git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
usb: dwc3: patches for v3.6 merge window
lots of changes for the dwc3 driver which will make
the driver a lot more stable and some changes which
are just cosmetic.
The bulk of changes is related to mis-defined macros
which were never used before, some fixes to error path
which e.g. prevent the driver from initiating two
transfer on ep0out in case of stall, some fixes to
request dequeueing and the End Transfer Command.
We have some changes to U1/U2 handling where we were
enabling those transtions at the wrong spot (though
we haven't seen a problem from that as of today).
A few patches will make it easier to add support for
newer releases of the core by adding definitions for
new registers and changing the code to act accordingly
when certain revisions are detected.
There's also the usual comestic changes to make the
driver easier to maintain and make it easier for new-
comers to understand the driver. Also one patch fixing
a double inclusion of a header.
usb: gadget: patches for v3.6 merge window
This is quite a big pull request and contains patches
all over the place.
omap_udc is now a bit cleaner after removing omap2 support,
fixing some checkpatch.pl warnings and errors, switching over
to generic map/unmap routines and preventing a NULL pointer
de-reference.
s3c-hsotg has been switched over to devm_* API, got some
locking fixes and improvements and it also got an implementation
for the pullup() method.
the mass storage gadgets changed default value of the removable
parameter, dropped some unused options and made "file" and "ro"
module_parameters read-only in some cases.
ffs function got support for HID descriptor.
Some UDCs have been converted to clk_prepare_enable() and
clk_disable_unprepare().
Marvell now got support for its USB3 controller in mainline
after introducing its mv_u3d_core.c driver.
Although timeout has never been experienced, still to make it
meaningful, its better to return error if it ever occurs.
Signed-off-by: Pratyush Anand <pratyush.anand@st.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
As per databook, ACCEPT{U1,U2}ENA bits should be set after receiving
SetConfiguration Command.
as per databook, these bits are cleared by hardware on each USB reset,
so no need to clear it explicitly by software in reset ISR.
as per data book any HIRD threshold value greater than 4b1100 is
invalid. So set the maximum valid value as default values.
set_halt for ep0 is called to stall a deferred control responses by the
gadget. We already have a function to stall default control endpoint.
This patch points set_halt for ep0 to the already available function.
Signed-off-by: Michel Sanches <michel.sanches@st.com>
whenever we want to stall ep0, we always call
dwc3_ep0_stall_and_restart() which makes sure
to send ep0state properly rendering the code
in __dwc3_gadget_ep_set_halt() duplicated.
Reported-by: Pratyush Anand <pratyush.anand@st.com>
resource_index is more human readable. No
functional changes.
It makes it easier to read and also avoids
setting DWC3_EP_PENDING_REQUEST just so the
next branch evaluates true.
No functional changes otherwise.
Cc: Pratyush Anand <pratyush.anand@st.com>
Cc: Paul Zimmerman <paulz@synopsys.com>
Now we are sure that, if res_trans_idx is zero, then endpoint has been
stopped. So it's safe to just return if endpoint is already stopped. No
need to generate warning anymore.
While doing so, it's better to return when res_trans_idx is zero and
decrease one level of indentation.
[ balbi@ti.com: slightly changed commit log ]
In case of ep_disable and reset interrupt is received and, still there
was at least one request queued for dma transfer, then endpoint is
stopped first. Once endpoint is stopped, callback for all queued
request must be called.
In case of ep_dequeue , if dequeued request was submitted for dma
transfer, then endpoint is stopped. Once endpoint is stooped, callback
for the dequeued request must be called.
bMaxBurst field on endpoint companion descriptor
is supposed to contain the number of burst minus
1. When passing that to controller drivers, we
should be passing the real number instead (by
incrementing 1).
While doing that, also fix the assumption on
dwc3 that value comes decremented by one.
It is needed to enumerate recent cores like 2.10a.
By the time we're disabling the endpoint, HW
could already have posted more events to our
event buffer. In that case, we will receive
endpoint events for a disabled endpoint.
