path: root/drivers/usb/gadget/zero.c
2011-09-09usb gadget: clean up FSF boilerplate textKlaus Schwarzkopf
remove the following two paragraphs as they are not needed: This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc.,59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-08usb: gadget: zero: add superspeed supportAmit Blay
This patch adds SuperSpeed descriptors to the g_zero gadget. The SuperSpeed descriptors were added both for f_soursesink and f_loopback function drivers. Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org> Signed-off-by: Amit Blay <ablay@codeaurora.org> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-07-01usb: gadget: add max_speed to usb_composite_driverTatyana Brokhman
This field is used by the Gadget drivers to specify the maximum speed they support, meaning: the maximum speed they can provide descriptors for. The driver speed will be set in consideration of this value. [ balbi@ti.com : dropped the ifdeffery ] Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22usb gadget: don't save bind callback in struct usb_composite_driverMichal Nazarewicz
The bind function is most of the time only called at init time so there is no need to save a pointer to it in the composite driver structure. This fixes many section mismatches reported by modpost. Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: Revert "USB: gadget: section mismatch warning fixed"Michal Nazarewicz
This reverts a commit which proposed an invalid solution for a section mismatch. Next 3 commits will fix it correctly. Conflicts: drivers/usb/gadget/mass_storage.c Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: gadget: section mismatch warning fixedMichal Nazarewicz
In may gadgets bind and bind like functions were in a init section as they were only run during initialisation. However, being callback functions they were referenced from structures in “normal” sections. Changing the tag from “__init” to “__ref” fixes the warnings. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02USB: Remove unsupported usb gadget driversChristoph Egger
A bunch of USB gadget drivers where never ported from the linux 2.4 series to 2.6 kernels. However there's some code still in the tree for them which isn't used and is probably untested for ages. As the chance of these drivers being forward ported is probably quite small now it might be time to get rid of them. Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: gadget: gadget zero uses new suspend/resume hooksDavid Brownell
Use the new device-level suspend/resume hooks for Gadget Zero; always enable them with the OTG test mode; and support remote wakeup on both configurations even in non-OTG mode. This ensures that both configurations can pass the USBCV remote wakeup tests when the OTG test mode is enabled. This changes behavior by adding autoresume support to the loopback config even in non-OTG mode; the test failure was that it didn't work in OTG mode. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: replace uses of __constant_{endian}Harvey Harrison
The base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16usb gadget: link fixes for gadget zeroDavid Brownell
Change how the Gadget Zero driver builds: don't use separate compilation, since it works poorly when key parts are library code (with init sections etc). Instead be as close as we can to "gcc --combine ...". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget zero: use composite gadget frameworkDavid Brownell
Update Gadget Zero to use the more modular versions of the loopback and source/sink configuration drivers which build on the new gadget framework code. The core code is a LOT simpler, and it should be much easier now to understand how the parts fit together. The conversion is an overall source shrink in terms of this gadget, since it uses more midlayer support. However, it's an overall increase in object size because there's less sharing between the two configurations (improves code clarity) and because the midlayer is a bit more functional than this driver actually needs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02usb: gadget zero timer init fixDavid Lopo
Initialize timer earlier so if an error occurs allocating USB request or buffer request (zero_bind) Gadget Zero will not hang trying to delete an uninitialized timer (zero_unbind). Signed-off-by: David Lopo <lopo.david@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02usb: gadget zero style fixups (mostly whitespace)David Brownell
Minor updates to "Gadget Zero". - Primarily these are whitespace updates to address the fact that since this was written, Documentation/CodingStyle was changed to disapprove of parts of the original coding style. - Update a few comments that weren't quite correct, notably mentioning the "autoresume" module parameter. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: gadget code switches to pr_err() and friendsDavid Brownell
We now have pr_err(), pr_warning(), and friends ... start using them in the gadget stack instead of printk(KERN_ERR) and friends. This gives us shorter lines and somewhat increased readability. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: move <linux/usb_gadget.h> to <linux/usb/gadget.h>David Brownell
Move <linux/usb_gadget.h> to <linux/usb/gadget.h>, reducing some of the clutter in the main include directory. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: gadget: gadget zero cleanupsDavid Brownell
Clean up gadget zero, using newer APIs and conventions: - gadget_is_dualspeed() and gadget_is_otg() ... #ifdef removal - Remove many now-needless #includes - Use the VERBOSE_DEBUG convention - Some whitespace fixes. - A few comment updates - Plus a few other small cleanups: don't pass gfp_t around when it's always going to be GFP_ATOMIC, and do static init of serial number. Also go to straight GPL; there's no real point in dual licensing this stuff any more. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: "sparse" cleanups for usb gadgetsDavid Brownell
