storage device performance test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 25.280(avg:145,max:772) | 25.540(avg:14, max:75) Arndale board: 29.700(avg:33, max:129) | 29.700(avg:10, max:50) T410: 34.430(avg:17, max:154*)| 34.660(avg:12, max:155) --------------------------------------------------------------------- 2.2 test case2: two mass storage devices' performance test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 15.840/15.580(avg:158,max:1216) | 16.500/16.160(avg:15,max:139) Arndale board: 17.370/16.220(avg:33 max:234) | 17.480/16.200(avg:11, max:91) T410: 21.180/19.820(avg:18 max:160) | 21.220/19.880(avg:11, max:149) --------------------------------------------------------------------- 2.3 test case3: one uvc streaming test - uvc device works well(on x86, luvcview can be used too and has same result with uvc capture) -------------------------------------------------------------------- upstream | patched irq time(us) | irq time(us) -------------------------------------------------------------------- Pandaboard A1: (avg:445, max:873) | (avg:33, max:44) Arndale board: (avg:316, max:630) | (avg:20, max:27) T410: (avg:39, max:107) | (avg:10, max:65) --------------------------------------------------------------------- 2.4 test case4: one uvc streaming plus one mass storage device test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 20.340(avg:259,max:1704)| 20.390(avg:24, max:101) Arndale board: 23.460(avg:124,max:726) | 23.370(avg:15, max:52) T410: 28.520(avg:27, max:169) | 28.630(avg:13, max:160) --------------------------------------------------------------------- 2.5 test case5: read single mass storage device with small transfer - run below command 10 times and compute the average speed dd if=/dev/sdN iflag=direct of=/dev/null bs=4K count=4000 1), test device A: -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 6.5(avg:21, max:64) | 6.5(avg:10, max:24) Arndale board: 8.13(avg:12, max:23) | 8.06(avg:7, max:17) T410: 6.66(avg:13, max:131) | 6.84(avg:11, max:149) --------------------------------------------------------------------- 2), test device B: -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 5.5(avg:21,max:43) | 5.49(avg:10, max:24) Arndale board: 5.9(avg:12, max:22) | 5.9(avg:7, max:17) T410: 5.48(avg:13, max:155) | 5.48(avg:7, max:140) --------------------------------------------------------------------- * On T410, sometimes read ehci status register in ehci_irq takes more than 100us, and the problem has been reported on the link: http://marc.info/?t=137065867300001&r=1&w=2 Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17USB: EHCI: Remove double assignment of .start in ehci_msp_hc_driverEmil Goode
This patch removes a double assignment of .start in struct hc_driver ehci_msp_hc_driver and also makes the code look more tidy. Signed-off-by: Emil Goode <emilgoode@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31USB: EHCI: remove ehci_port_power() routineAlan Stern
This patch (as1623) removes the ehci_port_power() routine and all the places that call it. There's no reason for ehci-hcd to change the port power settings; the hub driver takes care of all that stuff. There is one exception: When the controller is resumed from hibernation or following a loss of power, the ports that are supposed to be handed over to a companion controller must be powered on first. Otherwise the handover won't work. This process is not visible to the hub driver, so it has to be handled in ehci-hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09EHCI: centralize controller initializationAlan Stern
This patch (as1564c) converts the EHCI platform drivers to use the central ehci_setup() routine for generic controller initialization rather than each having its own idiosyncratic approach. The major point of difficulty lies in ehci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ehci_setup() and some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. One point not addressed by the patch is whether ports should be powered on or off following initialization. The different drivers appear to handle this pretty much at random. In fact it shouldn't matter, because the hub driver turns on power to all ports when it binds to the root hub. Straightening that out will be left for another day. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-03USB: EHCI: Support controllers with big endian capability regsJan Andersson
The two first HC capability registers (CAPLENGTH and HCIVERSION) are defined as one 8-bit and one 16-bit register. Most HC implementations have selected to treat these registers as part of a 32-bit register, giving the same layout for both big and small endian systems. This patch adds a new quirk, big_endian_capbase, to support controllers with big endian register interfaces that treat HCIVERSION and CAPLENGTH as individual registers. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-25USB: EHCI bus glue for on-chip PMC MSP USB controllerAnoop
This patch add bus glue for USB controller commonly found in PMC-Sierra MSP71xx family of SoC's. Signed-off-by: Anoop P A <anoop.pa@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