In order to protect ourselves from that situation,
we simply ignore endpoint interrupts whenever
the endpoint is disabled.
Tested-by: Pratyush Anand <pratyush.anand@st.com>
In case we get disconnected, we will call gadget
driver's disconnect method, which should make
sure to disable all endpoints. At that point
we will call stop_active_transfers() to make
sure we didn't leave any pending request on the
controller.
That IRQ is causing way too much trouble. We have
a different handling which was agreed with IP
provider and has been tested with FPGA and OMAP5.
We never set CMDIOC bit for Start Transfer
command, so that code will never be used.
If event status says that its last completed TRB but TRB is still owned
by HW then break from the loop, because we are not going to get correct
TRB status from trb control/size register.
If an IN transfer is missed on isoc endpoint, then driver must insure
that next ep_queue is properly handled.
This patch fixes this issue by starting a new transfer for next queued
request.
Currently in case of isoc, interrupt is programmed after each
TRB_NUM/4 ie 8th TRB. A TRB is programmed against each submitted
request from gadget. If we do not want to limit the minimum number of
necessary request to be submitted from gadget then we must receive
interrupt on each TRB submission. There can be such situation with a
gadget working with ping-pong buffer.
If a gadget does not want to receive interrupt after each request
completion then it may set no_interrupt flag.
According to the databook, the DWC3 Core will
reset those bits to 0 on USB Bus Reset. This
means we must re-enable those bits on every
reset interrupt.
Because we will always get a Reset interrupt
after loading a gadget driver, we can, instead
of re-enabling something that was just lost,
move the handling of those bits to the Reset
Interrupt.
This patch fixes USB30CV U1/U2 Test.
Signed-off-by: Gerard CAUVY <g-cauvy1@ti.com>
If we get a disconnect IRQ, we should take
the core out of low power mode so we can
reconnect afterwards.
If we don't read out the contents of the register
(in order to reinitialize 'reg' variable) we will
be writing unknown contents to the DCTL register
whenever we try to use dwc3_gadget_wakeup() function.
Recent cores (>= 1.94a) have a set of new features,
commands and a slightly different programming model.
This patch aims to support those changes.
Signed-off-by: Paul Zimmerman <paulz@synopsys.com>
those two functions don't power PHYs, they simply
put them in suspend state. Rename to reflect better
what functions actually do.
retries is used twice without being reinitialized.
That semicolon doesn't do anything, it's not
needed and should be removed.
usb: dwc3: patches for v3.5 merge window
This pull request contains one workaround for a Silicon
Issue found on all RTL releases prior to 2.20a, which
would cause a metastability state on Run/Stop bit.
We also have some patches implementing a few extra Standard
requests introduced by USB3 spec (Set SEL and Set Isoch Delay),
as well as one patch, which has been pending for a long time,
implementing LPM support.
Last, but not least, we are splitting the host address space
out of the dwc3 core driver otherwise xHCI won't be able to
request_mem_region() its own address space. This patch is
only needed because we are (as we should) re-using the xHCI
driver, which is a completely separate module.
Together with these three big changes, come a few extra preparatory
patches which most move code around, define macros and so on, as
well as a fix for Isochronous transfers which hasn't been triggered
before.
[ resolved conflicts and build error in drivers/usb/dwc3/gadget.c - gregkh]
usb_ep
Remove redundant pointer to struct usb_endpoint_descriptor.
Signed-off-by: Ido Shayevitz <idos@codeaurora.org>
to avoid sprinkling magic constants on the driver
we define a constant to be used when allocating
setup_buffer and ep0_bounce buffer.
Issue an Update Transfer command after queuing a request to an isoc
EP with an active transfer. This is required according to the dwc3
databook. Pratyush Anand reports that this fixes a problem he was
having with Isoc IN transfers.
Tested-by: Pratyush Anand<pratyush.anand@st.com>
We want to re-use that buffer for other USB
requests, so let's increase it to biggest
wMaxPacketSize for ep0 so it works for everything
we have in mind.
