commit db62b9a804b4 (usb: dwc2: host: don't
use dma_alloc_coherent with irqs disabled)
introduced a build warning by using NULL
as an integer. Fix that by just using 0 instead
of NULL.
Signed-off-by: Felipe Balbi <balbi@ti.com>
dwc2_hc_nak_intr could be called with a NULL qtd.
Ensure qtd exists before dereferencing it to avoid kernel panic.
This happens when using usb to ethernet adapter.
Acked-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Gregory Herrero <gregory.herrero@intel.com>
dwc2 may not be able to exit from hibernation if the hardware
does not provide a way to detect resume signalling in this state.
Thus, add the possibility to disable hibernation feature.
As dwc2 pci module is now exporting dwc2 platform device, include
platform.o in dwc2-y and remove USB_DWC2_PLATFORM configuration
option. Driver will be built as two modules, dwc2.ko and dwc2_pci.ko.
dwc2.ko is the new platform driver.
Remove all EXPORT_SYMBOL_GPL as they are not needed any more.
Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@intel.com>
Add support for SetPortFeature(PORT_TEST) for root port.
Signed-off-by: Jingwu Lin <jingwu.lin@intel.com>
Align buffer must be allocated using kmalloc since irqs are disabled.
Coherency is handled through dma_map_single which can be used with irqs
disabled.
Reviewed-by: Julius Werner <jwerner@chromium.org>
During urb_enqueue, if the urb can't be queued to the endpoint,
the urb is freed without any spinlock protection.
This leads to memory corruption when concurrent urb_dequeue try to free
same urb->hcpriv.
Thus, ensure the whole urb_enqueue in spinlocked.
Once hub is runtime suspended, dwc2 must resume it
on port connect event.
Else, roothub will stay in suspended state and will
not resume transfers.
Update controller state to indicate suspend entry.
If phy driver is present register hcd handle to it.
Force argument is not used anymore. Clean up leftovers from
https://lkml.org/lkml/2014/12/9/283
Inform that device is otg-capable in case of otg configuration.
During vbus session, usb controller needs to exit hibernation if it was
previously in suspend state.
Since controller will be resetted and configured, there is no need
to restore registers.
Moreover, set lx_state to L0 on B session. vbus_session callback may
not be used by all platforms. Thus, controller software state needs
to be set to L0 if the controller detects a valid B session.
Otherwise, lx_state will remain L2 and prevent any request submission.
If usb controller is in partial power down, any write to registers may
cause unpredictable behavior.
Thus, prevent any new request submission once controller is in partial
power down.
Nothing to be done in pm suspend/resume when controller is in L2.
Don't disconnect or reset. State is already saved when putting
controller in hibernation and will be restored on USB bus resume.
ResetDet interrupt is used to detect a reset of the bus
while the controller is suspended.
This may happens for example when using Command Verifier.
So the parameters can be used in both host and gadget modes.
Also consolidate param functions in the core.h
This is required due to an Intel specific hardware issue. Where id-
pin setup causes glitches on the interrupt line when CONIDSTSCHG
interrupt is enabled.
Specify external_id_pin_ctl when an external driver (for example phy)
can handle id change, so that CONIDSTSCHG interrupt can be disabled
from the controller.
During suspend, there could a race condition between ep_queue and
suspend interrupt if lx_state is updated after releasing spinlock in
call_gadget(hsotg, suspend).
Allow controller to enter in hibernation during usb bus suspend and
inform both phy and gadget about the suspended state.
While in hibernation, the controller can't detect the resume condition.
An external mechanism must call usb_phy_set_suspend on resume.
Exit hibernation when controller gets the resume interrupt and inform
only gadget driver about it.
When suspending usb bus, phy driver may disable controller power.
In this case, registers need to be saved on suspend and restored
on resume.
Dump all registers to take a complete snapshot of dwc2 state.
Code is inspired by dwc3/debugfs.c
Prepare to add more debug code. Moreover, don't save dentry * for
each file in struct dwc2_hsotg as clean up is done with
debugfs_remove_recursive(). s3c_hsotg_delete_debug() is removed
altogether for the same reason.
msleep(USB_RESUME_TIMEOUT) must be done when the controller drives
the resume. This is true after HPRT0_RES is written.
