path: root/drivers/usb/host/ehci-mxc.c
2013-08-23usb: ehci-mxc: check for pdata before dereferencingDaniel Mack
Commit 7e8d5cd93fac ("USB: Add EHCI support for MX27 and MX31 based boards") introduced code that could potentially lead to a NULL pointer dereference on driver removal. Fix this by checking for the value of pdata before dereferencing it. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable <stable@vger.kernel.org> # 2.6.33+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-31USB: host: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25USB: host: Use usb_hcd_platform_shutdown() wherever possibleRoger Quadros
Most HCD drivers are doing the same thing in their ".shutdown" callback so it makes sense to use the generic usb_hcd_platform_shutdown() handler there. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-16USB: ehci-mxc: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-23USB: Fix initconst in ehci driverAndi Kleen
Fix some of the initconst markings in the ehci driver(s). Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15USB: remove incorrect __exit markupsDmitry Torokhov
Even if bus is not hot-pluggable, the devices can be unbound from the driver via sysfs, so we should not be using __exit annotations on remove() methods. The only exception is drivers registered with platform_driver_probe() which specifically disables sysfs bind/unbind attributes. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15usb: host: ehci-mxc: Remove dev_info on probeFabio Estevam
It is not very useful to indicate the the driver is about to be probed. Quoting Alan Stern [1]: "Plenty of drivers don't include any message like this at all. You might as well get rid of it entirely." Remove such dev_info(). [1] http://marc.info/?l=linux-usb&m=136138896132433&w=2 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15usb: host: ehci-mxc: Remove unneeded header fileFabio Estevam
Since commit c0304996b (USB: ehci-mxc: remove Efika MX-specific CHRGVBUS hack) there is no need to include <asm/mach-types.h>, so remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-21Merge tag 'usb-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big USB merge for 3.9-rc1 Nothing major, lots of gadget fixes, and of course, xhci stuff. All of this has been in linux-next for a while, with the exception of the last 3 patches, which were reverts of patches in the tree that caused problems, they went in yesterday." * tag 'usb-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (190 commits) Revert "USB: EHCI: make ehci-vt8500 a separate driver" Revert "USB: EHCI: make ehci-orion a separate driver" Revert "USB: update host controller Kconfig entries" USB: update host controller Kconfig entries USB: EHCI: make ehci-orion a separate driver USB: EHCI: make ehci-vt8500 a separate driver USB: usb-storage: unusual_devs update for Super TOP SATA bridge USB: ehci-omap: Fix autoloading of module USB: ehci-omap: Don't free gpios that we didn't request USB: option: add Huawei "ACM" devices using protocol = vendor USB: serial: fix null-pointer dereferences on disconnect USB: option: add Yota / Megafon M100-1 4g modem drivers/usb: add missing GENERIC_HARDIRQS dependencies USB: storage: properly handle the endian issues of idProduct testusb: remove all mentions of 'usbfs' usb: gadget: imx_udc: make it depend on BROKEN usb: omap_control_usb: fix compile warning ARM: OMAP: USB: Add phy binding information ARM: OMAP2: MUSB: Specify omap4 has mailbox ARM: OMAP: devices: create device for usb part of control module ...
2013-01-25Merge 3.8-rc5 into driver-core-nextGreg Kroah-Hartman
This resolves a gpio driver merge issue pointed out in linux-next. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-25Merge 3.8-rc5 into usb-nextGreg Kroah-Hartman
This fixes up a conflict with drivers/usb/serial/io_ti.c that came up in linux-next. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-23USB: EHCI: fix build error in ehci-mxcAlan Stern
This patch (as1643b) fixes a build error in ehci-hcd when compiling for ARM with allmodconfig: drivers/usb/host/ehci-hcd.c:1285:0: warning: "PLATFORM_DRIVER" redefined [enabled by default] drivers/usb/host/ehci-hcd.c:1255:0: note: this is the location of the previous definition drivers/usb/host/ehci-mxc.c:280:31: warning: 'ehci_mxc_driver' defined but not used [-Wunused-variable] drivers/usb/host/ehci-hcd.c:1285:0: warning: "PLATFORM_DRIVER" redefined [enabled by default] drivers/usb/host/ehci-hcd.c:1255:0: note: this is the location of the previous definition The fix is to convert ehci-mxc over to the new "ehci-hcd is a library" scheme so that it can coexist peacefully with the ehci-platform driver. As part of the conversion the ehci_mxc_priv data structure, which was allocated dynamically, is now placed where it belongs: in the private area at the end of struct ehci_hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-22usb: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11USB: ehci-mxc: remove Efika MX-specific CHRGVBUS hackMatt Sealey