This will be used by the ep0 layer for implementing
Set SEL Standard Request.
On device loading the driver enables LPM and the acceptance of U1 and U2
states. The [Set|Clear]Feature requests for "U1/U2" are forwarded
directly to the hardware and allow / forbid the initiation of the low
power links.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
All revisions prior to 2.20a have a known issue which
causes metastability state on Run/Stop bit if we
configure the core to work on any of the USB2-only
speeds.
The suggested workaround is just to never configure the
core to anything other than SuperSpeed.
usb: dwc3: changes for v3.4 merge window
Here are the changes for v3.4 merge window.
It includes a new glue layer for Samsung's Exynos platform, a simplification of
memory management on DWC3 driver by using dev_xxx functions, a few
optimizations to IRQ handling by dropping memcpy() and using bitshifts, a fix
for TI's OMAP5430 TX Fifo Allocation, two fixes on USB2 test mode
implementation (one on debugfs and one on ep0), and several minor changes such
as whitespace cleanups, simplification of a few parts of the code, decreasing a
long delay to something a bit saner, dropping a header which was included twice
and so on.
The highlight on this merge is the support for Samsung's Exynos platform,
increasing the number of different users for this driver to three.
Note that Samsung Exynos glue layer will only compile on platforms which
provide implementation for the clk API for now. Once Samsung supports
pm_runtime, that limitation can be dropped from the Makefile.
Transfer resource index is cleared in hardware when XFERCOMPLETE
event is generated, so clear the driver's res_trans_idx variable
immediately after that event is received. The upcoming hibernation
patches depend on this change.
dwc3_gadget_ep_set_wedge() and dwc3_gadget_set_selfpowered() were
modifying dwc->flags/dwc->is_selfpowered without taking the lock.
Since those modifications are non-atomic, that could cause other
flags to be corrupted. Fix them both to take the lock.
The loop in dwc3_gadget_set_link_state() was using a udelay(500),
which is a long time to delay in interrupt context. Change it to
udelay(5) and increase the loop count to match.
Zero is a valid value for a microframe number. So remove the bogus
test for non-zero in dwc3_gadget_start_isoc().
Cc: stable@vger.kernel.org
It's wrong to use the size of array as an argument for strncat.
Memory corruption is possible. strlcat is exactly what we need here.
Signed-off-by: Anton Tikhomirov <av.tikhomirov@samsung.com>
If we have a non-ISOC endpoint, we will not have a Link TRB
pointing to the beginning of the TRB pool. On such endpoints,
we don't want to let the driver wrap around the TRB pool
otherwise controller will hang waiting for a valid TRB.
trivial patch, no functional changes
those routines have everything we need to map/unmap
USB requests and it's better to use them.
In order to achieve that, we had to add a simple
change on how we allocate and use our setup buffer;
we cannot allocate it from coherent anymore otherwise
the generic map/unmap routines won't be able to easily
know that the GetStatus request already has a DMA
address.
This fix a bug in f_serial, which expect the ep->desc to be NULL after
disabling an endpoint.
this will get rid of a useless memcpy on
IRQ handling, thus improving driver performance.
Tested with OMAP5430 running g_mass_storage on
SuperSpeed and HighSpeed.
Note that we are removing the little endian access
of the TRB and all accesses will be in System endianness,
if there happens to be a system in BE, bit 12 of GSBUSCFG0
should be set so that HW does byte invariant BE accesses
when fetching TRBs.
When host requests us to enter a test mode,
we cannot directly enter the test mode before
Status Phase is completed, otherwise the core
will never be able to deliver the Status ZLP
to host, because it has already entered the
requested Test Mode.
In order to fix the error, we move the actual
start of Test Mode right after we receive
Transfer Complete event of the status phase.
Signed-off-by: Gerard Cauvy <g-cauvy1@ti.com>
Those transfer types are generally high bandwidth, so we
want to optimize transfers with those endpoints.
For that, databook suggests allocating 3 * wMaxPacketSize
of FIFO. Let's do that.