Moreover, restore the delay after controller power is up.
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-testing
Felipe writes:
usb: generic resume timeout for v4.1
This part 2 pull request contains only the patches
which make sure everybody on linux uses the same
resume timeout value.
Make sure we're using the new macro, so our
resume signaling will always pass certification.
Cc: <stable@vger.kernel.org> # v3.10+
Fix using the bare number to set the 'bDescriptorType' field of the Hub
Descriptor while the value is #define'd in <linux/usb/ch11.h>.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v4.1 merge window
As usual, a big pile of commits. This time a total
of 111 non-merge commits.
Other than the usual set of cleanups and non-critical
fixes, we have some interesting work for AM335x's MUSB
babble recovery. Now that takes a lot less time and we
don't have to Reset MUSB all the time.
The printer gadget has been converted to configfs interface
and the atmel udc has learned suspend/resume with wakeup.
The dwc2-pci driver should be compiled as a module when configured to
do so. If the dwc2-pci is configured as a module but actually
built-in, it can cause build errors due to the fact that the
generic-phy will be allowed to compile as a module causing undefined
references.
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: John Youn <johnyoun@synopsys.com>
When the HCD is disconnected, the DMA transfers still in-flight were cleaned-up
but the count of available DMA channels (e.g. available_host_channels) was not
reset.
The pool of DMA channels can be depleted when doing unclean
disconnection of USB peripherals, and reaches the point where no
transfer was possible until the next reboot/reload of the driver.
Tested by putting a programmable USB mux on the port and randomly
plugging/unpluging a USB HUB with USB mass-storage key, USB-audio and
USB-ethernet dongle connected to its downstream ports, and also doing the
disconnection early while the devices are still enumerating to get more URBs
in-flight.
After the patch, the devices are still enumerating after thousands of cycles,
while the port was totally dead before.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
The dwc2-pci driver requires the generic PHY. This fixes undefined
reference issues when it is not selected.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
If device is configured to work only in HOST or DEVICE mode, there is
no point in initializing both subdrivers. This patch also fixes
resource leakage if host subdriver fails to initialize.
The pci driver now registers a platform driver, like in dwc3, and lets
its probe function do all the initialization. This allows it to
account for changes to the platform driver that were not added to the
pci driver. Also future changes to the probe function don't have to be
duplicated. This also has the effect of adding device and DRD mode to
the pci driver. Tested on the Synopsys HAPS PCIe platform.
When dwc2 controller detects a disconnect interrupt,
dwc2_hcd_disconnect() should be called immediately to do clean-up
jobs and set port_connect_status_change flag to notify usb hub
driver disconnect status.
Tested-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Yunzhi Li <lyz@rock-chips.com>
Removed FIXME from usb/dwc3/dwc3-pci.c by moving definition of
PCI_VENDOR_ID_SYNOPSYS shared with usb/dwc2 to linux/pci_ids.h.
Signed-off-by: Joseph Kogut <joseph.kogut@gmail.com>
Felipe writes:
usb: patches for v3.20 merge window
Here's the big pull request for Gadgets and PHYs. It's
a total of 217 non-merge commits with pretty much everything
being touched.
The most important bits are a ton of new documentation for
almost all usb gadget functions, a new isp1760 UDC driver,
several improvements to the old net2280 UDC driver, and
some minor tracepoint improvements to dwc3.
Other than that, a big list of minor cleanups, smaller bugfixes
and new features all over the place.
According to the DWC2 datasheet, the HWCFG1 register stores
the configured endpoint directions for endpoints 0-15 in bit positions
0-31.
Endpoint Direction (EpDir)
This 32-bit field uses two bits per endpoint to determine the endpoint
direction.
Endpoint
Bits [31:30]: Endpoint 15 direction
Bits [29:28]: Endpoint 14 direction
Bits [3:2]: Endpoint 1 direction
Bits[1:0]: Endpoint 0 direction (always BIDIR)
The DWC2 driver is currently interpreting the contents of the register
as directions for endpoints 1-15 which leads to an error in determining
the configured endpoint directions in the core because the first 2 bits
determine the direction of endpoint 0 and not 1.
