path: root/drivers/usb/class/usblp.c
2008-10-17USB: remove err() macro from usb class driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove err() and use the system-wide standard of dev_err() wherever possible. In the few places that will not work out, use a basic printk(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17drivers/usb/class/usblp.c: adjust error handling codeJulia Lawall
In this code, it is possible to tell statically whether usblp will be NULL in the error handling code. Oliver Neukum suggested to make a goto to the final return rather than return directly. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ identifier f,err,l,l1; type T; expression x,E; statement S; @@ x = NULL ... when != goto l1; * x = f(...) ... when != x err = E; goto l; ... * if (x != NULL) S return err; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21USB: fix pm counter leak in usblpOliver Neukum
if you fail in open() you must decrement the pm counter again. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
2007-10-12usblp: Fix a double kfreePete Zaitcev
If submit fails, slab hits a BUG() because of a double kfree. The today's lesson is, you cannot just slap USB_FREE_BUFFER on code without adjusting the error paths. The patch is made bigger by opportunistic refactoring. Signed-Off-By: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usblp: CosmeticsPete Zaitcev
This is a small bunch of cosmetic fixes: - Timeout is not a write timeout anymore, rename - Condition in poll was confusingly backwards, invert and simplify - The comment log gave a wrong impression of version 0.13, terminate it. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usblp: mutex in usblp_check_statusPete Zaitcev
Add a mutex to protect the ->statusbuf. Not really an issue, because CUPS is single-threaded when it talks to the printer, but I feel safer this way. This should be deadlock-free, but I kept this as a separate patch in case someone ends running a git bisect. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usblp: Make use of URB_FREE_BUFFERPete Zaitcev
Employ the new API URB_FREE_BUFFER that we've got. There was talk of a combined constructor for this case, but apparently it's not happening, so just set the flag explicitly for now. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usblp: Implement the ENOSPC conventionPete Zaitcev
This patch implements a mode when a printer returns ENOSPC when it runs out of paper. The default remains the same as before. An application which wishes to use this function has to enable it explicitly with an ioctl LPABORT. This is done on a request by our (Fedora) CUPS guy, Tim Waugh. The API is similar enough to the lp0's one that CUPS works with both (but see below), but it's has some differences. Most importantly, the abort mode is persistent in case of lp0: once tunelp was run your cat fill blow up until you reboot or run tunelp again. For usblp, I made it so the abort mode is only in effect as long as device is open. This way you can mix and match CUPS and cat(1) freely and nothing bad happens even if you run out of paper. It is also safer in the face of any unexpected crashes. It has to be noted that mixing LPABORT and O_NONBLOCK is not advised. It probably does not do what you want: instead of returning -ENOSPC it will always return -EAGAIN (because it would otherwise block while waiting for the paper). Applications which use O_NONBLOCK should continue to use LPGETSTATUS like before. Finally, CUPS actually requires patching to take full advantage of this. It has several components; those which invoke LPABORT work, but some of them need the ioctl added. This is completely compatible, you can mix old CUPS and new kernels or vice versa. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19USB: class: usblp: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19USB: usblp: "Big cleanup" breaks O_NONBLOCKPete Zaitcev
I found the first regresson in the rewritten ("all dynamic" and "no races") driver. If application uses O_NONBLOCK, I return -EAGAIN despite the URB being submitted successfuly. This causes the application to resubmit the same data erroneously. The fix is to pretend that the transfer has succeeded even if URB was merely queued. It is the same behaviour as with the old version. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usblp: add dynamic URBs, fix racesPete Zaitcev
This patch's main bulk aims to make usblp the premier driver for code pillaging once again. The code is as streamlined as possible and is bug-free as possible. The usb-skeleton performs the same function, but is somewhat abstract. The usblp is usb-skeleton which is actually used by many. Since I combed a few small bugs away, this also fixes the small races we had in usblp for a while. For example, now it's possible for several threads to make write(2) calls (sounds silly, but consider a printer for paper record, where every line of text is self-contained and thus it's all right to have them interleaved). Also gone are issues with interrupts using barriers dangerously. This patch makes use of Oliver's anchor, and so it must trail the anchor patch on the way to Linus. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-08usblp: Don't let suspend to kill ->usedPete Zaitcev
Suspend destroys refcounting for open/release. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-22USB: usblp: Use correct DMA address in case of probe errorPete Zaitcev
Looks like the error path had a copy-paste error. The normal exit path uses correct URB already. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-19usblp: quirk flag and device entry for Seiko Epson M129C printerAlan Stern
This patch (as872) adds a device table entry and a new quirk flag to the usblp driver for the Seiko Epson Receipt printer. This printer returns Vendor-Specific values for bInterfaceClass and bInterfaceSubClass, but the bInterfaceProtocol value is valid and it works with usblp. The new quirks flag tells the driver to ignore the Class and SubClass values in the interface descriptor. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: autosuspend for usb printer driverOliver Neukum
this implements autosuspend for usb printers. It compiles and is tested. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-05USB: usblp.c - add Kyocera Mita FS 820 to list of "quirky" printersMartin Williges