This removes complaints about the gadget stack which are generated by the currrent "sparse": it doesn't like the fact that zero is the null pointer. (Last I checked, C guarantees that's correct ...) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12usb gadget stack: remove usb_ep_*_buffer(), part 1David Brownell
Remove usb_ep_{alloc,free}_buffer() calls, for small dma-coherent buffers. This patch just removes the interface and its users; later patches will remove controller driver support. - This interface is invariably not implemented correctly in the controller drivers (e.g. using dma pools, a mechanism which post-dates the interface by several years). - At this point no gadget driver really *needs* to use it. In current kernels, any driver that needs such a mechanism could allocate a dma pool themselves. Removing this interface is thus a simplification and improvement. Note that the gmidi.c driver had a bug in this area; fixed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: <linux/usb_ch9.h> becomes <linux/usb/ch9.h>David Brownell
This moves <linux/usb_ch9.h> to <linux/usb/ch9.h> to reduce some of the clutter of usb header files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-12[PATCH] USB: gadget section fixupsDavid Brownell
Recent section changes broke gadget builds on some platforms. This patch is the best fix that's available until better section markings exist: - There's a lot of cleanup code that gets used in both init and exit paths; stop marking it as "__exit". (Best fix for this would be an "__init_or_exit" section marking, putting the cleanup in __init when __exit sections get discarded else in __exit.) - Stop marking the use-once probe routines as "__init" since references to those routines are not allowed from driver structures. They're now marked "__devinit", which in practice is a net lose. (Best fix for this is likely to separate such use-once probe routines from the driver structure ... but in general, all busses that aren't hotpluggable will be forced to waste memory for all probe-only code.) In general these broken section rules waste an average of two to four kBytes per driver of code bloat ... because none of the relevant code can ever be reused after module initialization. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] USB: gadget zero poisons OUT buffersDavid Brownell
Fill OUT buffers with 0x55 before RX, so that controller driver bugs that mangle data can be more readily detected during testing. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: kzalloc() conversion in drivers/usb/gadgetEric Sesterhenn
this patch converts drivers/usb to kzalloc usage. Compile tested with allyes config. I think there was a bug in drivers/usb/gadget/inode.c because it used sizeof(*data) for the kmalloc() and sizeof(data) for the memset(), since sizeof(data) just returns the size for a pointer. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: gadget driver section fixupsDavid Brownell
This adds __init section annotations to gadget driver bind() routines to remove calls from .text into .init sections (for endpoint autoconfig). Likewise it adds __exit section annotations to their unbind() routines. The specification of the gadget driver register/unregister functions is updated to explicitly allow use of those sections. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: Zero driver: Removed duplicated codeFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: gadget zero and dma-coherent buffersDavid Brownell
This makes sure that the correct length is reported when freeing a dma-coherent buffer; some platforms complain if that's wrong. It also makes two parameters readonly in sysfs, as they're not safe to change while tests are running. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-13[PATCH] Remove usb gadget generic driver methodsRussell King
USB gadget drivers make no use of these, remove the pointless comments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: gadget drivers - add .owner initialisationBen Dooks
Ensure the the device_driver and usb_gadget_driver have their .owner fields initialised to associate the module owner to the driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-09-08[PATCH] USB: Gadget library: centralize gadget controller numbersDavid Brownell
This patch centralizes the assignment of bcdDevice numbers for different gadget controllers. This won't improve the object code at all, but it does save a lot of repetitive and error-prone source code ... and will simplify the work of supporting a new controller driver, since most new gadget drivers will no longer need patches (unless some hardware quirks limit USB protocol messaging). Added minor cleanups and identifer hooks for the UDC in the Freescale iMX series processors. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-12[PATCH] USB: Fix kmalloc's flags type in USBOlav Kongas
Greg, This patch fixes the kmalloc() flags argument type in USB subsystem; hopefully all of its occurences. The patch was made against patch-2.6.12-git2 from Jun 20. Cleanup of flags for kmalloc() in USB subsystem. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB: gadget driver updates (SETUP api change)David Brownell
This updates most of the gadget framework to expect SETUP packets use USB byteorder (matching the annotation in <linux/usb_ch9.h> and usage in the host side stack): - definition in <linux/usb_gadget.h> - gadget drivers: Ethernet/RNDIS, serial/ACM, file_storage, gadgetfs. - dummy_hcd It also includes some other similar changes as suggested by "sparse", which was used to detect byteorder bugs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