This is based on testing/next branch in Felipe's git.
Signed-off-by: Roshan Pius <rpius@chromium.org>
We want the USB fixes in here to make merges easier.
It is currently possible to configure the dwc2 driver as built-in
when host mode or dual-role is enabled, but the USB core is
a loadable module. This leads to a link failure:
drivers/built-in.o: In function `_dwc2_hcd_start':
:(.text+0x84538): undefined reference to `usb_hcd_resume_root_hub'
drivers/built-in.o: In function `_dwc2_hcd_urb_dequeue':
:(.text+0x84aa0): undefined reference to `usb_hcd_check_unlink_urb'
:(.text+0x84e4c): undefined reference to `usb_hcd_unlink_urb_from_ep'
:(.text+0x84e74): undefined reference to `usb_hcd_giveback_urb'
drivers/built-in.o: In function `dwc2_assign_and_init_hc':
:(.text+0x86b98): undefined reference to `usb_hcd_unmap_urb_for_dma'
drivers/built-in.o: In function `_dwc2_hcd_urb_enqueue':
:(.text+0x8717c): undefined reference to `usb_hcd_link_urb_to_ep'
:(.text+0x872f4): undefined reference to `usb_hcd_unlink_urb_from_ep'
drivers/built-in.o: In function `dwc2_host_complete':
:(.text+0x875d4): undefined reference to `usb_hcd_unlink_urb_from_ep'
:(.text+0x87600): undefined reference to `usb_hcd_giveback_urb'
drivers/built-in.o: In function `dwc2_hcd_init':
:(.text+0x87ba8): undefined reference to `usb_disabled'
:(.text+0x87d38): undefined reference to `usb_create_hcd'
:(.text+0x88094): undefined reference to `usb_add_hcd'
:(.text+0x880dc): undefined reference to `usb_put_hcd'
drivers/built-in.o: In function `dwc2_hcd_remove':
:(.text+0x8821c): undefined reference to `usb_remove_hcd'
:(.text+0x8823c): undefined reference to `usb_put_hcd'
drivers/built-in.o: In function `dwc2_hc_handle_tt_clear.isra.10':
:(.text+0x88e2c): undefined reference to `usb_hub_clear_tt_buffer'
drivers/built-in.o: In function `dwc2_hcd_qtd_add':
:(.text+0x8b554): undefined reference to `usb_calc_bus_time'
To fix the problem, this patch changes the dependencies so that
dwc2 host mode can only be enabled if either the USB core is
built-in or both USB and dwc2 are modules.
USB reset interrupt is no more used to reset the controller.
Thus, reset the controller in pullup callback as described by
Synopsys programming guide. Otherwise enumeration sometimes
fails when usb configuration is switched without physical
disconnection.
Tested-by: Robert Baldyga <r.baldyga@samsung.com>
Defines are more readable and searchable than constants.
hsotg->phyif is set in dwc2_gadget_init according to phy interface
width. Use it for configuration instead of hardcoded value.
Moreover, set USB turnaround time according to phy width.
Print debug message according to zlp direction. Always saying
"Sending" is misleading.
Pullup doesn't need to be enabled during usb reset since it is
already enabled. This leads to shorter chirp-k duration if done
during usb reset.
Add a flag to request physical reset of the controller when
s3c_hsotg_core_init_disconnected is called.
During the usb reset, controller must not be fully reconfigured and
resetted. Else this leads to shorter chirp-k duration during
enumeration.
When using DMA, dwc2 requires buffers to be 4 bytes aligned. Use
bounce buffers if they are not.
Remove dead code as well.
s3c_hsotg_process_req_feature comments was not correct
Handle SET_FEATURE TEST_MODE request sent by the host.
Slightly rework FEATURE request handling to allow parsing
other request types than Endpoint.
Also add a debugfs to change test mode value from user space.
When clearing HALT on an endpoint, req->complete of in progress
requests must be called with locks off. New request should only be
started if there is not already a pending request on the endpoint.