This patch gets the Kyocera FS-820 working with cups 1.2 via usb again. It adds the printer to the list of "quirky" printers. The printer seems not answer to ID requests some seconds after plugging in. Patch is based on linux-2.6.19.1. Background: As far as I could see (strace, usbmon), the Kyocera FS-820 answers to ID requests only a few seconds after plugging it in. This applies to detecting it with cups and is also true for the printing itself, which is initiated with an ID request. Since I have little usb knowledge, maybe someone can interpret the data, especially the fist bulk transfer - why request 8192 bytes? This is the second version of the patch. usbmon output of printing an email without patch: tail -F /tmp/printlog.txt c636e140 3374734463 S Bi:002:02 -115 8192 < c9d43b40 3374734494 S Ci:002:00 s a1 00 0000 0000 03ff 1023 < c9d43b40 3379732301 C Ci:002:00 -104 0 c636e140 3379733294 C Bi:002:02 -2 0 [...repeating...] with patch: tail -F /tmp/printlog.txt d9cb82c0 3729790131 S Ci:002:00 s a1 00 0000 0000 03ff 1023 < d9cb82c0 3729791725 C Ci:002:00 0 91 = 005b4944 3a46532d 3832303b 4d46473a 4b796f63 6572613b 434d443a 50434c58 df956320 3732493190 S Bo:002:01 -115 1347 = 1b252d31 32333435 5840504a 4c0a4050 4a4c2053 4554204d 414e5541 4c464545 [...more data...] Signed-off-by: Martin Williges <kernel@zut.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: mutexification of usblpOliver Neukum
this patch: - converts usblp fully to mutex - makes sleeping interruptible where EINTR can be returned anyway Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-03USB: usblp: fix system suspend for some systemsOliver Neukum
this has been confirmed to fix suspend problems with usblp. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-03USB: failure in usblp's error pathOliver Neukum
if urb submission fails due to a transient error here eg. ENOMEM , the driver is dead. This fixes it. Regards Oliver Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17USB: fix suspend support for usblpOliver Neukum
this implements suspend support for usblp. According to the CUPS people ENODEV will make CUPS retry the job. Thus it is returned in the runtime case. My printer survives suspend/resume cycles with it. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: fix __must_check warnings in drivers/usb/class/Greg Kroah-Hartman
2006-09-27USB: usblp: Use usb_endpoint_* functions.Luiz Fernando N. Capitulino
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: convert a bunch of USB semaphores to mutexesArjan van de Ven
the patch below converts a bunch of semaphores-used-as-mutex in the USB code to mutexes Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: cleanup of usblpOliver Neukum
this fixes -potential hang by disconnecting through usbfs -kzalloc -general cleanup -micro optimisation in interrupt handlers It compiles and I am printing. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-04[PATCH] USB: Export IEEE-1284 device id in sysfs for usblp devicesDavid Woodhouse
I looked at the userspace code which uses the LPIOC_GET_DEVICE_ID ioctl and I almost went blind. Let's export it in sysfs instead, and just as a string instead of with a big-endian length at the beginning of it. This also prints the message about finding the printer _after_ we know the minor device number it's going to have, rather than reporting all printers as 'usblp0'. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: ioctl compat for usblp.cPete Zaitcev
From: David Woodhouse <dwmw2> David has a G5 with a printer. I am quite surprised that nobody else noticed this before. Linus has a G5. Hackers hate printing in general, maybe. We do not use BKL anymore, because one of code paths had a sleeping call, so we had to use a semaphore. I am sure it's safe to use unlocked_ioctl. The new ioctls return long and retval is int. It looks completely fine to me. We never want these extra bits, and the sign extension ought to work right. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> --
2006-01-04[PATCH] USB: mark various usb tables constArjan van de Ven
patch below marks various USB tables and variables as const so that they end up in .rodata section and don't cacheline share with things that get written to. For the non-array variables it also allows gcc to optimize more. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03update the email address of Randy DunlapAdrian Bunk
This patch removes all references to the bouncing address rddunlap@osdl.org and one dead web page from the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2005-10-28[PATCH] devfs: Remove the mode field from usb_class_driver as it's no longer ↵Greg Kroah-Hartman
needed Also fixes all drivers that set this field, and removes some other devfs specfic USB logic. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/class/usblp.c | 3 +-- drivers/usb/core/file.c | 19 ++++--------------- drivers/usb/image/mdc800.c | 3 +-- drivers/usb/input/aiptek.c | 2 +- drivers/usb/input/hiddev.c | 3 +-- drivers/usb/media/dabusb.c | 3 +-- drivers/usb/misc/auerswald.c | 3 +-- drivers/usb/misc/idmouse.c | 5 ++--- drivers/usb/misc/legousbtower.c | 5 ++--- drivers/usb/misc/rio500.c | 3 +-- drivers/usb/misc/sisusbvga/sisusb.c | 5 ----- drivers/usb/misc/usblcd.c | 9 ++++----- drivers/usb/usb-skeleton.c | 3 +-- include/linux/usb.h | 7 ++----- 14 files changed, 22 insertions(+), 51 deletions(-)
2005-09-08[PATCH] USB usblp: rate-limit printer status error messagesRandy Dunlap
Rate-limit usblp printer error status messages. I unplugged my USB printer and almost instantly got several hundred of these in my kernel message log: drivers/usb/class/usblp.c: usblp0: error -19 reading printer status Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB: usblp: 2x up() in usblp_readDomen Puncer
up(&usblp->sem) was called twice in a row in this code path. Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB: Fix race condition in usblp_writeC. Adam Oldham
Initialize status fields in the read and write urbs to prevent a race condition with open/read/close - open/write/close sequences. Fixes bug #4432 at bugzilla.kernel.org Signed-off-by: Adam Oldham <oldhamca@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