Since Efika MX platform support (pre-devicetree) was removed from the tree this code no longer has any possibility of running and clutters up the driver which is being replaced by the chipidea host in the future anyway. Signed-off-by: Matt Sealey <matt@genesi-usa.com> Tested-by: Steev Klimazewski <steev@genesi-usa.com> CC: Sascha Hauer <kernel@pengutronix.de> CC: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
2012-11-14usb: ehci-mxc: Remove unused 'echi' variableFabio Estevam
Since commit c73cee7 (USB: EHCI: remove ehci_port_power() routine), the 'ehci' variable is no longer used, so remove it and fix the following build warning: drivers/usb/host/ehci-mxc.c:41:19: warning: unused variable 'ehci' [-Wunused-variable] Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31USB: EHCI: remove ehci_port_power() routineAlan Stern
This patch (as1623) removes the ehci_port_power() routine and all the places that call it. There's no reason for ehci-hcd to change the port power settings; the hub driver takes care of all that stuff. There is one exception: When the controller is resumed from hibernation or following a loss of power, the ports that are supposed to be handed over to a companion controller must be powered on first. Otherwise the handover won't work. This process is not visible to the hub driver, so it has to be handled in ehci-hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-15usb: ehci-mxc: remove unneeded mach/hardware.h inclusionShawn Guo
The inclusion of mach/hardware.h is not used by the driver at all. Remove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linux-usb@vger.kernel.org
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-09-14ARM: imx: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the imx include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Sascha Hauer <kernel@pengutronix.de> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Dan Williams <djbw@fb.com> Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org> Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Cox <alan@linux.intel.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Javier Martin <javier.martin@vista-silicon.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2012-08-10drivers/usb/host/ehci-mxc.c: use devm_ functionsJulia Lawall
The various devm_ functions allocate memory that is released when a driver detaches. This patch uses these functions for data that is allocated in the probe function of a platform device and is only freed in the remove function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09EHCI: centralize controller initializationAlan Stern
This patch (as1564c) converts the EHCI platform drivers to use the central ehci_setup() routine for generic controller initialization rather than each having its own idiosyncratic approach. The major point of difficulty lies in ehci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ehci_setup() and some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. One point not addressed by the patch is whether ports should be powered on or off following initialization. The different drivers appear to handle this pretty much at random. In fact it shouldn't matter, because the hub driver turns on power to all ports when it binds to the root hub. Straightening that out will be left for another day. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-25USB ehci mxc: sanitize clock handlingSascha Hauer
Every i.MX ehci controller has a ahb and a ipg clock, so request it on every SoC. Do not make a special case for the usb phy clock of the i.MX51. Just request it but make it optional. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-04-25USB ehci mxc: prepare/unprepare clockSascha Hauer
2012-02-27usb: otg: Convert all users to pass struct usb_otg for OTG functionsHeikki Krogerus
This changes the otg functions so that they receive struct otg instead of struct usb_phy as parameter and converts all users of these functions to pass the otg member of their usb_phy. Includes fixes to IMX code from Sascha Hauer. [ balbi@ti.com : fixed a compile warning on ehci-mv.c ] Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-27usb: Convert all users to new usb_phyHeikki Krogerus
Use the new usb_phy_* functions with transceiver operations instead of the old otg functions. Includes fixes from Sascha Hauer. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-09-18USB: irq: Remove IRQF_DISABLEDYong Zhang
This flag is a NOOP and can be removed now. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-08usb/ehci-mxc: add missing inclusion of mach/hardware.hShawn Guo
As cpu_is_mx stuff is being used in the driver, header mach/hardware.h should be explicitly included. The missing of the header is causing today's linux-next build error as bleow. CC drivers/usb/host/ehci-hcd.o In file included from linux-next/drivers/usb/host/ehci-hcd.c:1190:0: linux-next/drivers/usb/host/ehci-mxc.c: In function 'ehci_mxc_drv_probe': linux-next/drivers/usb/host/ehci-mxc.c:175:2: error: implicit declaration of function 'cpu_is_mx35' linux-next/drivers/usb/host/ehci-mxc.c:175:2: error: implicit declaration of function 'cpu_is_mx25' linux-next/drivers/usb/host/ehci-mxc.c:185:2: error: implicit declaration of function 'cpu_is_mx51' Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-03USB: EHCI: Support controllers with big endian capability regsJan Andersson
The two first HC capability registers (CAPLENGTH and HCIVERSION) are defined as one 8-bit and one 16-bit register. Most HC implementations have selected to treat these registers as part of a 32-bit register, giving the same layout for both big and small endian systems. This patch adds a new quirk, big_endian_capbase, to support controllers with big endian register interfaces that treat HCIVERSION and CAPLENGTH as individual registers. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-11ARM i.MX ehci: do ehci init in board specific functionsSascha Hauer
The mxc-ehci driver calls SoC specific phy initialization right after calling board specific initialization. To offer greater flexibility for boards to setup the phy and to get rid of some unnecessary flags in platform data this patch lets the boards call the SoC specific phy initialization and remove it from the driver. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-01-22USB: ehci-mxc: add work-around for efika mx/sb bugArnaud Patard (Rtp)
Add support for setting CHRGVBUS to workaround a hardware bug on efika mx/sb boards. See http://lists.infradead.org/pipermail/linux-arm-kernel/2011-January/037341.html Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-22USB: unbreak ehci-mxc on otg port of i.MX27Eric Bénard
commit 711669e5b80b6f2d88f61ed8a9681f83d8cbd201 fixed port 0 support for i.MX51 but broke it for (at least) i.MX27 which doesn't have a usb_phy1 clock but has a pdev->id 0. Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits) USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004) USB: serial: ftdi_sio: add support for TIOCSERGETLSR USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport USB: atmel_usba_udc: fix freeing irq in usba_udc_remove() usb: ehci-omap: fix tll channel enable mask usb: ohci-omap3: fix trivial typo USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096 USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's USB: gadget: update ci13xxx to work with g_ether USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers Revert "USB: musb: pm: don't rely fully on clock support" Revert "USB: musb: blackfin: pm: make it work" USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added ... Manually fix up trivial conflicts in USB Kconfig changes in: arch/arm/mach-omap2/Kconfig arch/sh/Kconfig drivers/usb/Kconfig drivers/usb/host/ehci-hcd.c and annoying chip clock data conflicts in: arch/arm/mach-omap2/clock3xxx_data.c arch/arm/mach-omap2/clock44xx_data.c
2011-01-03mx51: fix usb clock supportArnaud Patard (Rtp)
Current code doesn't really enable the usb clocks so if they're disabled when booting linux, the kernel/machine will hang as soon as someone is trying to read a usb register Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-12-16USB: ehci-mxc: Setup portsc register prior to accessing OTG viewportFabio Estevam
In order to read/write to the i.MX OTG viewport register it is necessary to setup the PORTSCx register first. By default i.MX OTG port is configured for USB serial PHY. In order to use a ULPI PHY the PORTSCx register needs to be configured properly. commit 724c852 (USB: ehci/mxc: compile fix) placed the PORTSC setup after the OTG viewport is accessed and this causes ULPI read/write to fail. Revert the PORTSC setup order. Tested on a MX31PDK board with a ISP1504 transceiver: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver mxc-ehci mxc-ehci.0: initializing i.MX USB Controller ULPI transceiver vendor/product ID 0x04cc/0x1504 Found NXP ISP1504 ULPI transceiver. ULPI integrity check: passed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-16Merge branch 'usb-next' into musb-mergeGreg Kroah-Hartman
* usb-next: (132 commits) USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added usb: gadget: f_ncm.c added usb: gadget: u_ether: prepare for NCM usb: pch_udc: Fix setup transfers with data out usb: pch_udc: Fix compile error, warnings and checkpatch warnings usb: add ab8500 usb transceiver driver USB: gadget: Implement runtime PM for MSM bus glue driver USB: gadget: Implement runtime PM for ci13xxx gadget USB: gadget: Add USB controller driver for MSM SoC USB: gadget: Introduce ci13xxx_udc_driver struct USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc USB: gadget: Separate out PCI bus code from ci13xxx_udc ...
2010-11-30usb: Add in missing EHCI helpers.Paul Mundt
Several of the EHCI glue drivers either predate or were merged in the same timeframe as API changes at the USB core level, resulting in some missing endpoint_reset and clear_tt_buffer_complete callbacks. This fixes up all of ehci-atmel, mxc, w90x900, and xilinx-of to tie in the new helpers, which brings them in line with everyone else. Reported-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11USB: ehci/mxc: compile fixUwe Kleine-König
Commit 65fd427 (USB: ehci tdi : let's tdi_reset set host mode) broke the build using ARM's mx51_defconfig: CC drivers/usb/host/ehci-hcd.o In file included from drivers/usb/host/ehci-hcd.c:1166: drivers/usb/host/ehci-mxc.c: In function 'ehci_mxc_drv_probe': drivers/usb/host/ehci-mxc.c:192: error: 'ehci' undeclared (first use in this function) drivers/usb/host/ehci-mxc.c:192: error: (Each undeclared identifier is reported only once drivers/usb/host/ehci-mxc.c:192: error: for each function it appears in.) drivers/usb/host/ehci-mxc.c:117: warning: unused variable 'temp' make[3]: *** [drivers/usb/host/ehci-hcd.o] Error 1 make[2]: *** [drivers/usb/host/ehci-hcd.o] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 Fix it together with the warning about the unused variable and use msleep instead of mdelay as requested by Alan Stern. Cc: Dinh Nguyen <Dinh.Nguyen@freescale.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Tested-by: Nguyen Dinh-R00091 <R00091@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: ehci tdi : let's tdi_reset set host modeMatthieu CASTET
tdi_reset is already taking care of setting host mode for tdi devices. Don't duplicate code in platform driver. Make ehci_halt a nop if the controller is not in host mode (otherwise it will fail), and let's ehci_reset do the tdi_reset. We need to move hcd->has_tt flags before ehci_halt, in order ehci_halt knows we are a tdi device. Before the setup routine was doing : - put controller in host mode - ehci_halt - ehci_init - hcd->has_tt = 1; - ehci_reset Now we do : - hcd->has_tt = 1; - ehci_halt - ehci_init - ehci_reset PS : now we handle correctly the device -> host transition. Signed-off-by: Matthieu CASTET <matthieu.castet@parrot.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-29Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable
2010-07-26i.MX25: fix EHCI supportEric Bénard
i.MX25's EHCI is the same as i.MX35's one. Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-06-30USB: ehci-mxc: bail out on transceiver problemsWolfram Sang
The old code registered the hcd even if there were no transceivers detected, leading to oopses like this if we try to probe a non-existant ULPI: [ 2.730000] mxc-ehci mxc-ehci.0: unable to init transceiver [ 2.740000] timeout polling for ULPI device [ 2.740000] timeout polling for ULPI device [ 2.750000] mxc-ehci mxc-ehci.0: unable to enable vbus on transceiver [ 2.750000] mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller [ 2.760000] mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 2 [ 2.770000] Unhandled fault: external abort on non-linefetch (0x808) at 0xc4876184 [ 2.770000] Internal error: : 808 [#1] PREEMPT [ 2.770000] last sysfs file: [ 2.770000] Modules linked in: [ 2.770000] CPU: 0 Not tainted (2.6.33.5 #5) [ 2.770000] PC is at ehci_hub_control+0x4d4/0x8f8 [ 2.770000] LR is at ehci_mxc_setup+0xbc/0xdc [ 2.770000] pc : [<c0196dfc>] lr : [<c019bc8c>] psr: 00000093 [ 2.770000] sp : c3815e40 ip : 00000001 fp : 60000013 [ 2.770000] r10: c4876184 r9 : 00000000 r8 : c3814000 [ 2.770000] r7 : c391d2cc r6 : 00000001 r5 : 00000001 r4 : 00000000 [ 2.770000] r3 : 80000000 r2 : 00000007 r1 : 80000000 r0 : c4876184 [ 2.770000] Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 2.770000] Control: 0005317f Table: a0004000 DAC: 00000017 [ 2.770000] Process swapper (pid: 1, stack limit = 0xc3814270) ... Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: stable <stable@kernel.org> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-03mxc: Add generic USB HW initialization for MX51Dinh Nguyen
This patch adds USB HW initializiation code to /plat-mxc/ehci.c. -Sets some specific PHY settings Renames mxc_set_usbcontrol to mxc_initialize_usb_hw. Adds new register bit defines for the USB HW on Freescale SoCs. This patch applies to 2.6.34-rc6. Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com> Reviewed-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02USB: fix occasional ULPI timeouts with ehci-mxcValentin Longchamp
On various mxc boards, the intial ULPI reads resulted in a timeout which prevented the transceiver to be identified and thus the ehci device to be probed. Initializing the hardware lines connected to the transceiver (through pdata->init call) before actually enabling clocks and configuring registers in the devices fixes this problem. Signed-off-by: Valentin Longchamp <valentin.longchamp@epfl.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB: Add EHCI support for MX27 and MX31 based boardsDaniel Mack
The Freescale MX27 and MX31 SoCs have a EHCI controller onboard. The controller is capable of USB on the go. This patch adds a driver to support all three of them. Users have to pass details about serial interface configuration in the platform data. The USB OTG core used here is the ARC core, so the driver should be renamed and probably be merged with ehci-fsl.c eventually. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
